- Felrobbant a Pixel Fold Zack Nelson kezében
cigam
MaCS_70 #6479 üzenetére
Elég ritka, mondhatni fehér holló megoldás, hogy gyárilag adnak olyan szoftvert, ami betűjelhez köti a hálózati tartalmat. Ugyanakkor nem kötelező használni. Most nem ugrik be a neve, de régebben itt is téma volt, hogy létezik olyan (fizetős) program ami elég sok szolgáltatót ismer, és az általad megadott betűhöz társítja a felhő szolgáltatót. Használd azt a gyári helyett.
jbl
MaCS_70 #6352 üzenetére
— CyberGhost VPN Support
Franz, Apr 20, 2024, 10:34 PM GMT+8:Hello,
Thank you for writing back, and please know that I appreciate your patience.
I’m sorry that you’ve decided to refund your subscription to us.
I acknowledge that you provided your reference number Uxgdwsp, and the refund was processed successfully.
You should expect to see the refunded amount reflected in your account within 5 to 10 bank business days (excluding weekends and legal holidays). It usually takes less but it depends on how soon each bank processes these types of transactions and we would ask you to wait through the above-mentioned time frame first.
Thank you for being a part of CyberGhost VPN and should you wish to consider VPN service again, please know that it can provide you with a multitude of benefits such as improving your security and privacy. For streaming, we have optimized streaming servers that may help you access geo-restricted services.
Would appreciate any further feedback that will help us better in the future and your expectations on the product. We value your comments and hope to serve you again in the future.
If you have any more questions, please do not hesitate to contact us.
Thank you and have a great day!
Regards,
Franz
CyberGhost VPN Support -
borges7
cigam
MaCS_70 #6284 üzenetére
Egy 8 éve működő csapat/program szerintem nem a "semmiből jött". Ha én holnap kiadom a mountcloud 1.0-át, akkor sem feltétlen ártó szándékkal, hátsó kapuk tömkelegével.
Tudom, jobb félni mint megijedni, de mindenki volt kezdő. Az MS-nek évtizedes rutinja van, és mégis gyomorgörcsel teszed fel a havi frissítést, hogy vajon most mit b...tak el.
De ott van pl. a Google. Nem tegnap kezdte, azt mégis rengeteg adatot törölt a programjuk. -
jbl
MaCS_70 #6266 üzenetére
Mert szerinted nem történt semmi. "Véletlenül bugos lett" ahol több 100000 IT szakember dolgozik. Itt nemcsak cicás kutyás fényképek tűntek el. Több millió cég dolgozik Google drive ba. Google úgyis takarítani fogja szemetét mindenhonnan le lesz törölve a bakit nyoma nem fog maradni.
#20584850
MaCS_70 #6162 üzenetére
Valamelyik hasonló felhő kezelő progi bekavarhatott, hogy valószínű nem léptem ki a csatlakozásból és úgy töröltem.
Írja is, hogy This file will be decrypted as soon as the cryptographic key becomes available(when the share creator logs in again) csak nem tudtam mire utal, hogy ki jelentkezzen be újra. -
#20584850
MaCS_70 #6160 üzenetére
Szerinted mi lehetett a kérdés ha felmegyek a felhőbe és az összes fájlom undecrypted fájl néven van és nem tudom megnyitni?
Közben találtam a neten megoldást az AirLiveDrive használatával belépek úgy már megjelennek.
AirLiveDrive lecsatlakozása után böngészőből ismét belépve a megába ugyan az fogad undecrypted fáj. -
#46824192
MaCS_70 #6134 üzenetére
Miért nem?
A syno wines sync progija egy fokkal használhatóbb ,mint a one drive.Szabad kezet ad szinte mindenben és jól működik.
A végső cél pedig az ,hogy a onedrive-ban legyen egy mentés és ez ezzel teljesül.
A köztes lépcsőfok ,ami egy nas, az sem azért van ,mert nem volt jobb ötletem és elszaladtam venni egyet. Az is a cégnél (céges a laptop és a számlázó progi is) van, és annak a teljes mentése is onedrive-ba történik.Szóval az én szemszögből nézve ez így szerintem jobb ,mint a jobbra balra linkelgetés.
