- Windows 10 Mobile (Windows Phone) szakmai topik
- Örömkönnyek és üres kezek a TriFold startjánál
- Xiaomi 12X – kicsi a bors és hűvös
- Huawei Watch D2 - nyomás utána!
- Vivo X300 - kicsiben jobban megéri
MichaelSD
avahi- daemon megy
CUP log:
localhost - - [22/Mar/2017:09:07:44 +0100] "POST / HTTP/1.1" 200 417 Create-Printer-Subscriptions successful-ok
localhost - - [22/Mar/2017:10:06:04 +0100] "POST / HTTP/1.1" 200 186 Renew-Subscription successful-ok
localhost - - [22/Mar/2017:13:22:45 +0100] "POST / HTTP/1.1" 200 186 Renew-Subscription client-error-not-found
localhost - - [22/Mar/2017:13:22:45 +0100] "POST / HTTP/1.1" 200 216 Create-Printer-Subscriptions client-error-bad-requestvagy
D [13/Mar/2017:10:30:26 +0100] [Job 34] %Produced by poppler pdftops version: 0.52.0 (http://poppler.freedesktop.org)
D [13/Mar/2017:10:30:26 +0100] [Job 34] %%Creator: Calligra Words 3.0.0.1
D [13/Mar/2017:10:30:26 +0100] [Job 34] %%LanguageLevel: 2
D [13/Mar/2017:10:30:26 +0100] [Job 34] %%DocumentSuppliedResources: (atend)
D [13/Mar/2017:10:30:26 +0100] [Job 34] %%DocumentMedia: A4 595 842 0 () ()
D [13/Mar/2017:10:30:26 +0100] [Job 34] %%BoundingBox: 0 0 595 842
D [13/Mar/2017:10:30:26 +0100] [Job 34] %%Pages: 2
D [13/Mar/2017:10:30:26 +0100] [Job 34] %%EndComments
D [13/Mar/2017:10:30:26 +0100] [Job 34] Before copy_prolog - %%BeginProlog
D [13/Mar/2017:10:30:26 +0100] [Job 34] Before copy_setup - %%BeginSetup
D [13/Mar/2017:10:30:26 +0100] [Job 34] Before page loop - %%Page: 1 1
D [13/Mar/2017:10:30:26 +0100] [Job 34] Copying page 1...
D [13/Mar/2017:10:30:26 +0100] [Job 34] pagew = 571.0, pagel = 818.0
D [13/Mar/2017:10:30:26 +0100] [Job 34] bboxx = 0, bboxy = 0, bboxw = 595, bboxl = 842
D [13/Mar/2017:10:30:26 +0100] [Job 34] PageLeft = 12.0, PageRight = 583.0
D [13/Mar/2017:10:30:26 +0100] [Job 34] PageTop = 830.0, PageBottom = 12.0
D [13/Mar/2017:10:30:26 +0100] [Job 34] PageWidth = 595.0, PageLength = 842.0
D [13/Mar/2017:10:30:26 +0100] [Job 34] \033[31;01merror: Failed to create /var/spool/cups/tmp/.hplip\033[0m
D [13/Mar/2017:10:30:26 +0100] [Job 34] STATE: +connecting-to-device
D [13/Mar/2017:10:30:26 +0100] [Job 34] Traceback (most recent call last):
D [13/Mar/2017:10:30:26 +0100] [Job 34] File \"/usr/lib/cups/filter/hpps\", line 203, in <module>
D [13/Mar/2017:10:30:26 +0100] [Job 34] os.write(output_fd, to_bytes_utf8(\'@PJL SET JOBNAME=\"%s\"\\x0a\' % title))
D [13/Mar/2017:10:30:26 +0100] [Job 34] File \"/usr/share/hplip/base/sixext.py\", line 109, in to_bytes_utf8
D [13/Mar/2017:10:30:26 +0100] [Job 34] return s.encode(\"utf-8\")
D [13/Mar/2017:10:30:26 +0100] [Job 34] UnicodeEncodeError: \'utf-8\' codec can\'t encode character \'\\udcef\' in position 22: surrogates not allowed
D [13/Mar/2017:10:30:26 +0100] [Job 34] STATE: -connecting-to-device
D [13/Mar/2017:10:30:26 +0100] [Job 34] STATE: -media-empty-error,media-jam-error,hplip.plugin-error,cover-open-error,toner-empty-error,other
D [13/Mar/2017:10:30:26 +0100] [Job 34] PID 1634 (/usr/lib/cups/filter/hpps) stopped with status 1.
