- Mindenki Z Fold7-et akar
sto1911
Intruder2k5 #10337 üzenetére
Nem is kell egyetertenunk, bar ha jol emlekszem, a FATFS-el volt part1, lehet ott keresendo a kulonbseg? MOD: nyilvan ha egyben van a lemez, az is particio, csak maga a particio szo veszti el az ertelmet.
root@sto_home:~# ls -l /dev/discs/disc0/*
brw------- 1 root root 8, 0 Jan 1 1970 /dev/discs/disc0/discroot@sto_home:~# cat /proc/partitions
major minor #blocks name31 0 128 mtdblock0
31 1 7936 mtdblock1
31 2 5696 mtdblock2
31 3 960 mtdblock3
31 4 64 mtdblock4
31 5 64 mtdblock5
31 6 64 mtdblock6
31 7 8192 mtdblock7
8 0 1945600 sdaMeg MOD: mas csomagnal is ez van:
root@sto_home:~# opkg install elinks
Installing elinks (0.11.7-1) to root...
Downloading http://downloads.openwrt.org/backfire/10.03/ar71xx/packages/elinks_0.11.7-1_ar71xx.ipk.
Configuring wget.
Configuring elinks.
Collected errors:
* pkg_run_script: postinst script returned status 1.
* opkg_configure: wget.postinst returned 1. -
sto1911
Intruder2k5 #10335 üzenetére
Az egesz lemez egyben van formazva, ext2-re, Easeus-al, irni lehet ra. A part1 jelentene, ha tobb particio lenne rajta, akkor az elso van mountolva.
--- /dev/discs/disc0/disc
Block device, size 1.855 GiB (1992294400 bytes)
Ext2 file system
Volume name "ROUTER"
UUID 9512316BE9-EE10-0136-D538-123123 (MS GUID)
Volume size 1.855 GiB (1992294400 bytes, 486400 blocks of 4 KiB)
Status: Mounted on /jffs -
sto1911
Intruder2k5 #10327 üzenetére
Na csak el tudtam indulni:
root@sto_home:~# mount
/dev/discs/disc0/disc on /jffs type ext2 (rw)
root@sto_home:~# ls -l /jffs/
drwxr-xr-x 2 root root 4096 Mar 4 13:38 bin
drwxr-xr-x 2 root root 4096 Mar 4 13:38 etc
d--------- 2 root root 4096 Jan 1 1970 lost+found
-rw-r--r-- 1 root root 609285 Mar 4 13:38 opkg-ddwrt.tar.gz
drwxr-xr-x 2 root root 4096 Jul 23 2010 tmp
drwxr-xr-x 3 root root 4096 Mar 4 13:38 usr
drwxr-xr-x 3 root root 4096 Mar 4 13:38 varroot@sto_home:~# opkg update
opkg: can't resolve symbol 'glob64' in lib 'opkg'.root@sto_home:~# opkg install wget
opkg: can't resolve symbol 'glob64' in lib 'opkg'.Rakeresek neten is.
Valami olyasmit irnak, hogy nem jol vannak forditva a libek -
sto1911
Intruder2k5 #10330 üzenetére
Nekem is az EASEUS van fenn, a gondot most nem a szoft jelenti, hanem, hogy valoszinuleg fizikailag nem leszek a router kozeleben jovo hetig.
sto1911
Koszi, de ebbol jovo het lesz, mivel az elso pontnal elakadtam, mert sima fat-ra van formazva a pendrive
DD-ben meg nem tudok formazni (?).
Ahogy elnezem sokat egyszerusodott a modszer miota nem foglalkoztam vele.
Esetleg letezik olyan browser, ami a visszaszamlalos letolteses oldalakrol is letolt?
@(#10328) vargalex: vmi tuzfalas gondom volt, egy nap mulva mindenfajta valtoztatas nelkul se engedett be ssh-n
zsolt501
Intruder2k5 #10315 üzenetére
Van néhány szolgáltatás amit csak így tudok rendesen tesztelni, a másik viszont wifis gépek esetén mikor vendég jön nem az IP címet adom meg hanem a dyndns címet a szerver eléréshez.
zsolt501
Intruder2k5 #10308 üzenetére
Rész sikerem már van, mióta feltettem a decemberit, már csak azt kellene elérnem hogy a dyndns címmel belső hálózatban is működjön mert külsőben már működik, de kellene hogy belső hálózat esetén is működjön.
