- Határtalan erő - szabadjára engedve
- Az eddigi legjobb S26 Ultra renderkép
- Tényleg nem biztos, hogy lesz Galaxy S26 Edge
- Hamarosan robottelefon figyelheti minden mozdulatod
- Apple iPhone 17 - alap
rii
ok, igyekszek, koszonom .-)
az apt-get update lement gond nelkul .... dolgozott vele egy ideig ...
de az apt get upgrade meg pont azt a ket library hianyolja,a -t es a libasound2-plugins-t$ sudo apt-get upgrade
Reading package lists... Done
Building dependency tree
Reading state information... Done
You might want to run 'apt-get -f install' to correct these.
The following packages have unmet dependencies:
skype : Depends: libqt4-dbus (>= 4:4.5.3) but it is not installed
Depends: libasound2-plugins but it is not installed
E: Unmet dependencies. Try using -f.
$esetleg amit ir, az `apt-get -f install' segitene?
rii
esetleg innen le lehet szedni azt a ket library-t?
rii
` .... Package libqt4-dbus is not available, .....`
# apt-get install libqt4-dbus libasound2-plugins
[B]Package libqt4-dbus is not available,[/B] but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
However the following packages replace it:
[B]libqtdbus4 qdbus[/B]
Package libasound2-plugins is not available, but is referred to by another package.
E: Package 'libqt4-dbus' has no installation candidate
E: Package 'libasound2-plugins' has no installation candidate
#akkor most a libqtdbus4 qdbus -al kellene probalkozni?
(#37347) kovaax:
beirtam, de a dpkg sajnos ugyanugy leall hibaval
rii
a wget lement siman
de a gpkg ezt mondja:# dpkg -i skype-install.deb
Selecting previously unselected package skype.
(Reading database ... 109649 files and directories currently installed.)
Preparing to unpack skype-install.deb ...
Unpacking skype (4.3.0.37-1) ...
dpkg: dependency problems prevent configuration of skype:
skype depends on libqt4-dbus (>= 4:4.5.3); however:
Package libqt4-dbus is not installed.
skype depends on libasound2-plugins; however:
Package libasound2-plugins is not installed.
dpkg: error processing package skype (--install):
dependency problems - leaving unconfigured
Processing triggers for dbus (1.8.16-1.0nosystemd1) ...
Processing triggers for desktop-file-utils (0.22-1) ...
Processing triggers for mime-support (3.58) ...
Processing triggers for hicolor-icon-theme (0.13-1) ...
Errors were encountered while processing:
skype
agy73p
Lehet, hogy csak beállítások adják a különbséget, mondtam, nem értek hozzá, és így azt használom, amelyiket ezért vagy azért jobbnak gondolok. Nagyon élvezem, hogy egyszer ez a disztró, egyszer az a disztro fut....mindenesetre mostanában megint gyakrabban indítom az OpenSuse-t, mint a másikat.
Debiant szerettem volna mindig is kipróbálni, de pár hónapja még nem tudtam feltelepíteni. -
King Unique
Kubuntu 14.04.1 LTS verziót próbáltam.
Először azt hittem, hogy asztali környezet függő a dolog, de miután a fentieket tapasztaltam, elkezdtem másra gyanakodni. Tehát van ilyesmi hozománya a régebbi / újabb csomagoknak. A kérdés másik fele arra vonatkozott, hogy ezeket az új drivereket bele lehet könnyedén pakolni telepítés után manuálisan, vagy inkább hagyjam és várjam meg az újabb verziót, netán alapból frissebb disztrót használjak? -
jimmy399
Igaz, tényleg openbox-ot kicsit konfigolni kell, mire minden patent lesz, meg opcionálisan fel kell tenni a tint2-őt is ha akar az ember tálcát, de azért néha kell használni terminált
Hallod, leizzadtam, mire a tv-tunert sikerült a tvtime-val müködésre bírni arch alatt... SAA7135-ös, és mire rájöttem, hogy sox-al át kell játszani a tunerkártya hangját a hangkártyára hajam kihullott, pedig pl. ubuntu alatt pöccre ment a tvtime.
Látom neked is fent van a doublecmd, én a thunar helyett tettem fel, és fényévekkel körözi a tunart...
Igaz, mire belaktam az arch-ot nekem olyan 180 MB-ot használ boot után.... Ha meg elindítom a chromiumot, akkor a határ a csillagos ég
Csak azt látom, hogy a conky írja hogy 200-300-500- ... csillagos ég MB ramhasználat...
