- Örömkönnyek és üres kezek a TriFold startjánál
- Xiaomi 12X – kicsi a bors és hűvös
ngabor2
#11464
Az még oké is lenne, h nincs 3D gyorsítás (miért is nincs
) de a felbontást se tudom 800x600 felé állítani...pár kimenet:
sipi@sipi-desktop:~$ fglrxinfo
display: :0.0 screen: 0
OpenGL vendor string: Mesa project: www.mesa3d.org
OpenGL renderer string: Mesa GLX Indirect
OpenGL version string: 1.4 (2.1 Mesa 7.0.3-rc2)sipi@sipi-desktop:~$ sudo sh ati-driver-installer-8.28.8.run
Creating directory fglrx-install
Verifying archive integrity... All good.
Uncompressing ATI Proprietary Linux Driver-8.28.8.....................................................................................................................................................................................................................................................................................................................................................................................................................................................................................
-e ==================================================
-e ATI Technologies Linux Driver Installer/Packager
Detected configuration:
Architecture: i686 (32-bit)
X Server: unable to detect
Removing temporary directory: fglrx-install -
Thusor
ngabor2
#11467
Ez usb-s ezért lsusb-t adok:
Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 006 Device 002: ID 05e3:1205 Genesys Logic, Inc. Afilias Optical Mouse H3003
Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 004 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 002: ID 0bda:8197 Realtek Semiconductor Corp. RTL8187B Wireless Adapter
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hubIlletve iwconfig:
lo no wireless extensions.
eth0 no wireless extensions.
pan0 no wireless extensions.
mg105
ngabor2
#11447
köszönöm a gyors választ!
igen, nekem is nVidia kártyám van és hozzá az ilyen "zárt driver" vagy mi. a legfrisebbet tettem fel, mert az volt az ajánlott (NVIDIA accelerated graphics driver (version 177).
van még ezen kívül version 96 és 173. próbáljam meg a 173-asat? a 96-os egy kicsit réginek tűnik, én pedig szeretnék játszani is
kem
ngabor2
#11123
A log fájlban nem találtam hibát. Írja benne hogy felismerte a videokártyát. A rendszert csak recovery mod-ban tudom indítani. Amikor fekete képernyő van, akkor semmire se reagál a gép.
cabal: A Live CD nem igazán működik, bejön a GUI mindennel, de a legvégén amikor látszólag minden látnivalót betöltött, akkoris még összevissza olvasgatja a CD-t, s végülis megfagy ( valszeg kevés a 256Mb ram). De a gui bejön...
Így a karakteres Alternatív installCD-t használom telepítésre. -
Kai Hansen
ngabor2
#10838
Kate fentvan, de itt vannak a hibaüzenetek:
Ezt írja ki a terminálban:
Error: "/var/tmp/kdecache-adam" is owned by uid 1000 instead of uid 0.
kate(5768): createDoc
kate(5768) KateSessionManager:
ateSessionManager: LOCAL SESSION DIR: "/home/adam/.kde/share/apps/kate/sessions"
kate(5768) KateApp::initKate: Setting KATE_PID: ' 5768 '
Error: "/tmp/kde-adam" is owned by uid 1000 instead of uid 0.
kate(5768) KateViewDocumentProxyModel::updateBackgrounds: false
kate(5768) KateMainWindow::setupMainWindow: HACK:***********************CONNECTING CLICKED***************************
ateMainWindow: **************************************************************************** 0x98d32e0
kate(5768) KateDocManager::slotDocumentNameChanged: docname changed: "Nincs cím" -----> "Nincs cím"
kate(5768) KateDocManager::slotDocumentNameChanged: docname changed: "Nincs cím" -----> "Default"
Error: "/tmp/ksocket-adam" is owned by uid 1000 instead of uid 0.
kate(5768) KateViewDocumentProxyModel::updateBackgrounds: trueMajd utána megnyitja a Kate-t és ezt a hibaüzenetet írja:
A(z) /etc/gdm/Init/Default fájlt nem sikerült betölteni, mert nem sikerült olvasni a fájlból.Ellenőrizze, van-e olvasási jogosultsága a fájlhoz.
