- Mindenki Z Fold7-et akar
DrGonzo22
szurmakotium #105 üzenetére
Akkor ez azt jelenti, hogy egy ASUS P4P800SE Gold-hoz nem jó ez a táp?
Fade_Away
THE HEAVIEST LOAD
As a matter of curiosity, a system of the most power hungry components in our lab was put to the highest load we could devise. The AOpen Aeolus 6800GT was installed in the Pentium D Dual Core system, and both the CPU and the GPU were stressed by running two instances of CPUBurn simultaneously with 3DMark05. Peak power consumption was noted on each voltage line.
Load +12V (total) +12V1 +12V2 +12V (ATX) +12V (PCIe) +5V +3.3V Total Power
2x CPUBurn +
3DMark05 16.9A 6.4A 10.4A 3.4A 2.5A 3.6A 0.7A 223W
91% 34% 56% 18% 13% 8% 1%
Under this extreme load, the total power draw peaked at about 220W. Neither the +5V nor the +3.3V lines drew appreciably
szoval a legtöbbet zabáló proci agyonterhelve + legtöbbet zabáló vga agyonterhelve megeszik 220Wt
akkor normális usernek mire nemelég egy márkás 300Ws táp?
.....3) Looking at the total power draw alone, it would appear that all of our systems could easily be handled by a 300W power supply. Given that as much as 90% of that power comes from the +12V lines, it is likely that that the ratings for the +12V lines matters more than the total wattage. If these lines are inadequate, the power supply may not provide enough power even if its ''wattage rating'' exceeds the total power draw of the system. It would be wiser to qualify our statement thus: When it comes to adequate power delivery, all of our test systems could easily be handled by a 300W power supply that conforms to ATX12V v2.xx. Conversely, an older PSU rated honestly for 300W output may not be adequate for the most powerful system examined here because of the much lower 12V current capacity on models that comply with v1.3 and earlier versions of the ATX12V spec. -
PEPE85
MC Pite: al_age fél éve írt ezt a hozzászólását ... no comment ...
strike-force: köcce, valószínűleg beruházok egyre. -
sztem eleg hozza. de ha nem agy benne biztos, olvasd el Bővebben: link ezt utana meg
Bővebben: link ezt -
PEPE85
Valaki hozzáértőt kérdeznék, hogy ez a táp elég lenne-e a konfigomhoz úgy, hogy lehet veszek még egy winyót és esetleg jobb AGP-s videókártyára cserélek majd?!
zeg
Azt nem értem, hogy a notiknál hogyan tudják megoldani hogy a gép passzív tápról menjen? Az sem teljesen világos, miért kell minden áron a tápot a gépben tartani, miért nem lehetséges csak egy csatlakozópanel(némi passziv hűtésű áramkörrel) beszerelése a ház megfelelő helyére, és a tápot/táp leginkább melegedő elemeit a gépen kívül lehetne elhelyezni.
szurmakotium
ide is beírom ...
Hi all,
A véleményetekre vagyok kíváncsi ...
Összeszerelésre van tervezve a következő konfig:
ASUS A8NE Nforce4 ultra
AMD64 VENICE 3000+ CPU
Gainward GF 6800GT DualDVI 256MB PCIe
2 db 512MB DDR400 HYNIX RAM
1 db SEAGATE 120G HDD
1 db NEC DVD-RW
Kérdésem az lenne hogy ehhez a konfighoz elég-e az FSP ZEN 300W-os passzív hűtésű táp ?
http://www.jscustompcs.com/power_supply/ számoló gép szerint minimum 290W
-os kell. Az FSP ZEN hatékonysága a gyári adatok szerint legalább 89 százalék.
Szerintetek elegendő ez a táp vagy rizikós ?
És abban az esetben elegendő ha a 6800GT helyett egy 6600Gt lenne benne ?
előre is thnx -
szurmakotium
Huh, majdnem vettem egy ilyet ...
Az ok amiért mégsem az ez:
4 Pin molex connector is not enough and it only support the 24-pin main power connector motherboard ...
Fene vegye el, pedig milyen jó lett volna -
gorlin
Megvan!
