- CES 2026: Bemutatta a világ legkisebb aktív zajszűrős fülhallgatóját a JLab
- CES 2026: Látható gyűrődés nélküli hajlítható kijelzőt hozott a Samsung
- CES 2026: Alig nagyobb egy AirPods Pro tokjánál a Baseus 45 wattos power bankja
- Tízezres aksit tuszkolt a Honor a Power 2-be
- iPod Nanóra hasonlító USB DAC és zenelejátszó a Snowsky Disc
Maximusz
neduddki
H!I
Tok jol elvagyok itt magamban: - )))
Akkor en tevedesben eltem eddig... ez megis csak sb32pnp:- )))
''The main difference between the AWE32 and Sound Blaster32 cards is the onboard memory, 512k memory on the AWE32 cards vs. 0 k on the Sound Blaster32 cards. In addition, there is a Wave Blaster Header on the AWE32 cards, not in Sound Blaster32 cards.''
udv
neduddki -
neduddki
hi!
eSZT OLVASTRSD???
Technical Specifications of the Sound Blaster Pro
Model Numbers:
CT1600
CT1900
Sound Blaster Pro 2 is an 8-bit audio board equiped with a Panasonic/MKE CD-ROM interface.
Hardware Specifications
Frequency Response: 100Hz - 10KHz
Signal to Noise Ratio: 48 db
Sampling Rate for Playback/Recording Mono: 5 KHz - 22.1 KHz (4-44.1kHZ Sound BlasterPro only)
Sampling Rate for Playback/Recording Stereo: 5 KHz - 22.1 KHz (Sound BlasterPro only)
Supply Voltage Requirement (Loading): +5, +12, -12 Volt
Current Consumption (Typical): 50, 500, 30 mA respectively
Microphone Impedance: 600 Ohms
Line-In Impedance: 39 KOhms
CD Audio-In Impedance: 50 KOhms (Sound BlasterPro only)
Microphone Sensitivity: 10 - 200 mVpp
Line-In Sensitivity: 0 - 2 Vpp
CD Audio-In Sensitivity: 0 - 2 Vpp (Sound BlasterPro only)
AD/DA Resolution: 8 bits
Output Power (Max.): 4 Watts @ 4 Ohms PMPO (Amp out)
Hardware Settings
Note: Default settings are shown in [brackets]
Interrupt (IRQ): 2, [5], 7, 10
DMA Channel: 0, [1], 3
Channel: 0 [1] 3
DRQ0, DACK0 ON OFF OFF
DRQ1, DACK1 OFF ON OFF
DRQ3, DACK3 OFF OFF ON
Joystick I/O Address: 200 Hex
Joystick: [Enabled] Disabled
JYEN ON OFF
Audio I/O Address: [220], 240 Hex
ADDRESS: [220] 240
22X ON OFF
24X OFF ON
FM Synthesizer I/O Address: 388 Hex
Wave Synthesizer I/O Address: Not Applicable
Sharing DMA [disabled] (DMACTL on pins 1 & 2), or enabled (DMACTL on pins 2 & 3)
Connectors
Line-In: Yes
Mic-In: Yes
Line-Out: No
Speaker-Out: Yes
PC Speaker-In: Yes
Game/Joystick Port: Yes
CD-ROM Audio-In (Sound Blaster Audio Socket): Yes
CD-ROM Audio-In (MPC2 Socket): No
External CD-ROM: Not Applicable
System Requirements
IBM® PC XT or higher, or 100% compatible motherboard
VGA
5 MB of hard disk space for Sound Blaster software.
MS-DOS® 4.0 or higher, Windows® 3.1 or higher.
