- Honor Magic V2 - origami
- Eltűnhet a Dinamikus Sziget
▼▼▼ ANDROIDOS TABLETEK ▼▼▼
Utolsó frissítés: 2025. március
szilchi
Crytek #16592 üzenetére
Itt van egy rövid leírás az általa talált hibákról:
Got mine today - 5 days delivery to Brisbane, Australia. Quite outstanding.
Anyway - I have a few problems with the thing. Overall, it seems very good.
1. Bluetooth lag between video and audio. Quite unusable. This has been reported by many users, so I was not surprised.
2. Speaker is useless. Also reported by other users. It is worse than my HTC Desire HD phone, and the phone was infamous for being bad.
3. When I plug in the power pack, it often will not charge. If it does, the tablet is unusable. Really weird. If you type on a keyboard, you can get 2,3 (random number of characters) inserted. The screen flickers all over the place. It seems like the screen is generating inputs, so programs close/open etc, causing the flickering. This is more serious, but I guess I can get another power supply.
4. the headphone socket was stuffed. You could not insert the supplied earphones. I was thinking about returning the damn thing just for this alone (as bluetooth is useless, and so are the speakers)...but eventually I was able to force (carefully) the headphone plug into the socket. Very bad quality there...and the earphones are awful quality - they even rattle! Still, seem to have freed up the headphone socket now.It seems very responsive - love the speed. The screen looks good. I thought the Wifi was a bit weak. I have 3 Wifi points here, and initially it only picked up two of them. The third one came in a short time ago, so that is a bit weird.
All in all, not a bad buy. It has some serious problems though that I hope some firmware updates will fix.
Ahogy olvastam más kommentet is,a sebességgel és kijelzővel mindenki elégedett és szerintük ezek a problémák többsége valószínüleg szoftver frissítéssel orvosolhatók.Kivéve talán a fülhalgató-csatlakozóét.
szilchi
A kínainál a felsőbe írod a tr. numbert,amit kaptál,alatta pedig azt az azonosító kódot írod be,ami a 3. sorban fel van tüntetve.Majd katt a jobbra mutató nyílra.De ha gondolod privibe küld el a tr. numbert és megnézem neked.
Pár infó,amit írtak róla (aki már megkapta)
First - limited - comments for my Pandawill Cube after just a few hours:- Firmware/version: running on a custom 1.02 firmware apparantly: Pandawill logo at startup + no chinese apps whatsoever. Non rooted. Very stable so far
- no logo on backside. Don't see other differences. Build quality seems very acceptable
- Lightning fast!
- SCreen is great. Very limited bleeding on one edge, only visible with very dark images. Doesn't disturb me at all
- Wifi seems good, haven't used a test app yet, but get connection all through the house which wasn't the case with my previous tab (an old Ramos). This was my biggest worry
- Limited testing only, but no SD card corruption (yet). Will see furtherÉn csupa nagybetüvel írtam be az azonosító kódot,mert kisbetűnél nekem is írta,hogy rossz a kód
szilchi
hevizms #16543 üzenetére
Nekem végig követte,Shenzen-Hong-Kong-Peking Nemzetközi reptér-Magyarország.De ha Crytek-nél is van 2-3 napos késés az aktualizálásnál,mint nekem,akkor lehet neki is csak 8-án jelenik meg először az adat.Ezért neki is folyamatosan kellene frissíteni a nyomkövetést a posta oldalán.Ja és van egy post Panda fórumán 06.29-én,hogy a sárkányhajó fesztivál miatti 3 napos szünet következtében a Hong-Kong-i reptéren be vannak havazva munkával és késés léphet fel a kiszállításban.Lehet még ezt sem sikerült megoldani.
szilchi
Kh@oSz #16513 üzenetére
Jaa..akkor ok
.Azt hittem,már visszafogták a csomit és értesítették a TEK-et,hogy van egy súlyos áfacsaló az országban,akit el kell fogni.Már láttam szemei elött,amint nézem a TV-t és kinntről hallom,hogy "..FIGYELEM,ITT A RENDŐRSÉG!!...."Majd pár jól szituált,határozott fellépésű álarcos fiatalember berúgja az ajtót.