#46824192
MaCS_70 #6130 üzenetére
Köszönöm!
Ez lesz a megoldás , bár a lényeg csak annyi hogy a c:\szamlazo egyszerűen kerüljön szinkronizálásra a többi onedrive mappával.(mivel elmozgatni nem tudom a gyökérből)
Szóval ha belinkelem ezt a c:\onedrive mappába , akkor jól gondolom hogy szinkonizálva lesz és a onedrive nem fog tudni róla , hogy az egy máshol lévő mappa?
RoryBreaker
MaCS_70 #6113 üzenetére
Valóban... Egy user/onedrive/asztal mappában...
Ha áthelyezem, gondolom nem szinkronizál. Ha átmásolom, gondolom nem szinkronizál....
Hogy van ez?Nekem mind2 gépen az aztali elemeket kellene szinkronizálnia.
Parancsikon, ami rá mutat nem oké. A konkrét mappa kellene mind2 gépen az asztalon fizikailag. -
#46824192
MaCS_70 #6117 üzenetére
Továbbra sem értem ,hogy miért a win hibajavítását erőlteted , hiszen már 2x írtam , hogy azzal nincs baj.
A hiba a telefonos app-ban van.
Ezt a javítást :
pedig [ez] : "Gyakorlatilag már mindent végig zongoráztam ami csak eszembe jutott." természetesen magába foglalja. -
RoryBreaker
MaCS_70 #6105 üzenetére
Köszi.
Olyan gond jött elő, hogy az egyik gépen megjelenik az asztalon lévő mappa, amit szinkronizál, egy másik gépen meg nem. A fájlok megvannak a c/users/felhasználónév/onedrive/asztal mappában. De az egyik gépen nem jelenik meg az asztalon. Miért van ez?Egyik gép win10, másik 11, ez lehet a baj?
cigam
MaCS_70 #6074 üzenetére
Tényleg nem teljesen értem, mert bármikor kijelölhetem az adott fájlt/mappát, hogy offline is elérhető legyen: [link]
11. Hogyan engedélyezhetem az Offline hozzáférést a kívánt fájlokhoz?
Hálózati kapcsolat nélkül is elérheti és megtekintheti fájljait. Egyszerűen csak elérhetővé kell tennie őket offline módon:
- Keressen meg egy fájlt/mappát, és nyissa meg a További opciók menüt
- Válassza az Offline elérhetővé tétel lehetőséget.
Az összes offline hozzáféréssel rendelkező fájlhoz hozzáférhet a bal oldali menü Offline fájlok szakaszában.
Ha le szeretné állítani az offline hozzáférést, jelölje ki az adott fájlt/mappát, és válassza az Offline hozzáférés eltávolítása lehetőséget.
Alapértelmezés szerint a fájlokat csak akkor teheti offline elérhetővé, ha Wi-Fi hálózathoz csatlakozik. Ha a mobiladatokat szeretné használni, tegye a következőket:
- Nyissa meg a Beállításokat a bal oldali menübenGörgessen le az Offline fájlok szakaszra
- Kapcsolja be a Mobil adatok használata opciót.Szóval úgy tűnik nyitott kaput döngettek. Persze a működése lehet nem olyan szofisztikált mint a FolderSync (Eddig nem is hallottam róla, nem nagyon használok/keresek Android-os programokat).
A Solid Explorer pedig működhet a webdav protokollal, ha előfizetsz a "prémium" szolgáltatásra. [link]
Az európai szerver címe: https://ewbdav.pcloud.com -
WhiteWalker
MaCS_70 #6066 üzenetére
Az ingyenest megértem , hogy így csinál.
De ha fizetek érte azért ezt nem szeretném.
Jó lenne a fizetős Google Drive is , ha tudnám hogy nem használják fel a képeket.
Vagy ott a Dropbox is , azzal se lenne semmi bajom , ahogy írják van náluk titkosítás is.