Open 16 bit ISA slot for Sound Blaster Pro cards
Speakers or headphones
Na akkor megis sb16 volt amin ide volt:
Model Numbers
CT1730 (Sound Blaster16 non CSP, Panasonic interface)
CT1740 (Sound Blaster16 CSP, Panasonic interface)
CT1750 (Sound Blaster16 MCD CSP, Panasonic, Mitsumi, Sony interface)
CT1770 (Sound Blaster16 SCSI-2, CSP, SCSI-2 Interface)
CT1779 (Sound Blaster16 SCSI-2, Non CSP, SCSI-2 Interface)
CT2230 (Sound Blaster16 MCD CSP, Panasonic, Mitsumi, Sony interface)
CT2230C (Sound Blaster16 CSP, Panasonic interface)
CT2239 (Sound Blaster16 MCD Non CSP, Panasonic, Mitsumi, Sony interface)
CT2239C (Sound Blaster16 MCD Non CSP, Panasonic)
CT2290 (Sound Blaster16 IDE)
CT2291 (Sound Blaster16 IDE)
CT2750 (Easy CD, External CD-ROM drive)
CT2770 (Sound Blaster16 Value, No CSP, Panasonic interface)
CT2779 (Sound Blaster16 Value, No CSP Panasonic interface)
CT2919 (Sound Blaster16 No CSP IDE and Panasonic interface)
The Sound Blaster® 16 card is a 16-bit ISA audio board. It is the single largest group of audio cards from Creative Labs. This card comes equipped with a Panasonic/MKE, Mitsumi, or Sony CD-ROM interface. Some new models of the Sound Blaster16 are equipped with the standard IDE interface as well.
De eldobom az agyam!! SCSI a sb-n??? errul meg ne mhallotam:- )))
udv
neduddki -
neduddki
HI!
NA itt az oldal is, d egondolo erre jartal...
Bővebben: link
udv
neduddki -
neduddki
HI!
Gondolom ez megvan???
Bővebben: link
a tijjed is ijjen???
udv
neduddki
p.s. qva lassu:- ((( -
neduddki
HI!
Na korotrasztam!!!:- )))
Es talaltam egy sb clont 94. 30-heti ezen van sony mitsumi meg panasonic cd csatlakozott:- ))) nem is hittem hogy ez meg megvan: -))) mv thubder csipp, made in china... hangero szabajjzo a hatlapon!!!:
ES...
egy AWE32-t is!!!ct3600-as, 96. 29. heti. az van rairva hogy sb32pnp de rajta van ramcsatlakozas meg egyebek EMU8000; a csip rajta CT2502-sdq!!!
Ez akkoribanmekkora ize lett volna ha nincs a GUS:- ))) bevallhato hoy pokoli alapzajs meg minden de 10 eve nem is egy 250d-n hallgattam a hangot:- )))
es jol emlexetem ezen is ide, mind a 40 lab bekotve, es haznlatm ais cd-k hez ha jol tevedek
es folotteb nagyon utaltam rajta a pnp-t mert mig a jumpereknel elottem oszt kesz addig ezzel neha /maig nem tom miert/ napokat el kelelt szorakozni hogy megjegyezze amit beallitottam neki. aszem volt harom lemeze es azokkal kellet dos-bol beloni... win31 alalt hasznaltam, de en nem hasznaltam 95 ala, tan mintha 98 alal tigen, de nem tom mijjen driverrel...
bisztos hogy jol ertelmezed??? mert nem hinnem hogy akkoriban lette volna ojjan gyors cd-k:- )))
udv
neduddki![[kép] [kép]](http://images.google.com/images?q=tbn:n-oJZfnI5vQJ:www.yjfy.com/images/oldhard/sound/ct3600.jpg)
![[kép] [kép]](http://images.google.com/images?q=tbn:nDtAAw5jXeEJ:http://img6.dena.ne.jp/ex63/20050409/249/47237369_3.jpg)
Bővebben: link
amugy nen: Bővebben: link -
Maximusz
Jelenleg ott tart a helyzet, hogy sikerült dos-os drivert találnom - és kapnom.
Egész korrekt, van hozzá midi lejátszó, és wav lejátszó.
sőt a régi XTC-Play-t is sikerült beíízítanom!!
Igaz, hogy a kártya csak 8 bites, és 22Khz körüli a mintavételi frekivje (hallás alapján), de ilyen bika erejű fejhallgató csatlakozást még életembe nem pipáltam
windowsba - hát az egy érdekes dolog.