Van másik internetem is meló miatt mobil net azzal is teszteltem, most már csak az kellene hogy az a fránya dyndns cím belső hálón is működjön. -
TeeJay
Intruder2k5 #10277 üzenetére
első perctől Tomato van rajta, és a transmit power is fel van picit emelve
sőt a routert úgy helyeztem el a szomszéd szobában is hogy szinte a legközelebb legyen a falhoz meg az én szobámban lévő laptophoz.
sajnos szar a környék, itt már csak N-es wifi meg nagy antenna segíthet, vagy ha az sem akkor fúrnom kell és gigabites LAN-t csinálni -
zsolt501
Intruder2k5 #10298 üzenetére
A telepítés tökéletesen lezajlott, viszont a port átirányítás az istenért nem akar összejönni.
A gépek fix ipt kapnak és a port átirányításnál megadom neki a gép IP címét és a kívánt portot de ennek ellenére nem akar átirányítani, mit kell még csinálnom hogy működjön?A legutolsó vagyis a 2011-es firm van rajta
ToBeY
Intruder2k5 #10287 üzenetére
Sima gyári fw van a routeren
Csabi1984
Intruder2k5 #10286 üzenetére
Szia Köszi majd kipróbálom
Csak fáradt vagyok
Csabi1984
Intruder2k5 #10282 üzenetére
Köszi a választ! Visszatérve a file elérés vagy megosztásra.
Berakom a Pendrivot,ki is írja hogy felismeri.
1,NAS fülön van az, hogy
Server String- ide mit kell beirni?
Workgroup
path of files /mnt /jffs stb. Ez mi a hóhér?
Ha Public onlyra rá megyek, van olyan hogy csak olvasás engedélyez ,és Tilt
Ha jól értelmezem,ha engedélyezem,akkor írás jogosultság nincs,ha engedélyezem akkor mindent lehet..?
Van olyan hogy User custom configuration
user 1
password 1
user2
password 2
és Custom config (ide lehet írni) -
Bernath
Intruder2k5 #10278 üzenetére
Erre még én is rájöttem,csak az a bibi,hogy a tracker jó,másik gépen simán jön ergo valami a freenassal hibádzik
Csabi1984
Intruder2k5 #10266 üzenetére
DDWRT van rajta
BigBlackDog
Intruder2k5 #10209 üzenetére
VIMnek a profile fájlát hol tudom elérni?
Csabi1984
Intruder2k5 #10247 üzenetére
Köszike
Holnap jelentkezem ahogy beüzemeltem!
Flashcash
Közösségépítő
Intruder2k5 #10225 üzenetére
Vidékre adtam kölcsön ilyet ismerősnek TP-Link WR1043ND routerhez, semmi javulást nem hozott neki, és nincsenek a közelben üzemelő wifi hálózatok. Persze lehet nála volt a közelben más zavarforrás.
Speeedfire
Intruder2k5 #10204 üzenetére
Elmentve, lehet beruházok rá majd egyszer.
Flashcash: De csak szedhet, lakótömbben esetleg lehet baj, de ott is meglehet oldani szerintem a csatornák állításával. Bár nem hinném, hogy panelbe kellene egy 8dbi-s antenna.
mobal: Szinte ugyan az mint a 1043nd csak nincs usb és nem giga lanos, amúgy ajnlott a 941.
Badb0y: Miért akarod azt 1500-ra állítani? -
Intruder2k5 #10213 üzenetére
BigBlackDog
Köszönöm, megpróbálom. Viszont van még egy kérdésem; hogy lehetne megoldani, hogy a routerre tett winyó (usb hubon keresztül) folyamatosan pörögjön. Jelenleg, ha nem fut a transmission egy idő után leáll a pörgés. Winyón van egy swap fájl is, de hiába. Ha nincs használva leáll. Túlzottan nem tűnik jó megoldásnak, ha naponta többször is le- felpörög, rövidül az élettartama. Ezért akarnám konstans módon pörgetni.
vargalex
Intruder2k5 #10187 üzenetére
Hi!
Szerintem csak visszafelé működik.
TeeJay
Intruder2k5 #10194 üzenetére
Broadcom BCM43225 miniPCIe kártya van az Acer notimba
úgy olvastam a Broadcom oldalán hogy ez 2x2MIMO-s N-es tudású tehát 300megabitre tippelek nem pedig "draft" N-es 150megabites.kiderül majd mit tud a routerrel
ha meg nem lesz elég még a vétel átcseréltem mind a három antennát 8dBi-re mert az megvan max 3ezerből és akkor már lakáson belül hasítani kell a wifi-nek -
netboy
Intruder2k5 #10200 üzenetére
1. megvolt
2. tplink oldaláról szedtem de a 3 közűl egyikkel sem működik megfelelően
3. az lesz -
kispal1980
Intruder2k5 #10196 üzenetére
És usb hub alatt van valami RAID megoldást esetleg, az adatveszteség elkerülése miatt??
