csixy
Mint a vilám , úgy bootol! Klón .... igaz scriptből van, de jó !
csixy
Frawly #64286 üzenetére
[senki@fatengelyes-pc ~]$ sudo smartctl -t short /dev/sdb
[sudo] senki jelszava:
smartctl 6.6 2017-11-05 r4594 [x86_64-linux-4.19.8-arch1-1-ARCH] (local build)
Copyright (C) 2002-17, Bruce Allen, Christian Franke, www.smartmontools.org=== START OF OFFLINE IMMEDIATE AND SELF-TEST SECTION ===
Sending command: "Execute SMART Short self-test routine immediately in off-line mode".
Drive command "Execute SMART Short self-test routine immediately in off-line mode" successful.
Testing has begun.
[senki@fatengelyes-pc ~]$ sudo smartctl -t short -a /dev/sdb
Copyright (C) 2002-17, Bruce Allen, Christian Franke, www.smartmontools.org=== START OF INFORMATION SECTION ===
Model Family: Indilinx Barefoot based SSDs
Device Model: Corsair CSSD-V32GB2
Serial Number: 10340061080009870002
Firmware Version: 2.1
User Capacity: 32.017.047.552 bytes [32,0 GB]
Sector Size: 512 bytes logical/physical
Rotation Rate: Solid State Device
Device is: In smartctl database [for details use: -P show]
ATA Version is: ATA8-ACS (minor revision not indicated)
Local Time is: Sun Dec 16 20:51:54 2018 CET
SMART support is: Available - device has SMART capability.
SMART support is: Enabled=== START OF READ SMART DATA SECTION ===
SMART Status not supported: Incomplete response, ATA output registers missing
SMART overall-health self-assessment test result: PASSED
Warning: This result is based on an Attribute check.General SMART Values:
Offline data collection status: (0x00) Offline data collection activity
was never started.
Auto Offline Data Collection: Disabled.
Self-test execution status: ( 249) Self-test routine in progress...
90% of test remaining.
Total time to complete Offline
data collection: ( 0) seconds.
capabilities: (0x1d) SMART execute Offline immediate.
No Auto Offline data collection support.
Abort Offline collection upon new
command.
Offline surface scan supported.
Self-test supported.
No Conveyance Self-test supported.
No Selective Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x00) Error logging NOT supported.
General Purpose Logging supported.
recommended polling time: ( 0) minutes.
Extended self-test routine
recommended polling time: ( 0) minutes.SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x0000 --- --- --- Old_age Offline - 6
9 Power_On_Hours 0x0000 --- --- --- Old_age Offline - 490
12 Power_Cycle_Count 0x0000 --- --- --- Old_age Offline - 807
184 Initial_Bad_Block_Count 0x0000 --- --- --- Old_age Offline - 11
195 Program_Failure_Blk_Ct 0x0000 --- --- --- Old_age Offline - 0
196 Erase_Failure_Blk_Ct 0x0000 --- --- --- Old_age Offline - 0
197 Read_Failure_Blk_Ct 0x0000 --- --- --- Old_age Offline - 0
198 Read_Sectors_Tot_Ct 0x0000 --- --- --- Old_age Offline - 4239321810
199 Write_Sectors_Tot_Ct 0x0000 --- --- --- Old_age Offline - 2198158606
200 Read_Commands_Tot_Ct 0x0000 --- --- --- Old_age Offline - 90344251
201 Write_Commands_Tot_Ct 0x0000 --- --- --- Old_age Offline - 38618593
202 Error_Bits_Flash_Tot_Ct 0x0000 --- --- --- Old_age Offline - 11514890
203 Corr_Read_Errors_Tot_Ct 0x0000 --- --- --- Old_age Offline - 10661672
204 Bad_Block_Full_Flag 0x0000 --- --- --- Old_age Offline - 0
205 Max_PE_Count_Spec 0x0000 --- --- --- Old_age Offline - 5000
206 Min_Erase_Count 0x0000 --- --- --- Old_age Offline - 533
207 Max_Erase_Count 0x0000 --- --- --- Old_age Offline - 1156
208 Average_Erase_Count 0x0000 --- --- --- Old_age Offline - 899
209 Remaining_Lifetime_Perc 0x0000 --- --- --- Old_age Offline - 83
211 SATA_Error_Ct_CRC 0x0000 --- --- --- Old_age Offline - 0
212 SATA_Error_Ct_Handshake 0x0000 --- --- --- Old_age Offline - 0
213 Indilinx_Internal 0x0000 --- --- --- Old_age Offline - 0Warning! SMART ATA Error Log Structure error: invalid SMART checksum.
