- LTE frekvenciák
Az előzmények:
(rögzített hozzászólás)
Figyelem!
nyunyu
Egyedül a minimapLines.xc-ben kellene varázsolnom hogy csak a löveg irányát lássam (erre rájöttem hogy a "dot" mező de hogy miként tudnám folyamatos vonallá tenni a jelenlegi pontokat még nem tudom.
Nalam szaggatott-pontozott vonal a loveg iranya valami osregi konfigbol:
"lines": { // Only for owned vehicle.
// Works only with xvm-stat.exe
"enabled": true,
// "inmeters": true - make line size to be in real map meters.
// "inmeters": false - make line size to be in minimap interface clip points. Minimap interface clip side is 210 points.
// Distance between farthest corners at 1km map is somewhat more than 1400 meters.
// Sections can contain any number of lines.
// To set a point try setting line with length of one and large thickness.// You can leave one line for simplicity. Remember comma positioning rules.
"vehicle": [ // Own vehicle direction.
{ "enabled": true, "from": 50, "to": 95, "inmeters": true, "thickness": 1.5, "alpha": 55, "color": "0x60FF00"},
{ "enabled": true, "from": 100, "to": 145, "inmeters": true, "thickness": 1.4, "alpha": 50, "color": "0x60FF00"},
{ "enabled": true, "from": 150, "to": 196, "inmeters": true, "thickness": 1.3, "alpha": 45, "color": "0x60FF00"},
{ "enabled": true, "from": 200, "to": 246, "inmeters": true, "thickness": 1.2, "alpha": 43, "color": "0x60FF00"},
{ "enabled": true, "from": 250, "to": 296, "inmeters": true, "thickness": 1.1, "alpha": 40, "color": "0x60FF00"},
{ "enabled": true, "from": 300, "to": 397, "inmeters": true, "thickness": 1, "alpha": 40, "color": "0x60FF00"},
{ "enabled": true, "from": 400, "to": 497, "inmeters": true, "thickness": 0.9, "alpha": 40, "color": "0x60FF00"},
{ "enabled": true, "from": 500, "to": 2000,"inmeters": true, "thickness": 0.75, "alpha": 40, "color": "0x60FF00"}
"camera": [ // Camera direction.
{ "enabled": true, "from": 50, "to": 80, "inmeters": true, "thickness": 1.3, "alpha": 55, "color": "0xFFCC66"},
{ "enabled": true, "from": 120, "to": 180, "inmeters": true, "thickness": 1.2, "alpha": 50, "color": "0xFFCC66"},
{ "enabled": true, "from": 220, "to": 280, "inmeters": true, "thickness": 1.1, "alpha": 45, "color": "0xFFCC66"},
{ "enabled": true, "from": 320, "to": 380, "inmeters": true, "thickness": 1, "alpha": 40, "color": "0xFFCC66"},
{ "enabled": true, "from": 420, "to": 480, "inmeters": true, "thickness": 0.9, "alpha": 40, "color": "0xFFCC66"},
{ "enabled": true, "from": 520, "to": 580, "inmeters": true, "thickness": 0.8, "alpha": 40, "color": "0xFFCC66"},
{ "enabled": true, "from": 620, "to": 680, "inmeters": true, "thickness": 0.75, "alpha": 40, "color": "0xFFCC66"},
{ "enabled": true, "from": 720, "to": 780, "inmeters": true, "thickness": 0.75, "alpha": 40, "color": "0xFFCC66"},
{ "enabled": true, "from": 820, "to": 880, "inmeters": true, "thickness": 0.75, "alpha": 40, "color": "0xFFCC66"},
{ "enabled": true, "from": 920, "to": 980, "inmeters": true, "thickness": 0.75, "alpha": 40, "color": "0xFFCC66"},
{ "enabled": true, "from": 1020,"to": 1080, "inmeters": true, "thickness": 0.75, "alpha": 40, "color": "0xFFCC66"},
{ "enabled": true, "from": 1120,"to": 1180, "inmeters": true, "thickness": 0.75, "alpha": 40, "color": "0xFFCC66"},
{ "enabled": true, "from": 1220,"to": 1280, "inmeters": true, "thickness": 0.75, "alpha": 40, "color": "0xFFCC66"},
{ "enabled": true, "from": 1320,"to": 1380, "inmeters": true, "thickness": 0.75, "alpha": 40, "color": "0xFFCC66"},