Vettem tegnapelőtt egy asus oplay3 airt , hogy majd a szerverről nézem a filmeket!
De ez így most nem nagyon jön össze, a másolási sebesség miatt!Elképzelhetőnek tartod , hogy az usb miatt lassú a sebesség és hdd-vel megoldódik????
kispal1980
Intruder2k5 #10192 üzenetére
Aha értem!
Lenne lehetőség hdd-vel próbálkozni. Nézem majd egyet!
Olyan kérdés lenne ha állandóan menne egy hdd, meddig birja az kb?
Lehet hülye kérdés ,de úgy gondolom árt neki ha állandóan megy ! Vagy tévedek?Valami RAID lehetőség lenne esetleg, mondjuk usb-hub és két vinyó ?
Lehet mondjuk akkor már érdemesebb lenne egy dns-323!
Ismered? Van róla valami véleményed? -
TeeJay
Intruder2k5 #10154 üzenetére
én is tudom hogy a csatlakozási sebesség kb. felét jó ha el lehet érni nettóban
54megabites Wifi is kifullad úgy 22-23megabitnél...
engem az érdekelt hogy mixed módban tud-e a laptop egyáltalán 300megabitre csatlakozni vagy max 130-ra (20MHz csatornákkal vagy mivel)most is az a bajom hogy szinte alig van olyan csatorna ahova stabil 54megabitre tudna csatlakozni a wifi és ha már 48-ra visszaesik akkor már 18megabit sem megy át nettóban...
30megás netnél ez elég gáz...azért akarom az N-es routert hogy ott hátha több az esély 3antennával arra hogy legalább a 30megabites internetet gondtalanul átvigye normális minőségben
kispal1980
Intruder2k5 #10190 üzenetére
Hát már ott tartok hogy fejjel megyek tényleg a falnak...........
Fölteszek egy régebbit akkor
Melyiket tegyem föl?
factory-to-ddwrt.bin ?
tl-wr1043nd-webflash.bin ?Jó lenne használni a hálózatot, már örültem hogy jó lesz, meg jó is volt. Csak ezzel a sebességgel nem lenne baj!
kispal1980
kispal1980
Intruder2k5 #10183 üzenetére
root@DD-WRT:~# mount -t ext3 /dev/sda1 /jffs
rootfs on / type rootfs (rw)
/dev/root on / type squashfs (ro,relatime)
proc on /proc type proc (rw,relatime)
sysfs on /sys type sysfs (rw,relatime)
ramfs on /tmp type ramfs (rw,relatime)
none on /dev type tmpfs (rw,relatime,size=512k)
devpts on /dev/pts type devpts (rw,relatime,mode=600)
root@DD-WRT:~# df
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/root 6400 6400 0 100% /
none 512 0 512 0% /dev
root@DD-WRT:~# -
kispal1980
Intruder2k5 #10181 üzenetére
root@DD-WRT:~# mount -t ext3 -o rw,noatime /dev/sda1 /jffs
root@DD-WRT:~# df
root@DD-WRT:~# -
kispal1980
Intruder2k5 #10179 üzenetére
Az ext3-at nem tölti be csak valamiért!!!
root@DD-WRT:~# find / -name ext3.ko
/lib/modules/2.6.34.8-svn16124/kernel/fs/ext3/ext3.ko
root@DD-WRT:~# insmod /lib/modules/2.6.34.8-svn16124/kernel/fs/ext3/ext3.ko
root@DD-WRT:~# lsmod
Module Size Used by
ext3 107200 0
mbcache 3904 1 ext3
jbd 30544 1 ext3
nf_nat_pptp 1296 0
nf_conntrack_pptp 3312 1 nf_nat_pptp
nf_nat_proto_gre 832 1 nf_nat_pptp
nf_conntrack_proto_gre 2288 1 nf_conntrack_pptp
etherip 4224 0
bonding 74144 0
ath_mimo_ahb 398480 0
ath_mimo_hal 187248 2 ath_mimo_ahb
usb_storage 33008 0
sr_mod 10832 0
sd_mod 22384 0
cdrom 31168 1 sr_mod
scsi_wait_scan 368 0
scsi_mod 69952 3 usb_storage,sr_mod,sd_mod
ehci_hcd 30496 0
usbcore 96544 2 usb_storage,ehci_hcd
ag7100_mod 10352 0
rtl8366rb 8784 0
rtl8366_smi 6400 1 rtl8366rb
root@DD-WRT:~# -
kispal1980
Intruder2k5 #10176 üzenetére
root@DD-WRT:~# find / -name mbcache.ko
/lib/modules/2.6.34.8-svn16124/kernel/fs/mbcache.ko
root@DD-WRT:~# insmod /lib/modules/2.6.34.8-svn16124/kernel/fs/mbcache.ko
root@DD-WRT:~# df
root@DD-WRT:~# -
kispal1980
Intruder2k5 #10174 üzenetére
megcsináltam előtte!!!