SMART Error Log Version: 1
No Errors LoggedWarning! SMART Self-Test Log Structure error: invalid SMART checksum.
SMART Self-test log structure revision number 1
No self-tests have been logged. [To run self-tests, use: smartctl -t]Selective Self-tests/Logging not supported
Can't start self-test without aborting current test (90% remaining),
add '-t force' option to override, or run 'smartctl -X' to abort test.
[senki@fatengelyes-pc ~]$ -
csixy
ubyegon2 #64273 üzenetére
[senki@fatengelyes-pc ~]$ sudo smartctl -a /dev/sdb
Local Time is: Sun Dec 16 19:43:03 2018 CET
was never started.
Self-test execution status: ( 0) The previous self-test routine completed
without error or no self-test has ever
been run.
command.
power-saving mode.
9 Power_On_Hours 0x0000 --- --- --- Old_age Offline - 489
198 Read_Sectors_Tot_Ct 0x0000 --- --- --- Old_age Offline - 4239304818
199 Write_Sectors_Tot_Ct 0x0000 --- --- --- Old_age Offline - 2197665990
200 Read_Commands_Tot_Ct 0x0000 --- --- --- Old_age Offline - 90343929
201 Write_Commands_Tot_Ct 0x0000 --- --- --- Old_age Offline - 38610438
202 Error_Bits_Flash_Tot_Ct 0x0000 --- --- --- Old_age Offline - 11514836
203 Corr_Read_Errors_Tot_Ct 0x0000 --- --- --- Old_age Offline - 10661622
208 Average_Erase_Count 0x0000 --- --- --- Old_age Offline - 898
csixy
ubyegon2 #64266 üzenetére
[senki@fatengelyes-pc hdsentinel]$ sudo ./hdsentinel-017-x64
Hard Disk Sentinel for LINUX console 0.17x64.8556 (c) 2017 info@hdsentinel.com
Start with -r [reportfile] to save data to report, -h for helpExamining hard disk configuration ...
HDD Device 0: /dev/sda
HDD Model ID : KINGSTON SA400S37480G
HDD Serial No: 50026B76826717B0
HDD Revision : SBFKB1C2
HDD Size : 457863 MB
Interface : S-ATA Gen3, 6 Gbps
Temperature : 30 °C
Highest Temp.: 41 °C
Health : 100 %
Performance : 100 %
Power on time: 0 days, 23 hours
Est. lifetime: more than 1000 days
The status of the solid state disk is PERFECT. Problematic or weak sectors were not found.
The health is determined by SSD specific S.M.A.R.T. attribute(s): #233 Media Wearout Indicator
No actions needed.HDD Device 1: /dev/sdb
HDD Model ID : Corsair CSSD-V32GB2
HDD Serial No: 10340061080009870002
HDD Revision : 2.1
HDD Size : 30534 MB
Interface : SAT Standard SCSI/USB/ATA
Temperature : Unknown °C
Highest Temp.: Unknown °C
Health : 83 %
Performance : 100 %
Power on time: 20 days, 6 hours
Total written: 1.02 TB
The health is determined by SSD specific S.M.A.R.T. attribute(s): #209 Remaining Drive Life
It is recommended to continuously monitor the hard disk status.[senki@fatengelyes-pc hdsentinel]$
csixy
ubyegon2 #64264 üzenetére
[senki@fatengelyes-pc ~]$ sudo journalctl -u fstrim.timer
-- Logs begin at Sun 2018-12-16 13:56:00 CET, end at Sun 2018-12-16 17:11:30 CET. --
dec 16 16:58:10 fatengelyes-pc systemd[1]: Started Discard unused blocks once a week.