D [13/Mar/2017:10:30:26 +0100] [Job 34] Hint: Try setting the LogLevel to "debug" to find out more.Encoding (UTF-8) probléma lesz csak nem értem hogy miért.
foomatic- van. foomatic-db nincs
teleahocipöm
Na, már ki is próbáltam a "ffmpeg -i /home/vinetu/Videók/hfe.mp4 -vn -acodec copy /home/vinetu/Zenék/ez_legyen_a_hangfajl_neve.aac" parancsot és mint a villám már kész is volt, kipróbáltam, lejátsza. Nagyon szuper,
el kell ismernem ebben az esetben a terminál csodát tett, valahova el is mentem ezt a parancssort.Bevallom először az "acodec copy" után nem írtam elérési útvonalat, gondoltam oda másolja, ahol az eredeti van, de nem, kell a az elérési útvonal a kimenetre is, pedig úgy láttam másolt valahova, de még nem találtam meg.
Most már csak a nyomtatást kell megoldanom, hogy mindig van valami
teleahocipöm
Frawly és BoB
Most tettem mégegy próbát, de egy hirtelen ötlettől vezérelve az egész elérési útvonalat beírtam a fájlnév elé /home /.../.../.. és így már sokkal több adat jött ki.
Metadata:
major_brand : isom
minor_version : 0
compatible_brands: mp41avc1Duration: 01:41:10.98, start: 0.000000, bitrate: 260 kb/s
Stream #0:0(eng): Audio: aac (LC) (mp4a / 0x6134706D), 44100 Hz, stereo, fltp, 125 kb/s (default)
Metadata:
creation_time : 2017-03-05T14:16:51.000000Z
handler_name : SoundHandler
Stream #0:1(eng): Video: h264 (Main) (avc1 / 0x31637661), yuv420p, 720x720 [SAR 1:1 DAR 1:1], 125 kb/s, 29.96 fps, 29.97 tbr, 1000k tbn, 59.94 tbc (default)Úgy nézem a hangfájl aac formátumban lehet.
Ezen te kacajgassz?
Már ezer éve nem használtam sms-t, de pár hónapja muszáj volt vagy ezret írnom/fogadnom, ezeket jó, hogy lementem!
Nem vagyok ősember, de ez így alakult. Ismerem a 21. század lehetőségeit.
(még azt is tudom, hogyan tudok voipon kersztül sms-t küldeni, hogy ne írja ki a számomat) -
Lathronos
Ígéretesnek tűnik. Ha jól tudom, ez is Arch-ból származik. Külön dicséret illeti őket, hogy a saját tárolójukban megtalálható a 8192cu-dkms fix, ami nélkül a PC-m wi-fi stickje nem hajlandó működni. Valamint a csomagkínálata is látványosan bővül. Már szinte kísértésbe esek. De a jól megszokott Ubuntu-mat akkor sem cserélem le egyelőre.
Azért arra marhára kíváncsi lennék, hogy ezt a RAM terhelést hogyan sikerült elérni
Remélem nem ez az alapfogyasztása.
Tudtam, hogy ezt meg fogja valaki kérdezni.
Igazság szerint először úgy csináltam, de rájöttem, hogy sokkal kényelmesebb két kattintással rebootolni, mint a kijelentkezési procedúrát végigcsinálni jelszóbeírással. Időben nincs szignifikáns különbség SSD-nél, nem az idő kivárásától kaptam agyhugykövet, hanem attól, hogy nem állt vissza az a rohadt betűszin.