Meghatódtam.Végre csend lett.Nagyon furcsa ez a hangtalanság.
Tehát a gép
-Athlon Xp 2500+ @ 3200+ ,Zalman 7700ACU ,Artic Silver 5 hűtőpaszta(két ellenálással leszabályozva
-X800 Pro Zalman 80DHP Artic Silver 5 hűtőpaszta +OP1 két ellenálással leszabályozva
-512Mb ram
-Hitachi 160Gb Sata
-Lg 4120 Dvd író,és egy Lg Dvd rom
-Cooler Master Stacker ház.
-Házhűtő:AcousticFan 12cm-es (nem csatlakoztattam)
Hőmérsékletek.
Videókártya Terheletlenül 46 fok Terhelten 75 fok
Processzor Terheletlenül 46 fok terhelten 59
Maga a táp gyönyörű,egy kis vigasz ,hogy nem kell lemondanom a kék világításról(Phantom) mert a bekapcsoló gomb átlátszó és szép kéken világít
A feszültségek :12,032 4,945 3,296 1,696
Terheletlenül a táp kézmeleg ,terhelten már melegebb olyan 50 fok körül lehet majd lemérem .
Cincogás,ciripelés és egyébb zaj sehogy sincsen!(remélem ez így is marad
Mint látáttok nem használok házventillátort,mert mivel elsősorban dolgozom a géppel Word ,Excel,Flash Fireworks,Internet ezért szerintem nem szükséges, ha játszom azonnal rákapcsolom a ventillátort!
Egyszóval fantasztikus ez a táp.Tényleg csend lett! Egyetlen dolog amit azért megemlítek az a csatlakozók száma és hossza a régi enermaxommal nem vetekedhetDe mivel rövidebbek ezért nincs akkora káosz a házban .Ja és az alaplapi tápcsatlakozóhoz kellett egy átalakító.
Egyenlőre ennyi ha valamit elfelejtettem vagy kérdés van szívesen válaszolok.
[Szerkesztve] -
al_age
Flashcash #98 üzenetére
Ha nincs leragasztva akkor tényleg bátran megvenném, nekem az számít, hogy a táp nagyon hatékony legyen (márpedig ezt a szériát ugye ezzel reklámozzák), valamint hogy halk legyen, ez pedig jelen esetben könnyen orvosolható.
Gari mennyi van rá? 1 év? - Azért légyszi nézd meg, hogy tényleg nem volt-e leragasztva.
MOD: ja és a gépen elég halk, én vagy YS-Tech, vagy Noiseblocker ventit tennék bele
[Szerkesztve] -
Ottoka
Egy kérdés, nemigen passzol ide. Nemrég raktam össze az új konfigot, és egy Thermaltake 480W-os tápot raktam bele. 5 HDD, K8N Diamond, AMD64 3500, x850xt. A táp nem melegszik, az everest szerint a 12v-os értek 11.43. Nem alacsony? Nem lehet gond belőle? Kérlek írjátok meg véleményeteket.
[Szerkesztve] -
Nekem két FSP tápom van most, emlékeim szerint nincs leragasztva egyik sem.
Vedd meg az én Green Powerem.13K-ért megkapod, a hangos ventilátor pedig relatív, nagyon függ attól hogy mennyire hangos a konfigod mellette.
Én egy Nexus ventivel moddolnám.
Ha érdekel dobj egy mailt, eljöhetsz meghallgathatod élőben, ha tetszik megveszed.
[Szerkesztve] -
al_age
Mondjuk erre ez az FSP pont megfelelő
Azt nem értem, hogy ha a 300-as Zen-t telenyomják bordával, akkor ebbe miért csak ilyen tömböt tesznek, aminek a gyakorlati értelme szigorúan monoton 0-hoz tart?
Okéoké az egyik teljesen passzív a másikat meg hűti egy 12-es halk venti, de azok a tömbök nagyon kevéskének tűnnek.
