- Fele annyit ér az iPhone Air, mint amennyibe pár hete került
- Huawei Mate 20 Pro - a mindenit!
- Zsebre vágta a Samsung a hajlítható piacot
- Macrodroid
agy73p
lev258
#56456
fdisk -l
Disk /dev/ram0: 31,3 MiB, 32768000 bytes, 64000 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytesDisk /dev/ram1: 31,3 MiB, 32768000 bytes, 64000 sectors
I/O size (minimum/optimal): 4096 bytes / 4096 bytesDisk /dev/ram2: 31,3 MiB, 32768000 bytes, 64000 sectors
I/O size (minimum/optimal): 4096 bytes / 4096 bytesDisk /dev/ram3: 31,3 MiB, 32768000 bytes, 64000 sectors
I/O size (minimum/optimal): 4096 bytes / 4096 bytesDisk /dev/ram4: 31,3 MiB, 32768000 bytes, 64000 sectors
I/O size (minimum/optimal): 4096 bytes / 4096 bytesDisk /dev/ram5: 31,3 MiB, 32768000 bytes, 64000 sectors
I/O size (minimum/optimal): 4096 bytes / 4096 bytesDisk /dev/ram6: 31,3 MiB, 32768000 bytes, 64000 sectors
I/O size (minimum/optimal): 4096 bytes / 4096 bytesDisk /dev/ram7: 31,3 MiB, 32768000 bytes, 64000 sectors
I/O size (minimum/optimal): 4096 bytes / 4096 bytesDisk /dev/ram8: 31,3 MiB, 32768000 bytes, 64000 sectors
I/O size (minimum/optimal): 4096 bytes / 4096 bytesDisk /dev/ram9: 31,3 MiB, 32768000 bytes, 64000 sectors
I/O size (minimum/optimal): 4096 bytes / 4096 bytesDisk /dev/ram10: 31,3 MiB, 32768000 bytes, 64000 sectors
I/O size (minimum/optimal): 4096 bytes / 4096 bytesDisk /dev/ram11: 31,3 MiB, 32768000 bytes, 64000 sectors
I/O size (minimum/optimal): 4096 bytes / 4096 bytesDisk /dev/ram12: 31,3 MiB, 32768000 bytes, 64000 sectors
I/O size (minimum/optimal): 4096 bytes / 4096 bytesDisk /dev/ram13: 31,3 MiB, 32768000 bytes, 64000 sectors
I/O size (minimum/optimal): 4096 bytes / 4096 bytesDisk /dev/ram14: 31,3 MiB, 32768000 bytes, 64000 sectors
I/O size (minimum/optimal): 4096 bytes / 4096 bytesDisk /dev/ram15: 31,3 MiB, 32768000 bytes, 64000 sectors
I/O size (minimum/optimal): 4096 bytes / 4096 bytesDisk /dev/sda: 111,8 GiB, 120034123776 bytes, 234441648 sectors
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: dos
Disk identifier: 0xdb5de3acEszköz Indítható Start Vége Szektorok Size Id Típus
/dev/sda1 * 2048 31459327 31457280 15G 83 Linux
/dev/sda3 39847936 81790975 41943040 20G 83 Linux
/dev/sda4 31461318 234438655 202977338 96,8G 5 Kiter
/dev/sda5 31461376 39841199 8379824 4G 83 Linux
/dev/sda6 81793024 234438655 152645632 72,8G 7 HPFS/Partition table entries are not in disk order.
sudo: parted: parancs nem található
scream
lev258
#56368
Köszönöm az infót!
Sikerült tegnap a telepítés, meg a drivert is felraktam, viszont utána csináltam egy sudo apt-get update és upgrade-et ami az nVidia DKMS-es (asszem ez volt a neve) entry-jével valamit művelt, mert reboot után csak a login screen volt, bejelentkezés után elsötétült a kép és megint a loginscreen jelent meg.
Utána újra csináltam az egész nvdriver telepítést és az megoldotta.
