ASUSTO NAS összefoglaló
Stealth #4773 üzenetére
Illetve még egy kérdés:
Jelenleg 4 lemez van RAID5-ben. A jelenlegi cél mindezt egy lemezre átvinni.
Ha kiveszek egy lemezt a RAID-ből, degraded lesz, de az adatok még megmaradnak.
Vajon be tudom-e tenni az új HDD-t úgy, hogy ne akarja beépíteni a RAID-tömbbe?
Köszönettel: MaCS
Arc27
Stealth #4612 üzenetére
Hello
Már mindent megtaláltam a logba de jelszó sehol nincs
Pontosan hol találom ?Üdv Roland
(N) 2025-02-03T20:42:16 - qBittorrent v5.0.3 started. Process ID: 146
(N) 2025-02-03T20:42:16 - Using config directory: /config/qBittorrent
(N) 2025-02-03T20:42:16 - Trying to listen on the following list of IP addresses: "0.0.0.0:6881,[::]:6881"
(I) 2025-02-03T20:42:16 - Peer ID: "-qB5030-"
(I) 2025-02-03T20:42:16 - HTTP User-Agent: "qBittorrent/5.0.3"
(I) 2025-02-03T20:42:16 - Distributed Hash Table (DHT) support: ON
(I) 2025-02-03T20:42:16 - Local Peer Discovery support: ON
(I) 2025-02-03T20:42:16 - Peer Exchange (PeX) support: ON
(I) 2025-02-03T20:42:16 - Anonymous mode: OFF
(I) 2025-02-03T20:42:16 - Encryption support: ON
(I) 2025-02-03T20:42:17 - Successfully listening on IP. IP: "127.0.0.1". Port: "TCP/6881"
(I) 2025-02-03T20:42:17 - Successfully listening on IP. IP: "127.0.0.1". Port: "UTP/6881"
(I) 2025-02-03T20:42:17 - Successfully listening on IP. IP: "172.17.0.2". Port: "TCP/6881"
(I) 2025-02-03T20:42:17 - Successfully listening on IP. IP: "172.17.0.2". Port: "UTP/6881"
(I) 2025-02-03T20:42:17 - Successfully listening on IP. IP: "::1". Port: "TCP/6881"
(I) 2025-02-03T20:42:17 - Successfully listening on IP. IP: "::1". Port: "UTP/6881"
(I) 2025-02-03T20:42:17 - UPnP/NAT-PMP support: ON
(W) 2025-02-03T20:42:17 - Couldn't load IP geolocation database. Reason: No such file or directory
(N) 2025-02-03T20:42:17 - Using built-in WebUI.
(N) 2025-02-03T20:42:17 - WebUI translation for selected locale (en) has been successfully loaded.
(N) 2025-02-03T20:42:17 - WebUI: HTTPS setup successful
(N) 2025-02-03T20:42:17 - WebUI: Now listening on IP: *, port: 18181
(I) 2025-02-03T20:42:17 - Detected external IP. IP: "176.63.144.150"
(I) 2025-02-03T20:42:17 - IP geolocation database loaded. Type: DBIP-Country-Lite. Build time: Sat Feb 1 03:16:56 2025.
(I) 2025-02-03T20:42:17 - Successfully updated IP geolocation database.
(W) 2025-02-03T20:44:53 - UPnP/NAT-PMP port mapping failed. Message: "could not map port using UPnP[172.17.0.2]: no router found"
(W) 2025-02-03T20:45:50 - WebAPI login failure. Reason: invalid credentials, attempt count: 1, IP: ::ffff:192.168.0.34, username: admin
(W) 2025-02-03T20:46:31 - WebAPI login failure. Reason: invalid credentials, attempt count: 2, IP: ::ffff:192.168.0.34, username: admin
(W) 2025-02-03T20:46:38 - WebAPI login failure. Reason: invalid credentials, attempt count: 3, IP: ::ffff:192.168.0.34, username: admin -
Gawamatsu
Stealth #4430 üzenetére
Én meg itt örülök a már 7 év körüli 6104T-vel.
Sajna vagy sem az extension modulját megszüntették, csak a Lockerstore kinézetű USB-C-s változat van.