Pontosan az általában azonos élményt nyújtó disztribúciók miatt utaltam arra, hogy a programok terén érdemesebb válogatni.
De való igaz, ha az ajánlottnál rosszabb konfiggal rendelkezel, akkor kín, de ez épp úgy igaz a programokra.
A fentiek miatt (is) használok még Ubuntu-t, pedig az évek alatt lett némi fogalmam a linux világról. Mégsem érzem a késztetést, hogy ugyanezt a programokat pl. Debian alatt használnám, akkor attól bármi változna.
olivera88
Vladi
Nekem t60-as laposon van, igaz abban intel a gpu. Nagyon jól megy. Viszont fedora alapú 32 bites rendszered nem lesz ezen kívül belátható időn belül.
Persze az xfce régi benne. Viszont megnéztem az xorg ati driver 2014 májusi benne. Annak jól kéne kezelni a 9600-at. De még a 4-5xxx-es sorozatot is!
A retro gépemben pl. 9200-as ati van, centos 5.11 is lekezeli jól.
Azt hogy érted, hogy lassan kezelte? Ezen a gépen nekem még gnome 2 van. Alig tapasztaltam sebességkülönbséget xfce-vel szemben! -
agy73p
agy73p
erhas01
Köszöntem!
Egy napba került, mire sikerült rávenni p4-t a dvd írásra. Xfburn.
Teleírtam a lemezeket, most rá kell jönnöm, hogyan töröljem.
Üresnek látja a lemezt, amit előzőleg írtam, nem tudja törölni,
nem is lát lemezt, de bootolni tudnék róla, ott az adat.
Erőltetett kilépés... ez lesz a Mate halála...
Kiveszem a lemezt, ha automatikusan indul, ha letiltom,lefagy
a következő lemez behelyezésekor. Xfce írás indul...Az összefoglalókban, telepítő leírásokban látom az md5sum-ot.
Sehol nem írják le:
A winről áthozott üres pendrive, sdhc kártyát formázzam meg, mert
nem fog megjelenni a fájlkezelőben.Tudom ez alap, de az olvasót sem
jelezte. Ebből nem esett le, hogy a kártya nincs formázva és nem a driver
hiányzik. A telepítőkbe bele kellene írni, vagy jelezni az összefoglalóba.
Ez másfél napba volt.qt, gtk ... Libreoffice, VLC, dvd író, Firefox, kétablakos fájlkezelő.
A midnigh commander -nél picivel nézhetőbbet.
Synaptic, úgy tíz éve láttam.Xfce írás kész, nézem.
CPT.Pirk
Jómunkásember
Igen, pont szombaton gondolkodtam, hogy Mate vagy Cinnamon legyen az új Debianon egy P4 celeron 2.4GHz 512MB ramos gépen, de aztán szerencsére nem ezek mellett döntöttem. XFCE és LXDE felületet néztem meg rajta, mindkettővel olyan a gép, mintha szaladna. A teljes Debianos memória használat Lxde-vel 110MB volt mindössze.
Jah és ne csukoljál!
teleahocipöm
Most már nem emlékszem, de ha felajánlotta a billentyűzet beállítást, akkor biztos magyarra állítottam.
/etc/default/keyboard : itt nekem csak az "us" szerepelt, állítólag be kell írni a "hu" -t és magyar lesz a billentyűzet, de ez nekem nem jött be.De most már mindegy, ideiglenesen felraktam a Pepper 5 -öt és várok, hátha lesz hivatalos magyarosítás az Antix 15-re, az legalább felismerte az Pendrájvot és a DVD-t.
teleahocipöm
Mát a Live indításkor kiválasztottam a rendszer nagy része magyar is a telepítés is magyar nyelven ment. Most azon filózok, hogy érdemes-e vele kinlódnom, beraktam ugyan a Pepper 5 -öt, hogy felültelepítem az AntiX-et, de már azzal is megjártam. Egyszerűen túl koros a gépem, hogy egy jó linuxot futtassak.
Freel
Itt voltam a monitor kérdéssel. Azóta változott picit a helyzet, de alapvetően az LXDE irány feltétlenül marad. Köszönöm a linkeket, eltettem őket.