Viszont van rá valami bevállt mód, hogy ne kelljen minden kernel update után a vga drivert fixálgatni?
Ez az első driver problémám linux alatt.
Flowtation
lev258
#55996
Közben elfelejtettem a dolgot, most ránéztem, a synapticban nem tudok alkalmazni, mert nincs csomag, illetve ha kikeresem ezt:
libdrm-common_2.4.85-5~x~padoka0_all.deb
vagy ezt:
libdrm-amdgpu1:i386 2.4.85-0~x~padoka0nem lehet alkalmazni (inaktív marad a gomb), ha két kattal kiválasztom, akkor ugyanezzel a hibával leáll.
(#56154) berus.berus:
Értem. Simán böngészés közben el tud hasalni?
DeFranco
lev258
#56032
igen, rátaláltam, de ez a problémakör pontosan mit jelent és hogyan oldja fel?
amit linkeltél ott azt írják, hogy ezzel átléphető a pae ellenőrzés, illetve hogy a proci (celeron m350) amúgy tudja a pae-t csak nincs benne flagelve és ezért akad meg. mástól azt az információt kaptam, hogy nem tudja a pae-t vagy lényegtelen hogy tudja-e mert maga a telepítő/live tölt be ilyenkor pae-igénytelen kernelt így nem átugrik az ellenőrzésen, hanem b kernelt választ.
valójában mi történik?
- átlöki az ellenőrzésen (a) és lesz ami lesz, vagy pae-biztos kernelt tölt (b)
- vajon számíthatok-e arra, hogy a proci tudja amit kell a pae szempontjából és (a) esetben sem lesz gond, vagy ettől lehet számítani anomáliákra? -
#58682368
lev258
#56025
Valóban feltettem a Linux Mint topicban is ezt a kérdést. Azért kérdeztem meg itt is, mert az érdekel, hogy a kismillió verzió közül melyikkel járok a legjobban. Abszolút kezdő vagyok a Linux témával kapcsolatban.
Egyébként lényeges lehet még a gépem adatai. Egy régebbi komponensekkel rendelkező konfigról van szó, amellyel a fentebb leírt alacsony gépigényű játékokat szeretném futtatni.
A konfig a következő: Xeon X5460 + 2x2GB 800MHz + GTX 560 Ti
jackal79
lev258
#56007
Szia! Nem veszi el, ez a Linux Mint nagyon tetszik. Win10-et használtam mellette, de meg jött az évfordulős frissítés és onnan nem bootolt be a Win, folyamatosan újraindult. Ez tette fel sz i-re a pontot... Meg a sok crackelés, hogy működjenek az app-ok, mert ha valaki legálisan akarja használni az k..va drága lenne
A Linuxhoz egyenlőre tök láma vagyok, de ha egyszer sikerül normálisan testreszabnom meg a win progikra alternatívát találni, akkor nem lesz gond
Sok kérdésem lesz még az biztos
lajos0001
lev258
#55766
Ne haragudj, én csak egy hozzá nem értő felhasználó vagyok, nem nyomozni akarok portok után, amiról fogalmam sincs, hogy derítem ki, sem hogy egyáltalán hány van, amit meg kellene találnom, nem plusz feladatokat keresek.
Egy egyszerű tűzfalat keresek, hogy megmondhassam, melyik app mehet ki a netre, melyik nem. Nem hiszem el, hogy ez csak agyonkomplikált módon oldható meg Linux alatt. Ennyi. A nem profi ezt vajon hogyan oldja meg? Sehogy? Kienged mindent egy konfigurálatlan gufw-val? -
nOvOp
lev258
#55684
LibreOffice, Darktable, chromium, firefox, keepass. Most hirtelen ezek jutnak eszembe, melyeket használok és vagy tartalmazott a Cinnamont 18.1 vagy a szoftverkezelővel telepítettem. Azért kérdeztem, mert hallotam (vagy olvastam), hogy a szoftverkezelő nem mindig a legfrissebbet tartalmazza és gondoltam, akkor nem is biztos, hogy frissül.
kovaax
lev258
#55677
És @Godvazzeg:
Szóval disztró függő, ha jól tudom, de a biztonsági frissítéseket mindenhol megkapják az adott kiadás*** programjai, és van ahol még újabb verziót is hajlamosak betuszkolni, ha úgy adódik. Szóval mindkettőtöknek igaza is van, meg nem is.