root@DD-WRT:~# insmod /lib/modules/2.6.34.8-svn16124/kernel/fs/ext3/jbd.ko
root@DD-WRT:~# df
root@DD-WRT:~# -
Mr.Skynet
Intruder2k5 #10162 üzenetére
Nagyon köszi, neked is Keresztapper
Logout-okba, honlapokon, mindenhol láttam már ezt és k.rvára nem ugrott be
, az 1. hsz-nél meg egy az egybe átmentem rajta és már arról olvasgattam, hogy volt aki Siemens adatkábelből épített életmentő kábelt stb. már teljes mértékben beletörődtem, hogy vége a dalnak...
Speeedfire
Intruder2k5 #10137 üzenetére
Hmmm. Ma is okosabb lettem.
Shono
Intruder2k5 #10135 üzenetére
Köszönöm a gyors segítséget! Nekiesek.
A reset gomb OpenWrt alatt tényleg nem működik. -
Speeedfire
Intruder2k5 #10133 üzenetére
Mostmár árúljátok el nekem is mi az a hard reset...!!!
Shono
Hard reset = 30/30/30 ?
Nem frissítek / ddwrt / openwrt tennék fel, hanem a gyárit vissza! -
Intruder2k5 #10090 üzenetére
Van benne egy ilyen:
config global automount
option from_fstab 1
option anon_mount 1config global autoswap
option from_fstab 1
option anon_swap 0config mount
option target [ide mit írjak???]
option device /dev/sda1
option fstype ext3
option options rw,sync
option enabled 0
option enabled_fsck 1
option is_fsroot 1config mount
option target /mnt
option device /dev/sda3
option fstype ext3
option enabled 0
option enabled_fsck 1config swap
option device /dev/sda2
option enabled 0 -
Koszi szepen!
Ettol tenyleg nem fagyhat, mert normal Linux disztrok alatt is mukodik.
De vbox ala belovok egy tesztrendszert, es ott megnezem, hohy hogy megy -
amargo
Intruder2k5 #10096 üzenetére
Én nem láttam 14896-ban sehol a web-es felületen, a firmware-ben biztos volt.
De a services->nas->File Sharing nem volt látható.A auto mount-ot nem értem milyen logika alapján csinálja.. mert gyanítom, hogy a behelyezett eszköz első partícióját csatolja fel egyből. Ugyanakkor nem tudom miként tudja megelőzni az 1T winyó a 2GB-os pendrive-ot.
Ellenben ott van a startup script, csak nem tudom mennyire használható, mert a pendirve-on vannak a telepített programok és config-ok - bár a dd-wrt ez úgy is később csatolja fel, azaz nem innen indítja a rendszert vagy tévedek? Mert itt gondolom van lehetőség sorrendben mount-ni az eszközöket.
kispal1980:
Meg kell adni, hogy hova csatolja!
mount -t ext3 -o rw,noatime /dev/sda1 /mntvargalex:
Ebben az esetben, akkor a /jffs tartalmát az alapon kell hagyni, azaz ami a router-ben van memória van oda csatolva és az /opt -be fog kerülni a rendszer. Ilyenkor össze lehet kötni - bind - a két csatolási pontot?
Legalább is ebből azt veszem ki. -
tomi7711
Intruder2k5 #10087 üzenetére
USB-n keresztül (adatkábellel) rá lehetne dugni egy olcsó telót... Még sms-t is tudna küldeni
kispal1980
Intruder2k5 #10081 üzenetére
DD-WRT v24-sp2 (02/17/11) std
(SVN revision 16214)lehet nem jó ddwrt van fönnt?
ez a verzio van , masikat kellen föltenni?
