- Friss koncepciót hoz a Nothing Phone (3)
- Íme az új Android Auto!
Arch Linux topik
vargalex
anorche1 #5601 üzenetére
Arch linux alatt nem "divat" a fejlesztéshez szükséges header file-okat (azért kell neked, mert valami saját alkalmazást akarsz készíteni?) külön devel csomagba tenni. Az alap csomag része:
[gavarga@gavarga-e5540 ~]$ pikaur -Ql openmpi | grep ".h$"
openmpi /usr/include/mpi-ext.h
openmpi /usr/include/mpi.h
openmpi /usr/include/mpi_portable_platform.h
openmpi /usr/include/mpif-c-constants-decl.h
openmpi /usr/include/mpif-config.h
openmpi /usr/include/mpif-constants.h
openmpi /usr/include/mpif-ext.h
openmpi /usr/include/mpif-externals.h
openmpi /usr/include/mpif-handles.h
openmpi /usr/include/mpif-io-constants.h
openmpi /usr/include/mpif-io-handles.h
openmpi /usr/include/mpif-sentinels.h
openmpi /usr/include/mpif-sizeof.h
openmpi /usr/include/mpif.h
openmpi /usr/include/openmpi/ompi/mpi/cxx/comm.h
openmpi /usr/include/openmpi/ompi/mpi/cxx/comm_inln.h
openmpi /usr/include/openmpi/ompi/mpi/cxx/constants.h
openmpi /usr/include/openmpi/ompi/mpi/cxx/cxx_glue.h
openmpi /usr/include/openmpi/ompi/mpi/cxx/datatype.h
openmpi /usr/include/openmpi/ompi/mpi/cxx/datatype_inln.h
openmpi /usr/include/openmpi/ompi/mpi/cxx/errhandler.h
openmpi /usr/include/openmpi/ompi/mpi/cxx/errhandler_inln.h
openmpi /usr/include/openmpi/ompi/mpi/cxx/exception.h
openmpi /usr/include/openmpi/ompi/mpi/cxx/file.h
openmpi /usr/include/openmpi/ompi/mpi/cxx/file_inln.h
openmpi /usr/include/openmpi/ompi/mpi/cxx/functions.h
openmpi /usr/include/openmpi/ompi/mpi/cxx/functions_inln.h
openmpi /usr/include/openmpi/ompi/mpi/cxx/group.h
openmpi /usr/include/openmpi/ompi/mpi/cxx/group_inln.h
openmpi /usr/include/openmpi/ompi/mpi/cxx/info.h
openmpi /usr/include/openmpi/ompi/mpi/cxx/info_inln.h
openmpi /usr/include/openmpi/ompi/mpi/cxx/intercomm.h
openmpi /usr/include/openmpi/ompi/mpi/cxx/intercomm_inln.h
openmpi /usr/include/openmpi/ompi/mpi/cxx/intracomm.h
openmpi /usr/include/openmpi/ompi/mpi/cxx/intracomm_inln.h
openmpi /usr/include/openmpi/ompi/mpi/cxx/mpicxx.h
openmpi /usr/include/openmpi/ompi/mpi/cxx/op.h
openmpi /usr/include/openmpi/ompi/mpi/cxx/op_inln.h
openmpi /usr/include/openmpi/ompi/mpi/cxx/request.h
openmpi /usr/include/openmpi/ompi/mpi/cxx/request_inln.h
openmpi /usr/include/openmpi/ompi/mpi/cxx/status.h
openmpi /usr/include/openmpi/ompi/mpi/cxx/status_inln.h
openmpi /usr/include/openmpi/ompi/mpi/cxx/topology.h
openmpi /usr/include/openmpi/ompi/mpi/cxx/topology_inln.h
openmpi /usr/include/openmpi/ompi/mpi/cxx/win.h
openmpi /usr/include/openmpi/ompi/mpi/cxx/win_inln.h
openmpi /usr/include/openmpi/ompi/mpiext/affinity/c/mpiext_affinity_c.h
openmpi /usr/include/openmpi/ompi/mpiext/cuda/c/mpiext_cuda_c.h
openmpi /usr/include/openmpi/ompi/mpiext/pcollreq/c/mpiext_pcollreq_c.h
openmpi /usr/include/openmpi/ompi/mpiext/pcollreq/c/pmpiext_pcollreq_c.h
openmpi /usr/include/openmpi/ompi/mpiext/pcollreq/mpif-h/mpiext_pcollreq_mpifh.h
A pvm egy elég régen módosított aur csomag. A gondja az, hogy nincs rpc/types.h header file (azaz /usr/include/rpc/types.h). Ha jól sejtem, ez most már a libtirpc csomag része lett. Így a fordításnál a /usr/include/tirpc-t kellene include-olni.