Szerk.: *** aktuális stabilra gondolok itt, de van ahol van LTS, amit több évig támogatnak (Ubuntu), meg a Debian az előző kiadásban is szokta foltozni a hibákat egy darabig (lusta vagyok utánanézni meddig).
ArthurShelby
lev258
#55565
ID 2001:ab00 D-Link Corp.
De ahogy látom, aki ügyesebb annak lecsatlakozik, és utána vált erre: ID 2001:7e35 D-Link Corp.
Ha jól értem ez valami mobil stick tulajdonság, hogy le-fel csatlakozik másképpen (mondjuk az okát nem értem)
Windows alatt is állandóan bimm-bamm-ol a (csatlakozások miatt. -
cyber86
lev258
#55522
Innen a magyar nyelvű változat 64 bites verzióját szedtem le.
Amúgy a felbontás pedíg jó, mert a monitor ennyit tud.Más amúgy melyik linuxot érdemes használnom ha egy HP Proliant microserverre szeretném feltenni és a célja az lenne, hogy belső hálózaton windowsos gépekkel elérjem a meghajtókat, hogy adatokat tudjak rá másolni meg teamspeak server is futna rajta.
ArthurShelby
lev258
#55287
Szerintem inkább az a bja, hogy linux-nál egy idő után előkerül a parancssor, míg windows-nál soha. Ami egy informatikai analfabétánál probléma.
Az embereknek nem a testre szabhatóság kell. Nekik az egyszerű, szimpla, divatos, jól kinéző kell. Ha elég nagy divat lenne az ubuntu biztos sokan váltanának. -
Freel
lev258
#55284
Még annyit ha már felhoztad, hogy én a MESA-t Xubuntu alatt is betettem PPA-ra. Jó döntés? Vagy nem ajánlanád? Az Ubuntus rendszerek alatt nem érdemes frissítgetni a programokat?
Ezt amúgy tényleg nem értem. A qBittorrent például valami 3.3.1-es verzióval jött le a tárolóból és nekem konkrétan el sem indult. PPA-val felfrissítettem 3.3.16-ra és elindult egyből. Vagy a Double Commander 0.7.1-esébe például van olyan hiba, hogy a kurzor színét nem engedi változtatni. PPA-ból lejött a 0.7.8 és megoldódott a probléma... Szóval nem értem, hogy az Ubuntus rendszerekben miért nem frissítik a programokat?
Freel
lev258
#55284
Sok bajom volt az utóbbi időben a Manjaro-val. Eredeti steames játékok nem indultak, programok nem működtek stb... Volt olyan hibaüzenetem amire a googlee nulla találatot talált. Nagyon szerettem a rendszert egyébként. Most Xubuntut használok és úgy gondolom ez az Ubuntu vonal egy kezdőnek sokkal kifizetődőbb. Szinte percek alatt találok megoldást a problémáimra, a rendszer is 'segít' sok mindenben és mostanában elég stabilnak érzem és bugmentesnek. Hozzáteszem a 16.04.3-at használom most teljes megelégedettséggel. Jelenleg csak ajánlani tudom.
Amióta egyébként elsődleges rendszernek használom (Windows nuku) és ezzel (is) rákényszerítem magam a problémák megoldására, azóta rájöttem, hogy nagyon jó rendszer a Linux, hogy bele lehet nyúlni és szinte MINDEN problémára találok megoldást és meg tudom oldani.
Win 10 alatt (pedig megvan egyébként eredetiben) például a HD3000 már nem is működik!!!