kispal1980
Intruder2k5 #10079 üzenetére
root@DD-WRT:~# cat /proc/partitions
31 1 7936 mtdblock1
31 2 6336 mtdblock2
31 3 320 mtdblock3
31 4 64 mtdblock4
31 5 64 mtdblock5
31 6 64 mtdblock6
31 7 8192 mtdblock7
8 0 7833600 sda
8 1 7829568 sda1
root@DD-WRT:~# mount -t ext3 /dev/sda1 /jffs -o rw,noatime
root@DD-WRT:~# df
root@DD-WRT:~# -
kispal1980
Intruder2k5 #10077 üzenetére
root@DD-WRT:~# umount /jffs
root@DD-WRT:~# df
/dev/sda1 7675651 271 7283902 0% /jffs
root@DD-WRT:~#nem csatolja le
ggaben1
Intruder2k5 #10058 üzenetére
EASEUS Partition Master Home Edition
Simán formáz ext3 windows alatt.
kispal1980
Intruder2k5 #10068 üzenetére
király
jóéjt
kispal1980
Intruder2k5 #10066 üzenetére
nem jó. 6000-ről indul és pár másodperc múlva lemegy 1000alá is
root@DD-WRT:~# unmount /jfss
-sh: unmount: not found
root@DD-WRT:~# umount /jfss
root@DD-WRT:~# df
/dev/sda1 on /jffs type ext2 (rw,relatime)
root@DD-WRT:~# -
kispal1980
Intruder2k5 #10064 üzenetére
kispal1980
Intruder2k5 #10062 üzenetére
semmi ilyesmi nincs nekem.
sikerült megformáznide a sebbesség így is ugynaz!!!
sőt lemegy 500ig is
kispal1980
win7 van 64bit es
te hogy szoktad formázni, linux alatt?
kispal1980
Intruder2k5 #10056 üzenetére
sztem ntfsbe van!
ext3-at hogy tudok formázni?
az miért van hogy ha hálózati megosztott meghajtóról hozok létre ékezetes fájlokat, akkor a explorer és mozilla böngészőben nem jelenenk meg ékezetesen chromba jóóó
Ha ftp- ről hozok létre ékezetes fájlokat akkor minden ok!!
kispal1980
Intruder2k5 #10054 üzenetére
ddwrt van rajta!
ggaben1
Intruder2k5 #10023 üzenetére
Az első verzió és utána a df eredménye:
root@DD-WRT:~# ntfs-3g /dev/sda2 /mnt
ntfs-3g-mount: fuse device is missing, try 'modprobe fuse' as root
root@DD-WRT:~# df
/dev/sda1 201582220 109857976 81484416 57% /jffs
root@DD-WRT:~#A második verzió és utána a df eredménye:
root@DD-WRT:~# mount -t ntfs-3g /dev/sda2 /mnt
root@DD-WRT:~# df
root@DD-WRT:~# -
ggaben1
Intruder2k5 #10021 üzenetére
Az első verzióra ez a válasza:
ntfs-3g-mount: fuse device is missing, try 'modprobe fuse' as rootA második pedig minden látható következmény nélkül marad
amargo
Intruder2k5 #10018 üzenetére
Igazad van! Nem is feltételeztem..
zsolt501
Intruder2k5 #10012 üzenetére
Szerinted mi lehet a lassúság oka, mert router nélkül remekül megy.
nimfas
Intruder2k5 #10009 üzenetére
majd kipróbálom :-D
Most nem is értem hogy miért hasít a Samba 11Mbyte-al, de örülök neki....
nimfas
Intruder2k5 #10007 üzenetére
Speeedfire
Intruder2k5 #10004 üzenetére
Jól van belinkelem az asztalit mindjárt.
Vagy inkább a szerverét ahol az oldalam van.
nimfas: Nálam mondjuk alapból passzív a TC a beállításokban.Step by step
nano /etc/config/fstab
Olyat keress, hogy :
option 'options' 'rw,noatime'
Ilyenre írd át majd
Ctrl +o majd ctrl +x
Majd újracsatolod őket:
/etc/init.d/transmission stop && /etc/init.d/fstab restart && /etc/init.d/transmission start
Ennél jobban nem tudok leírni.
nimfas
Intruder2k5 #9971 üzenetére
Ext 4-re megy.