vargalex
vargalex
attilav2 #5287 üzenetére
Nálam NetworkManager van, LAN oldalon IPv6 és IPv4 osztva OpenWrt alapú routerről. Igaz, WAN oldalon csak IPv4 van az UPC-nek köszönhetően. Systemd-networkd-vel is kapsz IPv6 címet? Én valami olyanra gondolok, hogy a youtube a Digi hálózatáról valamiért nem megy rendesen IPv6 alatt, ellenben IPv4-el igen.
Frawly: Nálam a wifivel sincs semmi gond. Ma is egész nap wifi-n lógok, itthonról dolgozom, így a céges VPN-re is folyamatosan csatlakozva vagyok (OpenVPN) délelőtt 10 óta.
vargalex
De, szerintem is ettől zengene. De a kolléga valamiért nem akarja elhinni nekünk (pedig már mindannyian írtuk), hogy nem az Arch-ban kell keresni a hibát, akárhogy bizonygatjuk... Itt konkrétan kérte is (illetve kijelentette, hogy új telepítésnél tuti gond lesz), így gondoltam jó fej leszek. A telepítés pedig néhány percet vett el az életemből, aztán töröltem is a virtuális gépet.
vargalex
attilav2 #5270 üzenetére
Szerintem, ha proxyn keresztül (valamennyire) megjelenik az oldal, akkor nem az Arch-ban kell keresni a hibát. Én is inkább DNS szerverre gondolnék. Nézd meg, hogy Arch alatt mi a DNS szervered és nézd meg azokon a rendszereken is, ahol megjelenik az oldal.
Ha holnap lesz időm, feltolok egy Arch-ot virtuális gépre és megnézem.
vargalex
vargalex
A queued trim <> continuous trim. Előbbi akár ütemezett, akár folyamatos trim esetén működik, ha tudja a drive és nincs blacklist-en. Sajnos a 850 esetében blacklist-en van, azaz a hagyományos blokkoló trim működik. Ekkor is használható mindkét módszer (continuous trim - discard, illetve periodic trim - fstrim.service, vagy kézi futtatás), csak a blokkolás miatt talán a periodic kevésbé zavaró.
vargalex
Cégnél kaptam egy 500 GB-os SSD-t, így arra fogok a notebookon átköltözni. Kérdésem, hogy ki milyen filerendszert javasol? Nálam az XFS, illetve EXT4 merült fel. Persze más is lehetséges. Az szinte biztos, hogy LVM-en lesz.
Sajnos az SSD az egy Samsun 850 EVO, így a queued trim nem fog menni. Jobban járok a discard mount opció helyett az fstrim.service futtatásával? -
vargalex
Arról nem is beszélve, hogy alapból nincs is semmilyen cron implementáció telepítve.
vargalex
Sokkal régebben jelen van az intel_pstate. Akkor még 3.15-ös kernel volt. A linkelt hozzászóláshoz annyit fűznék hozzá, hogy nem a governor volt bugos, hanem a BIOS. Egy későbbi BIOS frissítés után minden helyreállt.