Örülök, hogy áttértem a Linuxra és nagyon-nagyon szeretem a rendszert, sokkal jobb használni, mint a windows-t. Tény, hogy elég sok időt kellett ráfordítanom a tanulására. De egy bizonyos holtponton (befektetett időn) átesve már szinte ugyan annyi idő alatt meg lehet oldani egy problémát Linux alatt, mint Windows alatt.
lev258
#54924
Igen, ezen én is agyaltam először, aztán még a 7.3-mal kipróbáltam és ment szépen.
Szerintem a driver megoldja a kernel patch-elését.Mivel az fglrx már nem tölthető ehhez a gpu-hoz, így gondolom az AMD ezt komolyan gondolja.
mod: Most vettem észre, hogy egy minor verzióval sikerült elnézni a dolgot. Valószínűleg pont a megjelenés napján töltöttel le. Nem gondoltam volna, hogy ez gondot okozhat, azért oda sem figyeltem erre.
Így szerintem tárgytalan a dolog, és sorry a fölösleges kérdésért!
Legalább már tudom, hogy legközelebb a kisebb verzió váltásokra is oda kell figyelnem. -
lev258
#54922
Volt már fent ezen a GPU-n és az AMD driver letöltője is ezt dobja, amikor megadom az adatokat.
Arra gyanakszom, hogy várnom kell egy újabb driver verzióra, mert most nézem, hogy sikerült a legújabb (4 napos) 7.4-es CentOS-t letöltenem és feltennem, amit hivatalosan még nem támogat az AMD drivere.
Vagy teszek egy próbát 7.3-mal, csak az meg visszalépés... Kéne egy jósgömb, hogy az AMD mikor reagál egy újabb OS verzióra.
lev258
#54916
Igen, az alapján. Annyi még, hogy eleinte a repo ellenőrző sh file frankón lefutott, most meg azt írja, hogy:
Something went wrong and the install media repository was not set up successfully.
Try running the script with root priviledges.
The required repositories have been set up.
Please run amdgpu-pro-install to install the amdgpu-pro driver.pedig root-ként fut. Nem sudo-val, hanem rendesen root-ként.
Nem tudom, hogy köze van-e az eredeti problémához.
lev258
#54914
Legújabb CentOS-ről van szó, és azért kell a PRO, mert OpenCL fejlesztéssel akarok elkezdeni foglalkozni tanulási céllal.
Nemrég már fent volt egyszer a Centos és a gyári AMD driver, de akkor a DVD install-lal tettem fel a CentOS-t, most meg minimal install után okosítottam fel Cinnamon-ra, hogy ne legyen fent egy csomó felesleges gnome csomag.Az alapján választottam disztrót, hogy az AMD mely disztrókat támogatja a driverrel hivatalosan. Ez az Ubuntu és a CentOS az ingyenesek közül. Akkoriban az Ubuntura valami Xorg verzió frissítés miatt nem ment fel a driver, ezért lett CentOS.
King Unique
lev258
#54809
Használok több verziót is (2010 - 2016, O365), de eddig különösebb problémákat nem tapasztaltam ilyen téren. Sőt, volt hogy egy régi gépen a 2000-es verzión kellett megnyitni X-es doksikat, ami a kompatibilitása csomag felrakása után ment és OK volt. Lehet nálad előfordult ilyen, de attól még általánosan rendszerint az LO és társai esetében szokott emiatt több panasz lenni... De akadnak olyan programok is, mint pl. a WPS fizetős verziója, amelynél egész jó a kompatibilitás.