Persze elfekvő készletekben lehet, hogy van még nekem való, de másik kérdés ilyen koros cucchoz érdemes e venni kiegészítőt vagy inkább lemezeket cserélni. -
Stealth #4399 üzenetére
A mindenkori legfrissebb (éppen 2.6.12) OpenVPN klienst használom.
A beállítások kb. így néznek ki:
A kliensoldali konfig pedig így:remote megfelelonev.myasustor.com 62211 #El is éri.
client
dev tun
script-security 3
proto udp
nobind
float
ca ca.crt #stimmel
auth-user-pass
reneg-sec 0
cipher AES-256-CBC
data-ciphers-fallback AES-256-CBC
auth SHA512
remote-cert-tls serverÉn nem látom benne a hibát...
Köszönettel: MaCS
cigam
Stealth #4386 üzenetére
Mint kiderült nem tévedtek, tényleg tud
Nem kell. Az utolsó pont az ellenség megtévesztése. Kamerákon nem ritka, hogy Formázás, az nem a PC-s értelemben vett új fájlrendszer létrehozását jelenti, hanem csak a kamera működéséhez szükséges könyvtárszerkezet, és fájlok létrehozását jelenti.
Nem mellesleg egy megosztott mappát a megosztáson keresztül semmi nem tud "formázni", főleg nem az egész lemezt. -
cigam
Stealth #4384 üzenetére
Igen, ezt írtuk az elején is: #4361 Olyan kamerát vegyél, ami elég okos ahhoz, hogy magától elintéz mindent. A feltöltést, a mozgásérzékelést, maszkolást, riasztást, meg mindent amire szükséged van. Csak egy mezei FTP/NFS/SMB kapcsolatot kell biztosítania a NAS-nak. Így kihagyhatod a képletből a NAS gyártójának programját (SC), ill. több kamera esetén a kameralicence-eket is megspórolod.
cigam
Stealth #4382 üzenetére
A gyártó elképzelése gyakran nem találkozik a felhasználóéval. Kicsit impulzus vásárlásnak tűnik a választásod. Első körben kinézel egy még nem is kapható modell-t, aztán másnap már megvettél egy teljesen másikat.
A Spec. átnézésekor sem állítja magáról, hogy képes ftp-re csatlakozni. -
Stealth
Stealth #4377 üzenetére
Működik a Tapo C520WS az AS5202t-vel.
Elég érdekesen csinálja a TP-link ezt az egészet, nem is biztos, hogy tetszik így.
Innen le kellett szednem az Agent DVR programot linuxhoz -én LMDE6-ot használok.
Majd ebben a programban kell mindent beállítani, például: előre be kell állítani egy ftp szervert -persze a nas az, működik az sftp is. Be lehet állítani, hogy hogyan reagáljon a kamera bizonyos eseményekre: ha mozgást észlel indítsa el a felvételt ÉS (és kapcsolattal egy újabb esemény) -> töltse fel egyből az ftp szerverre. Vagy ha arcot érzékel azonnal készítsen fotót ÉS töltse fel az ftp szerverre. Azt is be kell állítani, hogy ha a mozgás befejeződik állítsa le a felvételt. Minden működik egyébként, de lehetne ezt egyszerűbben is szerintem. Nem mondhatnám, hogy így akartam. -
Stealth
Stealth #4376 üzenetére
Működik, úgy ahogy. Tettem bele SD kártyát, egyből hozzáadta a kamerát az SC-hez.
A live view-nál csak pörög középen az egér, de nincs kép, viszont mindent tudok csinálni a kamerával. Mozgatom, felveszek, stb. A felvételek megjelennek a nason. Még gyűröm kicsit, hátha lesz élő kép az SC-ben. -
cigam
Stealth #4362 üzenetére
Nálam is mennek napelemes-wifis kamerák. Az Imilab (Xiaomi) sajnos nem dolgozik NAS-ra (FTP) és saját bázissal működik. A Reolinkek viszont önállóak, és emlékeim szerint van a Reolinknek PT(Z)-s, napelemes, wifis kamerája intelligens tárgyfelismeréssel és FTP-lehetőséggel.