KDE nálam mindig produkál valami kiborítót. -
sanhose
Annyival még kiegészíteném, hogy amikor utoljára próbáltam, akkor még nem működött a "szoftverbolton" keresztüli bejelentkezés, ahogy látom még most sem működik, csak terminálon keresztül.
Az így telepített alkalmazások Dash-ből is indíthatóak.A Snap/Sanppy-ról (angol) itt, magyarul pedig itt olvashatunk bővebben, az elérhető alkalmazások listája, pedig uappexplorer.com-on érhető el.
A kérdése nem Arch specifikus
Bizonyos esetekben ez nem egyértelműen derül ki, de teljesen mindegy, ha valaminek van topikja, miért ne oda kerüljön a thread. Ennél alig látok egyszerűbb dolgot, de úgy látszik ebben nem értünk egyet.
Vagy úgy kéne elképzelni, hogy csak bizonyos problémaszinttől írjanak az Arch topikba? Hogyan dönti el egy kezdő, hogy ezt a kérdést már a szaktopikba kellene feltenni? Arra gondolok inkább, hogy ti ott az Archban nem szeretnétek kezdőkkel vacakolni, az maradjon a ti kis belső körötök!
Pedig az van, hogy ha valaki használ egy disztrót, annak van topikja, akkor oda kell feltennie a kérdését!
És ha már itt tartunk, miért jönnek ide ubuntus kérdésekkel, miért nem mennek az ubuntu topikba, ha már van???
Épp ez lett volna a kezdő topikok reformja, hogy a kezdő és az Ubuntu alapúak egy topikba kerüljenek. De ezt te is tudod, csak jól esett feltenni a kérdést.
_NCT
Daemon indul, az alkalmazás nem. Elvileg indulnia kellene magától, másik disztron így volt. Azt nem tudom hogy Daemon indítja e a progit is.
Nem gondoltam hogy ekkora tüzet fogok gerjeszteni... Azért írtam ide, mert úgy alle zusammen kezdőnek mondom magam, s lehet valami triviális dolgot nem állítottam be, ezért nem rohantam rögtön az arch topikba. (és itt jobban is pörög az élet)
#21078528
Már én is kifejtettem párszor, ettől a kezdőknek való disztró, nem kezdőknek való disztró marhaságtól lever a víz!
Hogy ki mekkora Linux Guru, az nem a használt disztribúció kérdése!
Aki eljut egy saját számítógép beszerzéséig, az nyilván tud olvasni, ha tudsz olvasni, akkor el tudod olvasni az Arch, a Gentoo, a Lunar vagy épp a Slackware telepítési útmutatóját is, és fel tudod rakni. Nyilván szöszölősebb mint egy Ubut felrakni, de azért nem kell egyetemi professzornak lenni hozzá... -
& (#50172) MMA87
Lathronos: Mert ez aztán haladó kérdés. Arch Linux jujj, meg kell ijedni
Szerintem nem a Haladó topikra gondolt Lathronos, hanem arra, hogy van Arch Linux topik. Azt akarták sokan, hogy legyenek külön disztró specifikus topikok! Nekem ez elég egyértelmű! Ha valaki olyan disztrót használ, aminek van saját topikja, tegye fel ott a kérdést! Azért ennek aztán tényleg megvan a logikája!
Az is nagyszerű, ha itt teszik fel a kérdést és átjön az Arch topik Tg-je és itt megválaszolja, csak....
De az is lehet, hogy nekünk volt igazunk, akik azt mondtuk, hogy minek ennyi rengeteg topik, bőven elegendő lenne egy kezdő meg egy haladó!? és az off persze
Balion
Köszi, ott kell lennie, mert a Steam is írja, miután elindítom, hogy az az alapértelmezett telepítési hely, de .... nem találom, mert nem hoztam külön létre home-ot, hanem a roottal egyben van, és egyszerűen nincs meg a .local mappa. Hol kell ilyenkor keresni, ha nincs külön home?