Bátran vennék egy ilyen tápot, vagy később (ha lesz MO-n) egy 350-est ha nem lenne leragasztva, mert akkor ventit cserélnék benne első pillanatban, de melyik gyártó az, amelyik nem ragasztja le a tápjait? -
brownus
Dzsekónak tetszik, a gépe alapzaja eleve nagyobb mint az enyém. A konfigja alapból úgy megterheli a tápot, hogy nem hallatszik ez a morgás, ráadásul jóval kevesebb levegőt tol terhelés alatt a Green Power mint az előző suhogó FSP-je.
Egyedül a kevés csatlakozó nem tetszik neki.
1500RPM az elég sok egy 12cm-es ventitől.
[Szerkesztve] -
brownus
Flashcash #84 üzenetére
Hello Flash!
qrva jó a Blue Storm, sokkal halkabb lett a gépem!
A PSU ventillátora 1500 körül forog, és semmit nem hallani. Kisseb fordulat számra gondoltam , de nem értek hozzá, szóval?
viszont a Green Power jól dolgozik ahogy elnézem a mért adatokat.
Dzsekó mit szólt?
[Szerkesztve] -
A Zen teljesen más téma.
Green Power:
Dzsekó elégedett vele, nálam a halk gépben eléggé hallatszik a ventilátor morgása. Lehet hogy kicserélem a ventilátort benne, és utánna ha nyáron is csendes marad elégedett leszek.De most nem igazán vagyok elégedett.
A Green Powerben nem de a Zen-ről írják hogy ciripel.
[Szerkesztve] -
gorlin
Most akkor ilyen lesz a zen is?Vagy a hangján kívül elégedett voltál vele? -
strike-force #83 üzenetére
Ha végigolvasod a témát Dzsekó hozzászólásában külön szerepel hogy jellemzően melyik táp mekkora hatásfokkal rendelkezik. 70-75/80/80++%
Tehát nincs semmi titok csak végig kell olvasni a topicot. Nekem pedig sem időm sem kedvem átrajzolni ezeket az ábrákat. -
gorlin
Megrendeltem!Fsp ZEN 300W.Holnap vagy hétfőn érkezik.A phantom hiánycikk két hónapja nem lehet kapni,ma tudtam meg.Úgyhogy ha megjön majd beszámolok.
Kérdés:Szerintetek alulra vagy felülre tegyem a tápot?
Mert ha alulra teszem, ugye a meleg levegő mindíg felfelé,és a hidegebb levegő felé áramlik,tehát alulra érdemes nem ?
Rendeltem hozzá egy 12cm-es AcousticFan-t ,amin hőérzékelő van ,ez lesz a házhűtőm.(persze szigorúan leszabályozva legalább egyszeresen)
Üdv -
FSP Green Power 400W:
A tápot a www.varazspalca.hu oldalon rendeltem meg. Hogy ne legyen minden tökéletes, az átvételkor kiderült hogy OEM kiszerelés: Önmagában ez még nem volna baj ha csak a doboz hiányozna, de kevesebb csatlakozó és rövidebb kábelek kerültek az OEM változatra.
-4 Molex csatlakozó
-1 SATA (a bolt árlistáján 2X SATA szerepelt)
-ATX 12V csatlakozó
-24 pólusú ATX csatlakozó, átalakító nem jár a táphoz. (Szerencsére nincsenek alkatrészek a tesztelt alaplapok ATX 20 pólusú csatlakozói körül, így figyelve a színkiosztásra, közvetlenül átalakító nélkül is csatlakoztatni lehetett a tápot.)
Csatlakozók:
Bővebben: link
Belső felépítés:
A táp könnyebb mint egy Bluestorm, vagy mint az előző generációs FSP-350-60PN(PF). A táp belső felépítése is meglepő 3 nem túl nagy méretű tömb hűtőbordát alkalmaztak. Semmi formázás nincs, a hőleadó felületük emiatt nagyon kevés. A Green Power félig üres, különösen egy alkatrészekkel telerakott Bluestromhoz képest.
Bővebben: link
Jobb kép egy külföldi tesztoldalról:
Bővebben: link
Ventilátor:
Az FSP a régen jól bevált csendes járású Yate Loon ventilátorok helyett Protechnic-et használ. A tápban egy Protechnic MGA12012LR (12V, 0,3A) ventilátor kapott helyet.