Ebből a szempontból inkább oda fizetnék elő.(Eddig a pCloud is megfelelne, csak kevés appba van integrálva)
vond
MaCS_70 #6019 üzenetére
Én sem értem, hogy miért nem lehet megadni egy tetszőleges betűt. Mennyi lenne ez, két sor a kódban? Én kipróbáltam azt, hogy foglalt a P:/ (nálam itt vannak a nagyobb projektek a NAS-on, hálózati meghajtóként felcsatolva). Akkor visszafelé a legközelebbi elérhetőt foglalta be magának. Esetemben a K:/-t. Ami amúgy a kártyaolvasóé, csak mivel épp nem volt benne kártya, így szépen felborította nekem az egész rendszert. De ezelőtt még magát a P:/-t is eltoszta, amikor épp offline volt a NAS, közvetlenül a gép bekapcsolása után. Szóval igen jópofák ezek a pCloud-nál.
Ahogy azzal kapcsolatban is, hogy a korlátlan tárhely náluk alapból 2 TB-ot jelent. Aztán írnod kell nekik, hogy szeretnél bővítést. Kapsz valamennyit (erről nem találtam leírást, és a support sem árulta el, hogy mennyit), aztán ha az is elfogy, akkkor lehet újra könyörögni.
Emiatt, plusz a külön fizetős titkosítás miatt, nomeg a 20 éve is gagyi UI miatt pottyant ki nálam az esélyesek közül.
A Sync.com bűn lassú (nem is értem ezt az 5 MB/s-ot 2022-ben) és körülményes, feature-ökben nem annyira gazdag volt nekem.
Az Icedrive meg drága és egyelőre nem olyan nagy cég, plusz itt is fizetős a titkosítás.
A Dropbox is drága, és azzal is akadtak biztonsági problémák a múltban, meg a szinkronizálás sem úgy működik, ahogy kellene.
A Google One meg bármennyire is jó, hogy van benne közel teljes értékű Office, meg egy rakás másik plugin, elég véleményes a biztonság szempontjából, az asztali alkalmazás is elég tré, plusz nem tud például olyan alapvető dolgokat, mint a file request, vagy drop folder regisztrálatlan felhasználóknak. Márpedig nekem ez is fontos lenne.
Úgyhogy nálam egyelőre a Mega a befutó, azzal együtt is, hogy ismerem a cég múltját.
sopruk
MaCS_70 #5948 üzenetére
Igen az Amazonnál is van ilyen jelölés, meg iDrive-nál, Scaleway-nál is említik az S3 kompatibilitást...
Nézegetem a különböző szolgáltatókat melyeket korábban ajánlottak itt a fórumban, olyan esetekben amikor nagy mennyiségű adat archiválására lenne szükség kedvező áron. Említve volt még hasonló: Backblaze
Ha jól gondolom, ezek nem hagyományos felhők, például eszközök közötti szinkronizálással, hanem inkább tárolásra valók.
Milyen S3-at kezelő programok léteznek? Vagy ha csak tárolásra használnám, akkor engem nem érint? -
sopruk
MaCS_70 #5941 üzenetére
Most manuálisan frissítettem a klienst 2.1.0-ról 2.1.2-re, mert egyszer mintha hasonló problémát oldott meg a frissítés, de nem segített.
Kb 4 percig indexel újraindításkor, kis file módosításnál, vagy megáll 20, vagy 99 %-nál az upload, kb. egy 20 MB-os új file esetén...
Nincsenek fedvény ikonok sem a win filekezelőben.
Mintha minden egyes módosításkor az összes szinkronizált file-t újra indexelné, átvizsgálná (Kb 3 GB az egész, 16.500 db file...) -
rolkaDb
MaCS_70 #5926 üzenetére
Én is igy gondolom, mégis csak a meglévő információ halmazból tudok tájékozodni.
Mondtam neki, hogy ne használni a laptopot, amig tüzetesebben szemügyre nem tudom venni. Szerintem a szinkronizálás alapvetően nem lett piszkálni, ahogyan alapból felajánlja a program.
Ellenben éredekesség, hogy ~1,5 hónappal ezelőtt egy ismerős is járt igy, hogy a onedrive szinkonizációt megszüntette és az asztaláról a fájlok eltüntek, pc kukában nem, DE a onedrive kukájában megvolt hiánytalanul.
rolkaDb
MaCS_70 #5924 üzenetére
Én arra tippelek, mert a google driveval csak képeket akart szinkronizálni és aznap telepitette mikor ez történt. Annak fényében irom, hogy érthető legyen a prnscrn. Ezt kaptam tőle, ezért gondolom hogy a onedrive szinkron megvolt. Esetleg más, ami nem jött le nekem a screenből?