Balion
Köszi, Antergosban már a telepítőben ki lehetett választani a legfrissebb zártat, tök jó.
Szeretném feltelepíteni az usb wifimhez a megfelelő drivert, amihez kellene egy bizonyos header. (4.7.6.1?)Legalábbis a telepítéskor azt írja ki, hogy a DKMS-nek kell. Honnan tudom megszerezni ezt, mert AUR-ban nincs ilyen.
Ja, amúgy nemrég panaszkodtam, hogy antergos hibát dob ki induláskor, mert nem találja a swapot.
Most újra telepítettem, de saját kezűleg partícionáltam, és kutya baja. Jó élmény, hogy saját kezemmel oldottam meg
V.Stryker
Megnézem, köszi.
Amúgy nem feltétlen a kis gépigény a lényeg. Van egy örökölt netbookom, amiben egy kétmagos Atom N570, 2GB ram, 320hdd van. Semmi extra. Ez a gép semmire nincs használva, kizárólag netre. Azon belül chrome, a szükséges kiegészítők miatt.
Nem kell nekem se szövegszerkesztő, se médialejátszó, semmi. Igazából azt se bánnám, ha egyből a chrome ba bootolna be és ha a sarokban ki Xelem, akkor meg leállna.
A lényeg, hogy gyorsan induljon, gyorsan álljon le és ne laggoljon.
Lathronos
Tény, hogy még egy 800 MHz-es P3-ason is elfut 256 MB RAM-mal, és még YouTube is megy vele akadás nélkül 360p-ben ezt saját tapasztalat által merem kijelenteni, viszont az alap design icewm esetében nagyon csúnya. Nekem a Windows 3.11 jut róla eszembe.
És melyik az icewm és melyik a fluxbox változat? Mert én csak felszereltség szerint csoportosított ISO-kat látok a 16-osból: Full, core-libre, base.
Melack
és lev258: Erre gondolsz?
Melack
aug 13 21:06:03 melack-HP-G62-Notebook-PC AptDaemon[10360]: INFO: Quitting was requested
aug 13 21:06:03 melack-HP-G62-Notebook-PC org.freedesktop.PackageKit[2182]: 21:06:03 AptDaemon [INFO]: Quitting was requested
aug 13 21:06:03 melack-HP-G62-Notebook-PC org.freedesktop.PackageKit[2182]: 21:06:03 AptDaemon [INFO]: Quitting due to inactivity
aug 13 21:06:03 melack-HP-G62-Notebook-PC AptDaemon[10360]: INFO: Quitting due to inactivityEz lenne a bibi?
Lathronos
Na most elindítottad a lavinát. Nemsoká jönnek megint a "Ne keverjünk gtk-ba qt-t, mert az istenkáromlás! Máglyára az eretnekkel!" hozzászólások.
Lesz itt olyan boszorkányper mint az ubuntu.hu-n szokott. -
lev258
Persze, hogy vannak. Nincs egy éve, hogy beindult a dolog, míg Windows-ra már hosszú ideje elérhető. Emellett azért sincs a hivatalos oldalon, mert nem vállalnak érte teljes értékű support-ot jelenleg. Ettől még a fejlesztők, akik csinálják, mindent próbálnak javítani, fejleszteni. Újabban pl. SDL2-t is használnak, aminek elég sok előnye van.
Ha megnézed, az Unreal Editor Linux verziója sem hivatalos, pedig ezt már jó ideje késznek tekintik a fejlesztők. -
King Unique
Normál módban indítom, gondolom az a systemd. De már tárgytalan, megoldódott.
(#46681) lev258: az átnevezéssel megjavult. Utána valóban visszaállt alapállapotba, de szerencsére nem kellett sok mindent beállítgatni. Azért egyszerűbb, mint az újratelepítés. Ha legközelebb ilyen gondom lesz, már tudom merre kell elindulni.