AC Teljesítményfelvétel:
2 konfigurációban teszteltük a tápot, egy halk Athlon64 rendszerben és egy tuningolt Barton konfiggal. A teszt során a 400W-os Green Power-rel és egy FSP-350-60PN(PF) táppal mértük le a konfigurációk fogyasztását, különböző alkalmazásokkal. A tápon kívül semmi nem változott, így egyszerűen összehasonlítható a két tápegység.
Konfig1: Asus K8N, Athlon64 2800+, 512MB BGA DDR400 memória, 160+120GB 7200RPM HDD, Pioneer A08, Gigabyte 9600 PRO, Miro PCTV Pro, SBlive, a rendszerben 3db ventilátor ment: 900RPM Noiseblocker SE2 Blue (92mm), egy 850 RPM Panaflo FBA08A 12L1BX, és a tápegység 12cm-es ventilátora.
Konfig2: Epox KT600 alaplap, AMD Barton 2500+@2,2GHz, 512MB DDR400 memória, 2x200GB+2x160GB 7200RPM HDD, Pioneer A05, Pioneer A08, Gigabyte 9600PRO, Miro PCTV PRO, SBlive, ez már egy hangosabb rendszer 5 ventilátorral.
Konfig1 AC teljesítményfelvétele FSP-350-60PN(PF) táppal:
1, Kikapcsolt állapot (standby): 3,6W
2, Windows XP alatti terheletlen állapot üresjárásban: 99W
3, Virtualdub videó tömörítés (Highest priority): 135W
4: Játék (Pacific Fighters, 3Dmark2005): 145W
Konfig1 AC teljesítményfelvétele FSP Green Power 400W táppal:
1, Kikapcsolt állapot (standby): 2,1W
2, Windows XP alatti terheletlen állapot üresjárásban: 87W
3, Virtualdub videó tömörítés (Highest priority): 121W
4: Játék (Pacific Fighters, 3Dmark2005): 128W
Konfig2 AC teljesítményfelvétele FSP-350-60PN(PF) táppal:
2, Windows XP alatti terheletlen állapot üresjárásban: 120W
3, Virtualdub videó tömörítés (Highest priority): 175W
4: Játék (Pacific Fighters, 3Dmark2005): 195W
Konfig2 AC teljesítményfelvétele FSP Green Power 400W táppal:
2, Windows XP alatti terheletlen állapot üresjárásban: 102W
3, Virtualdub videó tömörítés (Highest priority): 158W
4: Játék (Pacific Fighters, 3Dmark2005): 172W
Értékelés:
Zaj: A Protechnic ventilátornak elég érdekes hangja van az Athlon 64 konfigban, folyamatosan morgó kattogó (klikk-klikk) zaja van, ami egy csendes konfigurációban tisztán hallható és zavaró, a rezonancia is nagyobb mint egy Yate Loon ventilátornál. Ha tehelem a gépet akkor ez a morgó hang alig hallhatóan lecsökken, így terhelés alatt ebben a konfigban a tápegységnek kevésbé zavaró a hangja.Nem túl meggyöző.
Magas frekvenciás ciripelést (az asus K8N-t kivéve) nem hallottam.
Ventilátor vezérlő: (amennyire 3 óra használat alatt kideríthető) végig még a 2. konfigban is alacsony fordulatszámon maradt a ventilátor, de az apró bordák miatt nagy melegben lehet hogy jóval magasabb fordulatszámra szabályozna fel.
Összességében nem győzött meg a táp, a rossz minőségű ventilátor miatt csendes gépbe nem ajánlott, nyugodtan elfértek volna nagyobb hőleadó felülettel rendelkező bordák is a tápban, így nagy melegben ez a minimális hőleadó felület kevés lehet. Így hiába termel kevesebb hőt a táp az előző generációhoz képest ha nem tudja azt leadni.
A ventilátor vezérlő jónak tűnik, a 2. konfigban magasabb fordulaton már nem olyan zavaró a ventilátor alapzaja sem.