*A gyorselérésből nyitna meg a "de-gazdaságinformatika" mappát, ami alapjáraton az asztalon helyezkedett el.
Plusz itt elvileg nem is lépett ki a onedrive fiókból, csak telepitette a Gdriveot. Azt sem teljesen értettem, hogyan lehetséges vagy mi történt.Valahogy úgy érzem ilyen visszaállitó programok nem lesznek 100%-osak, deha valakinek van ezel kapcsolatban ötlete szivesen fogadom! Illetve tüzetesebben megnézem az internet adta lehetőségeket!
rolkaDb
MaCS_70 #5922 üzenetére
Először is köszönöm mindekettőtöknek a választ!
Kifejtem bővebben, néhány eshetőségre felkészülve. E/1-ben egyszerűbb volt fogalmazni, de mégsem olyan egyszerű kérdéskörré alakult! Egy kedves barátom problémájának megoldásában szeretnék segiteni, mivel ő nem feltétlen kompetens ezen területen.
A téma adott, asztalon lévő mappa tartalma eltünt, ami onedrive szinkronban volt valószinűleg. Namár most a pc lomtárában nincs, azóta utánaolvastam, teszteltem egy laptopon, hogyan viselkednek a pc-n megosztott/onedriveban megosztott fájlok. Namármost 2 dolog biztos, hogy a fájloknak nyoma veszett, illetve nincsenek a pc lomtárjában sem. Itt kezd érdekessé válni a dolog, mert állitása szerint nem használt ilyen fiókot, ergo nem tudja a mailt arra a fiókra. Ellenben akkor tüntek el a fájlok, mikor nem szándékosan leválasztotta a fiókot/kijelentkezett az applikációból pc-n. Vissza tudom keresni valahogyan a fájlokat valami recovery programmal, ha igen melyikkel kellene probálkoznom?(Feltéve, ha a pcn voltak helyileg és a onedriveba szinkronizáltak, s nem forditva, mert a test során nekem sem jelentek meg a pc lomtájában, csak a onedrive lomtárjában.) Vissza tudom keresni milyen email cimmel volt bejelentkezve előtt a pc-s od appba? Ha mindezeket sikerül meglépni, eszébe jut, emlékezik, valahol felvolt irva véletlen. DE nem lesz annak a lomtárjában, akkor hova tovább?
Őszintén azért lenne fontos, mert 7 félév egyetemi anyagai, illetve egy pár %-os szakdolgozat voltak ezek a fájlok.
Közelebbről megnézni jövőhéten tudom.
Ha meglenne a fiók, illetve sikerülni is beloggolni, akkor lehet restoret csinálni, ha van előfizu, de nekem ugy jött le ez a dolog, hogy amit az egyetemtől kapnak is valamiféle ilyesmi lehet, tehát él ez a lehetőség. Legalábbis remélem.
Elolvastam mielőtt elküldeném, remélem érhető a történet és a fennálló probléma is, köszönöm! -
lanszelot
MaCS_70 #5845 üzenetére
Először is köszönöm szépen a választ
Pcloud-ot néztem, de ott azt se tudják mi a backup és a szinkronizálás között a különbség.
Azt írják szinkronizálás, és leírják a backup fogalmát /videón is backup-ot mutatják/
Ezert nem mertem.Icedrive pedig semmit se ír, hogy mi merre, azt azért nem mertem.
Megírom majd, hogy ha sikerült akkor is -
Snoop-y
MaCS_70 #5777 üzenetére
Ez most egy kicsit bonyolultabb lett:
Mivel nekem Enterprise accountom van en mar regota hasznalom ezt igy sok ujdonsag nincs benne, gyakorlatilag most osszevontak a lakossagi es a business klienseket.
Szoval az uj Google Drive nemreg megkapta a FileStream opciot ami eddig a business kivaltsaga volt.