[senki@fatengelyes-pc ~]$ systemctl list-timers -a
NEXT LEFT LAST PASSED UNIT ACTIVATES
Mon 2018-12-17 00:00:00 CET 6h left n/a n/a fstrim.timer fstrim.service
Mon 2018-12-17 00:00:00 CET 6h left Sun 2018-12-16 00:00:09 CET 17h ago logrotate.timer logrotate.service
Mon 2018-12-17 00:00:00 CET 6h left Sun 2018-12-16 00:00:09 CET 17h ago man-db.timer man-db.service
Mon 2018-12-17 00:00:00 CET 6h left Sun 2018-12-16 00:00:09 CET 17h ago shadow.timer shadow.service
Mon 2018-12-17 00:00:00 CET 6h left Sun 2018-12-16 00:00:09 CET 17h ago updatedb.timer updatedb.service
Mon 2018-12-17 01:17:27 CET 8h left Sat 2018-12-15 22:57:08 CET 18h ago reflector.timer reflector.service
Mon 2018-12-17 14:11:33 CET 20h left Sun 2018-12-16 14:11:33 CET 3h 0min ago systemd-tmpfiles-clean.timer systemd-tmpfiles-clean.service
Sat 2019-01-05 15:00:00 CET 2 weeks 5 days left Sat 2018-12-15 22:57:08 CET 18h ago pamac-cleancache.timer pamac-cleancache.service8 timers listed.
csixy
ubyegon2 #64247 üzenetére
-- Logs begin at Sun 2018-12-16 07:40:04 CET, end at Sun 2018-12-16 12:26:06 CET. --
-- No entries --
Mon 2018-12-17 00:00:00 CET 11h left Sun 2018-12-16 00:00:09 CET 12h ago logrotate.timer logrotate.service
Mon 2018-12-17 00:00:00 CET 11h left Sun 2018-12-16 00:00:09 CET 12h ago man-db.timer man-db.service
Mon 2018-12-17 00:00:00 CET 11h left Sun 2018-12-16 00:00:09 CET 12h ago shadow.timer shadow.service
Mon 2018-12-17 00:00:00 CET 11h left Sun 2018-12-16 00:00:09 CET 12h ago updatedb.timer updatedb.service
Mon 2018-12-17 07:55:38 CET 19h left Sun 2018-12-16 07:55:38 CET 4h 31min ago systemd-tmpfiles-clean.timer systemd-tmpfiles-clean.service
Mon 2018-12-17 11:31:12 CET 23h left Sat 2018-12-15 22:57:08 CET 13h ago reflector.timer reflector.service
Sat 2019-01-05 15:00:00 CET 2 weeks 6 days left Sat 2018-12-15 22:57:08 CET 13h ago pamac-cleancache.timer pamac-cleancache.service7 timers listed.
[senki@fatengelyes-pc ~]$ fstrim
fstrim: no mountpoint specified
[senki@fatengelyes-pc ~]$ fstrim -hUsage:
fstrim [options] <mount point>Discard unused blocks on a mounted filesystem.
Options:
-a, --all trim all mounted filesystems that are supported
-o, --offset <num> the offset in bytes to start discarding from
-l, --length <num> the number of bytes to discard
-m, --minimum <num> the minimum extent length to discard
-v, --verbose print number of discarded bytes-h, --help display this help
-V, --version display versionFor more details see fstrim(8).