Még egy kérdésem lenne! 120-as SSD-re tenném akkor most úgy néz ki a Debiant. Száz meg száz topikot is elolvasva még mindig nem tiszta, hogy milyenek legyenek a partíciók méretei! Először is miért van az, hogy a Distrowatch oldalán 10 DVD-sre írják a Debian méretét? Én 40 gigát gondoltam / -nek (sok annyi? felesleges), 17 gigát swapnak (valahol azt írják nem kell 8 giga fölött, valahol meg azt írják kétszer annyi kell, hozzáteszem játszanék nagy játékokkal, valahol meg azt írják nemszabad SSD-re rakni), és a maradékot /home -nak (erre meg azt írják, hogy maradjon SSD-n partícionálatlan terület! Most maradjon partícionálatlan, vagy csak elég ha marad sok üres hely? -
Vladi
Az ilyen gépek általában egyébként is speciálisabb felhasználásra mennek. Ha már átlagos felhasználásra kell, akkor elég nagy a baj.
Mondjuk én biztos vagyok benne, hogy Magyarországon nagyon sokan nyomulnak 5+ de inkább 10+ éves géppel. Mert nem futja jobbra.
Ami inkább a gondom, hogy mit tekintsünk átlagos felhasználásnak. Konkrétan mit csinál vele egy felhasználó. Jó oké netezik, de azon belül?
De ez már nagyon off téma itt, inkább blogout topikot csinálok majd neki.
Vladi
Írom, írom. részleteket nem közlök.
Sajnos nagyon kevés időm van, talán nyárra lesz valami. Ha lesz, akkor bőséges lesz. Persze ilyen kérdésekre is kitérek benne.
Viszont a te számaiddal nem értek egyet! Ami tapasztalatom eddig van, az azt mutatja, hogy bizonyos szűk feladatkörre nagyon kevés erőforrás kell. A gép amit összeraktam 256 mega rammal ment. Nem gyorsan, de vitte a filemeket, zenét, ami kellett. Minimális netezés is belefért. mindezt gnome 2-vel. Jó hozzá tartozik az igazsághoz, hogy ezt monotask tudta.
Tehát egyszerre csak egyet. 768 mega ramig megtömtem, így más többet tud együtt.
Maga a hardver nem olyan rossz. Szovtveres oldal is egész jó lenne. Ami gond, az a web minősége... egyáltalán nem adnak az igényességre, nagyobb csilli-villi oldalak teljesen feleslegesen emésztik az erőforrásokat. gyakorlatilag a semmire.
Video kártya sem kell ennyi. Talán majd megbuggyantom egy kde4-5-el, meg gnome 3-al. De itt is a csillivillizés viszi el a gépet. Nem kell. Sima lxde, mate, xfce, fluxbox. Régi gépnél örülsz, ha megnézed rajta a szulejmánt, meg a hvg.hu-t.
Köszi a válaszokat!
Szerverből ubuntu (samba, core2 2gb ram) és debian (samba+ftp dual p3) van vegyesen, illetve egy ősi slackware (sokféle inventory és feltérképező őskövület netbrust xeonon 2gb rammal). Meg korábban volt egy IBM szintén régi szerver ubuntuval. Úgy vagyok vele hogy mindegyik kiszolgálja a célját, igazából nekem mindegy.
Ublockot kirpróbáltam, tényleg jobb mint az adblock!
Xubuntu lesz az alapból xfce.
Azt a beállítást meg megnézem. Viszont úgy tudom hogy már html5-el megy a youtube. Elég az ha 480p-be viszi.Majd írok eredményeket mennyire használható.
max4o4
Sima első generációs Dx9-es kártya. A maga korában egész jó volt. És tényleg csak mpeg2-t tud.
A youtube-hoz meg kellene h264, az meg ati x1xxx vagy gef 6600 tól van. -
Vladi
BoB
Köszi, ezt úgy összefoglaltad, hogy minden benne van és még értem is elsőre!
Kipróbáltam egyébként mindent, compizt is, mintha azzal futtatva nem lett volna ez, de csak amiatt nyúztam, hogy a kérdésekre válaszoljak.
Nem játszom egyik disztrón sem, bár a múltkor Cinnamonon kipróbáltam valami City Live v. hasonló játékot Linuxra volt megcsinálva, de az indításkor létrehozandó terület kialakítása egyszerűen megette a 8 GB memóriát, csináltam 8 GB swapot is, de úgy is szaggatott.