MaCS
Stealth #4360 üzenetére
Amint írtad is, az okosságot érdemes a kamerára bízni. Tehát a NAS szerepe kizárólag a tárolás.
Az ugyan egy másik topic, de a Reolink / Hikvision / Dahua és társai körből könnyedén találsz olyan kamerát, amelyik megbízható, és FTP-re + kártyára is rögzít, illetve telefonra riaszt, ahová mehet a letöltés a kártyáról. (Nálam a Reolink nagyon bevált. Talán ez a legolcsóbb a jók közül, és egy héten belül szállítanak.)Lényegében bármilyen NAS jó, amelyiken van SFTP / FTPS lehetőség -- elég nehéz olyat találni, amelyiken ne lenne. Szóval szinte bármelyik NAS megfelel erre a feladatra.
A másik kérdés az elérés. Tehát magának a NAS-nak az elérése -- hiszen a kamera elérése az appon keresztül megoldott. (A netkapcsolat már egy másik kérdés, másik réteg.)
A neves NAS-ok mindegyikéhez lehet VPN-nel kapcsolódni. Ha az adott helyen van publikus IP, akkor sima ügy akár WireGuarddal, akár OpenVPN-nel, ha csak privát (NAT-olt) IP-címet adnak, akkor a NAS saját boltjából telepíthető TailScale (de facto WireGuard) a megoldás. A három nagy márka szerintem listázza a boltjában. (Az Asustor biztosan.)
MaCS
Stealth #4336 üzenetére
Az otthoni hálózatod (LAN) praktikusan vagy Fast Ethernet (100 Mbps), vagy gigabites.
Az, hogy az internetkapcsolatod milyen, már egy másik kérdés, de a RAID0 előnyeinek kihasználásától még messzebb lesz.
De legalább kipróbáltad ezt is. Nem rosszak ezek a személyesen szerzett tapasztalatok, még ha jár is velük némi kellemetlenség. A nagy szívást megúsztad.
MaCS
Gawamatsu
Stealth #4324 üzenetére
Attól függ hány lemezes a NAS-od.
Ha csak 2, akkor elég macera, mert közvetlen nem udsz költözni.
Ha több, akkor nem gond.Első esetben többlépcsős.
1. Futó NAS-ra rá USB keretbe a 12TB és adatmásolás.
2. a két 4TB-s Raid-et bontod és visszamásolod szétosztva rá az adataidat a 12TB-ról
3. 12TB-s be a NAS-ba és au USB dock-ba be az egyik, majd a másik 4TB-s adat visszamásolásra.
4. kész -
Stealth
Stealth #4261 üzenetére
Meg kellett változtatnom a portot a kliensben, majd beállítani az új portra a forwardingot és persze engedélyezni a tűzfalon. Most megy.
A qbittorrent logban volt egy ilyan, hogy:
Failed to listen on IP. IP: "NAS IP címe". Port: "TCP/régi portom". Reason: "Address in use" -
Stealth #4153 üzenetére
1. igen, ugyanaz a kettő csak máshol van hostolva
2. 6881 az alapértelmezett torrent port, ezt érdemes valami másra állítani
A 9865 az a webui, kétszer van megadva, első a docker számára hogy azon a porton fog a külvilág felé kommunikálni, a második az ENV környezeti változók között van, a konténeren belül, ezek adják meg a qbittorrentnek az alapbeállításokat (időzóna, user és group ID és a webui port). A webui portot természetesen át tudod állítani később a Webui-n is de így egyszerűbb és automatikusan arra áll.
3. persze, ha neked máshol van (másik volume, másik könyvtár stb).
Többet is megadhatsz ha például egyből külön könyvtárba tennél valamit, nálam is három van megadva és az RSS letöltések bizonyos feltételek szerint ezekbe mennek direktben. -
ugyes
Itt az én stack-em:
A config fájlokat a standard NAS Docker könyvtárba teszi. A letöltéseket a Torrent könyvtáramba. Mást nem is tudsz megadni. Ezeket kell a saját könyvtáraid szerint megadnod. A qbitben majd ezen két könyvtárban tudsz majd megadni alkönyvtárakat, stb.
