- Kezünkben a OnePlus 15 és az Oppo Find X9-ek
- Az iPhone Air buktája elkaszálhatta vékonyítási lázat
- iOS alkalmazások
CPT.Pirk
#90540
Amúgy a minimál DE-t azt miért szeretitek annyira?
Pálcika WM-et imádni lehet, mert 64GB RAM-ból boot után még mindig mutat a htop 63-at és konzolos böngészővel még később is marad 60+ giga! Te ezt nem értheted.
(én se nagyon)Garuda super, egy verziója van, ami tényleg extremturbo csilivili, attól anno félóra alatt kiolvadt a műszemgolyóm.
CPT.Pirk
#90525
[ 6.801527] xhci_hcd 0000:05:00.4: WARNING: Host System Error[ 8.153957] usb 4-2.2: Failed to suspend device, error -19[ 8.250502] Bluetooth: hci0: command 0xfc20 tx timeout[ 8.428307] usb 4-2.4: Failed to suspend device, error -19[ 12.410944] wlp2s0: authenticate with d6:92:5e:0d:a9:2d[ 12.947218] wlp2s0: send auth to d6:92:5e:0d:a9:2d (try 1/3)[ 12.950471] wlp2s0: authenticated[ 12.957865] wlp2s0: associate with d6:92:5e:0d:a9:2d (try 1/3)[ 12.960584] wlp2s0: RX AssocResp from d6:92:5e:0d:a9:2d (capab=0x1011 status=0 aid=26)[ 12.961024] wlp2s0: associated[ 13.040832] wlp2s0: Limiting TX power to 23 (23 - 0) dBm as advertised by d6:92:5e:0d:a9:2d[ 13.061073] IPv6: ADDRCONF(NETDEV_CHANGE): wlp2s0: link becomes ready[ 13.221817] systemd-journald[284]: /var/log/journal/512a8e4e693f485993282234f7940703/user-1000.journal: Monotonic clock jumped backwards relative to last journal entry, rotating.[ 16.143868] Bluetooth: hci0: RTL: download fw command failed (-110)[ 16.859852] usb 4-2.4: Failed to suspend device, error -19[ 18.277375] Bluetooth: hci0: Failed to read MSFT supported features (-110)[ 20.769339] usb 4-2.2: Failed to suspend device, error -19[ 99.210739] usb 4-1: USB disconnect, device number 2[ 99.210757] usb 4-1.1: USB disconnect, device number 4[ 99.211425] usb 4-1.4: USB disconnect, device number 5[ 99.212102] usb usb4-port1: couldn't allocate usb_device[ 102.037201] usb 4-2.4: Failed to suspend device, error -19[ 102.037219] usb 4-2.2: Failed to suspend device, error -19[ 143.461628] usb 4-2.4: Failed to suspend device, error -19[ 143.461655] usb 4-2.2: Failed to suspend device, error -19 -
zoltanz
CPT.Pirk
#90468
"Mit ír a dmesg, mikor ezt csatlakoztatod?"
Erre gondolsz?:62.002808] usb 4-1: new high-speed USB device number 5 using ehci-pci[ 62.180823] usb 4-1: New USB device found, idVendor=32bb, idProduct=0004, bcdDevice= 0.01[ 62.180828] usb 4-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3[ 62.180830] usb 4-1: Product: HiBy FC1[ 62.180831] usb 4-1: Manufacturer: HiBy[ 62.180833] usb 4-1: SerialNumber: 0[ 62.185115] input: HiBy HiBy FC1 as /devices/pci0000:00/0000:00:1d.7/usb4/4-1/4-1:1.2/0003:32BB:0004.0004/input/input22[ 62.243115] hid-generic 0003:32BB:0004.0004: input,hidraw3: USB HID v1.00 Device [HiBy HiBy FC1] on usb-0000:00:1d.7-1/input2 -
lanszelot
CPT.Pirk
#90453
Heatman partition recovery -m van.