Lehet, hogy nyílttal próbáltam, ki tudja
Sonja
Igen, így van beállítva.
Tűzfalat még nem aktiváltam, szóval azzal nem lehet probléma. Az irpstacksize értékét nem Windows alatt gondoltad beállítani? Mert az nekem nincs.
Csak egy Linuxos gépem + Dune HD Media Player.
(#35767) lev258: Persze, az volt az első, hogy a 2 NTFS HDD-met beállítottam az fstab-ban.
Aktívan használom azokat is, így fontos is volt.
Sonja
Feltettem azt is tegnap, de azzal se bírtam beállítani úgy, ahogy szerettem volna.
Leírom a pontos szituációt, talán lesz valakinek ötlete, hogy mit rontok el.
Adott egy Dune HD média lejátszó, amiben be lehet állítani Samba és NFS megosztásokat is. Eddig Win 8.1-et használtam, ahol a Samba megosztást úgy állítottam be, hogy ne legyen jelszókérés, és a Sorozatok mappát osztottam meg. Ennyi elég is volt, ezután a Dune HD-ban úgy kellett beállítani, hogy lássa a Sorozatok mappát, hogy megadtam egy nevet (Sorozatok), majd a gépem IP címét, végül magát a megosztott mappa nevét (Sorozatok). Utána már látta is a sorozataimat. Nos, itt Linux alatt ezt sehogy se sikerült elérni, ezért állítottam be NFS-t, azt rögtön látta is.
Samba megosztásnál a GUI programban annyit csináltam, hogy megadtam a Sorozatok mappát (Ez egyébként NTFS partíción van!), csak olvasható, majd a hozzáférés fülön kiválasztottam a Hozzáférés mindenkinek opciót. Sajnos semmi.
Amikor még az alap Ubuntut használtam Unity-vel, akkor ott a filekezelőben (Nautils, ha jól emlékszem) a mappán állva jobb gomb -> megosztást választva tökéletesen látta a Dune HD.
CPT.Pirk
Jómunkásember
Természetesen volt újraindítás, de azonos értékeket produkált. Ha mind a 9 lap be van töltve, akkor 100MB-on belül mozog az eltérés a két mód között. Drasztikusan akkor nő meg a ram használat, ha menet közben engedélyezem az ABP-t és minden oldalt újratöltök. Viszont ha bezárom és újra elindítom a böngészőt, akkor meg beáll a normális 440-520 közé. Érdekes.
Viszont az biztos, hogy ABP nélkül lassabban töltődnek be az oldalak.Na mindegy, ez már off.
CPT.Pirk
Jómunkásember
A dupláját biztos nem. Kipróbáltam az itthoni gépemen most, 9 tab van nyitva. Indulás után 283MB ramot fogyasztott a böngésző. Aztán letiltottam az adblockot minden lapon, ettől 20MB-al lett csak kevesebb a ram használat indulás után.
Ráadásul pont hogy csökkenti a proci terhelés csökkentését a reklámok meg egyebek nem kirajzolásával.
teleahocipöm
Bocs, hogy ilyen értetlen vagyok, de indulásnál melyiket válasszam?
1. Test/Primenet
2. Test/Worker threads
3. Test/Status
4. Test/Continue
5. Test/Exit
6. Advanced/Test
7. Advanced/Time
8. Advanced/P-1
9. Advanced/ECM
10. Advanced/Manual Communication
11. Advanced/Unreserve Exponent
12. Advanced/Quit Gimps
13. Options/CPU
14. Options/Preferences
15. Options/Torture Test
16. Options/Benchmark
17. Help/About
18. Help/About PrimeNet Server -
teleahocipöm
Egy hete cserétem hűtőt és akkor bepasztáztam, de most visszaesett 70-re, igen ez PB EasyNote.Két Magonként egy terminálablak?
Próbaképp egy ablakba infítottam, 1-18-ig lehet választani az 1. Test/Primenet választottam és valami ID számot kér, meg komputer nevet"Use PrimeNet to get work and report results (Y): Y
You must first create your user ID at mersenne.org or leave user ID blank
to run anonymously. See the readme.txt file for details.