[senki@fatengelyes-pc ~]$ fstrim -a
csixy
ubyegon2 #64243 üzenetére
[senki@fatengelyes-pc ~]$ cat /etc/fstab
# /etc/fstab: static file system information.
# Use 'blkid' to print the universally unique identifier for a device; this may
# be used with UUID= as a more robust way to name devices that works even if
# disks are added and removed. See fstab(5).
# <file system> <mount point> <type> <options> <dump> <pass>
/dev/mapper/luks-efe99217-5e96-4de1-b0f7-1a7c3bae2304 / ext4 defaults,noatime 0 1
UUID=84576768-3b25-4512-b57d-67737cb63cf1 swap swap defaults,noatime 0 2
[senki@fatengelyes-pc ~]$ systemctl cat fstrim.timer
# /usr/lib/systemd/system/fstrim.timer
[Unit]
Description=Discard unused blocks once a week
Documentation=man:fstrim[Timer]
OnCalendar=weekly
AccuracySec=1h
Persistent=true[Install]
WantedBy=timers.target
Mon 2018-12-17 00:00:00 CET 13h left Sun 2018-12-16 00:00:09 CET 10h ago logrotate.timer logrotate.service
Mon 2018-12-17 00:00:00 CET 13h left Sun 2018-12-16 00:00:09 CET 10h ago man-db.timer man-db.service
Mon 2018-12-17 00:00:00 CET 13h left Sun 2018-12-16 00:00:09 CET 10h ago shadow.timer shadow.service
Mon 2018-12-17 00:00:00 CET 13h left Sun 2018-12-16 00:00:09 CET 10h ago updatedb.timer updatedb.service
Mon 2018-12-17 07:55:38 CET 21h left Sun 2018-12-16 07:55:38 CET 2h 47min ago systemd-tmpfiles-clean.timer systemd-tmpfiles-clean.service
Mon 2018-12-17 11:31:12 CET 24h left Sat 2018-12-15 22:57:08 CET 11h ago reflector.timer reflector.service
Sat 2019-01-05 15:00:00 CET 2 weeks 6 days left Sat 2018-12-15 22:57:08 CET 11h ago pamac-cleancache.timer pamac-cleancache.service7 timers listed.
csixy
ubyegon2 #64235 üzenetére
/- senki@fatengelyes-pc
ooo: --------------------
yoooo/ OS: ArcoLinuxB-plasma v18.11.2
yooooooo Kernel: 4.18.16-arch1-1-ARCH
yooooooooo Uptime: 1 hour, 7 mins
yooooooooooo Packages: 1611 (pacman)
.yooooooooooooo Shell: bash 4.4.23
.oooooooooooooooo Resolution: 1366x768
.oooooooarcoooooooo DE: KDE
.ooooooooo-oooooooooo WM: KWin
.ooooooooo- oooooooooo Theme: KvOxygen [KDE], Breeze [GTK2/3]oooooooo.
oooooooo Icons: Adwaita [KDE], breeze [GTK2/3]
oooooooo.
oooooooo Terminal: konsole
ooarcooo .oooarcooo Terminal Font: Noto Sans Mono 11
oooooooy .ooooooooo CPU: Intel Celeron 1000M (2) @ 1.800GHz
oooooooo /ooooooooooooooooooo GPU: Intel 3rd Gen Core processor Graphics Controller
oooooooo .-ooooooooooooooooo. Memory: 995MiB / 5856MiB
ooooooooo- -ooooooooooooo.
ooooooooo- .-oooooooooo.
ooooooooo. -ooooooooo[senki@fatengelyes-pc ~]$ sudo journalctl -u fstrim.timer
-- Logs begin at Sun 2018-12-16 07:40:04 CET, end at Sun 2018-12-16 08:47:23 CET. --
-- No entries --
csixy
CPT.Pirk #63767 üzenetére
A hdparmos parancsokból kellene egy biztonságos scriptet írni erre a célra , azt már akár egy Slax distróba is bele lehetne rakni és akkor fuccsba mehetne a Parted Magic üzlete.
(#63775) Doky586:
Hát ez érdekes, mert a leírásokat olvasva azt gondolná az ember , hogy a hdparm utasításokat egy működő linux rendszerben hajtják végre. Tehát mondjuk a /dev/sda -ról van elindítva és üzemelve az OS és például a /dev/sdb SSD-t bizgerélik vele. Azt viszont olvastam, hogy csak alaplapi SATA portra dugott kütyüt lehet vele gyógyítani, USB-s kütyüt nem , mert ha ott elindulna a folyamat , akkor féltéglát, vagy levélnehezéket csinálna az USB-s kütyüből. -
csixy
Doky586 #63772 üzenetére
Ezt találtam:
https://www.thomas-krenn.com/en/wiki/SSD_Secure_Erase
Kérdezem ,ha ez így működőképes úgy, hogy még root jog sem kell hozzá, akkor egy akármilyen live distróból konzolban meg lehet csinálni az egész hadműveletet ?Már látom kicsit lemaradtam
csixy
ubyegon2 #63745 üzenetére
Köszönöm szépen!
Jó játék.
Úgy érted , hogy láttad előre az agyam megindulását?