vargalex
vargalex #4957 üzenetére
Már lemaradtam a szerkesztésről. LTS kernel esetén (4.14.18-1-lts) ez így néz ki:
gavarga@gavarga-e5540 ~ % cat /sys/module/snd_hda_intel/parameters/power_save_controller
Y
0Megoldásként létrehoztam a /etc/modprobe.d/disable_audio_powersave.conf file-t a következő tartalommal:
gavarga@gavarga-e5540 ~ % cat /etc/modprobe.d/disable_audio_powersave.conf
options snd_hda_intel power_save=0[ Módosította: Intruder2k5 ]
vargalex
vargalex #4956 üzenetére
Szerintem megvan a bűnös:
Y
10Ha jól sejtem, most lett default-ban aktív. Én mindenesetre kikapcsolom, mert a munkahelyen majdnem egész nap rajtam van a fejhallgató, viszont nem mindig szól valami. Ezek a "pukkanások" pedig elég zavaróak.
vargalex
Flowtation #4946 üzenetére
Akkor passz. Arch linuxon kipróbáltam, gond nélkül mount-ol.
vargalex
Flowtation #4944 üzenetére
Véletlenül privátot írtam, de ide is bemásolom, hogy rátaláljon más is:
Bocs, valóban nem lett jó a link, észre sem vettem (mobilról linkeltem). Egyébként igen, az általad linkelt wiki oldalra gondoltam és a kliens (nálad Manjaro) fstab-jába kell beírni.
vargalex
Flowtation #4939 üzenetére
Ezt olvasd el. Vagy _netdev opció kell, vagy systemd automount. Valószínűleg még nincs hálózatod, amikor mount-olna. Ezt támasztja az is alá, hogy később kézzel működik.
vargalex
A kolléga nem git clone-ról írt, hanem AUR package-ről. Ott pedig nem a legújabb jön. Mindig definiálnak egy commit numbert, hiszen nélküle sha256sum-ot és pontos függőségeket sem tudnának adni...
vargalex
vargalex
vargalex
Fritz Teufel #4364 üzenetére
Pedig, ha pulseaudio-t használsz, akkor elvileg nem kell semmit tenned. A wiki-ben ez áll:
"There is usually no need to add your user to the audio group, as PulseAudio uses udev and logind to give access dynamically to the currently "active" user. Exceptions would include running the machine headless so that there is no currently "active" user."
Persze megpróbálhatod az user-t az audio csoporthoz adni...
vargalex
ger15xxhcker #4065 üzenetére
A config-ban az incomplete_dir-ed /hdd/mnt a helyes /mnt/hdd helyett, ami így bizony nem a HDD-re mutat!
vargalex
ger15xxhcker #4061 üzenetére
Véletlenül nem éppen a transmission írja tele?
Mit mutat ilyenkor adu -h --max-depth=1 /
parancs kimenete? Mert most teljesen normálisnak tűnik a df kimenet.
Szerk.: kicsit lemaradtam, mert számodra is kiderült, hogy a transmission írja tele. Mi a transmission config-od? Esetleg torrent hozzáadásakor nem adsz meg a /mnt/hdd-n kívül álló cél könyvtárat?
vargalex
tibor23 #4054 üzenetére
Nem vártam meg a jövő hetet, megnéztem most. Szóval letöltöttem az image-t:
wget http://archlinuxarm.org/os/ArchLinuxARM-kirkwood-latest.tar.gz
Majd kicsomagoltam a pendrive-ra, azt betettem a GoFlex Net-be és boot-oltam. SSH-n bejelentkeztem, majd kiadtam a
pacman -Syu
parancsot. Ezután reboot. Ezzel a pendrive-val boot-olva mindkét GoFlex Net elérhető SSH-n és látszik, hogy egyik sem talál további frissítéseket:
[root@alarm ~]# uname -a
Linux alarm 4.3.3-1-ARCH #1 PREEMPT Thu Dec 17 22:16:31 MST 2015 armv5tel GNU/Linux
[root@alarm ~]# pacman -Syu
:: Synchronizing package databases...
core is up to date
extra is up to date
community is up to date
alarm is up to date
aur is up to date
:: Starting full system upgrade...