Az nem is látja a meghajtót
No, de nem is kell.Iszonyat nagy szerencsém van
Havonta csinálom a biztonsági mentéseket. Ami jövő héten esedékes. Azaz 3 heti jegyzet, tanulás stb bukó....lett volna, de:
Valamiért véletlen C -re mentettem ezt a hónapot.
Fogalmam sincs miért, hogy. De semmi sem veszett így el.
Véletlen vettem észre hogy meg tudom nyitni a file-im amik bukók lettek. Ekkor láttam meg, hogy rossz helyre mentegettem
Iszonyat nagy malacom van.
A hdd pedig természetesen kuka.
Mindenkinek nagyon szépen köszönöm a segítséget
CPT.Pirk
#90453
sőt, komoly csapdák vannak bennük. Hiszen ha olyan jellegű a hiba, akkor a mentés közben is lehet adatvesztés. Nekem ez tapasztalat, h anno a csatolt HDD-n szemre minden megvolt, majd másolás közben egyszer csak hibákat dobott, frissítve már csak a töredéke látszott az adatoknak...
Másik, h a sok ingyenesnek hirdetett az csak X GB-ot hoz vissza ingyen, ha meg is találja. Ezzel pár hete szembesültem, kisfiam egy játék moddal együtt a mentéseit is törölte...
cigam
CPT.Pirk
#90429
Éppen ezért is írtam, hogy másodlagos szerepe van nálam. Egy NAS-on futó víruskergető nem helyettesítheti a PC-n futó védelmet.
Értem én hogy a víruskergetőknek is van fájlméret limitje (a clamscan 4GB-os fájlméretig kezd bele a vizsgálatba, ha felülírod az alapértelmezett (25MB?) limitet), de minden másra ott vannak a a valós idejű védelmek. -
SIPAnonymus
friss újonc
CPT.Pirk
#90418
Szia! Jobb katt a meghajtó hosszú nevére és csatolás. Like a windows user
Még tanulom ezt a részét, úgyhogy ha esetleg parancssoros lépésekkel is meg tudod mutatni, akkor nagyon megköszönöm!
Még próbáltam a userem root/admin joggal felruházni (hamár az mkdirrel ment), de így sem működik a dolog. Az egész ott bukott ki, hogy a Qbittel nem tudtam letölteni egy iso filet, mert nem volt joga írni a mappába. Így láttam meg, hogy az owner "root". -
CPT.Pirk
#90373
Az lehet, ott van fél gigányi számomra ismeretlen valami.
Átírtam az ikonszerkesztővel az elérést, mert persze nem működnek az alkalmazásmenü meg a panel ikonok, érthető.
/snap/opera/249/usr/bin/
minden szuper, a panelen az ikonhoz se kellett nyúlnom, működik.
Nagy öröm ez egy kis linuxosnak. -
CPT.Pirk
#90358
Érdekes ez, kár, hogy az LMDE sorozattal folytatják ezt, amit pedig már az Ubuntu alapú 20.1, 20.2, 20.3-mal amúgy bevezettek! De így is jó dolog ez. A Debian Cinnamon testing 11-ből 12-re upgrade-elt disztró 6.1 kernellel egész pörgősen és gond nélkül megy. Szóval jó lesz a LMDE 6 is...
Most látom ezt:
In parallel to LMDE 6 we’re also planning to release an EDGE ISO for Linux Mint 21.2. This ISO will feature a kernel 6.2 and make it easier to boot Mint on brand new hardware.
Nem nagyon értem, mert a 21.2 már jó ideje kint van. Ja látom már, a 21.3-ra is tervezik, nem csak az LMDE 6-ra.