{ "enabled": true, "from": 1420,"to": 1480, "inmeters": true, "thickness": 0.75, "alpha": 40, "color": "0xFFCC66"},
{ "enabled": true, "from": 1520,"to": 1580, "inmeters": true, "thickness": 0.75, "alpha": 40, "color": "0xFFCC66"},
{ "enabled": true, "from": 1620,"to": 1680, "inmeters": true, "thickness": 0.75, "alpha": 40, "color": "0xFFCC66"},
{ "enabled": true, "from": 1720,"to": 1780, "inmeters": true, "thickness": 0.75, "alpha": 40, "color": "0xFFCC66"},
{ "enabled": true, "from": 1820,"to": 1880, "inmeters": true, "thickness": 0.75, "alpha": 40, "color": "0xFFCC66"},
{ "enabled": true, "from": 1920,"to": 2000, "inmeters": true, "thickness": 0.75, "alpha": 40, "color": "0xFFCC66"},
{ "enabled": true, "from": 99, "to": 100, "inmeters": true, "thickness": 2.2, "alpha": 55, "color": "0xFFCC66"},
// Dots
{ "enabled": true, "from": 199, "to": 200, "inmeters": true, "thickness": 2.1, "alpha": 50, "color": "0xFFCC66"},
{ "enabled": true, "from": 299, "to": 300, "inmeters": true, "thickness": 2, "alpha": 45, "color": "0xFFCC66"},
{ "enabled": true, "from": 399, "to": 400, "inmeters": true, "thickness": 1.9, "alpha": 40, "color": "0xFFCC66"},
{ "enabled": true, "from": 499, "to": 500, "inmeters": true, "thickness": 1.8, "alpha": 40, "color": "0xFFCC66"},
{ "enabled": true, "from": 599, "to": 600, "inmeters": true, "thickness": 1.7, "alpha": 40, "color": "0xFFCC66"},
{ "enabled": true, "from": 699, "to": 700, "inmeters": true, "thickness": 1.6, "alpha": 40, "color": "0xFFCC66"},
{ "enabled": true, "from": 799, "to": 800, "inmeters": true, "thickness": 1.6, "alpha": 40, "color": "0xFFCC66"},
{ "enabled": true, "from": 899, "to": 900, "inmeters": true, "thickness": 1.6, "alpha": 40, "color": "0xFFCC66"},
{ "enabled": true, "from": 999, "to": 1000, "inmeters": true, "thickness": 1.6, "alpha": 40, "color": "0xFFCC66"},
{ "enabled": true, "from": 1099,"to": 1100, "inmeters": true, "thickness": 1.6, "alpha": 40, "color": "0xFFCC66"},
{ "enabled": true, "from": 1199,"to": 1200, "inmeters": true, "thickness": 1.6, "alpha": 40, "color": "0xFFCC66"},
{ "enabled": true, "from": 1299,"to": 1300, "inmeters": true, "thickness": 1.6, "alpha": 40, "color": "0xFFCC66"},
{ "enabled": true, "from": 1399,"to": 1400, "inmeters": true, "thickness": 1.6, "alpha": 40, "color": "0xFFCC66"},
{ "enabled": true, "from": 1499,"to": 1500, "inmeters": true, "thickness": 1.6, "alpha": 40, "color": "0xFFCC66"}
],Marha egyszeru lenne atirni tomor vonalra, csak az elso bekezdest kell meghagyni, es abban atirni a vonal vegpontjat.
"enabled": true,
{ "enabled": true, "from": 50, "to": 2000, "inmeters": true, "thickness": 1.5, "alpha": 55, "color": "0x60FF00"}
{ "enabled": true, "from": 50, "to": 1500, "inmeters": true, "thickness": 1.3, "alpha": 55, "color": "0xFFCC66"}
nyunyu
Alapbol mindet menti, vagy csak nekem volt ugy beallitva?
Egyebkent meg van olyan is, hogy Replay Manager, akkor vissza tudod nezni a jatekban a korabbi napokon mentett meccsek vegeredmenyet is. (felteve, ha a replay megvan.)
jr1994
Kiválasztod hogy kredites ledobás (hacsak nem szánsz rá goldot), mielőtt leokézod látod hogy hány % marad a művelet után, de szerintem csak akkor csináld meg ha a parancsnoknak megmarad utána a BIA és a lámpa 100%-on, szóval ahhoz még menned kell párat. A biztonságos elhelyezést is tedd rá a töltőre másodiknak BIA után, a javítást meg 3-nak.
McCsaplak
Azért 2016-ban feature-ként berakták a hang kikapcs funkciót. Hmm, ez azért nem semmi.