Köszönöm!
Köszönöm a többi fórumtárs segítségét is!
King Unique
Először csak ennyit adott ki, de még egyszer megnéztem és itt az új, amit felraktam pastebin oldalára.
(#46675) lev258: nem tudom micsoda, mert semmi különöset nem babráltam. Csak frissítve volt, illetve pár program lett feltéve szoftverközpontból. Amúgy a béta 2-ről lett upgrade-elve a rendszer, de eddig emiatt nem volt semmi gond. Nem tudom miket kéne pontosan átnevezni, de nem is igazán van kedvem ezzel szórakozni.
King Unique
~$ journalctl -r
-- Logs begin at h 2016-05-30 20:06:42 CEST, end at h 2016-05-30 20:07:07 CEST.
máj 30 20:07:07 ku-lenovo org.gnome.zeitgeist.Engine[1057]: ** (zeitgeist-datahu
máj 30 20:06:55 ku-lenovo NetworkManager[856]: <info> [1464631615.6631] WWAN ha
máj 30 20:06:55 ku-lenovo NetworkManager[856]: <info> [1464631615.6630] WiFi ha
máj 30 20:06:54 ku-lenovo org.gnome.Terminal[1057]: (gnome-terminal-migration:18
máj 30 20:06:51 ku-lenovo NetworkManager[856]: <info> [1464631611.4193] manager
máj 30 20:06:50 ku-lenovo dbus[646]: [system] Successfully activated service 'or
máj 30 20:06:49 ku-lenovo org.freedesktop.fwupd[646]: (fwupd:1663): Fu-WARNING *
máj 30 20:06:49 ku-lenovo org.gnome.ScreenSaver[1057]: ** Message: Lost the name
máj 30 20:06:49 ku-lenovo gnome-session[1384]: ** (unity-fallback-mount-helper:1
máj 30 20:06:48 ku-lenovo udisksd[1628]: Mounted /dev/sda6 at /media/kingunique/
máj 30 20:06:48 ku-lenovo udisksd[1628]: Mounted /dev/sda5 at /media/kingunique/
máj 30 20:06:48 ku-lenovo udisksd[1628]: Mounted /dev/sda7 at /media/kingunique/
máj 30 20:06:48 ku-lenovo kernel: EXT4-fs (sda5): mounted filesystem with ordere
máj 30 20:06:48 ku-lenovo udisksd[1628]: Mounted /dev/sda3 at /media/kingunique/
máj 30 20:06:48 ku-lenovo kernel: EXT4-fs (sda3): mounted filesystem with ordere
máj 30 20:06:48 ku-lenovo kernel: EXT4-fs (sda7): mounted filesystem with ordere
máj 30 20:06:48 ku-lenovo kernel: EXT4-fs (sda6): mounted filesystem with ordere
máj 30 20:06:48 ku-lenovo udisksd[1628]: Mounted /dev/sda8 at /media/kingunique/
máj 30 20:06:48 ku-lenovo udisksd[1628]: Mounted /dev/sda9 at /media/kingunique/
máj 30 20:06:48 ku-lenovo kernel: EXT4-fs (sda8): mounted filesystem with ordere
máj 30 20:06:48 ku-lenovo kernel: EXT4-fs (sda9): mounted filesystem with ordere(#46671) lev258: vendég fiókkal már ok, behozza rendesen az asztalt.
Geripapa
Még egy kérdés, mert úgy néz ki ezzel sikerült megölni a pendrivémet
.Szóval hogy lehet visszahozni az életbe, mert jelenleg az van ha rádugom a linuxos gépre akkor felcsatolja, ha rákattintok akkor a 4 gigás mellé felcsatol még egy 7xx megásat, ha megint rákattintok megint felcsatol egyet... stb...
a gparted nem tudja helyrehozni.
