- Milyen GPS-t vegyek?
Sanyix
Az komoly, mert az apt-get semmit nem talál aminek köze lenne az mplayerhez.
Sourcét leszedtem, de configure-nél:
root@gep:/home/mplayer# ./configure
Detected operating system: Linux
Detected host architecture: i386
Checking for cc version ... 4.1.2, ok
Checking for host cc ... cc
Checking for cross compilation ... yes
Checking for CPU vendor ... GenuineIntel (6:11:1)
Checking for CPU type ... Intel(R) Celeron(TM) CPU 1200MHz
Checking for GCC & CPU optimization abilities ... CPU optimization disabled. CPU not recognized or your compiler is too old.
error
Checking for kernel support of mmx ... failed
It seems that your kernel does not correctly support mmx.
To use mmx extensions in MPlayer, you have to upgrade/recompile your kernel!
Checking for kernel support of mmxext ... failed
It seems that your kernel does not correctly support mmxext.
To use mmxext extensions in MPlayer, you have to upgrade/recompile your kernel!
Checking for kernel support of sse ... failed
It seems that your kernel does not correctly support sse.
To use sse extensions in MPlayer, you have to upgrade/recompile your kernel!
Checking for mtrr support ... yes
Checking for assembler support of -pipe option ... no
Checking for compiler support of named assembler arguments ... yes
Checking for assembler (as 2.17) ... ok
Checking for .align is a power of two ... no
Checking for Linux kernel version ... 2.6.17-10-generic, ok
Checking for MPlayer binary name ... mplayer
Checking for awk ... mawk
Checking for extra headers ... none
Checking for extra libs ... none
Checking for -lposix ... no
Checking for -lm ... no
Checking for langinfo ... no
Checking for language ... using en (man pages: en)
Checking for enable sighandler ... yes
Checking for runtime cpudetection ... no
Checking for restrict keyword ... none
Checking for __builtin_expect ... no
Checking for kstat ... no
Checking for posix4 ... no
Checking for lrintf ... no
Checking for round ... no
Checking for nanosleep ... no
Checking for socklib ... no
Checking for inet_pton() ... no (trying inet_aton next)
Checking for inet_aton() ... no (network support disabled)
Checking for inttypes.h (required) ... no
Checking for bitypes.h (inttypes.h predecessor) ...
Error: Cannot find header either inttypes.h or bitypes.h (see DOCS/HTML/en/faq.html).
Check ''configure.log'' if you do not understand why it failed.
faq-ot megnéztem, de csak más hibáról ír. -
Sanyix
Dehát miért a felhasználó jelszava kell, ha a felhasználó nem root? Így akkor bármelyik juzer azt csinál amit akar a sudo-val.
Hogy érted azt hogy x alá nem tudok bejelentkezni rootként? Elvileg a gnome ugye elindul, azt nem tudom hogy kell arra a felületre váltani. Merthogy írja hogy elindult, de még mindíg a parancssorban vagyok. -
Sanyix
Tudom van root jelszó, parancssorból be is tudok lépni rootként.
Sudo meg azt csinálja hogy semmit... beírom, terminálba hogy sudo és valami parancs, és nem történik semmi, újra kiírja a promptot. Guin meg ha valami programot indítok amihez root kell, ott kiírja, hogy sudo-val nem sikerült rootként indítani.
Az általad leírt parancssoros gui indítással meg az a bajom, hogy kiírja hogy starting gnome [ok] és ennyi. De nem jelenik meg a felület.
[Szerkesztve] -
dbius
jelenleg tudomásom szerint a 7.04-nek az 5. alpha cd-je tölthető le, mint ahogy ubuntuforum.org-on is olvastam.
Érdekes módon nekem két napja a frissítéseket követően MÁR felajánlja, hogy elérhető az újabb kubuntu, akarok-e frissíteni, és már a 7.04-re akarja magát frissíteni... de nem engedem neki. -
hát pontosan nem tudom melyik könyvtárra gondolsz.
ezt a gépet viszont globálisan én használom egyedül
úgyhogy jó ez a kis lang fájl bebetonozva az eredeti angol fájl mellé.
a flashel kapcsolatban annyi lenne akérdésem, hogy az rpm-et hogy lehet felinstallálni?? ugyanis ilyen formában szedtem le a flash plugint. illetve lett volna még tar.gz is. nem nagoyn értem mi a különbség -
Eszleny
Igen, az adataimnál lévő gépről van szó.
Anno leszedtem az Edgy CD-t. Ha most töltöm le szintén az Edgy CD-t, akkor tartalmazni fogja az Edgy-hez eddig kijött frissítéseket, pl. kernel frissítés?