Olyat nem akarnak betenni, hogy video off? És csak hangok lennének. Az 100%-os performance növekedés lenne, vagy mégtöbb. Tehát még mindíg egymagvas p4-ekre fejlesztenek, miközben egy C2Duo-s gépet már akár 15-20k-ért hozzád vágnak... -
lacibacsi
Csak pár tipp:
Ha Tier6:
A T-34-ből gondolom hamarosan meg lesz a T-34-85. Mivel a T-34-gyel jól megy a játék, szerintem kedvelni fogod a nagytesót is. Nekem is örök megtartós... USA vonalon a Sherman Jumbo áll a garázsomban. Megtartottam, mert jó az egyes küldetésekhez, meg amúgy is elég jó (főleg a saját tier-jében)Tier7-8-ban:
USA T20, illetve Pershing. T20-am van. Amíg nem fullos és főleg a legénység nem 100%-os, addig szenvedős, de kifullozva egészen jól használható. Pershing-et teszten próbáltam, már nagyon várom, hogy meg legyen.
Szovjet T-43-on túl vagyok, felejtős, T-44-et húzom, ami néha szenvedős, néha "kúúl", de túl kell lenni rajta, mert a T-54 már egészen jól muzsikál a kezem alatt a teszten (bár az már T9...). -
Mister_X
Nyilván azt, amire kíváncsi vagy. Én a kínai med ágat próbálgatom, mert még csak T-34-1-nél járok.
Nyolcasokkal kihívás játszani, de legalább megtudod, hogy milyen a f@*z rossz végén állni, mert mindenki 10-esekkel nyomul (eddigi meccseim alapján többségében 10-13 T10 tank, 2-3 T8/9 akármi és egy T7 LT).
kchryss
A teszt szervereket sokszor bütykölik, mert több mindent kipróbálnak a fejlesztők is és szakaszosan kerülnek bele az újabb dolgok. Ilyenkor szoktak kiadni egy changelogot hogy mik változtak aztán elérhető megint. Szóval nem kell aggódni biztos elérhető lesz még a teszt szerver hetekig.
lacibacsi
Ejnye-bejnye Zodo! Tisztán emlékszem rád, amikor először idejöttél a fórumra és olyan kérdésekkel bombáztad az ittlakókat, amelyek ismerete elemi követelmény lett volna egy 100 csatás parancsnoknak is, most meg már pedózni jársz TV-be?!?!?
Hát micsoda dolog ez? Ezért tanítottak téged, hogy megtanulj játszani? .... Ezért hát! Szép kör! Gratula!
Ja, és külön elismerés ahhoz, hogy van lekierőd ehhez a tankhoz. Akármennyira is OP a saját tierjében, egyszerűen nem tudtam megszokni a vég"sebesség"ét és eladtam. Ilyen köröket nézve többször elgondolkodom, hogy jól tettem-e...
(#109450) emre: Néha megesik, hogy ismeretlen csapattársakkal is jól megérti magát az ember. Ilyenkor szoktam artyban ülve pingelni a fókuszom az értelmesebb lightoknak, vagy medeknek, jelezve a töltési állapotot is. Néha meglepő módon jól össze lehet dolgozni. Rosszabbik eset az, amikor dőlő fákra, házakra pingelek és írom a csetbe, hogy rombolást látok, a jónép meg szépen irányt vált és húz onnan a csába...
zodo
jano_77
Jó lesz amit javasolnak, az a hármas: Venti, Töltésgyorsító és Vert.stabi!
(#108923) h1mpi: sajnos ez így van, mármint, hogy a sok auto aim sokszor saját kárunkra van csak. Ezt sajnos magamon is észre vettem az utóbbi időben, hogy túl sokat nyomok a jobb klikkre és bízom rá magam.
nyunyu
Kepezni csak olyan tankra lehet, ami mar ki van fejlesztve vagy premium.
Nem kell, hogy a garazsban alljon. (E100 2 eve ki van fejlesztve, de sosem vettem meg.)VK4502B7 az valami prem akar lenni?
Maus vonalnak neki sem alltam, Tig P/4502A/B sincs kifejlesztve.Mindenesetre JP utan a JP2 kvazi azonnal jatszhato, kevesebbet kell vele stock allapotban szopni, mint a motorok nelkul nagyon lomha Ferdivel.
Valoszinuleg hamarabb ossze lehet vele szedni a 128mm-t.Esetleg, ha megtartottad a Stugot kreditet farmolni, annak a toltojet is at tudod tenni kesobb a JT-be, ha nem akarsz a Ferdi fele "kerulni", T5-ben egyszerubb egy uj legenyt potolni, mint T8-9-ben.