...Crytek!Ragályos vagy
A kínai oldalt is nézted?A china post csomagkövető oldalát?
Ja és a csomag követésnek kb. 1,5-3 napos késése van.Ma délben még a 3 nappal ezelötti állapot volt
szilchi
KaiotEch #16407 üzenetére
Pedig titokban reméltem,hogy arra elég lesz
Shoo: Ok,kösz.Van egy fölös telenor sim kártyám,arra aktiválnám a klikk-et.Tableten átlag mennyi MB adatforgalom van netezés közben?Gondolom függ az oldaltól.Mert gondolom más a freemail-nél meg más az analslutadventure.com-nál
is.De úgy kb. átlagba..
Már én is bánom,hogy nem rendeltem 6-7 dollárért Pandán műbőr tokot.Pedig azért kellene majd.Itthon vaterán ugyan az a tok már 2100+posta.
szilchi
Tableten mennyi időre elég a telenor-os klikk a 100 MB-al.Csak munkahelyre kellene 3G-s net,max. a 25 perces szünetemben tudnék netezni.Akkor is csak email,estleg PH fórum.
szilchi
Crytek #16396 üzenetére
Nekem is 25-én mondták,hogy utána nap adják fel.Majd 27-én láttam először a nyomkövetési oldalon.Szal 1-2 nap,mire megjelenik ott.Én itt tartok
Vagy nézd meg itt: china mail tracking
Beírod a számot,majd a direct tracking-re böksz.A következő ablakban ismét megadod a tr. számot és beírod alatta a biztonsági azonosíót.A szöveg kínai lesz,szal google fordító ajánlott. -
szilchi
jkutya #16342 üzenetére
Annyit még hozzá tudok szólni a témához,hogy nekem volt tavaly egy Wayteq Xpad 70-es tablet.Azzal elvileg kompatibilis volt a Huawei e220-as 3G-s modem.De nekem mégsem ment.Aztán a fórumában írták,hogy nem csak a modem típusa,hanem a firmware verziószáma is fontos.Mert egy típuson belül lehet több revízió is.És az egyikkel jól megy,a másikkal meg lehet nem.Persze gondolom ez nem jó hír neked.Esetleg próbálj meg szerezni másik firmware-t a modemhez.Hátha..
szilchi
VMatteo: Nekem úton van egy ilyen 18K-s tab Kínából,nekem is alap dolgokra kell (net,Angry Birds,sorozatok nézése divx-ben). Szerintem ehhez épp elég ez a gép is.De konkrétan akkor tudom meg,ha ideér persze.Nehezen találtam egy kisebb tesztet róla és ott azt írta az illető,hogy rootolva érkezett meg hozzá a gép.Így elvileg ezek is rootolhatók.Persze egy teszt alapján nem kell még fixre venni.
Pandawill rendelés témához
ekem,mint írtam,visszaigazoló mailt sem küldtek.A mai napig sem.De miután írtam a fórumban és rákérdeztem,másnap már úton is volt felém és nekem is elküldték privibe a tr. numbert.Szal ezek szerint rákérdezni,különben ráérősre veszik mert azt hiszik nem szólsz ezért nem sürgős.
szilchi
Semmit,mert én ... elfelejtettem,hogy ilyen is van és nem néztem meg
(F)ordítás folyamatban
jelenlegi állapota:átvételi iroda elfogadása (balról 3. oszlop)
rendeltetési ország:Magyarország(balról 4. oszlop)
jelenlegi tartózkodási hely:semmi(5. oszlop)...valószínüleg felküldték föld körüli pályára -
szilchi
Ez gyakori gond,én eddig a legtöbbször IE-vel tudtam belépni.
szilchi
Panda fórumon jött egy privi,hogy tegnap feladták a csomagot.Leírták a tracking number-t is,majd lesem merre tart a csomag.
szilchi
Most írtak a Panda fórumon,hogy három napig Sárkányhajó-fesztivál volt és ezért nem jött válasz nekem,de szólnak a kiszállításnak,hogy mihamarabb adják fel a csomagot.Majd meglássuk,mire lesz meg.