Ez a transm.conf:
config transmission
option 'enable' '1'
option 'config_dir' '/mnt/hdd/downloads/config'
option 'download_dir' '/mnt/hdd/downloads'
option 'incomplete-dir-enabled' 'true'
option 'incomplete-dir' '/mnt/hdd/downloads/incomplete'
option 'rpc_whitelist' '127.0.0.1,192.168.1.*'
option 'rpc_whitelist_enabled' 'false'
option 'preallocation' '1'
option 'watch_dir_enabled' 'false'
option 'open_file_limit' '60'
option 'peer_limit_global' '200'
option 'peer_limit_per_torrent' '30'
option 'speed_limit_down' '1300'
option 'speed_limit_up' '75'
option 'upload_slots_per_torrent' '8'
#option 'open_file_limit' '32'
#option 'peer_limit_global' '125'
#option 'peer_limit_per_torrent' '15'
#option 'speed_limit_down' '800'
#option 'speed_limit_up' '50'
#option 'upload_slots_per_torrent' '5'
option rpc_authentication_required 1
option rpc_password ***
option rpc_port 9091
option rpc_username ***
option 'cache_size_mb' '2'
option 'watch_dir' '/mnt/hdd/watchdir'
option script_torrent_done_enabled true
option script_torrent_done_filename '/mnt/torrentrar.sh'
#config transmission
# option enable 0
# option config_dir /tmp/transmission
# option download_dir /tmp/transmission/done
# option speed_limit_up 20
# option speed_limit_up_enabled true
# option rpc_whitelist '127.0.0.1,192.168.1.*'
# option rpc_whitelist_enabled trueA "#"-ott rész ami a torrent limitekre vonatkozik... na azzal is akadozott a WIFI... mi lehet a gond?
Mr.Skynet
Intruder2k5 #9929 üzenetére
Nem tudom, csak most kezdtem el randizni a linux-al, szóval zero ismereteim vannak
hati: engem már csak az érdekel, hogy mikor jó, "eltalálom" és úgy is hagyom xDAlábbival nem ment a dolog, de ha átírom az sda1 -et sda -ra, akkor hibátlanul megy.
root@OpenWrt:~# ntfs-3g -o rw,noatime /dev/sda1 /mnt/hdd
ntfs-3g: Failed to access volume '/dev/sda1': No such file or directoryMost viszont talán valami jogosultsági gondom lehet a fájlal, mert az /etc/init.d/usbdrive a fenti módosítással hibátlanul fut, viszont az írás sambával továbbra sem megy és jön a lényeg: /etc/init.d/usbdrive stop
Majd kézzel beírom neki ugyan azt a parancsot ami a fájlban is van:
ntfs-3g -o rw,noatime /dev/sda /mnt/hdd és valamiért ezt követően tudok írni is 2,4Mb/sec ír és 4,5Mb/sec olv. bár engem ez egyáltalán nem zavar, ez még csak egy "teszt" pendrive, csak másom nincs teszt célra (esetleg még a telóm, de az meg fat32), most sajna nem megoldható, hogy pl. etx3 legyen rajta... -
Speeedfire
Intruder2k5 #9927 üzenetére
Kicsit több beállítási lehetőség kellene nekem.
vargalex: Valóban csak symlink, akkor nem értem minek. Elvégre, mindegy akkor már, hogy ntfs-3g vagy mount.ntfs-3g paranccsal hivatkozok rá.root@Server:~# cat /etc/config/transmission | grep enabled
option enabled 1
root@Server:~# /etc/init.d/transmission start
root@Server:~# ps aux | grep tranmission
8862 root 1288 S grep tranmissionBe volt állítva nekem, de nem akar menni. Vagy törött a csomag vagy valami más beállítási gondja van.
Igen gondoltam velük is megosztom a mentett snapshotot, hátha másnak is kellene.
Shodan
Intruder2k5 #9918 üzenetére
valóban, router databasenél ezt hozta le dd-wrt oldalán
most már van samba is.
A pendriveot is felmountolja /mnt-be viszont a samba nem működik.
(ennyit találtam: Samba is currently reading /jffs, so please select mount point for USB to /jffs (if you mounted your USB to /mnt, you simply do mount --bind /mnt /jffs ) )
mount --bind /mnt /jffs ezt beírtam de igy se megy.meg igazából azt se értem hogy FTP-nél mi a login
, anonymusként működik...
Keresztapper
Az nem rossz ötlet!
Shodan
Intruder2k5 #9913 üzenetére
sto1911
Intruder2k5 #9900 üzenetére
Ez a FW miert nem jon ki, ha a router db-n keresztul megyek?
Speeedfire
Intruder2k5 #9904 üzenetére
Shodan
köszi, közben kicsit visszaolvastam ez az optware kell a transmission telepítéséhez?
ErosenZold
Intruder2k5 #9897 üzenetére
Már megvolt, ezért furcsálom. Nem nagyon zavar, de azért mégis
ErosenZold
Intruder2k5 #9893 üzenetére
Logót, és jó hülyén mondtam, lapfül vagy mi
Shodan
szerintem a favourite ikon-ra gondol,
nimfas
Intruder2k5 #9886 üzenetére
Köszi... sikerült belőni, már megy a dyndns címről is a távelérés.... köszi mégegyszer!