A manjaróban azt az egyet nem szeretem, hogy ha egy másik linux új kernelt telepít és újraconfigolja a Grubot akkor a manjaro bootja bex@rik legacy rendszer esetén - UEFI-vel már nem csinálja ezt."Nekem az imént meg a teljes SSD tűnt el": Mérd ki a tápegységet "terhelővillával".
csixy
Frawly #63550 üzenetére
Engem a Slax elcsábított! Hátha kipróbálja valaki a picinyke első bálos buildecskémet. Örülnék neki!
csixy
Frawly #63549 üzenetére
Frász álljon bele ! Ott van a lehetőség a fluxboxban. Már perzisztensen el is mentette a magyar billentyűzetet. Még barkácsolni sem kellett vele.
Jó a küzdés. Linux mintből törölten a penről az egész slax mappát és betoltam a régi helyett egy új gyárit ,amin nincsenek elállítgatva a jogosultságok . A bootinst.sh fájlt már úgysem kell futtatnom a boot könyvtárból , mert a pendrájv MBR-jében még úgyis ott él a korábban ákom-bákom módon megcsinált bootsector. Így most lett egy gyári szűz Ext4-re tett slax telepítésem. Ezt már megőrzöm.
King Unique : Köszi a kiigazítást!
csixy
Egyenlőre csak Legacy módot tud, de már Tomáš Matějíček tervezi az UEFI verzió megvalósítását is.
csixy
Hát nem egy Windows to go, De attól sokkal jobb!
Még spéci pendrájv sem kell hozzá. Be lehet simán akár a RAM-ba tölteni, vagy perzisztens módban indítani, vagy szűz gyári állapotban indítani.
Még az lenne az érdekes, ha egy optimális perzisztens módból egy kis optimalizált "gyári" mini disztrót lehetne csinálni. -
csixy
csixy
Victor Súgó #63525 üzenetére
csixy
Aksomatic #63345 üzenetére
Ja bocs , ezt:https://prohardver.hu/tema/linux_abszolut_kezdoknek/hsz_63363-63363.html neked akartam írni.
Biztonságos és egy virtuális telepítgetéstől jóval többet ér, mert valós rendszered lesz.
csixy
Shyciii #63362 üzenetére
add ki a sudo pacman -Syu parancsot és látni fogod , hogy van még egy tároló, amire rákeres és arra nincs szükséged, de azt egy #-tel ki lehet iktatni , vagy inkább kettővel ,majd a többiek megmondják, hogy melyik fájlban kell kilőni.
asszem a mirrorlist végén van a bejegyzés.
csixy
MBR esetén jó megoldás, ha bedugsz egy pendrájvot is és a linux bootladerét telepítéskor oda irányítod /dev/sdb például, ha a pendrájv az sdb, így szűzen megmarad a windowsod, ha az SSD-ről bootolsz. Ha pedig a pendrájvról bootolsz akkor meg a GRUB fog indulni és választhatsz az indítható oprendszerek közül.
csixy
ubyegon2 #63318 üzenetére
Most épp egy ócska technika tyilivízort használok 1360x768-as (tudna még 1920x1080-at, de úgy túl aprók a betűk) felbontással HDMI átalakítóval a 10 éves flexelt keskeny kliensem DysplayPortjáról. Tökjó, csak a talpát alá kell támasztani egy csomag papírzsepivel ,mivel nem dönthető. Ez így jobb mint a DVI-VGA átalakító, mert így nincs tudathasadása a linuxnak és így nem nyitja ki folyton az ablakaimat a "másik" nem látható DVI képernyőre. ... A szemüvegem műxik, de nekem a minták egyformák. Jól olvashatók.
szórakozottságomban meg akartam dönteni és eltört a nyele , de a zselés cyanakrilát megfogta rendesen.
csixy
DP-ról DP-HDMI átalakítóval nincs hang. AMD HD Audio Device, AMD Radeon HD 6310 Graphics . Ez így nómális? Még jó, hogy van a monitoron egy stereo Jack luk is.