CPT.Pirk
#90344
köszi a linket. ha jól emlékszem, összevesznének a pci-e laneken a vinyókkal. ez egy home server, amit nasnak és mediaplayernek használunk, sok vinyóval. egy nagyon halk, szekrénybe beépített gép, minimális hűtési igénnyel, és szeretném, ha ez így is maradna. emiatt integrált vga megoldás a preferált.
yanpec
CPT.Pirk
#90337
Vam egy HP Proliant G6 Home szerverem, Intel xeon3470 proci van benne. A HW olya 2013s kb, nem mai darab de a célnak tökéletesen mwgfelel. Amire a Radieont be akartam fogni az a Plexen belüli videó konvertálás, HDR SDR tone mapping. De ahogy utánaolvastam, nem igazán támogatja a Plex az amd kártyákat, csak az Nvidia-t.
yanpec
CPT.Pirk
#90335
Igen elvileg úgy működik mint egy sima linux. Fel is ismeri a kártyát. Hardveres gyorsításra akartam ezt a kártyát használni Plex médiszerver részére, de valszeg a plex nem támogatja az AMD kártyákat. Aztán arra gondoltam, hogy frissíteni kellene lehet a driveret. Olvasgattam is a netet ez ügyben, de parancsokra nem reagál, scripteket nem tudok indítani. Talán ha jól értelmezem, hogy a kernelt kellene előkészíteni az amd fogadására. Létezik ilyen? Nem vagyok linuxos, de most már bele fogom ásni magam a témába, mert idegesít, hogy nem értek hozzá
lanszelot
CPT.Pirk
#90181
Először is köszönöm szépen a választ.
Nincs jobb klikknél ikon hozzá adása.
Semmit se lehet a tálcára húzni, behajtani tilos jel jelenik meg.
Az alap ikonoknál az internetet próbáltam, illete a start menüből a böngészőt tálcára húzni.
Ha valamit fogd és húzd -al akarok asztalra rakni akkor kimasolhatom, vagy áthelyezhetem. És nincs több lehetőség.Érdekesség:
Raktam fel - Debian XFCE
- Debian Cinnamon
- Manjaro KDE
Eek mind jobban futnak mint a Lubuntu
Cpu 8% -ot se éri el frissítés/telepítés közben/2,1GB frissítést telepitett/
Méreteik 8GB korul van mindnek.
Egyedul Manjaro 11GB, de még az is jó.
Lubuntu alatt működtek a ventik halkan.
Másik 3 alatt semmi, és nem is melegszik egyáltalán.
Pedig Lubuntu tetszik eddig a legjobban.
Nem állítottam semmit, netet nyitottam meg, és az ikont próbáltam kirakni. Terminalt meg se nyitottam.
Ha a desktop nem lenne 'lezárva', és nem melegedne, akkor Lubuntu lenne a nyerő.
Desktop environments -ből xfce nem tetszett, a többi mind jó, az LXQT -val sincs semmi bajom.
Rendszerből a Debian nem nekem való. -
lanszelot
CPT.Pirk
#90162
Igen. Nagyon szokatlan a linux még nekem
Ez okozza, hogy ennyire elveszett vagyok benne.
Pl parancsikont próbáltam kitenni a böngészőhöz, hogy ne kelljen annyit kattingatni, hisz azt fogom legfőképp használni.
De az se sikerül.
Fogd és húzd kimásolja vagy kirak valamit, de nem parancsikont.
Jobb klikk nincs ilyen opció se file kezelőben, se start menüben.
Stardock fences alternatívát gondolom itt felejtsem el.
[kép] [kép]
Egeret felé vive lenyilik az ikonok mappa.
/Ez nem kell, csak nézegettem mi van mi nincs linuxba amit napi szinten mindig használok/ -
K0zm0
lanszelot
CPT.Pirk
#90153
No, a Zorin OS -t sikerült felrakni.
Ezek szerint a többivel valahogy nem jól készítettem a boot usb-tBár fel ment a Zorin OS, de nem tudom hogy boot-olhatok arról.
[kép] [kép] [kép]
Tehát ez a boot manager
Gondolom 'add boot option'
Ekkor File Explorer nyílik, és
Az első üres, a második -pedig a linux file systemHogyan tovább?