Stream mode-ban az osszes file elerheto a szamitogepen, viszont nem ott tarolodik. A file amikor megnyitod letoltodik a gepedre. Ezzel lehet ugye helyet sporolni meg hat ha 10+ TB cucc van a felhoben lokalisan ritkan van ennyi helyed egy laptopon mondjuk
Az uj Drive for Desktopban a beallitasoknal kivalaszthatod, hogy hogyan hasznalod. Stream vagy Mirror mode-ban.
Pl ha fotokat syncelsz valaszthatsz, hogy a mappaban levo fileokat elmentse drive-ra plusz megadhatod, hogy feltoltse oket Google Photos-ba is. Ezzel ovatosan mert eszi a tarhelyet annak eredmenyekeppen, hogy duplan tarolod a kepeidet (Drive + Photos)
Es itt el is erkeztunk egy fontos tudnivalohoz:
- Ha Photos-bol torolsz akkor nem torli Drive-rol sem lokalisan
- Ha Drive-rol torolsz akkor torli lokalisan viszont nem torli Photos-bol
- Ha lokalisan torolsz akkor torli Drive-rol viszont nem torli Photos-bolmod:
Ha syncelt mappabol torolsz akkor nem lehet mert amit lokalisan letorolsz azt letorli a drive-ban is es forditva.
Ha kerdes van keress nyugodtan remelem tudok majd segiteni
Snoop-y
MaCS_70 #5774 üzenetére
Az uj Gdrive az valoszinuleg ujra Syncelt olyan fileokat is amit esetleg korabban toroltel az online feluletrol. Sync & backup -ban volt olyan lehetoseg, hogy a torleseket ne szinkronizalja igy lehetett localban torolni pl de megis megvolt online es vice versa. Most ilyen nincs. Amit syncelsz azt feltolti/letolti ugyanugy le is torli mindenhonnan.
Ha most migraltal akkor az osszes file-t ami a gepeden volt egy adott konyvtarban azt szepen feltoltotte.
tonyrulez
sopruk
MaCS_70 #5553 üzenetére
Akkor ez a Syncplicity probléma azóta többször is előfordult? #5496
Pedig épp most akartam felrakni két gépre, de akkor inkább a Sync. Úgy látom ez gyorsabban is szinkronizál...A SpiderOak-nál nem találom a 2 GB-os ingyenest, csak a 21 napos kipróbálási lehetőséget. Megszüntették volna, vagy csak én keresem rossz helyen?
Zsolt_16
MaCS_70 #5342 üzenetére
Nekünk az egész céges környezet rávan húzva ma reggelig minden gond nélkül jó volt az elmúlt másfél évben.
Több telephelyen is ugyan azt az üzenetet kapják:
,,Hiba történt.
A kért lap átmenetileg nem érhető el. Elnézést kérünk a kellemetlenségért. Látogasson vissza néhány perc múlva."
Akkor csak várni tudunk és reménykedni, hogy helyre hozza a microsoft -
ledgeri
MaCS_70 #5271 üzenetére
Windows lenne ja... Mondjuk nekem picit OP gigás "progit" tartani arra, hogy heti/havi egyszer lefusson a sync párszáz megával.
Amiket találtam:
Talán a synology kliense, airexplorer, odrive. Vártam még velük, hogy ha lenne itt "ezek jók" pakk.
Csak a tervezett rendszerem, ha valakinek lenne hozzászólnivalója:
Haldoklónak tűnő SSD-ről napi/kétnapi mentés (csak fontosak, progival automatán) HDD-re, erről heti/havi egyszer mentés fel cryptomatoron keresztül. Alapból meg HDD-ről mentés külsőre helyben havonta..
- Gyúrósok ide!
- ROG Xbox Ally X: Összefogás
- Airsoft
- eBay-es kütyük kis pénzért
- Eredeti játékok OFF topik
- Építő/felújító topik
- BESZÁMÍTÁS! ASRock Fatal1ty Z97 Killer alaplap garanciával hibátlan működéssel
- Samsung UE46F5005AK 46" (116cm) FULL HD LED TV
- Lenovo E490 Notebook i7/16/500
- iKing.Hu - Apple iPhone 15 Pro Max Natural Titanium Titán dizájn, 5 optikai zoom 256 GB- Gari
- Lian Li LCD-s 360mm-es vízhűtés akciós áron eladó!
