- Poco F6 5G - Turbó Rudi
gyurma111
Indiant #7085 üzenetére
Root is van meg gyors is meg jól bánik a memóriával is.
4.4.4-vel kezd,ez felrakja a TWRP-t.
Ne ijedj meg,ha elsőre nem sikerül és kilép.Nálam harmadik próbálkozásra rakta fel.
Persze csak a TWRP-t
Utánna mehet a romozás.
A korábban belinkelt videót feltétlen nézd meg!!....ha mégsem tetszik (ez kizárt) van visszaút mégpedig a stock rom!!
ui: meg válaszolni kéne néhány kék emailra is
Indiant
Indiant #7072 üzenetére
The users of Samsung P1000 Galaxy Tab can now update their handsets to Android 5.0 Lollipop using custom ROM. The new Android 5.0 Lollipop comes with many new features :
- Up to 4x performance improvements.
- A battery saver feature which extends device use by up to 90 mins.
- It has a faster, smoother and more powerful computing experience.
- Support for 64-bit SoCs using ARM, x86, and MIPS-based cores.
- OpenGL ES 3.1 and Android extension pack brings Android to the forefront of mobile graphics putting it on par with desktop and console class performance.
- Responsive, natural motion, realistic lighting and shadows, and familiar visual elements make it easier to navigate your device.
- More intelligent ranking of notifications based on who they’re from and the type of communication. See all your notifications in one place by tapping the top of the screen.
- New devices come with encryption automatically turned on to help protect data on lost or stolen devices.
- SELinux enforcing for all applications means even better protection against vulnerabilities and malware.
- State of the art video technology with support for HEVC main profile to allow for UHD 4K 10-bit video playback, tunneled hardware video decoding to save power and improved HLS support for streaming.
- and other cool features.Here are some more aspects that users should know before trying out the custom ROM :
- Users need to have proper back-up for their personal data on the device.
- The handset should have at least 80 percent of battery power.
- The users also need to ensure that USB Debugging is enabled on the device.
- During the installation, if the device gets stuck on booting, users can perform wipe cache partition and wipe dalvik before rebooting the device.HOW TO INSTALL :
1- Install TWRP Manager APK ; open it and install TWRP recovery
2- Move the rom and gapps to externel SDcard
3- Restart your device in the recovery mode
4-WIPE /select : dalvik cache , system , cache and data
5- Install rom and gapps
6- Install SuperSU.ZIP
7- RebootTHANKS TO MY friend Humberto Borba
Indiant
Indiant #7063 üzenetére
Videó hozzá, sajnos link még nincs
gabrielarky
gabrielarky
Indiant #7001 üzenetére
Nah, közben lehet megtaláltam a megoldást és viszonylag közel. (UK, nem pedig mondjuk kína v. india)
Ha az egész tönkrement (nekem csak az LCD tűnik annak, mivel a hátára esett a kütyü) akkor kb. 67e.
Ha "csak" az LCD (ez a valószínű, ráadásul a kép is "ugyanígy" néz ki, csíkózódik, csak nekem a teljes, nincs ilyen fekete rész) akkor kb. 35e
Ami a tünet, hogy "fut" a kép alap esetben mint anno a junoszty tévé hangolásánál
és hiába érintgetem, nem mindig tudom eltalálni a gombokat (inkább szerencsén múlik) de ez szerintem lehet attól is, hogy a digitizer mögött az LCD-n ott a hajszálrepedés és ettől torzult el / csíkozódott be teljesen a kép és lehet amit én X helyen látok az valójában nem is ott van, ezért nem tudok rátapintani)
Ha mégis mindkettő kompletten halott (digitizer) akkor is "csak" kb. 75e-ből jön ki postával, nem 100ból mint amit az egyik boltban mondott valaki.
Egy ismerőssel aki UK-ban él, felhivatom a céget, hogy nem kamu-e.
Luissimo
Indiant #6984 üzenetére
Vazze, INDI, amit hibaként felsoroltál, aztat levonod a full 5 pointból, akkor szerintem még 4 sem marad.
én legalábbis nem hallelujáznék, ha a rendszer egyszercsak összerogy a kezeim között, tele a tablet olyan dolgokkal, amik nemnagyon nem bocsájthatók meg összeomlásügyileg, mondjuk céges levelekkel, dokumentekkel és miegymásokkal
szerintem ez eléggé gázos, majdnem olyan mikor a tűzokádó sárkány füstöt köhög fel a torkából -
redfox75
Indiant #6951 üzenetére
Ezt a verziót szeretném feltenni a P1000-es tabomra.