King Unique
lev258
#54803
Azért azt mondjuk hozzá lehetne tenni, hogy ezeket a kompatibilitási problémákat a gyakorlatban házon belül nem, vagy nem olyan mértékben tapasztalni (már aki), mint amikor a másik programmal (LO) vannak megnyitva a doksik. Használom az előbbi szoftver több verzióját is, de ilyen kisebb / nagyobb "elcsúszásokat" rendszerint akkor tapasztalok, amikor az utóbbival (LO) akarom megnyitni őket. A 2 program és a formátumaik között eddig sem volt tökéletes a kompatibilitás és valószínűleg ezután sem lesz. Aki nem akar ilyenekbe belefutni, az akkor jár a legjobban, ha vagy egyik, vagy másik programot és annak saját formátumát használja.
vmk
lev258
#54632
Oké, kipróbálom, de most egy kicsit akkor részletesebb segítséget kérnék, hogy mi kell tennem
Az imént próbáltam egy 5.4-es verziót letölteni (deb) és telepíteni, de ugyan azt az eredményt kaptam.
Szóval a "Libreoffice fresh ppa" hozzáadása gondolom így:
sudo add-apt-repository ppa:libreoffice/libreoffice-5-4
sudo apt-get update
(Bár ez a már kirpróbált 5.4-es verzióra mutat, de ha azt mondod, hogy van értelme akkor megcsinálom újra)A gnome és gtk telepítése nem tudom pontosan mit takar.
szerk:
#54633: Rendben, köszi. Ezt hogyan tudom megtenni? Hol találom a vsync beállítást?
szerk2:
Gondoltam megnyitom újra megnézem, hogy mi a helyzet. És...működik.
A Calc-ban látszik a cella, a Writerben működik a táblázat.
Na innentől már tényleg nem értem...
Pedig az előbb még egy Ubuntu Live-al is megnéztem és ott is előjött a hiba.Talán az segíthetett, hogy volt pár rendszer frissítés amit telepítettem és pont ezek között volt a problémámra a megoldás??
vmk
lev258
#54621
A drivert nem tudom hogyan tudom megnézni.
lspci | grep VGA
00:02.0 VGA compatible controller: Intel Corporation 82946GZ/GL Integrated Graphics Controller (rev 02)szerk: Hacsak nem:
lshw -c video
WARNING: you should run this program as super-user.
*-display
description: VGA compatible controller
product: 82946GZ/GL Integrated Graphics Controller
vendor: Intel Corporation
physical id: 2
bus info: pci@0000:00:02.0
version: 02
width: 64 bits
clock: 33MHz
capabilities: vga_controller bus_master cap_list rom
configuration: driver=i915 latency=0
resources: irq:27 memory:d0000000-d00fffff memory:c0000000-cfffffff ioport:18c0(size=8) memory:c0000-dffff -
King Unique
lev258
#54402
Normál esetben rendszerint AHCI szokott lenni az alap beállítás, ami nyilván OK mindkét rendszernél és eleve azzal számol az ember. Bár a kérdező is említhette volna az UEFI menüjében a pontos beállításokat, de mindegy. Viszont az is igaz, hogy ott a kereső, ami nálad eredményes volt.
(#54400) ROBOTER:
Az egyik megoldás tehát az AHCI mód beállítása, ha már a Linux, vagy legalábbis Mint a másikat nem támogatja. Meg, ha nem akarsz a kettő között állandóan váltani a 2 rendszer indításakor. Viszont az ilyen átállítás belezavarhat a Windows működésébe és akár reinstallra is szükség lehet. Az lenne egyébként ezen belül az egyik opció, de az a korábbi válaszok alapján gondolom kizárva. Másik opció az utólagos kozmetikázás, amire elvileg szintén vannak megoldások: [link], [link]. -
lev258
#54372
Huh... azér megnyugodtam, hogy nem kavarodtam el.
Azt viszont nem értem, miért kellene ragaszkodni a régi Grub-hoz. Másrészt akkor már a telepítésnél ki kell "erőszakolni" ezt valahogy.
Hát én ilyen őskövület vagyok, szeretem a fapados/egyszerű dolgokat.
Amikor megérkezett az új grub valamelyik disztribúcióval, akkor csak lestem mint a luki nyúl, nem értettem, hogy miért nem tudom indítgatni saját szájíz szerint a különböző partíciókról a linuxokat, meg módosítani a menu.lst-t... aztán visszaraktam a régi grub1-et, és megkönnyebbültem. Mivel csak júzer vagyok, néhány dolgot meg tudok oldani, de a grub2 megértése a torkomon akadt. Szimplán ennyi. Esetleg még az időhiányt tudnám felemlegetni, de az már kifogás lenne.