Más: Egy új monitoron már csak két HDMI port van és egy kék fülhallgató kimenet. Erre a kütyüre sehol semmilyen rendszerben nem tudok hangot csiholni. Egyszer kétszer beledugtam a sztereo Jack-es hangot is . Lehet, hogy azt nem díjazta, vagy esetleg mechanice kiakadt itt a hangleválasztó netán és azért nem szól sehogy se ? Persze headphone-t még eddig nem dugtam bele. Vagy netán ehhez már valami fullosabb HDMI kábel kellene? Dehát a gyári kábelével sem megy a hangja.
csixy
ubyegon2 #62982 üzenetére
Most, hogy a Win10 "megajándékozott" egy a fotóimból kreált albummal és még egy videót is csinált nekem belőle szintén kérés nélkül és még a téma nevét is helyesen találta el , végleg felforrt a gyomorsavam !!!! Már újra beizzítottam egy linux mintet, beleplántáltam a kedvenc Irfan View-mat (ezt engedjétek meg nekem pls !) és jól működik az Evolution levelezője is. A ma estét végig neteltem a L Minten és észre sem vettem , hogy nem az ablakok működnek épp nekem és már ideje lefeküdni aludni. Azért marad a pici puha op rendszere is ha már megvan,de csak igen válogatott esetekben fogom használni. Marad nekem a Mint , meg a Manjaro.
csixy
Mit lehet kezdeni ezzel a 1.55 no IRQ handler for vector boot üzenettel? -
csixy
King Unique #62021 üzenetére
Ha van a gépben legalább 4 Giga ram a 64 bites win10-nek, vagy a 32bitesnek 2,66 Giga ram , akkor már nem olyannyira akadós a járása.Szerény tapasztalataim szerint. Azért minden gépemen van telepítve még legalább egy linux is.
csixy
Ha az indított alkalmazás azon a képernyőn nyílik meg amit nem látsz , akkor a jobb gomb move egér áttolás és visszahúzással be tudod húzni a látóteredbe az indított alkalmazást. Még egyszerűbb hogy az alkalmazás indítása után az egereddel gyorsan belekattintasz a látható képernyődbe.
csixy
SwissAirplan #61474 üzenetére
A gond akkor szokott jelentkezni, ha DVI-VGA átalakítóval teszed a DVI kimenetre a VGA bemenetű monitort. Ekkor lesz két képernyőd a beállításoknál, de az EDID infók a VGA felől nem jutnak el az OP rendszerig és nem tudsz csak alacsony felbontást beállítani mert nem tud értesülni arról, hogy mit tud a monitorod , ha meg törlöd a DVI képernyőt, akkor nem lesz VGA képernyőd sem és képed sem.
De van megoldás ! Szánj rá egy kis időt, hátha bejön ez neked is.
A cvt -vel arra a felbontásra kérdezz rá , amiben biztos vagy , hogy monitorodnak tudnia kellene azt a felbontást. -
csixy
Frawly #61497 üzenetére
Akármilyen SSD szaki vagy, ebben most még egy picit várj ki , mert nem olyan egyszerű a 2 , meg 4 gigás régi SSD helyére rendes SSD-t betolni egy átlagos vékonykliensbe. A SATA toldókábel pedig megint nem eccerű, mert pont fordított lesz az ADAT része. A RAM-nál meg külön élmény ha el tud tántorodni az 1 gigától.
Jaaa!! Én most épp egy ehhez hasonló vékonykliensről folytatom veled a diskurát .
Amiben valóban egy beleflexelt Samsung 470-es SSD van. De ezt a végét a mostani témának már Te is tudod töviről hegyire, csak akkor a lovagitornás dárdádat nem értem mostan éppen.
csixy
SwissAirplan #61482 üzenetére
A gépedbe simán belefért az SSD?
csixy
ubyegon2 #60444 üzenetére
A CSM még lehetővé teszi a hagyományos Legacy módot.
CSM booting
To ensure backward compatibility, most UEFI firmware implementations on PC-class machines also support booting in legacy BIOS mode from MBR-partitioned disks, through the Compatibility Support Module (CSM) that provides legacy BIOS compatibility. In this scenario, booting is performed in the same way as on legacy BIOS-based systems, by ignoring the partition table and relying on the content of a boot sector. -
csixy
Frawly #60330 üzenetére
Ne kavard már meg , szerintem egy sima legacy - MBR alap telepítésre szeretné rávezetni a Kapitány. Előbb a vinnyóz menne föl egy előre megcsinált hátrafelé Ext4-es partícióval lehatárolt üres partícinálatlan helyre a vinyó , vagy SSD elejére, Majd mögé az Ext4-es partícióra újra formálván a /-ba menne a linux automatikus Grub telepítéssel a /dev/sda-ra. Oszt ennyi lenne.