Masik opcio az, hogy JP2-on kihuzod a loveget, utana atteszed a nepet+1 uj toltot a Ferdibe, aztan akkor azon csak a motorokat (12+31k XP) kell huzni a JT (150k) elott, ezalatt a legenyek tudnak rendesen fejlodni.
Chris0321
Csak akkor tudsz egy tankra legénységet képezni ha már kifejlesztetted, ez alól csak a prémium tankok a kivételek. Nekem már megvolt az Aladár mikor megvettem a Ferdit így a motorokkal nem nagyon kellett foglalkoznom, de ha nem lettek volna meg akkor is a Ferdit választom. Egy plusz töltőt a JT-be nehezebb lett volna összehozni, vagy nagyon le lett volna maradva, míg ha free xp-ből kifejleszted a középső motort az jóval könnyebben megvan. A 128-as lövegig még így is elég rossz volt vele a statom, de amint meglett ugrásszerűen elkezdett javulni és az xp is gyorsabban gyűlt, így a top motort már könnyen kifejleszthettem volna.
nyunyu
Kerits valahonnan egy masodik toltot, mert a JT-be, JgE100-ba mindenkeppen kelleni fog, es ne ott akarj szopni egy ujonccal.
JP2-nek ugyanaz a legenysege, mint a JP-nek, csak egy toltoje van.
Ferdinek 2 toltoje van, igy egy az egyben atteheto utana a JT-be.Eredetileg JP2-vel toltam sokat, pont a JP legenyseg miatt, azon fejlesztettem ki a JT-t, aztan valtottam csak Ferdire egy Stug III tolto bealdozasaval. (azon is megvolt mar a BIA)
Most mar jobban szeretem a Ferdit, mivel jobb a gun depressionje, es szelesebben forgathato balra-jobbra az agyuja, igy kevesebbet kell vele forgolodni/mozogni kempeles kozben, nem esik le olyan sokszor a camo.
Masreszt az alacsonyabb sebessege miatt nincs meg az a veszely, hogy a frontra menet o er oda elobb, nem a heavyk, igy nem nyirjak ki a meccs elejen, mint az eszetlen JP2-ket.
Vagy ha megis, akkor a vastagabb pancelja miatt sokkal tobbet pattint, mint a JP2, ami csak a frontjanak a dolesszogere tud epiteni, a vastagsagara nem. Esetleg a gun mantletjere.Mondjuk akkor van szivas, ha kettesben marad egy ellen lighttal, mivel az szo szerint korberohogi, mig a JP2 kepes leforogni+leloni a korulotte korozo keselyuket.
Grind amugy mindket TDvel nehez, amig nincs meg a nagy agyu, mivel a JP-rol hozott 88 L/71 vagy 105 L/52 200 koruli penje mar nem szereti a T9+ tankokat.
Raadasul a 105mm-be draga a loszer, ezresbe kerul minden lepattano/melle, igy hamar minuszos lesz minden meccs. 88-assal viszont nem lehet komolyan venni oket
128mm-be viszont fajlagosan olcso a loszer, mivel 300 helyett 490-es puszikat osztogat alig dragabban.Ja, plusz szivas faktor a Ferdivel, hogy o a Tig P/Aladar/Bela vonallal kompatibilis motorokat hasznal, nem a Tiger/Pantherekkel, igy stock allapotban nem fog gyorsabban hasitani, mint az amerikai T28-ak, vagy a brit bunkerek. -> fokozott arty veszely.
JP2 ugye orokli a JP motorjait, vagyis kezdettol fogva (tul) gyors, azon valoszinuleg egyszerubb a nagy agyura koncentralni.
Chris0321
Én a Ferdi felől mentem, a JP II ki van fejlesztve de nem vettem még meg, sokkal rosszabb a lövegkitéríthetősége mint a Ferdinek. Arról az apróságról nem is beszélve, hogy ha mindenképp meg akarod venni a JT-t akkor nem egyszerűbb 8-as szinten keresni egy töltőt, akár goldért 100%-osra kifejleszteni mint majd a JT-n 9-es tierben?
Szasinka
Nem bántásként írtam egyáltalán. 1-1,5 hónapból lehet tendenciára következtetni de annyira sok változós a dolog, hogy bármi előfordulhat, sőt az ellenkezője is
Sztem amíg az embert szórakoztatja a játék addig elérte a célját, persze mindenki jobb szeret nyerni de 100% nem nagyon lehet ugye. -
jano_77
Hogy lehet az EFF ennyire jó, miközben a wn8 az csak átlagos?