Optional user ID: xxxxx
Optional computer name: yyyyyy
Computer uses a dial-up connection to the Internet (N): N
Optional proxy host name: ?Accept the answers above? (Y): Y"
és itt újból kiírta a listát 1-18-ig
Nem olyan egyszerű, mint gondoltam
teleahocipöm
Ha 2-3 óra alatt már látni lehet van-e gond akkor egyszerűbb a helyzet. A Manjaro LO menürendszere angol, nyelvi beállításoknál egyedül az User interface az angol nyelvű a többi magyarra:
A másik gépen az Antix15 , -na ez nem teljesen magyar a telepítés óta- van próbaképp, vagyis addig, amíg működik, mert a halálán van, de ha ne lesz más az AntiX 13 is sóba jöhet a notin, régebbit ne akarok, mert nem tudom hogy áll a frissítésekkel.
A Pepper 3-at próbáltam, de nincs frissítés hozzá így nem hiszem, hogy túl biztonságos lenne, szerintem a frissítésekke lehet most is a baj a Pepper 5-ön. A notira régebben Lubuntu 12.04-ö telepítetem én is, de a frissítéskkel 14.xx lett belőle -lehet tíltani kellett volna- és egyre lassult, majd is fagyogatni kezdet.manjaro-xfce-0.9.0-pre4-i686.iso fut, Live-ben, így egész gyorsnak tűnik., 2 GB van a gépben 600KB körül fogyaszt belőle, most 10-22% köröl van a CPU terhelés.
Tegnap próbáltam ismét a Fedora LiveCD-n, tetszik, de a csomagkezelő nehézkesnek tűnik, nem találtam amiket kerstem, így nem jöhet szóba. -
teleahocipöm
Köszi, akkor megy Pepperminten, bár ha egy napot kell mennie, akkor nem is tudom mikor fogom tudni futtatni, mert nem szivesen hagyom felügyelet nélkül a gépet, de megoldom.
Azért meg vagyok győződve, hogy a Synaptic alatti fagyásokat valami szoftveres hiba okozza, de végig megyek a teszteken. A memtesztett délelőtt már efuttattam, semmi hibá nem találtTegnap leltem rá a Burn In Test -re, Wine alatt futtattam, elméletileg elég sok mindent tesztel, de nekem nem nagyon akart így működni.
A Pepper tuti nem marad fent a gépen -az Ubuntus vonal tarthatatlan-, most a Manjaro futl Live-módban feltünően gyors, feltehetően ez kerül rá. Persze gondok itt is vannak, pl a LibreOffice nem magyar és a Csomagtelepítő nem müködik, de szerintem ez csak a Live-mód miatt van, legalábbis remélem, mert ellenkező esetben ez sem maradhat, de akkor még ott a Netrunner, a Frugarware, Handylinux.
BoB
Csomagkezelőből - ilyen nincs. Tárolóból - olyan van.
Ha elolvasod a hozzászólásokat látni fogod hogy elmaradt frissítés miatt nem fordul a csomag - mert az csak AUR-ban van, tárolóban nincs - amit egy pacman wrapper-el telepítene, ami a yaourt.
Te fel tudtad rakni mert neked friss a rendszered és ment a gcc, és egyébként számodra a fordítás transzparens volt, nem látható hogy nem repóból van.
TLDR: nyugi, megy minden rendben.
Rimuru
Lehet biztonság miatt nincs, bár ki tudja.
Nekem is "félig" van csak autologin mert egyből elindít egy jelszókérő alkalmazást is, de így legalább betölt mindent amit szeretnék.
m165le2: Annyira zavarja a szemem a "cinnamon ablakkezelő".
Az már egy DE, és ott muffin az ablakkezelő.
Más: Szerintetek lenne értelme egy írni egy fogalmak összefoglalót (gondolok itt pl a fenti dologra, WM, DE, DM, stb...)
m165le2
kovaax
Fenyő
Ill hogy ne csak teljesen kulcsrakész (nem kell megijedni csak a nonfree dolgokat kell hozzáadogatni) disztrókat ajánljak Fedora 21 Lxde Spin és OpenSuse 13.2 is telepíthető Lxde vagy Enlightenment De-vel.
Freel
Megnéztem, és elvileg mindent feltelepített a Lubuntu. De a firefoxban az ABOUT : PLUGINS alatt nincs Java és nem is működik pl. a BWIN!!! Akkor mégiscsak hekkelni kell? Ez alapján jó lehet szerinted?