Ja most látom , hogy GPT- UEFI sémát követ a koma.
csixy
csixy
ubyegon2 #60249 üzenetére
Egyenlőre erről nem írnék tanulmányt. A vinyókettyegettetést csak ez a döglött solus csinálta újra bootolási próbálkozás közben. Ebbe a hp250-esbe pedig a fiam sony waiojából megörökölt 750gigás vinyó került ami eddig hibátlan volt.. A flexelt kis keskeny kliensemen már egy refurbished win 10 pro és egy manjaro kde dübörög békés egymás mellett élésben.
csixy
Frawly #60234 üzenetére
Köszönöm! Végül lévén hogy még sok adat nem volt benne a solus után a manjarot is újra telepítettem egy kiterjesztett logikaiba, a régi partícióját meg megcsináltam /adat exfatként a vinyón. Az mbr maradt, mert a munkahelyi progihoz majd 32 bites windows fog kelleni. Uj tocsikot meg nem nyitok.
csixy
Na fent van a Solus Budgie . Egyenlőre első blikkre tetszik. Van már a Solusnak tocsikja? Ha nincs nem lenne-e érdemes neki nyitni egyet?
csixy
Legacy rendszeren jelenleg a harmadik primary partíción leledzik egy manjaró . A kérdés az lenne, hogy ezt a partíciót bele tudhatom-e valahogy szerkeszteni egy most még nem létező kiterjesztett partícióba logikai partíciónak? Vagy kisebb szenvedés lenne egy újratelepítés?
csixy
Drughi #60087 üzenetére
Az UEFI-"BIOS"-ba be tudsz lépni?
Shiftes újraindítással, vagy a képen jelzett módon el kellene jutnod az UEFI-"BIOS"-ba és a SECURE BOOT-ot kikapcsolni.Ha majd eljutsz a telepítésig, előfordulhat , hogy a képernyőn keresztben 90°-kal elfordulva lesz a kép, legalábbis az asus transformer 101HA kütyümön így csinálja windows és linux telepítéskor is és telepítés után majd menűből kell normálisra beállítani.
Mindjárt kapok uborka úrtól , de én a fenti kütyüre ubit nem tudtam feletenni, viszont Mintet ill manjarót igen.
csixy
Rimuru #60075 üzenetére
Természetesen teljesen nem biztos, hogy tudom, de már használtam korábban és működött. Tudom ,hogy bizonyos biztonsági kockázatai vannak a használatának, de a segítségével lehet grubot telepíteni partícióra.
installing grub2 to a partition
"Run: chattr -i /boot/grub/i386-pc/core.img. This will unlock the GRUB2 core code file for updating, if it isn't unlocked already."
csixy
csixy
Frawly #60015 üzenetére
Köszönöm szépen ezt is és a linkgyűjteménynek is örülnénk szerintem itt egy jópáran. Várjuk.
A Manjari KDE is ARCH alapú és így diff diag céljára jó lehet egy próbatelepítésnek, bootoláskor a billentyűzetet állítsd magyarra , a többi ráér később.
Apropos antergos: az ősöreg kis flexezett EFI-s masinámba beletört a bicskája, a legacy MBR-es HP250G1-re meg csont nélkül felment dualbootban.
csixy
Nekem is van egy ilyen vasam ,igaz, az EL1600-as. Egyetlen baja, hogy csak egy darab 2 gigás RAM fér bele.
Én némi táp átcinezéssel tudtam beletenni az SSD-t a DVD SATA kábelére és a DVD-t ATAPI portosra cseréltem ki. Összességében az atom-kétgiga ram párosítás kínosan lassú kombináció sajnos. -
csixy
Bubisati #59659 üzenetére
Milyen billentyűzet van rajta a vason?
ez a hagyományos alapértelmezett magyar 105 gombos qwertz billentyűzet.Ilyen? Ha nem akkor milyen?
csixy
Jajj most segítsetek.
A keskeny kliensemet DVI-VGA átalakítóval használom. Van telepítve egy manjaro-KDE 64 bites verzió.
A VGA kimenetnek végre sikerült megtanítanom az 1368x768-as outputot 60 Herzen.
