- Garmin Forerunner 965 - csúcs
- Beépül a Nano Banana a Google Fotókba
- Motorola Edge 70 - többért kevesebbet
Tartalomjegyzék:
1. Előkészületek
3. Clover telepítése
4. macOS telepítése
5. Telepítés utáni tennivalók
9. Hasznos linkek
10. Hasznos alkalmazások
ko9
odessa32
#8554
De csak sikerült megnyitni
<!DOCTYPE plist PUBLIC "-//Apple//DTD PLIST 1.0//EN" "http://www.apple.com/DTDs/PropertyList-1.0.dtd">
<plist version="1.0">
<dict>
<key>Kernel</key>
<string>mach_kernel</string>
<key>Kernel Flags</key>
<string>arch=i386</string>
<key>GraphicsEnabler</key>
<string>No</string>
<key>Timeout</key>
<string>2</string>
<key>Legacy Logo</key>
<string>Yes</string>
<key>EthernetBuiltIn</key>
<key>device-properties</key>
<string>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</string>
</dict>
</plist>Na erre cseréld le a tartalmát. Mentsd le, és másold be oda ahonnan kiszedted, majd restart. Lehet, hogy nem fog menni, ha nem megy, akkor a másik output setting-el is adok egyet.
ko9
odessa32
#8232
Nekem a GT240M megy HDMI-n.
TonyMac fórumon írta valaki, hogy HDMI-n csatlakozott HD5770-el TVre, és FullHD-n ment tökéletesen a kép.
Amúgy nemlehet, hogy csak nem ismeri fel a DVI-n csatlakozott monitort, ezért nem kapcsolja be? Próbáltad úgy, hogy rádugod mind a 2 képernyőt (DVI+VGA), elindítod a rendszert, System Pref - Displays - Detect Displays. Ekkor elvileg be kell kapcsolnia a másik monitort is. -
ko9
odessa32
#8077
1.: Miért 4re? 2 nem elég? Macnek jó ha a rendszerpartíció ugyanaz mint az adatpartíció, ugyanis az alkalmazásokat is odarakja.
2.: Elsőnek a Win7-et kell felrakni.
3.:Mi írja ki azt? A Mac vagy a Win7?Ja a Mac, Win7 nem használ DMG-t
Utánnajárva a dolognak, bootloader+partícióhiba. Sok a partíció neki szerintem, kezd elölről
ko9
odessa32
#8033
NE Software Update-tel rakd fel, mert az a SMBIOS infói alapján szükséges dolgokat rakja fel, és az nem mindig jó.
Az meg írtam, hogy NE indítsd újra, mert akkor felrak egy jópár dolgot, amit restart előtt lecserél a MultiBeast.
Persze, rakd újra, formázd le, úgy kell
Mindjárt nézem mi kell az alaplapodhoz.Ugye ilyen lapod van? -
ko9
odessa32
#7943
Őőő, milyen terminál?
MultiBeast felrakja a Chameleont is. (Chimera-t).
Jelszót felhasználónévvel adtad meg a telepítés után.
Ha MultiBeast-tel nem boldogulsz, szólj, segítek.
Az EFI stringet feljebb leírtam. Esetleg megcsinálok neked egy teljes com.apple.Boot.plist fájlt, amit csak be kell másolnod. -
ko9
odessa32
#7928
Akkor ha fennvan a Mac, és megvolt a MultiBeast (leirnád a géped pontosan mégegyszer, nem emlékszem rá... Esetleg ha az adataid közzé a cuccokhoz beirnád az nagy segitség lenne), akkor megkeresed a /Extra mappában a com.apple.Boot.plist fájlt, és beilleszted ezt a </dict> előtti sorba.
<string>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<string> -
odessa32
odessa32
#7884
Na ja, én már 3 hete nem tudok irni az irommal (jövö hétenjön a blu ray) másik gépen probáltam transmaccal kiirni egyböl el is dobta, neki sem állt. Va még lemez jelszoval transmac fel a saját gépemre s megirta.
Szoval nem rossz az.
A gépemröl, tavasszal alaplap, cpu, memoria csere volt + 2 terra winyo, most ugy tünik szépen sorba lehal minden ami még a régi volt.
- Milyen monitort vegyek?
- Nyíregyháza és környéke adok-veszek-beszélgetek
- ASUS notebook topic
- Ez a tágas mikrotorony már faberakással is választható
- Notebook hűtőpad
- Fizetős szoftverek ingyen vagy kedvezményesen
- BESZÁMÍTÁS! Dell Precision 5540 notebook - i9 9880H 64GB DDR4 2TB SSD nVidia Quadro T2000 4GB W11
- Xiaomi Redmi 13 128GB, Kártyafüggetlen, 1 Év Garanciával
- ÁRGARANCIA! Épített KomPhone Ultra 7 265KF 32/64GB RAM RTX 5070 Ti 16GB GAMER PC termékbeszámítással
- 3DKRAFT.HU - 3D NYOMTATÁS - AZONNALI ÁRAJÁNLAT - GYORS KIVITELEZÉS - 500+ POZITÍV ÉRTÉKELÉS
- Fém, összecsukható és kihúzható fotó állvány eladó
Egy próbát megér
Cserébe belinkelem a hozzászólást, ahol elmondtam hogy kell EFI-t csinálni
tlac