Freel
Hálás köszönet, az az érzésem, hogy ez lesz a járható út. Neki is esek, ha sikerül mindenképpen írok.
kisapa: valószínűleg egy 2 gigás modul volt benne eredetileg. Vedd ki az egyiket, nézd meg a biosban mennyi maradt. Ha nem az a modul, a másikat tedd be. Egyébként ha ez a baja a Linux telepítésnek, nagyon erősen javaslom, hogy add el azt az 1 gigás modult a francba és pontos típus és szériaszám alapján keress egy másik 2 gigás ugyanolyan modult és azzal bővítsd a gépet. HA-n szinte biztosan találni fogsz idővel.
Freel
Emlékszem, eddig jutottam tegnap is:
freel@freel-desktop ~ $ cvt 1280 1024 85
# 1280x1024 84.84 Hz (CVT 1.31M4) hsync: 91.46 kHz; pclk: 159.50 MHz
Modeline "1280x1024_85.00" 159.50 1280 1376 1512 1744 1024 1027 1034 1078 -hsync +vsync
freel@freel-desktop ~ $ xrandr --newmode "1280_1024_85.00" 159.50 1280 1376 1512 1744 1024 1027 1034 1078 -hsync +vsync
xrandr: Failed to get size of gamma for output default
freel@freel-desktop ~ $ inxi -G
Graphics: Card: NVIDIA GM107 [GeForce GTX 750 Ti]
Display Server: X.Org 1.15.1 drivers: vesa FAILED: fbdev,nouveau
Resolution: 1024x768@61.0hz
GLX Renderer: Gallium 0.4 on llvmpipe (LLVM 3.4, 128 bits)
GLX Version: 2.1 Mesa 10.1.3
freel@freel-desktop ~ $Most mi legyen?
U.I.: feltettem az xdiagnose-t... Elindítotm, teker, teker, teker... aztán semmi...
Freel
Igen igen, ezt az oldalt is néztem tegnap... Megpróbálom még egyszer a leírásod alapján, hátha sikerülni fog. Viszont azt mondod, hogy akkor az a novueo vagy mi, a nyílt driver alatt fog csak működni ez a trükk? És mivel játékra használnám (is) a Linuxot, ez a nyílt driver képes olyan erőt kipréselni a GTX-ből, mint az nVidia saját drivere? Vagy ez majd csak teszt (mondjuk Unigine Valley) után derül ki?
spammer
Kb. jó fél évvel ezelőtt használtam Chrome-ot, de lehet, hogy már több, mert utána Operára tértem át, aztán Firefoxra, mert utóbbit szabadon "hackelhetem".
A Chrome személyre szabhatóság szempontjából sajnos elég nagy nulla (már ami az interfészt illeti, nem a kiegészítőkre gondolok), ezért is hagytam ott, többek között, mert egyéb hiányosságai is voltak. Ha azóta javult a pepper is, az jó, mert ráfért.
Freel
Basszus, látod ezt sem tudtam. ADBlock automatikusan települ a Chrome-al, nem tudtam, hogy ennyire erőforrásigényes. Azt, hogy a html5 felejtős ezt nem értem. Lehet választani? Vagy kikapcsolni? Vagy, hogy? Azt hittem az csak úgy 'van', működik alapértelmezetten.
És akkor kicsit 'elosontunk' a válasz elől...Akkor azt kell leszűrnöm, hogy még Linux alatt sem zökkenőmentes a netezés sem ilyen géppel? Tehát nem érdemes foglalkoznom a dologgal?
U.I.: döbbenetes, hogy pl. LG G-PAD 7.0-mon szakít, hasít a net úgy megy, hogy ledöbbentem. Egy ilyen gépen, meg csak cummendotta minden...Pedig nem ezt vártam...
Hálás köszönet a segítségért!
Milyen program ami... [link]
- Teszt [Linux] A Flatpak
- 13-14" Új és használt laptopok , üzletitől a gamerig , kedvező áron. Garanciával !
- BESZÁMÍTÁS! ASUS A620M R7 7700X 32GB DDR5 1TB SSD RX 7900 XTX 24GB ZALMAN I3 NEO EVGA 850W
- AKCIÓ! Lenovo ThinkPad X13 Gen 5 üzleti notebook - Ultra 5 135U 16GB DDR5 512GB SSD Intel Win11
- DELL Precision 5560 i7-11850H 16GB 512GB T1200 FHD+ 1 év garancia
- AKCIÓ! 750W Seasonic PRIME TX-750 Titanium tápegység garanciával hibátlan működéssel
Cég: NetGo.hu Kft.
Város: Gödöllő