Gambit
ngabor2
#10330
Na, most lenyomattam a két parancsot, és ez lett:
glxinfo | grep direct
X Error of failed request: BadRequest (invalid request code or no such operation)
Major opcode of failed request: 143 (GLX)
Minor opcode of failed request: 19 (X_GLXQueryServerString)
Serial number of failed request: 10
Current serial number in output stream: 10glxinfo | grep vendor
Current serial number in output stream: 10A videokari egy 4870-es. Ezek nem túl jó hírek, ha jól sejtem.
christprhrdv
ngabor2
#10413
Köszönöm a válaszokat!
Tudom, h a "hibát ír ki" az semmit nem mond, csak nem foglalkoztam vele, mert már a 32bitben maradtam... Én ahol tudok 64bitest használok, mert gyorsabb! Persze itt majdnem mind1, hiszen router-ke lesz szegényből, de 32bites progit futtatni olyan, mint gyorsulási versenyen félig nyomni a gázt...
Persze tom, h a progik, amiket felrakok úgyis 32bitesek.Megnézem a memtest-et jó ötlet, bár vindózékkal semmi gondja nincs, valamint ha elindul, akkor már jó (leglábbis most, mert újratettem mindent)...
Bár azt tényleg nem értem, h most (32bitesnél) semmi hibaüzenet, csak boot után villogó kurzor és nem megy tovább... 2 reset, aztán megy minden! Nem lehet atom proci-támogatással valami? Bár én problémát nem olvastam vele kapcs...
Szóval tetszik na! Okos ez az ubuntu!
Finwe
ngabor2
#10339
Hello!
Abban tudsz segíteni, hogy hogyan lehet a témákat helyesen telepíteni (vagy kézzel tisztogatni a rosszakat/telepíteni a grafikus felület nélkül)? Kicsit visszább is olvasható a problémám és ma is az történt, hogy a Megjelenítés menüben telepítem a témát, megkérdezi, h azt használja vagy a régit. A régire nyomok de nem telepítette, legalábbis nem lehet látni az ablakban. Mégegyszer pedig nem lehet telepíteni, "a könyvtár nem helyezhető át" a hibaüzenet. Az usr/share/themes-ben megvan.
Erre esetleg valami okosság?
Finwe
ArGab
ngabor2
#10336
Travelmate 5530 noti: 780G, Turion X2, Mobility Radeon HD 3470 (mellette alaplapi HD 3200).
Külön 10 gigát kapott ext3-ban, mellette van egy Vista.8.04 első telepítéssel ment 4-5 napig, utána nem indult el. Második telepítésnél meghalt update közben 8.10-re. 8.10 CD-ről telepítve vagy live-ot indítva az x servernél dob egy failed-et, aztán kapok egy terminált.
fjani
ngabor2
#10334
Segíts nekem úttörő.A 8.10 64 bites változat simán felmegy a 32 bites telepítésnél a betöltés után a monitor elsötétül és ezt a hibaüzenetet kapom kis kék ablakban:attention out of range H:19.5khz V:24.2hz.Live módban is ezt hozza, memtest,cd ell. oké.videokari ati 3850.Mi lehet a bibi.
Gambit
ngabor2
#10315
Felraktam a magyar szótárat, nagyon királyul működik, köszi szépen!
Felraktam az Mplayer buzerálót is, és buzeráltam is, ahol értem. Eljutottam odáig, hogy most már frankón elkezdi a lejátszást, sőt, még csak nem is vibrál.
Viszont pár másodperc után elkezd ilyen hibaüzit dobálni, hogy "Too many video packets in the buffer." Gugliztam is, de itt sem érkezett válasz.
És persze köszi a segítséget nagyon.