(#108165) kgergely23: ez már csak így van, mióta a küldetések elindultak! Nekem hevay-vel 2 egy szinttel nagyobbat kellene ölnöm és rendszerint top tanknak tesz be WZ-111 1-4 és FCM 50t-el is! LT-el 3 tankot kellene felderítenem, hogy a saját csapat megsemmisítse. Ezt a pofon egyszerűnek tűnő feladatot nem tudom teljesíteni, mert olyan impotens csapatokat kapok, hogy hiába spottoltam a minap is 8-9 tankot és egyetlen lövést sikerült bevinni a drága csapatomnak. Ok ez a része csak részben "machinált", mert az több mint fura, hogy mindig a balfék csapatba kerülök. Ellenfélnél kékek és sötét zöld játékosok, nálunk narancsok és citromok egy-két zölddel. Sokszor lila szakasz vagy szakaszok az ellenfélnél, nálunk ezzel szemben max zöld szakasz!?!?
(#108166) nyunyu: tegnap előtt volt egy csatám, ahol nálunk egy Skoda T-25 maradt, ellenfélnél pedig egy IS-6! Az IS6 úgy lőtte a medünket, hogy szerencsétlen azt sem tudta, honnan jön az áldás! Lövés után fel kellett volna spottolódnia elvileg vagy olyan távolban lenni, hogy egy medet szerintem nem szabadott volna egy HT-nek látnia!? Többet is bele lőtt a Skodába spottolódás nélkül! Végül döntetlen lett, mert a balfék Skoda nem szaladt el foglalni 2,3 percnél - mondván túl késő, mert nem indult el mikor jeleztük, hanem megvárta az 1 percet. Akkor már tényleg késő volt.
(#108173) kchryss: köszi, azért nem dobnám el érte sem a javító csomagot, sem az EÜ ládát, sem pedig a poroltót. Jól jöhet bármelyik, jobban mint az olaj.
rlazol
ne akarj két csatából következtetést levonni.
nincs mindenek felett álló szabály arra nézve, h ha jók az egyéni statjaid, jó lesz a WR-ed is, de azért van összefüggés.
Ha következetesen le tudod sebzeni a HP-d, és top tierként annál is többet, akkor már pozitívan befolyásolod a csatát, ergó jobb az esély a győzelemre.
De Diegho 3500+s WN8a mellett is "csak" 62,5%-s a WR, vagyis ha megszakadsz is vesztesz majd' 40%-ot!
És még neki is vannak hosszabb-rövidebb vereségsorozatai. Vsz nem 20 csata egymás után, mert annál erősebb befolyással bír, de 4-5 vereség egymás után neki se újdonság.röviden: ha jó az egyéni statod, előbb-utóbb javulni fog a WR is, de vesztes csaták és rossz sorozatok mindig lesznek, nemhogy 2, de sokkal több is!
Stauffenberg
Nálam nem mindig áll vissza a csata indulásáig a normális fps.
Megvettem az AMX CDC-t délután (tényleg állat, csak mintha most meg én lennék mindenki legkedvencebb célpontja) és az első csatának a bő 70%-át 15 fps-el játszottam le.
Nem tudom az XVM-ben mi a bánat terhel ennyire.
Nincs más mod a térképre és a bevitt sebzések (spot?) kijelzésére? Nekem még sok is, amit az XVM alapból tud, mert csak ez a kettő ami jól jön.
h1mpi
Nem szeretem vissza adni, de ez nekem nagyon nem jött be, sokkal jobb a löveg a simán, mint ezen a prémen. Azért meg nem szenvedek vele.
Más: Akinek megvan a T-25 az nyugtasson meg, hogy nincs ennyit tier8-ban ,mint ma. Eddig 5/4 tier8... Ilyen IS6-ot kellene belőnöm, mert a med vonalon jön a barom
mod: 6/5
rlazol: nem pénzben, vissza megy paypalra a 11 Eur
nyunyu
Azt hiszem akkor valami ilyesmi taktika kell majd nekem a stug kampány lt 12-es küldihez.
Ennyire bonyolult lenne 500 assistot osszehozni, hogy ne spotoljanak kozben?
Aszondja, hogy palyahoz illo festes+alcahalo kell a masodlagoshoz.
Akkor ezt valoszinuleg a Chaffeeval csinalhattam meg, mivel egyedul azon hasznaltam eddig festest, tobbin nem.
De az is lehet, hogy meg a T71-gyel volt tavaly(elott?)Kedvcsinalonak itt a mult heti Stug LT15 korom, boven meglett volna az LT12 masodlagos is, ha lett volna festes a tankon.