there is nothing to do
[root@alarm ~]#Természetesen a legújabb systemd van:
[root@alarm ~]# pacman -Qs systemd
local/libsystemd 228-3
systemd client libraries
local/netctl 1.11-1 (base)
Profile based systemd network management
local/systemd 228-3
system and service manager
local/systemd-sysvcompat 228-3 (base)
sysvinit compat for systemdÜdv,
vargalex
tibor23 #4042 üzenetére
Igen, volt egy u-boot váltás az újabb kernel verzió miatt. De ha jól tudom, akkor az 3.2-es kerneleknél nagyobb verzió esetén volt szükséges. Az pedig biztos, hogy már több, mint 1 éve elérhető volt. De azért ellenőrizheted, hogy a működő image-ban milyen kernel van.
Ha ez a gond, akkor a működő rendszer alól először (vagy legalábbis még reboot előtt) az uboot-goflexnet csomagot tedd fel (és természetesen engedd, hogy frissítse az u-boot-ot), utána frissítsd a rendszert. -
vargalex
Nyilván a sokkal kevesebb RAM miatt a swap-ot hamarabb igénybe veszi, mint egy PC. De azt nem is mondtam, hogy a swap a pendrive-on legyen. Nálam az a HDD-n volt. Viszont valóban, ha elindultak a szolgáltatások, akkor igazából nem használja a pendrive-ot, csak a logokat írja.
vargalex
tibor23 #4036 üzenetére
Én azért raktam pendrive-ra a rendszert, mert ha valami gond lett volna (ahogy nálad most is van), akkor nem kellett volna HDD keretet kerítenem, csak 1 PC-be bedugni a pendrive-ot. Nálam egyébként több évig ment a rendszer pendrive-ról a GoFlex Net-et. Valamint azért is volt pendrive-on, mert az adatok egy RAID0 tömbön voltak (2x1 TB 2,5" HDD). Így nem volt több sata hely, külső HDD-t pedig nem akartam.
vargalex
tibor23 #4028 üzenetére
Az archlinuxarm.org-ról (bocs, de csak mobilról vagyok, így nem linkelek) töltsd le a GoFlex Net-hez való image-t, és csomagold ki PC-n (Linux alatt) egy pendrive-ra. Majd ezzel boot-olj a GoFlex-en. Persze ha újra akarod telepíteni, akkor kicsomagolhatod a HDD-re is. De korábban írtam, hogy szerintem egyébként is jobb, ha a rendszer pendrive-on van.
vargalex
tibor23 #4023 üzenetére
Ahogy írtam a másik topicban, mountold fel a GoFlex root-ját egy PC-n és nézd meg az ssh config-ot.
Esetleg soros konzolon tudsz csatlakozni is a GoFlex-hez (ehhez persze szét kell szedni), így ott is javíthatod akár.
Az is lehet, hogy csak most valamiért nincs engedélyezve az ssh. Ezt is javíthatod a fenti 2 módszer valamelyikével. -
vargalex
PandaMonium #3788 üzenetére
Fsck-hoz pont az a lényeg, hogy ne legyen mount-olva, így chroot-olni sem kell. Amint beboot-ol USB-ről a telepítő, azonnal lehet ellenőrizni a partíció(ka)t.
- Milyen routert?
- Óra topik
- OpenMediaVault
- Parkside szerszám kibeszélő
- Gaming notebook topik
- BGA-zók, ReWork-ösök szakmai topic-ja
- Antivírus szoftverek, VPN
- Adobe Előfizetések - Adobe Creative Cloud All Apps - 12 Hónap - NYÁRI AKCIÓ!
- Xiaomi Redmi 13128GB Kártyafüggetlen 1Év Garanciával
- 120 - Lenovo Legion Pro 5 (16ARX8) - AMD Ryzen 7 7745HX, RTX 4070 (48 hónap garancia!)
- Csere-Beszámítás! RGB Számítógép PC játékra! R5 5600X / RTX 3060Ti 8GB / 32GB DDR4 / 500GB SSD
- Bomba ár! Lenovo IdeaPad 330S-15IKB - i5-8G I 8GB I 256SSD I 15,6" FHD I HDMI I Cam I W11 I Gari!