Az Mplayer ablakai kb. 10s után jelennek meg és még kb. 15-20s mire elkezdi lejátszani, addig az egyik teljesen szürke, a másik fekete.
A témával kapcsolatos problémám, hogy a Synaptic-on jól alkalmazza (bemásoltam a témát a /usr/share/themes könyvtárba) a rendes programok esetén pedig nem alkalmazza.
Aptitude-dal tettem fel a kubuntu-desktopot. Azzal is szedtem le (ha jól emlékszem), mert valahol azt olvastam az jobban kezeli a függőségeket. De meghagyott még valami kde-s cuccokat s azokat is leszedtem Synaptic-kal.
Máskülönben nincs baj a rendszerrel, a Firefox se zárja le magát olyan gyakran, ezért sincs kedvem telepítgetni.
Végül kösz a segítséget. -
atis917
Nekem se tetszett amit a synaptic-al szdtem le. Ez 2.5.0.0 verzió volt. Az Automatix leszedte a 2.5.0.4-t ez sokkal jobb.
De ez se frissült.
De megoldottam.
Megnéztem melyik könyvtárból indul az azureus, ezt beírtam terminálba sudo után, és így frissítette magát. Kiléptem, elindítottam rendesen, és már a friss ment.
(sudo után nem volt az igazi, mert ott hiányoztak a torrentek és a beállítások, de a frissítés jó lett)
atis917 -
Bero
Köszönöm a segítséget, sorry hoyg nem íram eddig, de nem volt gépem.
Nos, egy utolsó hardver, és disztró csere:
Az Ati 9800-at lecseréltem egy Platinum Geforce FX5700 Ultra Vivos karira.
Itt látszik, hogy igazán nvidiával jó az ubuntu. Most már a videó is megy, köszönöm a segítséget, bár úgyis újabb kérdésekkel foglak titeket zaklatni. -
Bero
Érdekes, mert feltelepítettem az Operát, és azzal sem ment, ugyanúgy mint a Firefoxal. Azonban ha a Mozillát raktam fel, azzal ment. A 9-es flasht raktam fel. És mindezt Xubuntu alatt.
Nade most már fent van a Kubuntu, remélem más lesz a helyzet, aztán úgyis akadnak még az este folyamán problémák. -
Bero
Köszi, már ismerősöm próbálta, ő egy keveset ért hozzá, legalábbis többet mint én. De már másik gép melet ülök, igaz csak 32bites Athlon, de úgy megy rajt minden mint álom.
Más:
Kinek mi a véleménye a Xfce kezelői felületről? Érdekes, mivel minden teéepítő cd-m hibás volt, kivéve a Xubuntu, felraktam. Nekem tetszik, elég egyszerű, de eddig ezzel volt a legkevesebb gondom. -
Bero
Bero
Mitől van az, hogy az XMMS lejátsza a zenéket, de a Media Player, és amaroK nem?
Nem találtam liblame0, mert nem mertem extra reposytorokat felvenni. Universe alapból bent van. Mi lehet a gond?
Illetve ATI driver telepítés hogy megy?
Bocsi a sok kérdést, nagyon kezdő vagyok ezen a téren, de valahol el kell kezdeni.
Szerk.: Jah, és a Flash?
Előre is köszi!
[Szerkesztve] -
truba
Jó.Akkor 1gb a swap-nak,és 9Gb a linux-nak.Ha jól veszem ki amit tanácsolsz,akkor ezek után a linux nem zavar már be win.-nek.Mert feleségem diploma munkája van a win-es partición.
Telepitésnél meg válaszam ki számára az 1Gb-os részt a többit meg intézi,ésa 9Gb-os részre települ./remélem/
- Milyen légkondit a lakásba?
- Ford topik
- Futás, futópályák
- Kazy Computers vélemények - tapasztalatok
- PlayStation 1 / 2
- Windows 11
- Micro Four Thirds
- Adobe Előfizetések - Adobe Creative Cloud All Apps - 12 Hónap - NYÁRI AKCIÓ!
- Gyermek PC játékok
- AKCIÓ! Gigabyte B650M R7 7700X 32GB DDR5 1TB SSD RTX 3080Ti 12GB Cooler Master H500P WHITE 750W
- 35" ASUS ROG Swift PG35VQ curved GAMER monitor
- ÚJ- Lenovo ThinkVision T24i-10 - 24" monitor - Számla, garancia
- Epson Expression 12000 XL Nagyformátumú A3 szkenner
- Samsung Galaxy S21 Ultra , 12GB , 128 GB , Kártyafüggetlen