Mr.Skynet
Intruder2k5 #9867 üzenetére
Így 1,5 óra alvás után ténlyeg logikusnak tűnik amit mondasz
Köszi, este meglesem!
nimfas
Intruder2k5 #9864 üzenetére
Koszi! Kiprobalom. :-)
pluhi
Intruder2k5 #9836 üzenetére
Na sikerült kitakaritani a dolgokat, nekifutottam megint a témának és siker. Nem volt gyenge procedúra, még IRCn is boldogítottam a fejlesztő srácokat
. Nagyon segitőkészek voltak amúgy. Lehet megirom tutorialnak azt feldobhatjátok ide, ha érdekel valakit az RSS. Momentán ott tartok, hogy nézi a szűrt bithu RSSt a cucc, ha van találat beeteti a transmissionnek és emailt küldene róla, ha nem lenne bugos az emailező része
. Nyitottam ticketet nekik róla, majd fixálják.
amargo
Intruder2k5 #9770 üzenetére
Többször is rosszúl parsol-ta a szemem a szöveget, mert nem vettem észre, hogy a minidlna, alapból is azt a 400k libffmpeg-et rakja fel, míg a hivatkozott az 1,5M!
Ha haza értem kipróbálom, de így már gondolom nem lesz akkora probléma. -
gabipaci
Intruder2k5 #9834 üzenetére
Ok, köszönöm.
Reménykedem benne, hogy nem lesz több ilyen.
Üdv és köszi -
pluhi
Intruder2k5 #9800 üzenetére
Tényleg barbár, de működik. Más kérdés, hogy feltettem a cuccot, de elinditani már nem birtam. Addig szarakodtam, mig a python telefosta a fájlrendszerem a cuccaival és előjött a másoknál is tapasztalt "not found" probléma. Az se indul el, ami az aktuális könyvtárban van (SSH alól). Újra kéne kezdeni az egész hóbelevancot, csak nemtom hogy kezdjek neki. Ráflashelem ugyanezt a firmware-t, az mindent töröl?
Feribacsi555
Intruder2k5 #9812 üzenetére
Bevannak állítva. Cikk alapján csináltam. Puttyval is szenvedtünk, sőt én azzal kezdtem, de nem műxik egyik sem. Hyperterminalon sem megy, ahogy wwenigma is írta. Max szétbontom az egész kábelt, az usbről a műanyagot is leszedem és ott kimérem hogy van-e vmi. De ez már csak végső elkeseredésemben lehetséges
wwenigma
Jómunkásember
Intruder2k5 #9815 üzenetére
thnxxx, hazaerek tesztelve lesz. meg megkeresem ki irt errol a problemarol.
wwenigma
Jómunkásember
Intruder2k5 #9813 üzenetére
sajat kabelemmel win7 virtual xp alatt gond nelkul ment a loopback hyperterminallal. puttyal is lett probalva a kolleganal, de magikus varazsereje nem mutatkozott meg.
driver nem lehet? most mobilrol vagyok es nem tudom megkeresni, de egy kollega visszaallitasnal arrol irt, hogy normalis drivert egy oraig keresett. az Rx-et tapizva zaj kellene hogy keletkezzen amit hulye karakterekke alakit a soros port.... na ez sincs.
minden jol lett beallitva, egyszeruen vagy a kabel xar, vagy szerintem a driver.
BO nem szamit, szeretek segiteni.
kangoo70
Intruder2k5 #9792 üzenetére
841ND van, de sajna az open letöltő oldala (számomra) nem egyértelmű, ezért (még) bele sem vágtam a dologba. Nem tudom, honnan tudnám összeszedni a részeket, amik a "gépemhez" jók. Azt még csak Speedfire oldaláról jól megértettem, hogyan rakjam fel, de hogy hol lelem a megfelelő szoftot, azt nem látom...
Csak azt, hogyha szart teszek fel, akkor BRICK v. kábelt kell forrasztgatni a gépbe stb
Na ezt kihagynám. Különben mit ér az 5év gari.
És az eredmény nem igazán biztos (ti: hogy a QSS gombot használni is tudom).