Kb. masfel percnel villant eloszor a 6th sense, de akkor mar ~600 sebzesnel es ki tudja mennyi spotnal jartam.
Jut eszembe, LT15 miatt tettem csak halot a tankra, passziv spotra akartam gyurni, de csak nem birtam ki. -
nyunyu
Ha csak a prem FV4202 miatt akarnal nekiallni a Centurion vonalnak, akkor mar elkestel, elvileg januar 19-ig a garazsban kellene lennie az AXnek a kuldihez.
20 nap alatt meg premmel sem tudsz osszeszedni ~800k XPt, legalabbis nekem kb. 6-7k XP/ora volt az atlagom a mar nem stock Cent 7/1-gyel a multkori ingyen 3 nap prem alatt.
Te viszont meg nem sok meddel mentel korabban, igy annyi tapasztalatod sincs, hogy honnan mivel mit lehet loni.
nyunyu
Nyilvan jatekstilus kerdese, hogy ki melyik medet preferalja.
2 eve ev vegi learazaskor megvettem az E50, Leo PTA, Patton kombot, aztan sokaig porosodtak a garazsomban legenyseg nelkul (Patton azota se latott legenyeket!)
Aztan egyszer megkerdeztem itt, hogy melyiket erdemes hasznalni, legtobb velemeny az E50 mellett szolt, igy annak alltam neki, par honapja nagy nehezen meglett ra a nagy agyu is, addig eleg nagy szenvedes volt a tuzero hianya miatt.
Azota mintha kicsereltek volna, viszont a 220 pen miatt meg kell nezni nagyon, mire hogyan losz, sokat kell flankelni vele, hogy ne szembol kelljen loni a nagyobb heavyket, mert azok vissza is tudnak loni, es nekik nem okoz gondot a te pancelod...Alap lanctalppal vagy a Panther II 88 L/71-e, vagy a rammer fer csak fel, ketto egyutt NEM!
75 L/100+rammer komboval meg eleg rohejes BT9-11-ben "szaladgalni". (Mondjuk nekem a 8.8 patch elottrol megvolt az E50 nagy motorja, de anelkul tenyleg lassu.)Aztan Leo PTAba kerultek a StugIV kuldetesekre kapott csajok, elkezdtem azt is szorzozgatni, mostanra meglett a lanctalp, meg 30k XP, amit most vertem el a nagyobb toronyra. (eredetileg a nagy csuzlit akartam elobb fejleszteni.)
Ezt a tankot nagyon nem erzem, annyira papir, mar attol lesantul, ha ranez egy kettovel kisebb tank.Viszont a stock csuzli itt 212 pen, nem sokkal rosszabb, mint az E50 nagy agyuja, igy nem annyira nyogvenyelos az XP grind vele, mint az E50-nel.
Elvileg a gun depje jobb, mint az E50-nek, igy dombos palyakon jobban lehet vele bohockodni, viszont a tornya meg a Leo 1-nek is tul puha, rohogve atloheto...
Aztan ~2 honapja nekialltam az FV4202 agnak, amikor megint belengettek, hogy a nyolcas prem medde butitott valtozata azoknak lesz elerheto, akiknek megvan az ot valto Centurion AX.
Ugyhogy esznelkuli grind kezdodott, joreszt csak a brit medekkel mentem, tobbit legtobbszor le se szorzoztam.Viszont azt kell mondanom, hogy az en jatekstilusomhoz inkabb a Cent 7/1 passzol, nem a nemet medek.
Dombos palyakon regen az amerikai heavyket, TDket szerettem a jobb csolehajlas, es a nehezen loheto torony miatt.
Mar a Cent I sem all rosszul ezen a teren, de a 7/1 kifejezetten jobban teljesit, mint a Pershing, de ahogy irtatok a Patton tornya is puha. (azert nem foglalkoztam eddig azzal)Sebesseg hianya meg annyira nem zavar, igy nem erek tul koran sehova sem, hogy aztan engem lojenek romma eloszor.
Nagy csuzli 268 penje, meg 0.32 pontossaga gyakorlatilag barmit visz szembol, talan csak a Mausra nem mernek vele raloni, egyeduli bajom vele a karcsu ujratoltesi ido, de azt fedezekkel ellatott terepen konnyu orvosolni, inkabb csak akkor van a problema, ha tul nagy onbizalommal tamadsz meg valami gagyinak tuno tankot. (T49 konkretan elobb vag beled ketszer 900-at HEvel, mint Te beleje 3x390-et)
Mint kiderult, a Leo PTA nagy csuzlija a nagy toronnyal gyorsabban lo, penje, alphaja meg ugyanannyi, viszont annal meg mindig problema a tul puha torony, nem erdemes feled nezo tankkal kotekedni.
nyunyu
Cromwell utáni tankokra mint Comet és Centurion trióra érdemes időt áldozni?