Jelenleg 2.3.3 fut rajta.
Alapsáv verziója: P1000XXJPZ
Kernelverzió:
2.6.35.7 se.infra@SEP-52 #2
Build száma:
GINGERBREAD.XXJQ1Elég régen telepítettem fel ezt a tabra és fogalmam sincs, hogy hogyan tudnám feltenni a fenti CM 11 -es verziót.
Ehhez kérném a segítségeteket.
Mivel nincsen semmi gyakorlatom ebben ezért ha valaki leírná az egész folyamatot a bekapcsolástól kezdve nagyon hálás lennék.Az is érdekelne, hogy a tabon lévő adatok, fényképek megmaradnak e vagy előtte le kell töltenem róla.
Köszönöm ha segítetek egy laikusnak
gyurma111
Indiant #6882 üzenetére
Tényleg megelőztelek,de bocsi,hogy nem írtam a tapasztalatokat
Az elsöre megjelent verzát raktam fel.
Felment szépen,működött is szinte minden,viszont nem lett gyorsabb mint a 4.1-4.2
Nálam igazándiból nem villogott,de a sebessége nem fogott meg
Aztán átváltottam ART-ra és abba belehalt.
Várok még finomodik a dolog addig marad a Mycso által ajánlott 2.3.6 -
gyurma111
gyurma111
Indiant #6828 üzenetére
Tényleg nagyon jó az a rom...de tudod az a bizonyos kisördög...
Olasz romra cwm-ből feltoltam stable CM9 majd ugyanolyan gyors,de mégis 4.0.4
Flash előtt természetesen full wipe -
Luissimo
Indiant #6809 üzenetére
még mindig nemvagyok meggyőzve.
Sajna nekem napi melóhoz kell minden ami rajta van, tehát nemnagyon van időm vele kisérletezgetni (tudom, azthiszitek lustaság, de céges e.mailek (2 fiok + office alkalmazás, plusz a fényképező nagyon kell, plusz a gmail és a skype is nagyonnagyonkell
mitmondjak még mentségemül ?
nem játszom vele, de a hivatali laptopot símán kiváltom, tehát nekem atomstabil működő ROM kell és nem kerget senki sem az asztal körül ha ez nem a legujabb , jónekem a Trabant is, lassan de biztosan odaér jeligére...mindenesetre szurkolok, hogy találjunk egy rendes szerkezetet
gyurma111
Luissimo
Indiant #6769 üzenetére
szasz.
nekem még mindig a 4.0.4 2012.0528-as van rajta, ami igaz hogy nem új,de legalább régi, (emléxel, mikor feltoltuk) deviszont stabil mint az atom.
Jólenne már reája valami 4.2-es, erről juteszembe, most vettem egy ilyen telót, amire tegnapelőtt raktam fel a 4.2.2-es JellyBean-t és azért lássuk be nagyobbtudású lett mint előttevolt...
A TAB-unk is megérdemelne egy ilyesmit
ui:
lehet jövőhéten találkozunk -
Luissimo
Indiant #6656 üzenetére
kollégámmal most huzattam rá az Xperia SP nevű telójára, müxik neki rajta.
4.1.2-es ROMa van. (minden ut ROMa-ba vezet jeligére)Most megkértem, hogy az Xperia P-jére az NNG-től kapott tesztverziohoz kapott térképek közül rakjon alá egy magyart, hogy megeszi-é.
majd jelentkezem
danih
gyurma111
- Xbox tulajok OFF topicja
- sziku69: Szólánc.
- Vicces képek
- Hardverkemping június végén
- Marcona Thermaltake léghűtés jött HEDT processzorokhoz
- Milyen videókártyát?
- Milyen légkondit a lakásba?
- Telefon felvásárlás!! Honor 200 Lite, Honor 200, Honor 200 Pro, Honor 200 Smart
- Bomba ár! Fujitsu LifeBook U757 - i3-7GEN I 16GB I 256SSD I 15,6" FHD I HDMI I Cam I W11 I Garancia!
- BESZÁMÍTÁS! Apple MacBook Pro 16 M4 Pro 24GB RAM 512GB SSD - garanciával hibátlan működéssel
- Bomba ár! Lenovo ThinkPad T470 - i5-G6 I 8GB I 256GB SSD I 14" FHD I HDMI I Cam I W10 I Garancia!
- ÁRGARANCIA!Épített KomPhone i9 14900KF 32/64GB RAM RTX 5070Ti 16GB GAMER PC termékbeszámítással