-Vannak a windows eseményeknek hangjai (rendszer téma hangok), van mp3 lejátszás winamppal egy kicsit beleturkálva - (nem megy csak 1-2 output pluginnel)
viszont!!! és itt jön a különlegesség!!! - nem érzékeli, hogy lenne a gépbe hangkártya!!!
se a dxdiag nem megy rajta, de az sndvol32
lehet csak azért, mert win 95-ös drivert találtam? -
plömplöm
küldtem ímélben egy dos-os drivert, próbáld ki
neduddki
HI!
A vezerlokatyas cd-rom-ok megszunese utan mar volt ojjan amejiken ide volt, csak mai szemmelnem besztos hogy eremes hasznalni mert rohatt lassu es raadasul a eides mazzagokat meg hdd-kel nem tud mit kezdeni, raadsul ha jol tevedek mintha meg a 500-as virnyoknal nagyobakkal nem is boldogul...
amugy fiok mejjen szeritnem meg van ijjanom amejjiken van ide:- )))
udv
neduddki
p.s. nem nem akarom megkeresni:- ))) -
Loha
Pontosan ez van rajt: Sony, Panasonic, Mitsumi egyedi vezérlője.
Én anno, egy 2X Panasonic cdromot használtam hasonló cuccal, ezek mással nem mennek. Ezekre a vezérlőkre azért volt szükség, mert a cdmeghajtók elterkedésének kezdetén, az IDE vezérlők nem tudták még vezérelni. -
mr_ricsi
''az IDE csatorna részét is tudom majd használni? (akár két cd-rom-ot is dughatok rá?)''
Nem biztos, hogy sok örömöd lesz benne!
Ez a kártya elég koros ahhoz, hogy ne támogassa az UDMA átvitelt. Sőt, még talán a PIO4-et sem.
(Az biztos egyáltalán, hogy IDE vezérlő van rajta, nem pedig Sony, Panasonic, vagy -a 3. nem jut eszembe- egyedi vezérlője?) -
Pacák
Ezt neked kell kipróbálni. Még én sem használtam soha az IDE csatornáját, pedig a lehetőség meg lett volna rá.
Már arra se emlékszem, hogy az IDE eszközök között megjelent vagy sem, ugyanis akkoriban egy Abit BE-6 volt a lapom, és az eléggé jól el volt látva IDE csatolókkal. (2 csati a BX chipset tartozéka volt, 2 csati az integrált HPT-vezérlőé, ezért nem foglalkoztam vele, később meg lecseréltem egy jobb hangú SB Live -ra, de ez ma már történelem..) -
Pacák
Mindegyik ismeri. A win XP alatt kézzel kell megmutatni neki a saját driver készletéből, hogy ilyened van, mert a nem P&P eszközöket az Xp nem keresi telepítésnél. A 98 meg telepítésnél keresi és használatba veszi.
Szerk.: DOS driver -hez sajna nincs lövésem se.
[Szerkesztve] -
Maximusz
Üdv minenkinek!
Az alábbi kártyát kaptam minap, nuku drájverrel:
Sound Blaster Pro 2 CT1600 integrált IDE vezérlővel (IDE csatlakozó a hangkártyán!!!)
Hátul 3 Jack ajzat, tekerős (!!!) hangerőszabályzó, és MIDI port.
Szükségem lenne DOS driverre, és Windows 98SE driverre. Jól jönne esetleg egy XP driver is, de a Win98SE lenne a legfontosabb.
Előre is köszi a segítséget!
- Xiaomi Redmi Note 9 Pro 64GB,Uj, Dobozaval,12 hónap garanciával
- ÁRGARANCIA! Épített KomPhone Ultra 9 285K 32/64GB RAM RTX 5080 16GB GAMER PC termékbeszámítással
- Fujitsu Lifebook A3510 Laptop
- Lenovo ThinkPad T14 Gen1 Intel i5-10310U Refurbished - Garancia
- Sima Vs.Windows Logitech Mx keys s plus és hagyományos Mx keys magyar bemutatása. Új videó linkkel