Cometnek az a baja, hogy kevesbe mozgekony, mint a Cromwell, es csak +3 pennel nagyobb az agyuja, viszont eggyel nagyobb tankok jonnek neki szembe.
BT9-ben max kamikaze scoutnak jo, aztan rogton mehetsz szorzozni egy masik tankot.Stock Cent I eleg nagy szivas lesz azzal a meggymag kopkodovel, megvaltas lesz utana a 20 pounder.
Azzal kelloen gyorsan es nagyot lo, 226 penje is eleg a legtobb tankhoz.Cent 7/1 nagy csuzlija viszont brutalis, felteve ha ki birod varni a 10.35 masodpercet ket loves kozott.
Egyeduli problemajuk a 40-re limitalt vegsebesseg, sik terepen is alig tudod megelozni vele a heavyket.Mondjuk en a motorjaikkal nem foglalkoztam, meg mindig a stock 650 loeros van a 7/1-en.
Cent I nagyobbik, 700 pacis motorja nem hinnem, hogy sokat javitana rajta, 950 loeros meg tul sok XPnek tunik, majd valamikor sokara meglesz az is, de elobb az AXet akarom beguritani a garazsba, aztan jonnek csak a motorok.Sajna még a Cromwell-el sem barátkoztam össze és a legénység is csak ma lett 100%-os.
Nekik ha jól gondolom mindenképp lámpa és mindenki másnak javítást válasszak?Ajaj, eleg szivas volt a Comet, meg plane a Cent I lampa nelkul, kb. a 7/1-hez szukseges XP mennyiseg felenel lett meg a lampa.
En is a Cromwellnel kezdtem egy uj legenyseget, de a Cromwellre, Cometre innen-onnan megvolt par motor, meg radio, sot asszem a Churchillek csuzlija is passzolt.Ha meg nem volt masik brit tankod, akkor viszont mire a Cromwellen, Cometen kifejlesztesz mindent, addigra kb. meglesz a lampa.
kchryss
kchryss
Szerintem ne siess velük. Mindegyik gyengébb a saját tierjében, mint a Cromwell ráadásul 7-es szinttől ha nem játszol jól már lesznek kredit gondjaid. Előbb tanuld ki a Cromwellt, fejlődj, aztán menj tovább.
(#107422) @CirrMee:
2014-es cikk alapján igen: "A fejlesztési fája nagyon barátságos, az alap lánctalp minden fejlesztett modult és felszerelést elbír. 1: BL-9 löveg felszerelhető az alap toronyra, 2: fejlesztett torony, 3: motor, 4: lánctalp" -
rlazol
Ugyanolyan felszerelés, mint a töltésgyorsító vagy a csigaszem. Fejlesztett csavaralátét, hosszanti torziós rugók, erősített függőleges tekercsrugók, erősített laprugók meg ilyesmi neveken futnak. egyik tanknak az kell másiknak amaz. A lényeg, h ha nem bírja el a stock felfüggesztés a fejlesztett tornyot/ágyút, akkor ráteszed ezt az egyik felszerelés helyre és máris elbírja.
Tanktól függ, mennyit bír, van, h pl az ágyút elbírja, de a rádiót/motort/másik felszerelést plusszba már nem.
Komplex felszerelés, vagyis csak goldért távolítható el és persze elfoglal egy helyet a 3ból.
Én szeretem, mert így a láncot többnyire a fejlesztés végére hagyhatom, így kevesebbet kell grindelni alapágyúval, több sebzés, több XP, még kevesebb grind.
Persze alacsony tierben, ahol egy két duplázó a különbség (mert mondjuk 1500 a felfüggesztés és 2000 az ágyú) nem biztos, h megéri a 10 aranyat, de később, amikor már 60k XP az ágyú és 24k a felfüggesztés - na ott már (nekem) nem mindegy.
Bocs hogy csak most. Igen mindíg wikin néztem meg a prémium tankok battle tierjét. A táblázatot nem ismerem amit linkeltél. Amúgy már nem sok megvásárolható tierlimites tank maradt. Fcm megvételét nem bántam meg egy kicsit sem. Igaz, hogy ammorack érzékeny és nagyon papír viszont a löveg engem kárpótol mindenért. Sokat megyek csapat csatában és élvezem a játékot vele.
#43783936
Játssz Cromwellel, megtudod hogy mi a sérülékenység.