szilchi
Crytek #15794 üzenetére
Nálam pont fordítva volt.Pandawill-en nem adtam meg szállítási címet,viszont Paypal-on meg volt adva.A PP-os számlán ott is volt a címemnél,hogy "unconfirmed".Azért ajánlott megadni Paypal-on a pontos címet,mert van pár Kínai cég,aki csak azt a címet fogadja el ami ott meg van adva,mást nem.De konkrétan itt mi a helyzet azt nem tudom.Én azóta már Pandán is megadtam.Igaz még várok a visszaigazoló mailemre
Mondjuk Shenzhen-ben elvileg 2 óra múlva indul a hétfői délelöttös műszak,szal talán éjfélre már lesz válasz.Mondjuk azért írtam a fórumba is.
szilchi
Pandánál mennyi idő,míg feldolgozzák a megrendelésemet és jön valami visszaigazolás?
szilchi
Crytek #15608 üzenetére
Olvastam olyant is,hogy valaki Magyarországról rendelt és a mailben egyből írták neki,hogy azt írják a csomagra hogy "Gift" így nem lesz gond a vámolással.De olvastam olyant is,hogy külön írta valaki,hogy ne a valós értéket írják rá.Lehet inkább biztosra megyek és megírom nekik.
szilchi
Megrendeltem Pandan a D50 Lite 8Gb-ot.Bár az accountomban még egyenlőre nem látszik a rendelés.Hova kell küldeni a mailt,ha azt szeretném,hogy ne a 77$-t írják rá a csomagra?
szilchi
A Max Payne és a GTA3 mennyi eséllyel indul el egy occó kinai tableten?Vagy ezek kicsit túl nagy falatok lennének egy ilyen gépnek?Gondolom minimum tegra procis gép kellene neki.
szilchi
Igen,erre én is gondoltam hogy mostanában elég jól alakul az árfolyam és rendelni kellene egy Tab-ot, mielőtt jönne egy újabb ostoba Matolcsy-beszólás amitől megint romlani fog a Forint
Az ICS-nek mennyi ram előnyösebb?Az 512 vagy az 1GB?Az olcsóbb tabletek közt találtam egy ilyent [link],ez 8$-al több,mint amit néztem és ez már 1 GB Ram-al van.
szilchi
kisgyerek85 #15330 üzenetére
Esetleg megnézed melyiket támogatja és körülnézel itt hardveraprón.Lehet 2-3 ezerért már kapsz is olyant.
szilchi
kisgyerek85 #15319 üzenetére
Igen,azt jelenti.De nem biztos,hogy a meglévő modemedet támogatja.A legtöbb tablet csak pár mobil stick támogatásával rendelkezik.
szilchi
illes.bence #15262 üzenetére
Bár csak felületesen néztem át a két tablet tulajdonságait,de azt kell mondjam gyk. ugyan az a 2 gép.Talán annyi,hogy a Ghoo tab 10 g-al könyebb.Én a Concorde-ra szavazok,mert azt ki tudod próbálni.Ha meg az nem tetszik,akkor még ott a Ghoo.
szilchi
Üdv.Keresőben nézve láttam páran gondolkoztak egy ilyen tablet vásárlásán:
ICOO D50 Lite A13
Aki megvette,az esetleg tudna róla vélemény formálni..Találtam róla egy orosz Youtube-os videót[link],azon jól néz ki és a működése is meggyőző (nekem)de nem értem mit mond (hiába,csak 1 évig tanultam oroszt..).Kivéve a végén a dászvidányá
- Intel Core i7-8700, i7-9700 CPU, processzor - Számla, garancia
- Samsung Galaxy A32 4G 128GB, Kártyafüggetlen, 1 Év Garanciával
- Magyarország piacvezető szoftver webáruháza
- Csere-Beszámítás! Asus Rog Strix GTX 1080Ti 11GB GDDR5X Videokártya!
- Steam, EA, Ubisoft és GoG játékkulcsok, illetve Game Pass kedvező áron, egyenesen a kiadóktól!