CPT.Pirk
Jómunkásember
Még én is tudom, hogyha így csinálod akkor megszivatod magad, kell oda még a bs=... is.
Normi01: próba erejére megnéznéd egy másik klienssel is? Csak hogy ki tudjunk valamerre indulni.
Geripapa: terminálban lehet vele másolni, igazából a tolólapos rakodó lenne rá a jó szinonima, mert gyalul mindent az útjában.
King Unique
Azt nem tudom, hogy friss telepítéskor is, vagy csak később automatikusan pakolta fel a rendszer frissítésekor, de nálam benne van, ahogy az összes Mint, Antergos, Ubuntu MATE stb. disztró esetén is.
Viszont én néztem be az eltávolítást, mert a fenti parancsra már működik és most csak a 21-es van fent. Bár, mintha utóbbi telepítése előtt nem ment volna, de most már mindegy.Ismételtem köszönöm a segítséget!
King Unique
Igen, Ubuntu 16.04 alatt már valóban működik és a verziószám (21.0.0.216) is tetszetősebb. Viszont a 11.2-est nem tudtam sehogyan eltávolítani, csak letiltani lehet a böngészőben. Most mind a 2 plugin fent van Firefoxban és külön-külön nem lehet letiltani / engedélyezni őket.
Ilyenkor kizárólag az újabbat használja alapból, netán a régit el lehet véglegesen távolítani? -
King Unique
Jól emlékeztem, hogy nem mindenhol működik, pl. Mint MATE 17.3 alatt:
sudo apt install browser-plugin-freshplayer-pepperflash pepperflashplugin-nonfree
Csomaglisták olvasása... Kész
Függőségi fa építése
Állapotinformációk olvasása... Kész
E: Ez a csomag nem található: browser-plugin-freshplayer-pepperflashPróbáltam apt-get install beírva, azzal se ment. Na mindegy, mára egyelőre elég volt ennyi.
Köszönöm az eddigieket!
King Unique
Akkor ok, majd rápróbálok először Mint alatt. A verziószám onnan jön, hogy az általam fentebb linkelt megoldásnál ezt teszi fel, azt írja ki a böngésző is.
Amúgy kipróbáltam a korábban javasolt beállítást Antergos alatt, de nem segített. Ugyanúgy elállítódik az óra. Akkor vsz marad a másik megoldás [link], de azt még emésztenem kell.
King Unique
Hát, ha már 1-2 fokkal jobb megoldás, mint a 11.2 flash, akkor nekem egyelőre az is elég. Köszönöm az időbeállítást, majd kipróbálom. Amúgy most minden Linux jól mutatja, csak az Antergos nem, tehát alapból is ráfér egy kis piszkálás.
(#46128) spammer: egy kicsit bonyolultabb nekem, de ha a másik nem megy, akkor kipróbálom ezt is.
Köszönöm! -
lev258
Előfordul, hogy egy-egy nagyobb oldalt feltörnek és ott helyeznek el kártevőket. Azt viszont te is tudod, hogy nem ez a leggyakoribb ok. A fertőzött e-mailek, üzenetek, vagy feltört noname oldalak viszik a prímet, a szándékosan kreált oldalak mellett.
Nemcsak a Yahoo, neves internetes újságok is jártak már így. De ezek egyáltalán nem mindennapi esetek és nem a fertőzések döntő többségéért felelősek. -
Hol vagyok én a változtatástól... egyenlőre a létrehozással küszködök. Az a 2 Gb amúgy sem hiszem, hogy mostanában hiányozni fog.
Viszont megakadtam. Live módból indítottam a telepítést aztán a particiós résznél (a valami más-t választottam) nem tudok tovább menni.
Adott ugye a jelenlegi helyzet:
/dev/sda
/dev/sda1 ntfs
/dev/sda2 ntfs
/dev/sda3 ntfsEbből a dev/sda3 aminek meg kéne maradnia az előtte lévőkből pedig lenne a Linux partíció. De törölni vagy efféle nem enged. Hacsak nem a jobb oldalon az új particiós tábla gomb alatt de arra nem mertem rámenni...
lev258: nem fogok hibernálni és nem gyilkolom a rendszerem. 2 Gb-ra gondoltam.