Nálam nincs definitíve külön megadva a TORRENTING_PORT a compose fájlban, csak a portok között a 52881. -
ugyes
Stealth #4144 üzenetére
A patrick által készített apk-ban nem tudsz más elérési utat kijelölni csak azt, amit patrick berakott. Általában ez az 1-es kötet valamelyik standard könyvtára + egyedi alkönyvtár.
Ha máshová tennéd, akkor érdemesebb rögtön stack-ként Portainerbe tenni az eredeti linuxserveres kódot.
+1: frissíteni is könnyebb, ha magad csinálod. -
Stealth #4137 üzenetére
Nem lesz gond (ha más portokra rakod), bár lehet a "natív" is Docker-ben fut, ahogy elnéztem pár Asus gyári appot egyszerűen fogták a Dockeres verziót és azt kapod (urBackup, Adguard biztos, lehet a qbittorrent is).
Rakj fel egy Portainer-t és akkor mindegy min futtatod (Asustor, Synology, mini PC) ugyanaz lesz a felület/logika.
ugyes
Én a dockeres verziót használom, azaz nem tudom a natív beállításait. Valószínűleg a portokkal lehet majd gond. Azokat kellene megváltoztatnod.
Én a linuxserver.io verziót használom. Link itt
A docker-compose részen leírtakat átmásolod a Portainerbe stackként (a stack neve csak kisbetűs lehet!). A portok első (bal oldali a : előtt) számait megváltoztatod, hogy ne legyen azonos az eredetivel. A /path/to/.... részekre a NAS megfelelő könyvtárainak hivatkozását írod (pl. /share/programok/docker/config, illetve /share/letoltes/qbit/). Majd deploy. A bejelentkezéshez a webui porton kell belépned, a default jelszó a qbit oldalán megtalálható. -
Gawamatsu
Stealth #4092 üzenetére
USB 3 keretem van nekem is (kettő is) arra megy időnként az offline mentés arról ami fontosnak érzett.
De hiba (lemez) esetén nem az megy be a NAS-ba, az csak visszaállításra van. Hiba esetén egy ugyan olyan méretű lemez ugrik be a R5 tömb hibás lemezének a helyére.
De ez ugye esete válogatja, mert nálad nincs R5, hogy hibatűrő legyen. -
Gawamatsu
Stealth #4090 üzenetére
Az elgondolás ott hobás, hogy az ADM-et nem tudod lementeni.
Egy kis flash drive-on van (részben, nem elérhető) és az összes lemez is tartalmazza. Leginkább a beállításokat tudod exportálni (ezt időzítve heti egyszer megcsináltatom vele).
Ha raid konfig van, akkor a hibás vinyó ki, egy másik be és kezdi is a raid sync-et, a rajta tárolt (hozzáadott lemez) bárminek a törlésével kezdve. -
Gawamatsu
Stealth #4084 üzenetére
Most is négy van és a kapacitás bővítésére vannak kalkulációk
Jelen R5 3x3TB +2TB
Lemezcsere R5 3x8TB adna 16TB-t ~240k HUF-ért, plusz még egy ha gebasz lenne és még valahogy a 16TB mentését is meg kellene oldani8 lemezesben jelen lemezek +4x 3TB R5 adna 18TB-ot 120k HUF (a +4 lemez) és 300k a tár maga (minusz a jelenlegi, ha eladódna, ami mondjuk 50k, ha marad, mehet rsync backupnak.
6 lemezes 355k, 8 lemezes 407k, 10 lemezes 466k -
donat_sz
Na igen, ez erősen felhasználás kérdése
Én 1 lemezesről bővültem 4-re, a 2-t gyorsan átugrottam, nagyon nem bántam meg.
Ha kamerák képét mented rád, há hálózati meghajtónak használod a családi pc-k/laptopok számára, ha média lejátszók számára háttéradat forrásnak, stb.. és sorolható, akkor azért eltérő terhelések várhatóak, ha ezeket optimalizálnád, akkor hamar kevés lesz a 4 lemez.. vagy másik megoldás hogy enterpsrise nagy tárkapacitású hdd-ek használsz és csúcsra járatod a masinát, de ez utóbbi szintén nem olcsó megoldás és kérdés, hogy a hdd-ék élettartalmát, hogyan befolyásolja.