Nem tudtok valami másik fórumot, esetleg külföldit (német, angol), ahol ezzel foglalkoznak még? A Community-n nem túl aktívak... -
Speeedfire
Igen, csak neki elég friss van. Az rc van hozzá írvva...lehet, hogy a trunk jó lenne már hozzá.
kispal1980
Intruder2k5 #9782 üzenetére
mi az hogy opkg-t?
miaz hogy transmission?a ddwrt ugyanúgy megmarad? csak ezek még futnak alatta?
blscrn
Intruder2k5 #9776 üzenetére
Azzal, ha változtatom a csatornát, nőhet a wifi sebesség az n-es gépen?
blscrn
Intruder2k5 #9773 üzenetére
Köszi a gyors választ. A szomszédok wifi csatornáit hol tudom megnézni? (Win7)
kispal1980
Intruder2k5 #9758 üzenetére
kispal1980
Intruder2k5 #9755 üzenetére
megvan köszi
kispal1980
Intruder2k5 #9738 üzenetére
Csináltam, na most az van , hogy az otthoni hálózatról beírva működik a :
ftp://kispal1980.dyndns.org/ és TC is.De rácsatlakozok a szomszéd netjére, a laptopon. Azon nem jön be!!!
Mit kell még állítani? -
kispal1980
Intruder2k5 #9735 üzenetére
ok. megpróbálom az org-osat. a root miatt már elszórakoztam egy kis időt!!
kispal1980
Intruder2k5 #9726 üzenetére
ok, remélem valaki tud segíteni!!!
köszi mégegyszer
kispal1980
Intruder2k5 #9704 üzenetére
bba
Intruder2k5 #9705 üzenetére
megy ez, mint a karika csapás
köszi a segítséget! és neked is hati!lassan, de biztosan haladok, nem vagyok szakértő, de nem adom fel és tanulok és próbálgatok, most csinálom először ilyen mélységben a dolgot, ahhoz képest jó eredmény.
Csak tudnom kell, hogy mi mire való...na ezután jön márcsak a WOL, és ha megy, akkor ultraVNC-s elérés saját gépen, az már elvileg van a gépemen, anyám gépét is így szoktam buherálni, ha vmi nem megy neki.
aztán jön, - ha visszakapom tesómtól a külső HDD-s keretet, - a 1,5 terrás vinyó USB-n és a transmission beállítása. Igaz szinte tele van és NTFS partició van rajta, de az t már nem állítom át, még ha lassú is lesz így, de ne rontsa el a fájlrendszert rajta és vele a már letöltött adatokat.
bba
Intruder2k5 #9694 üzenetére
na átvariáltam a portokat, remote web egyelőre 80 (mert ezt engedi itt a tűzfal, ha bármi gebasz van még tudok innen állítani)
ssh 443-ra téve, WInSCP-vel be tudok rá ssh-val lépni.Ez akkor siker?
kispal1980
Intruder2k5 #9696 üzenetére
bba
Intruder2k5 #9685 üzenetére
sejtetem, hogy nem lehet azonos, de azért mgkérdeztem...
nem, sajnos nem érem el 8080-as porttal rendelkező linket, szerintem kb annyi megy innen amit korábban írtam: 80, 443 és slussz.
amúgy ki lehet deríteni vhogy, hogy milyen cél portokat lehet elérni? mert az itteni nyitottak meg vannak, de az gondolom nem feltételezi, hogy kifelé is ugyanazokat lehet...hogy érted "WebGUI-t helyi portszámon"? milyen helyi portszám, azt hol nézem meg?
bba
Intruder2k5 #9682 üzenetére
https webes felületét elérem a routernek (443-as port), akkor tegyem ere portra az ssh remote-ot is? ez nem fogja megzavarni, ha ugyanaz a port van mindkettőhöz (ssh management, web GUI managemet) rendelve?
vagy válaszak vmi más portot (pl 2000), amit egy bármilyen internet cím mögé írva portként nem utasít vissza a proxy, hogy tiltott: biztonnsági okokból, csak annyit ír a böngésző, hogy nem lehet kapcsolódni a kiszolgálóhoz?
kangoo70
Intruder2k5 #9652 üzenetére
Igen, az aláírásomban benne van, hogy én outsider vagyok...
kangoo70
Intruder2k5 #9639 üzenetére
- HIBÁTLAN iPhone 12 Pro Max 256GB Graphite -1 ÉV GARANCIA - Kártyafüggetlen, MS3035, 100% Akkumulátor
- Új és újszerű 13"-14" Gamer, ultrabook, üzleti készülékek nagyon kedvező alkalmi áron Garanciával!
- Gamer PC-Számítógép! Csere-Beszámítás! I7 6700 / Rog RX580 8GB / 32GB DDR4 / 500GB SSD
- Telefon felvásárlás!! iPhone 13 Mini/iPhone 13/iPhone 13 Pro/iPhone 13 Pro Max/
