- Műholdas AI chippel fedné le a bolygót a Samsung
- Szakított a OnePlus és a Hasselblad
- Nem lesz iPhone 19
- A legolcsóbb és a legdrágább új iPhone fogy a legjobban
mr_ricsi
Lompos48
#12017
Ha már a wikipédiából idézel, akkor azt a részt sem lenne szabad elhallgatnod, ami nem azt mutatja, hogy a ZnO-ot csak tornacipőkhöz használják:
"Thermal greases use one or more different thermally conductive substances:Ceramic-based thermal grease has generally good thermal conductivity and is usually composed of a ceramic powder suspended in a liquid or gelatinous silicone compound, which may be described as 'silicone paste' or 'silicone thermal compound'. The most commonly used ceramics and their thermal conductivities (in units of W/(m ·K)) are:[4] beryllium oxide (218), aluminum nitride (170), aluminum oxide (39), zinc oxide (21), and silicon dioxide (1). Thermal grease is usually white in colour since these ceramics are all white in powder form. These figures are for bulk material, not thermal grease.
Metal-based thermal grease contain solid metal particles (usually silver or aluminum). It has a better thermal conductivity[citation needed] and is more expensive than ceramic-based grease.
Carbon based. There are products based on with carbon-based conductors, using diamond powder,[5][6][7] or short carbon fibers [1], they have the best thermal conductivity[citation needed] and are generally more expensive than metal-based thermal grease.
Liquid metal based. Some thermal pastes are made of liquid metal alloys of gallium. These are rare and expensive.
Phase Change Metal Alloy (PCMA) is not a "grease" but another type of Thermal interface material. The design consists of a sealed alloy metal pad that needs to be "reflowed" under high heat (typically 90-100C.) The alloy on the inside of the seal will change phases, and fill all the micro-voids. Since this material is made of mostly metal alloy, the thermal properties of this interface material are very good."
forrás: [link]És még egy link:[link]
Meg egy Biztonsági adatlap, amely szerint nincs is a ZnO-on kívül más oxid a termékben.
[Ez] pedig még egy, ami szerint 60-80% a ZnO aránya a termékben.
- ÁRGARANCIA!Épített KomPhone Ryzen 5 5600X 16/32/64GB RAM RTX 5060 8GB GAMER PC termékbeszámítással
- GYÖNYÖRŰ iPhone 12 mini 128GB Green -1 ÉV GARANCIA - Kártyafüggetlen, MS3395, 94% Akkumulátor
- LG 35WN75C-B - 35" Ívelt VA - 3440x1440 - 100Hz 5ms - USB Type-C 60W - AMD FreeSync - HDR 10
- Telefon felvásárlás! Samsung Galaxy A15, Samsung Galaxy A25, Samsung Galaxy A35, Samsung Galaxy A55
- Bomba Ár! Lenovo ThinkPad E14 G2 AMD - Ryzen 5 I 8GB I 256SSD I 14" FHD I HDMI I W11 I Gari