K0zm0
CPT.Pirk
#90143
No, reggel nekiültem. Ez volna az Xfburn kimenete:
** Message: 08:18:45.766: Using UDEV
** Message: 08:18:46.278: Using gstreamer transcoder.
(xfburn:2097): libxfce4ui-CRITICAL **: 08:20:03.412: xfce_titled_dialog_update_icon: assertion 'icon_name != NULL' failed
(xfburn:2097): libxfce4ui-CRITICAL **: 08:20:25.543: xfce_titled_dialog_update_icon: assertion 'icon_name != NULL' failed
** (xfburn:2097): WARNING **: 08:20:43.585: [FATAL] 131357: SCSI error on write(-46,13): [3 0C 00] Medium error. Write error. (0)
** (xfburn:2097): WARNING **: 08:20:43.585: [FATAL] 131357: CDB= WRITE(10) : 2a 00 ff ff ff d2 00 00 0d 00 : dxfer_len= 30576 (0)
** (xfburn:2097): WARNING **: 08:20:43.585: [FATAL] 131339: Burn run failed (0)Ez pedig a Braseroé:
** (brasero:2490): WARNING **: 08:27:49.052: Could not establish a connection to Tracker: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.Tracker3.Miner.Files was not provided by any .service files
(brasero:2490): GLib-GObject-WARNING **: 08:28:11.897: attempting to add an interface (EggTreeMultiDragSource) to class (GtkFileSystemModel) after class_init
(brasero:2490): GLib-CRITICAL **: 08:28:15.312: Source ID 1244 was not found when attempting to remove itHa sudoval indítottam, akkor nem ismerte fel a nyers CD-t és image fájlt akart csinálni a kompozícióból. Valamilyen dependencia gondja lehet? Vagy ennyire sz*rok a Verbatim CD-k?
lanszelot
CPT.Pirk
#90134
Mivel csak bankhoz kell, így nem kell a tárhely.
Ha a linux elfut 8GB-s pendrive-on akkor a 16 sok is neki.
Pl Twister OS -nek is bőven elég, és gyengusz gépeken is vígan fut.
A kérdés inkább a biztonságra vonatkozott, hogy az a pár linux ami elfut ezen abból melyik a legbiztonságpsabb?A safari amellett, hogy rossz böngésző, már évek óta nem kap frissítést a rendszeremen. Ezért nem veszek többet almát.
6 év annyiért amennyiért árulják... és utána dobjam ki.
Operára gondoltam még, mert az Mozilla alapú, de nem tudom tamogatja e még, és meddig. Míg linuxon nem lesz ilyen gond, hisz a legújabb os fog futni.
Arra is gondoltam, hogy a Macbook Pro ra linux .. de ott már van Mac és Windows, most még egy harmadik .. még ha portable is.
Vagy SD kártyára felrakni és onnan futtatni amíg kell.
Nem tudom. -
CPT.Pirk
#90125
4 magos 1GHz-es AMD Puma+ procis integrált lap - valami spéci HP vékony kliens.
Manjaro-val olyan 22-24MByte/sec-el tud torrentezni amd-ucode felrakása után is, Windows-zal viszont 50-55 is megvan néha ugyanolyan körülmények közt, de a 35-40 leglább.
Emiatt törekszem maximális hatékonyságra. -
CPT.Pirk
#90098
Szerintem ez az egész erőlködés felesleges, amíg nincs kizárva a hardware hiba.
Én előbb bootolnék vmi live Ubuntut/Mintet/Slaxot, SMART report a storage-ról. Ha a storage rendben, ki vele a gépből, memtest. Ha az is okés, akkor másik táp. Ha táp is OK, akkor alaplap alapos bevizsgálása púpos kondik után.
CPT.Pirk
#90093
so-so. a szokásos crasheim voltak (i915 gpu hang). néhány után fsck-t is kellett futtatnom. az egyikből már net nélkül jött vissza a gép, strictly unmanaged ethernet csatolóval. totál defaultra visszaállt a teljes hálózati rész. a netplan generate nem futott le, meg utána a netplan többi része sem, a pythonból hiányolt modulokat. kézzel hálózatra tettem, utána akartam megnézni, hogy sudo apt --fix-broken installra mit mond, de minden apt hívásra a fenti hibaüzit dobja. most itt tartok.