Nekem (is) ezért lenne ideálisabb a gen2-es verzió, mert az SSD-kel tudnék kicsit optimalizálni, de csak ezért nem fogom cserélni, marad a gen1 5304. -
Stealth #4045 üzenetére
Elvileg igen, kell neki upstream mindenképpen (nekem mondjuk ott is az Adguard Family DNS címek vannak megadva), aztán abból szűri meg amit megadsz neki.
Ez router függő, milyen logikával dolgoznak. Ami a lényeg hogy a hálózati kliensek DHCP-n az Adguard ip címét kapják DNS-nek.
Pimpellér
Stealth #4034 üzenetére
Ez a vonat bár elindult, de a következő állomáson megállt és ott vesztegel
Annyit tettem, hogy App Centralból letöltöttem a programot, megnyitottam, belenéztem és feltettem a kérdést.
Ha jól értem el sem tudod indítani a programot ami gáz.
Nem segít, de megemlítem: Linux alatt jött elő nálam nem régen, hogy egy programot telepítettem, de az nem indul. Van ennek oka, de egyelőre ennek sincs időm utánajárni.
Milyen jó lenne, ha ez a tanúsítvány kérdés néhány kattintással megoldódható lenne és a biztonságosnak ítélt https címet zökkenőmentesen használhatnánk.. -
Gawamatsu
Stealth #3908 üzenetére
NEm tom, a Plex lehet még nem készült fel rá.
De inkább az lehetett a baj, hogy az IPv6-ra állítással együtt le lett tiltva a Port Forward és nem is látszott semmilyen módon, míg az IPv4 vissza nem tért.
Az is lehet - nem tudom -, hogy v6-ról nincs v4 felé port forvard. Fogalmam sincs, nem hálózatos IT-s vagyok -
ugyes
Stealth #3878 üzenetére
Alkalmasint: főként akkor, ha biztonsági javításban érintett és Asustor a karbantartó. Nagyok sok appot Patrick és Fathermade készít, amelyek egy jó része csak linixserver.io docker verzióinak apk-sítása (főként Patricknál), utána neked érdemes/kell pl. Portainerben frissítened.
A legtöbbet lecseréltem saját docker megoldásra, mert így a fájlútvonalakat jobban tudom szabályozni (pl. nálam az adat nem a vol1-en van, ezt az App Central-os verziókban nem lehet módosítani).
Az új verzióval még várok 1-2 napot. -
donat_sz
Stealth #3689 üzenetére
hasonló a helyzet nálam is. NAS kábelen a switch mögött, NFS (és tarcsiba van meg csak az SMB) hozzáféréssel az androidos TV-n futó Kodi a lejátszó. nálam megkapta a TV is a kábelt (most éppen egy kábelszakadás okán éppen wifin csatlakozik a tv és többet érzékelem a megakadást, de így se sokat) de így függ attól, hogy az ap mit bír és milyen terhelést kap a többi eszköztől. kábelen 99%-ban megy 4k H264 HDR DoVi is, bár van egy két magas bitrátájú film ami már a 100-as tv csatlakozó határát feszegeti.. egy időben direkt néztem a nas rendszer montiorán, hogy milyen sávszélesség terhelést adott egy-egy ilyen média és hát volt ami feszegette a határokat..
u.i. a jobb hangminőségben nem hiszek én se, ha csak és kizárólag SMB / NFS közti váltás az eltérés.
- Macska topik
- Okos Otthon / Smart Home
- Bluetooth hangszórók
- Több évig húzódó per várhat az Apple-re az iPhone-ok uralma miatt
- Prémium PC házak akár 20-40% kedvezménnyel eladók garanciával, számlával!
- ÁRCSÖKKENTÉS Dell Latitude E6320 notebook eladó
- ÁRGARANCIA!Épített KomPhone i5 10600KF 16/32/64GB RAM RTX 3050 6GB GAMER PC termékbeszámítással
- Bomba ár! Dell Latitude 5590 - i5-8GEN I 8GB I 256SSD I 15,6" FHD I HDMI I CAM I W11 I Gari!