Hétvégén qrva meleg lesz, nem nagyon akarok majd kimenni a hűvös házból, és akkor majd nekilátok.Másrészt akkor már a telepítésnél ki kell "erőszakolni" ezt valahogy
Elméletileg nem, legalábbis régebben simán telepítettem a grub2, amivel jött a distr., majd csináltam egy komplett frissítést, hogy minél inkább aktuális legyen, és utána raktam fel a grub1-et. A menu.lst-t meg régről lementettem, így csak be kell másolni a megfelelő helyre, és átírni olyanra, amilyenre akarom.Más:
Ha jól néztem, akkor mindkét LTS-ben a supertuxkart 9.x van.
Ez fontos azért , mert kölkeim nagyon szeretik. -
lev258
#54370
Az az érzésem, hogy a legacy-UEFI, valamint a Grub1-Grub2 fogalmak keverednek.
Remélem nem.
Vélhetően a régi grub a grub1, amit a synaptic-ban legacy grub-ként találok meg (10.04 esetén valami 0.9x verzióval), a grub2 a mostanság használatos grub.
Ami az uefi-t illeti, azt sem tudom mi az, nem hogy legacy-uefi
, így vélhetően nem keverem össze semmivel. Ha igen, akkor úgyis kijavítasz. -
Skullwipe
lev258
#54103
Azt nem akartam, viszont ez a pepper nagyon tetszik, kis gépigény, elég gyorsnak tűnik, a szoftver része is van olyan jó mint a mintnél, ahogy így elsőr mint szűrésként pár programra rákerestem, plusz alapból jó a sötét témája, nagyon meggyőzött. És nincs eddig semmi probléma, most óvatosabb leszek, sokkal kevesebb dolgot fogok babrálni.
vmk
lev258
#53956
Az első linken leírt paraméterezve indítás nem hozott eredményt.
A második linkről a
sudo apt-get install xcbnem működött.E: A dpkg megszakadt, saját kezűleg kell futtatnia a(z) „sudo dpkg --configure -a” parancsot a probléma megoldásához.A libqt5gui5 feltelepítettem, de nem javult meg a Viber.
Sőt... most már se előre, se hátra. Nem tudom törölni sem:
E: A(z) viber csomagot újra kell telepíteni, de nem található hozzá archívum.
E: Belső hiba a gyorsítótár megnyitása közben (1). Kérem jelentse.(#53960) ubyegon2:
endre@endre-linux:~$ ~ $ /opt/viber/Viber
bash: /home/endre: Ez egy könyvtárEzt dobta mindkettőre.
cigam
Milyen program ami... [link]
- Teszt [Linux] A Flatpak
- BLACK FRIDAY! - Jogtiszta Windows - Office & Vírusirtó licencek- Azonnal - Számlával - Garanciával
- MS SQL Server 2016, 2017, 2019
- Xiaomi Redmi 14C 128GB, Kártyafüggetlen, 1 Év Garanciával
- HIBÁTLAN iPhone 15 Pro 128GB Black Titanium -1 ÉV GARANCIA -Kártyafüggetlen, 100% Akkumulátor
- BESZÁMÍTÁS! MSI B450 R7 5700X 32GB DDR4 512GB SSD RTX 3080 10GB Zalman Z1 Plus Cooler Master 750W
- LG 55QNED86T3A / QNED / 55" - 139 cm / 4K UHD / 120Hz / HDR Dolby Vision / FreeSync Premium / VRR
- Bomba ár! HP ProBook 450 G7 - i5-10GEN I 8GB I 256SSD I HDMI I 15,6" FHD I Cam I W11 I Gar
Cég: BroadBit Hungary Kft.
Város: Budakeszi
Cég: ATW Internet Kft.
CPT.Pirk