Már majdnem minden jó volt. Egyetlen probléma , hogy időnként egy-egy megnyitott progit a baloldali DVI képmezőbe rakott ki, ilyenkor jobb klikk a tálcaikonra MOVE kiválaszt , egér balra kitol , majd visszahúz és imhol a VGA képmezóben a progi ablaka. Hurrá. Gondoltam, hogy letiltom a DVI kimenetet ..... hát ezt nem kellett volna, mert így se DVI, se VGA.
Most itt vagyok vakon. Hogyan tudok egyből konzolba bootolni, még mielőtt letiltaná a DVI kimenetet és mit írjak be, hogy újra engedélyezve legyen a DVI kimenet?Help me !!!!
csixy
ubyegon2 #59571 üzenetére
Én ezt töltöttem le , a telepítő segéd jól működik, de borzasztóan néz ki, mint egy gyerekjátszótér. Kiválogathatod, hogy mit szeretnél és szépen sorban leszedegeti a netről a hozzávaló legfrissebb csomagokat. A telepítő segéd neve is általam megjegyezhetetlen.
UEFI módban pakolásztam. Tökjó lett az eredmény. Próbáld ki és lesz egy hivatalos archod antergos néven.Most az egér megint tökéletes, valamit a kde menüben állítopttam rajta még éjjel a kikapcsolás előtt.
csixy
Felbátorkodtam egy Antergos KDE-t a laposomra. Egyből a legfrissebb csomikat tolta. Pöpecz ! Még az egérgörgő is egyből tudja , hogy mi a dolga.
csixy
Frawly #59442 üzenetére
Ez a cikk http://www.randomshouting.com/2012/12/09/How-to-override-the-screen-resolution.html jó lesz nekem valamire?
csixy
Az antergos miért az1920x1080-as felbontást nyomatja egyből ? Miért nem kezdi mondjuk 800x600-on első induláskor. Csak, hogy megőrüljön a júzer? Hogy lehet ezt gyógyítani? Már meg fogok bolondulni, egy hete lassan, hogy linuxokat telepítek. A végén vissza fogom tenni a manjarót a catalysttal, mert úgy jól működik. A frász essen bele.
csixy
Work in progress
csixy
lev258 #59379 üzenetére
Hát most kénytelen vagyok windowsból írni.Leszedtem az atit, meg a configját és mostmár farkasszemet nézhetek egy konzolos parancssorral. Már olyan öreg vagyok, hogy be tudok loginolni és utána ott nézek farkasszemet a parancssorral. Hüdejoó!
Na mehetek a wikire okosodni , majd kinyomtathatom. Mert ugye így még kopipastázni sem tudok sajna.
csixy
#79715584 #59363 üzenetére
"A harmadik problémám - ha nevezhetjük annak -, hogy a képernyőfelbontást nem tudtam optimálisra beállítani."
Na a képernyő beállítással én is szívtam ma éjjel 3-4 óra hosszat mint a torkos borz a kicsi slim okos radeon kártyájával, meg az acer emachinestől megörökölt buta monitorral ( már elfáradt a karom a buta monitor és az okos monitor oda-vissza csereberélgetése miatt) amíg megtaláltam , hogy hol van a kutya elásva. Már a guta kerülgetett a not supported képernyőktől mire erre a beállításra rátaláltam:
Milyen program ami... [link]
- Vélemény Ubuntu 20.04 LTS
- Tudástár MX-Linux 19
- Revolut
- Formula-1 humoros
- Mit tehetsz jogilag, ha átvertek, megkárosítottak a Hardveraprón?
- Óra topik
- Formula-1
- Fizetős szoftverek ingyen vagy kedvezményesen
- Nintendo Switch 2
- Adobe Előfizetések - Adobe Creative Cloud All Apps - 12 Hónap - NYÁRI AKCIÓ!
- Bontatlan - BATTLEFIELD 1 Collectors Edition - Játékszoftver nélkül
- iKing.Hu - Motorola Edge 50 Ultra - Nordic Wood - Használt, karcmentes
- AKCIÓ! Apple iPad Pro 11 2024 1TB WiFi + Cellular tablet garanciával hibátlan működéssel
- Apple iPhone SE 2020 64GB Kártyafüggetlen 1Év Garanciával
- Samsung Galaxy Xcover 6 Pro, 6/128 GB, Kártyafüggetlen
- AKCIÓ! Lenovo IS8XM LGA 1150 DDR3 alaplap garanciával hibátlan működéssel