CPT.Pirk
#89880
Még egy kis gondom van a zip-el:
/usr/bin/zip -8 -ruoq /MENTES/Dokumentumok/eagle-$(date +"%Y-%m-%d").zip /media/Resilio-sync/eaglezip warning: Permission denied
A parancs a user cron-jából indul. A kimásolt sorok a warning-gal a user parancssorából vannak.
A forrásmappa jogosultságai: 40775
A célmappa jogosultságai: 42777
A parancs sem a cronban sem cli-n nem hajtódik végre.
Mit rontottam el? -
Warton
CPT.Pirk
#89945
A gpartedet csak azért mondtam, mert nekem onnan tűnik a legegyszerűbben kiszedni ezt az infot.
Nekem jó az fstab, csak ne nekem kelljen kézzel megírni, hanem legyen egy program, amibe beállítom, hogy ezt a HDD-t ebbe a könyvtárba csatolja azt a HDD-t meg amabba, az SSD-t meg emide. Az beírja az fstabba azt, amit kell: UUID noatime ha kell, ha nem 0 0 vagy 0 1.
Aztán végül mount chown és az egyéb hülyeség.A linux fájlrendszer sinusgörbéjére még nem sikerült teljes mértékben ráhangolódnom.
CPT.Pirk
#89928
Nemnem. Ennél sokkal bonyolultabb
Mezei Ubuntu, az a borzadály aminek nem tudom a nevét, talán Unity...? de rettenet.
Mivel számomra élhetetlen volt, panel fönnt, lehetőségek nulla, ráment egy XFCE, mivel előtte Manjaroztam, az is soványka volt ezért erre még rárántottam a komplett KDE Plasmát.
A konfig 5. éve többször több eszközre klónozva, halálból visszahozva Timeshifttel, agyonüthetetlen, hibátlanul teljesít.
Beregeltem a PRO támogatásra, így a biztonsági frissítéseket még 5 évig kapom, a szoftverek... nos unatkoznék ha nem lenne ilyen Python meg egyebek matatás néha.Csomagkezelők.
A gyári nulla, ami kell annak a felét nem találja, ezért kellett a Synaptic.
Ez meg a gyári nálam random nem képes orosz weboldalakról
letöltött deb telepítésére, ezért kellett egy 3. is.
Mivel ezek nem nagyon rajonganak a KDE kisalkalmazások és még pár KDE app frissítéséért, kell a KDE Discover.
+ a gyárinak van egy modulja amibe a ppa-kat, Ubuntu PRO és egyéb engedélyeket lehet beállítgatni.
És ha mind csődöt mond valamiért, kell a terminál.
Amihez mivel tök vagyok, először végigzongorázom a 4-5 GUI-t és az esetek 95%-ában meg tudom oldani
Ez így van, legalábbis nálam, így élnek a lelkes de botcsinálta LL felhasználók.
LL- Láma LinuxosMaradna a tisztább szárazabb biztonságosabb megoldás, gyalu és a legújabb telepít de mit Uby írta, azt már nem, az túl egyszerű
-Skylake-
CPT.Pirk
#89905
minden szerver amivel a hetkoznapokban dolgozok ubuntu (1-2 cent-et leszamitva, de azokbol is ubuntu servert fogunk csinalni), szoval az ubuntu biztos. a gnome nem igazan szamit, mert GUI-t ezen a gepen soha senki nem fog latni, itt a linuxnak annyi funckioja lesz hogy legyen mire feltelepiteni egy dockert meg egy kubernetest kb. csak es kizarolag terminalbol lesz hasznalva ez a gep.
egyebkent pont azert is kerdeztem ra, mert ugye ez egy ryzen apu (2400ge). mindenestre koszi a valaszt mindkettotoknek, akkor ez lesz szerintem. -
szbalogh
CPT.Pirk
#89862
A hardinfo-t futtatom de csak 36 magot ír.
Az lstopo se ír két szálat magonként.