Vladi
"Mentségemre szóljon hogy munka közben írtam"
Énis.
Hát már ha fizikailag szét tudja szedni. De még az is lehet, hogy rá van varrva a háttértár. Vannak ilyen komplett gépek, gyárban rátölti a szoftvert és mehet. Ki/bemenet nuku.
(#45890) Flowtation:
Próbának, tanulásnak jó. Hosszú távon vagy vegyél célgépet - mondjuk msot is van 2 nasod
- vagy építs egyet. NÉzd meg a proc fogyasztását, a legkisebb fogyasztásút válaszd, pl: amd le sorozat. Azok nagyon keveset fogyasztanak idle - úgyis abban az állapotban lesz 99%-ban - plusz párszáz forintért jutsz hozzá.(#45896) DrojDtroll:
Nem biztos, hogy jó ötlet.
gari vesztés vagy valami? De mostmár nagyon kíváncsi vagyok, muti meg, hogy milyen robot az.
IstvánLászló
Kedves bob.zxr
Értem a string tömörítő témát, de hogyan mondjam, hűha és most??
Régebben 8-Bites kis személyi számítógépen dolgoztam 80Kb-on, igen nem vicc........
Azt hallottam: String szóról hogy, hibát vagy bármit is jelenthet, mert mondatban foglalva más értelmezései is bőven akadnak: számukat pontosan nem tudom de legalább 50-féle létezik: Angol műszaki és más kifejezések igen változóak lehetnek.A Wikiben bőven írnak is róla és itt a linkje: https://hu.wikipedia.org/wiki/String
Beidézem szavaidat, "Szerintem le kellene cserélned a string tömörítő algoritmust", mit tegyek hogy hiba nélkül is működjön?
Ha lehet step by step módon, mondjad hogy jól működjön, előre is köszönöm ha idő is engedi.
(#45841) Slapy kollégám, szlogenem: A türelem rózsát terem...
A LInux fórumokon ez természetes viselkedési forma...
Tiszteletem, ezért mindenkinek kijár... -
lev258
Az a kommentem GrotESC-nek szólt. Neki R9 270X van.
Hivatalosan a GCN1.2-nek van amdgpu drivere. Van már GCN1.1 támogatás is benne, de még kísérleti, külön kell engedélyezni. Állítólag valamikor lesz GCN1.0 is, de az még odébb van. Utóbbiak addig is a radeon-t használják.
Pano: Csak így tovább AMD!
Milyen program ami... [link]
- Teszt [Linux] A Flatpak
- Tudományos Pandémia Klub
- TP-LINK routerek
- TCL LCD és LED TV-k
- CADA, Polymobil, és más építőkockák
- Vírusirtó, Antivirus, VPN kulcsok GARANCIÁVAL!
- Keresem a Barkács Balázs Játékokat
- Game Pass Ultimate előfizetések 1 - 36 hónapig azonnali kézbesítéssel a LEGOLCSÓBBAN! AKCIÓ!
- GYÖNYÖRŰ iPhone 12 Mini 128GB Black-1 ÉV GARANCIA -Kártyafüggetlen, MS4203, 94% Akksi
- Samsung Galaxy S21 Ultra 5G 12/128GB Fekete / 12 hó jótállás
- iPhone 13 mini 128GB Green -1 ÉV GARANCIA - Kártyafüggetlen, MS4052, 94% Akkumulátor
- ÁRGARANCIA!Épített KomPhone i7 14700KF 32/64GB RAM RTX 5070 12GB GAMER PC termékbeszámítással
Cég: BroadBit Hungary Kft.
Város: Budakeszi
A 16.04-et meg nem szeretem.
CPT.Pirk