Laybee
ngabor2
#10282
Ez a válasz rá:
laybee@laybee-desktop:~$ xhost +
access control disabled, clients can connect from any host
laybee@laybee-desktop:~$ sudo nvidia-settings
[sudo] password for laybee:
Szegmens hiba
És ugyanúgy viselkedik. Az a legfurcsább, hogy maga a nvidia settings ismeri a monitoromat, maga a sima settings meg nem: ismeretlen-t ír ki. -
n0_gAboR
ngabor2
#10101
Ööö... magától dobja fel a lehetőséget, hogy beállíthassam a dolgokat, mikor elindul (még bejelentkezés előtt, valami script lehet). Arra nem gondoltam, hogy esetleg nem kapcsol root módba, de köszi, kipróbálom root-ként bejelentkezve is.
rtom: hát az az, amim nincs
Bár emlékeim szerint nem kértem, hogy csesszen el bármit is. -
n0_gAboR
ngabor2
#10068
Olvastam hogy az uj ath5k modult kikapcsoltak alapbol, mert vmi gaz volt vele. Ezeknek az embereknek javasoltak hogy tegyek fel az intrepidhez keszult backports csomagot, amibe az ujabb modulok vannak benne.
Hardyhoz is voltak folyamatosan backport frissitesek joval az intrepid megjelenese elott. Ami azt jelenti hogy nem az alap verziokat javitgatjak, foltozgatjak, hanem esetleg azota megjelent ujabb verziokat tesznek bele.
Primőr
ngabor2
#10051
Wubi volt, igen, ha jól emlékszem. Az fstab szerkesztés nem tudom, mit jelent.
Fejhallgató: de hát hogy lehet úgy támogatni egy eszközt, hogy egyik oldalán szól, a másikon nem?
A lekapcsolás alatt annyit értek, hogy kihúztam a dvd-olvasóból a tápkábelt.
Ja és még annyi: Xubuntu alatt ugyanazok a parancsok, mint Ubuntunál?
dbius
ngabor2
#9992
kiegészíteném egy aprósággal, ami fontos lehet:
tudtommal az alternate verzióban a telepítés során választható, hogy hová (melyik vinyóra) települjön a grub, a desktopnál mindig a hd0-ra rakja.
Szerk: gyorsan még ennyit találtam itt:
"The alternate install CD allows you to perform certain specialist installations of Ubuntu. It provides for the following situations:
* creating pre-configured OEM systems;
* setting up automated deployments;
* upgrading from older installations without network access;
* LVM and/or RAID partitioning;
* installing GRUB to a location other than the Master Boot Record;
* installs on systems with less than about 192MB of RAM." -
_ak_
ngabor2
#9974
Az ujjlenyomat olvasóhoz találtam egy csomó leírást, de sajnos eléggé limitáltak a képességei. Bejelentkezésre és sudo parancshoz lehet használni, de pl az idő átállításához már be jel gépelni a jelszót. Azt sem tudom, h lehet-e használni a weboldalakra való bejelentkezésre.
Btw a kártyaolvasó nálad működik egyből?
Egorov
ngabor2
#9872
Hello!
Igazad van. Eddig azért nem próbáltam mert az van odaírva, ha nincs Windows-om akkor csináljam. No de megpróbáltam, az fstab file-ba beírtam azt a sort.(/dev/sdb6/media/Ubuntu ntfs-3g force 0 0) Remélem külön sorba kell, mert én oda írtam
(1 hónapja van Ubuntum, így ha hülyeség akkor bocsesz
)Újraindítottam de semmi változás.
_ak_
ngabor2
#9863
awesome guide fail, 7ik pontban error: implicit declaration of function 'kill_proc"
Na mind1 12 nap és itt a végleges, remélem abban nem fog elmenni a net, ámbár meg kell még küzdenem majd az atheros wifivel is. ott majd az ndiswraperrel kell szórakozni
addig lehet simán feldobom a 8.04et, hátha az tud kezdeni vmi vele. -
_ak_
ngabor2
#9861
a 8.04be elvileg bekerült, ezért működhetett alapból amikor feltettem a rendszert, de az update után nem volt többé netem.
Megaláltam EZT a leírást, de nekem is a netről próbálja leszedi a cuccokat, úgy h szerintem nekiülök annak az awesome guidenak.
Az iwconfig, semmiféle wireless cuccot nem talál.
a pendrive egyszerűen nem volt rendesen leválasztva win alatt azért sírt.