Nem a benchmarkok érdekelnek, hanem az, hogy amire nekm kell ott számít-e
18 és 36 mag között majdnem feleződik egy bizonyos feladat ideje. Egy másik programmal windows alatt alig van különbség, ott tényleg nem volt értelme, de itt nem van rá esély, hogy sokat segít. -
#22163968
CPT.Pirk
#89856
Megnézem, elolvasom, köszönöm a linket.
A fura az egészben az, hogy desktop gépen (gtx1660) ugyanezen az OS-en kizárólag az "nvidia, nvidia-utils, nvidia-settings, opencl-nvidia" csomagok vannak feltéve és elméletileg rendben van a gyorsítás. Ezért azt hittem ez rendben lesz a laptopon is.
De tévedtem.Amúgy firefox esetében van valami olyasmi lista, mint chromium esetében a "chrome://gpu" ?
Találtam egy ilyet: "about:support"
De kicsit sok info van itt ahhoz, hogy megtudjam, aktív-e a gyorsítás.
Ueda
CPT.Pirk
#89846
Nekem nem . Egyrészt van a telepítő lemez káosz, amin Chris Titus is röhögött. [How to Download]
2. Hiányolom a csomagkezelőből a zstd tömörítést, ami csak simán bosszantó (kibírhatatlan). 3. Ahogy sh4d0w mondta nem smooth a Kde asztali környezet.Ettől függetlenül használnám ... ha nem lenne arch linux.
Ueda
CPT.Pirk
#89561
Most néztem meg live -ban. Inxi nem ismeri fel. A sebesség rendben van. [Realtek 8188EU wifi]
A telepített rendszeremen elromlott a dkms és nem tudtam megszabadulni tőle, hogy átálljak a mostani kernelre. Így a régi kernellel használom tovább. [Realtek 8188EU wifi old] -
Marcsello31
CPT.Pirk
#89787
Talátlam egy érdekes oldalt itt, ők ezt így magyarázzák le:
itt hol kellene a vodafone adatait beírnom?
[Dialer Defaults] Init1 = ATZ Init2 = ATQ0 V1 E1 S0=0 Modem Type = Analog Modem Baud = 9600 New PPPD = yes Modem = /dev/ttyUSB0 ISDN = 0 Phone = *99# Password = internet Username = internet Stupid Mode = on -
Marcsello31
CPT.Pirk
#89787
Szia! Rendben délután megpróbálom, addig letöltöm a linuxot, ha gondolod terminál alatt megnézheted te is, tudok távhozzáférést adni ha kel vcn keresztül is, ha eseteleg volna kedved hozzá, és ha nekem nem megy. Jó lenne tudni hogy melyik fájlba kellene tennem ezt? de melyik udev fájl ba? mindenért köszi, tölöm le a linuxot.
Marcsello31
CPT.Pirk
#89784
Rendben! Már is szedem lefele köszi, tényleg, délután majd ahogy látom ezzel fogok szórakozni, az volna az igazi hogy ha a beállítása után automatikus volna, így routert is rá tudnék kötni vagy wifit. megnézem amit javasoltál, remélem hogy be fog válni.
gondolom innen szedjem le:
[link] -
Marcsello31
CPT.Pirk
#89782
Szia! Rpi buster alatt megy? Valahol csak fent van a neten ez a linux, mert akkor megnézem azt is, azt még nem néztem meg, jó lenne egy linuxon nyugvó megosztás azért az nem eszi a gépet mint a windows, na meg talán wifi alatt is tudnám osztani a mobilnetet, letöltöm ezt a linuxot megnézem. Köszi! a rendes ubuntunál csak félig jutottam el vele, hasonló parancssokal de nem volt értelme., sajnos, nem látta rendesen.
ez egy új kínai 4g modem, szerintem az a baj. -
Marcsello31
CPT.Pirk
#89754
Rendben Este majd mutatok képet hogy jelenleg mi a helyzet vele, terminál alatt mobile mobile ként látja és egy pid vid szám is van mellette, de ennyi, nemsokára jövök pár képpel, kár hogy az rndis drivert linux alatt nem lehet feltenni, ezt a winfos automatikusan megteszi.