Általában, ha valami betalál, az visz is egy-két szuvenyírt magával.
A rekord az volt, amikor kaptam egy akkora taslit, hogy vitte a motort, a tankot és a tornyot.
Mivel a sofőrnek és az irányzónak már nem sok dolga akadt, elmentek kocsmázni, és a parancsnok is elkisérte őket. -
lacibacsi
Állítólagos kiszivárgott információk szerint holnap M46 Patton KR Tier 8 Medium várható.
mcwolf79
Eddig (és valszeg az uccsó nap sem lesz áttörés) a WG ünnepi ajándékainak színvonala (már az ünnepi akció mértékét tekintve) vetekszik a Steam Winter Sale színvonalával. Jó nagy nudli :-(
Bár így legalább megmarad az ember pénze.H1mpi: pedig elég fun tank, hülyére nem keresi magát az ember vele, de legalább nincs agyonbutítva az eredetihez képest (sőt).
nyunyu
szeretném a JagdPanzer IV-et is leváltani a JPanther-re de ahogy nézem sokkal rosszabb értékekkel rendelkezik mint vártam.
Ugyan az a páncél, lassabb forgás, rosszabb rádiójel és ami még rosszabb hír, szinte fele akkora álcaérték.Haaaaaaaat, probald ki a JPt legalabb a kozepso agyuval, aztan rajossz, hogy mennyivel jobb, mint a hasznalhatatlan JgPzIV.
Ispy
Lehet, hogy egyszer csak jó tank lett volna belőle, de nekem nem lenne idegrendszerem azt megvárni, 46 csata alatt megváltam tőle
Engem az bosszantott fel a legjobban, hogy ez a tank olyan, mint egy zsiráf és egyszerűen akárhova bújtam mindig eltaláltak (amiből szinte 99% bement és általában 2 lövés és mehettem zuhanyozni).
galervin93
A JP vicces járgány, a frontja troll, amit ki is lehet használni, mert gyorsan forog maga a gép. Kicsit cibálva IS-3-at lehet pattintani pl... Persze ez RNG is, de többet pattint, mint szimpla "véletlen". Ennek ellenére vártam a végét. És most ott vagyok, hogy megvehetném a JP II-t, de nem fogom - a Borsig ágba lettem szerelmes. Pontosabban a Borsigba, de a Nashornon és az alap Emilen kívül ez az ág marhajó! Csak kell a 6. érzék, anélkül esélytelen...
galervin93
LZs?!
@zodo
Nekem itt ajánlottátok mikor a Könnyű tank ágat kértem tanácsként a Szovjeteket de ugye még teljesen alap és free xp nincs hogy fejlesszem max 15k de azt inkább a leendő nehéz tankokra szórnám.
Úgy tűnik az írásodból hogy ez is "szenvedős" darab és mielőbb szeretném az LTTB -t?
Mindkettőről jókat mondtatok, igaz játszani is tudni kell velük.Szvsz az egyik, ha nem A legjobb T6 light mindent egybevéve.
Ha nem A legjobb, akkor is döntetlen a Type64 és AMX 12t mellett, bár utóbbi azért inkább "másként jó"...
LZs?!
@zodo
Tier for tier a JP jpbb, mint a JPzIV.
Jelenlegi alakulat menne tovább akik most érték el a lehetőséget hogy képességet válasszanak.
Parancsnok 6. érzék, mindenki más a fentiek tükrében, álca?Ahogy te is rámutattál a JP camo-ja egy jó kategóriával rosszabb és T7/8-tól az általános view range is nő, tehát én a camo-t nem javasolnám, inkább repair.
Ezen a TD ágon T7 és afelett inkább a rohamlöveg stílus, mint a álcázott mesterlövész az, ami eredményesebb.
- Csere-Beszámítás! Akciós Gamer PC! R5 5500 / GTX 1070Ti Rog Strix / 32GB D4 / 500GB SSD
- Bomba ár! Dell Latitude 3590 - i5-8GEN I 8GB I 256SSD I HDMI I 15,6" FHD I Cam I W11 I Garancia!
- ÁRGARANCIA!Épített KomPhone Ryzen 7 7800X3D 32/64GB RAM RX 9070 XT GAMER PC termékbeszámítással
- Lenovo ThinkPad X1 Carbon G8, i7-10510U, 16GB, 1TB SSD, 4K kijelző + WWAN (ELKELT)
- ÚJ Lenovo Legion Pro 5 16IRX9 - 16" WQXGA 165Hz - i5 14500HX - 32GB - 1TB - RTX 4060 - 3 év garancia