Vladi
ngabor2
#9847
Lehet, csak ikont nem tett neki. De szokott lenni egy szívás az automonttal, ha az xp/vista nem állt le rendesen. Akkor az automounter nem tuja felcsatolni az ntfs partíciókat. Csak --force -al. Erre érdemes mindenkinek odafigyelni.
Sianis: gratulálok én is!
"Nightmonkey (formerly DDTP-lp-html, but this name sucks ;))"
Tomics
ngabor2
#9836
Az a baj, hogy linux alatt nem látom azt a partíciót, ahova a linux telepítve lett (ezen csak doksik, médiafájlok vannak, tehát nem a windows).
A linuxot windowsból telepítettem fel, wubival, tehát unistallálható a windowsból.
Egy rakás zene, doksik vannak ezek a partíción, de nem tudom kipróbálni így őket linux alatt így... -
_ak_
ngabor2
#9831
Köszönöm a segítséget, ámbár ebből a szempontból még elég kezdő vagyok. Szóval, a sikertelen grub telepítés után live cd módból telepítettem az ubuntut, és elviekben a grubot is. sd3 partícióra, de restart után egyből a vista jött be, tehát a grub install nem működött.
Akkor nekem most megint live cd alól kéne egy terminál és bepötyögni a parancsokat sd3-al?Magam sem értem, h most min szenvedek. Ismerkedtem már az ubuntuval épp ugyan ezen partíciók mellett és működött minden, pedig akkor még azt sem tudtam mi az a terminál, csak szívtam az nvidia driverrel, plusz egy kernel update után nem töltött be az ubuntu sem, így back up partíció lett belőle. úgy tűnik itt a bosszú ideje.
bme
ngabor2
#9757
Ezt megcsináltam, de minden ment normálisan. Nem állt meg sehol.
De szerintem nekem nem is ez kell, mert nem bootoláskor fagy le, hanem amikor az újraindítás opciót választom, akkor ugye van ez a [URL:http://media.arstechnica.com/news.media/ubuntu_boot.png]kép[/URL], csak ilyenkor a narancssárga csík jobbról balra fogy el. Mikor elfogy a csík, ott akad meg.Major Major: azt is megcsináltam amit Te írtál, de miután beírom a jelszavam, akkor azt írja, hogy Login incorrect
Jah és még valami. Azt hol lehet beálltani, hogy Firfoxban a backspacet ha megnyomom, akkor visszamenjen az előző oldalra?
#25954560
ngabor2
#9524
madwifi bugnak tunik, ha nem neztem be...
#25954560
Wolfskin
ngabor2
#9096
sajnos semmi
valahogy az az érzésem, hogy aki nem születik bele a linuxba, esélye sincs, hogy használja... nekem továbbra is néhány fanatikus játszótere marad, ami valós munkára nem alkalamas. pc esetében még mindig, mindenre rájöttem, megoldottam, az valahogy egyértelmű, kézenfekvő, és felkínálja a megoldéási lehetőségeket. talán mert azt a felhasználóknak tervezték, a linuxot meg programozók saját maguknak. na mindegy, nem bosszankodom tovább, elment egy napom, meg a kedvem is a linuxtől egy életre...
azért köszi!
- Microsoft Surface Pro 7+ - Újszerű, billentyűzettel és ceruzával
- BESZÁMÍTÁS! MSI B450 R7 5700X 32GB DDR4 512GB SSD RTX 3080 10GB Zalman Z1 Plus Cooler Master 750W
- Segway Ninebot E3 elektromos roller - Bontatlan - Új
- AKCIÓ! Apple Studio Display 27 5K Nanotexturált üveg monitor garanciával hibátlan működéssel
Cég: ATW Internet Kft.
úgy néz ki, nem akarja a rendszer a hardveres gyorsítást, pedig a log szerint semmi hiba nincs, a kártyát is felismeri (G45), mégse. szoftveres van, de az eléggé szaggat még ezen a gépen is. no, majd utánanézek jobban, ha lesz időm.