Warton
CPT.Pirk
#89719
Been there, done that. Pupi, nem pupi tökmindegy. Nyugodtan rakhat rá Manjaro KDE-t is, LinuxMintCinnamont, XFCE-t, ZorinOS-t, EndevourOS-t, akármit, nem lesz gyorsabb vagy lassabb a pupihoz képest. Tudom, hogy a youtube tele van ezekkel a videókkal, hogy a régi szutyok gépet használhatóvá lehet tenni a fossapuppal, hát pontosan ugyanannyira mint bármelyik egyéb disztroval. És a DE se számít semmit. Lehet elemezgetni a RAM használatot, igazából ezeknél a CPU a szűk keresztmetszet. Tapasztalataim szerint a CPU az, ami folyamatosan 100%-on pörög, míg a RAM bőven bírna még. A pupit nem mondanám kezdőbarát disztronak.
Ha tényleg komolyan akarja valaki haszálni akkor az SSD kötelező. Amúgy meg, ez a netbook arra jó, hogy retroarchal NES, SNES, Genesis stb. játékokat futasson. Régi, DOS-os, win95-ös játékokat: Doom2, Heroes2 és Caesar3 stb., oszt annyi. Ezeknél is olyan launchereket kell keresni, ami nem nagyon akar grafikát javítani. Pl. a gzdoommal az én windumon nem indul a doom, csak a chocolatedoommal, ami nem tesz az eredetihez semmi plusz effektet.
Ha minden egyebet lekapcsolsz akkor elindul a youtube, nagyon max 480p-ben. Esetleg Spotify is elmegy rajta, bár az én windumesterem CPU-ja eléggé berecsegteti, úgy másfél percenként a hangot, úgyhogy nem az igazi. (bár ez utóbbi, lehet, hogy blutooth hiba inkább, nemtom.) Meg ha elég türelmes vagy akkor még a netet is böngészgetheted.
Összességében a mai telefonok kb. mindenben felülmúlják ezeket a gépeket, leszámítva a nagyobb kijelzőt és a fizikai billentyűzetet.
zoltanz
CPT.Pirk
#89651
Elvileg a készűl a Vulkan-os AV1 dekóder . (AOMedia Video 1)
Ami jó lenne met a Netflix-en már használatos (azt jön a társain is Disney, HBO, Apple, Amazon stemain szolgáltatóknál is)
Khronos, a Vulkan mögött álló szabványozó szervezet, nemrégiben jelentette be, hogy két új kódolót vezet be – az H264 és az H265 –, de az AV1 kódoló még nem volt része a szabványoknak.
RedHat alkalmazásában álló nyílt forráskódú illesztőprogram fejlesztő Dave Airlie és egy FFmpeg fejlesztő, Lynne együtt létrehozták saját kiterjesztésüket az AV1 videók dekódolásához, amelyet VK_MESA_video_decode_av1-nek neveztek el.
Milyen program ami... [link]
- Teszt [Linux] A Flatpak
- Számtech boltosok memoárjai, azaz amikor kiborulunk...
- Mennyibe fog kerülni a Steam Machine?
- Kuponkunyeráló
- Intel Core i7-5xxx "Haswell-E/EP" és i7-6xxx "Broadwell-E/EP" (LGA2011-v3)
- Okos Otthon / Smart Home
- Porszívók - akkus és klasszikus vezetékes
- Spórolós topik
- GYÖNYÖRŰ iPhone 12 mini 128GB Blue -1 ÉV GARANCIA - Kártyafüggetlen, MS3881, 100% Akkumulátor
- Samsung Galaxy S22 5G 128GB, Kártyafüggetlen, 1 Év Garanciával
- GYÖNYÖRŰ iPhone 14 128GB Red -1 ÉV GARANCIA -Kártyafüggetlen, MS3678, 100% Akkumulátor
- Lenovo Thunderbolt 3 kábel (4X90U90617)
- Eladó egy oneplus 9 pro 256/12
Cég: BroadBit Hungary Kft.
Város: Budakeszi
Cég: ATW Internet Kft.
(én se nagyon)
(nekem speciel fogalmam sincs)