Egy FSP Bluestormnál valamivel halkabb a Green Power, a régebbi FSP 350W táp üresjárásban halkabb, viszont hamarabb felpörög. Az OEM Green Power nem éri meg a 16500FT-os árát szerintem. A saját GP tápomba lehet hogy beépítek egy jobb minőségű ventilátort. -
Flashcash #52 üzenetére
Előre mondom, hogy a hozzászólással semmi bajom, de az általad belinkelt grafikonban találok némi kivetnivalót. Apró botlás csak, de én először megbotránkoztam, aztán rájötem, hogy semmi ok aggodalomra.
A kivetnivaló pedig: a grafikon Y-tengelyén ugye a hatásfokot ábrázolták, és a legnagyobb baj az, hogy csak 70 és 84% közötti tartomány néztek. Így a különbség óriási(nak tűnik), holott nem az, mert ha megnézed mondjuk olyan 150w körül (77 vs 81) már nem is olyan vészes.
Sztem úgy lett volna korrekt, ha vagy 0-100% között nézik, mert azon a tényleges különbség látszik, igaz nagyobb grafikon kellett volna és 100%-os hatásfokú táp sincs, vagy legalábbis egy nagyobb tartományban , mondjuk 50 és 90% között.
Legelőször tipikusan az a grafikon jutott eszembe róla ami egy VGA 3dmark pontjait mutatja, és a 6000 pontos oszlop kétszer akkora, mint az 5800 pontos oszlop. Tipikus megtévesztés esete, ''nagyobb a jobb'' alapon... -
Már itt van a táp de még nincs időm írni.
Este írok róla bővebben ventilátor típussal, teljesítménymérésekkel (összehasonlítva egy régebbi FSP-vel). -
al_age
Lassan remélem megosztja velünk tapasztalatait Dzsekó és Flashcash a GreenPower-reikkel kapcsolatban
al_age
Az is lehet
Ezt nézted? Bővebben: link -
Jujj. Ez az első, amire azt mondom, hogy le a kapappal. Se gigantikus heatpipe, mégnagyobb bordákkal, se egyéb. Igazán tetszik. Többet kellene tudni róla.
al_age
Most néztem a Pixel árlistáját, amin összesen 5 db FSP táp szerepel.
Ebből 3 BlueStorm, a maradék 2 pedig:
FSP 300W 8.990 Ft + áfa
FSP 400W 12.900 Ft + áfa
Viszont erősen kétlem, hogy az a 300 Wattos táp a Zen lenne.
MOD: De ez a kettő szerintem GreenPower lesz, máshol is láttam már ilyen utalást.
Ugyanakkor az FSP honlapján meg nem említ 300 Wattos GreenPower-t, csak 350-est, meg 400-ast...
MOD2: Bővebben: link
[Szerkesztve] -
LukE
Flashcash #69 üzenetére
az SPCR tudtommal sima kapcsolgatható ellenallasokat hasznal, ami eleg jo esellyel elrejti a ciripelest es egyebeket, mert nincsenek benne nehany szaz kHz-en kapcsolgato tranyok, szoval lehet, hogy alaplaptol-vga-tol fuggoen begerjedhet. Vagy az alaplap-vga allhat neki szotymorogni. Meg ha a tipus nem is zajong altalaban, lehet olyan alaplap-vga (ez a ket legnagyobb fogyasztasu eszkoz, es mindketton van sajat kapcsolo tap.) kombo, amivel hangosabb vagy halkabb az atlagnal.
szerk: tenyleg telefonolj oda, lehet hogy van nekik, vagy lesz, vagy sok kerdezes utan vegre rendelnek. Egy Fantom legalabb van MO-on, es az a Seneriten keresztul erkezett, valszeg van tobb is.
[Szerkesztve] -
Bővebben: link
Itt egy cikk az FSP Zen-ről, a tesztelők szerint elektromos zaj ciripelés hallható a tápból terhelés alatt. Mielőtt vásárolsz ezt vedd figyelembe.
Ugyanezt a zajt a Phantom-al kapcsolatban is említi az SPCR tesztoldal, de ők nagyon halknak nem zavarónak írták le a Phantom zaját. -
gorlin
Megnéztem a www.*.hu-t
sajnos itt sincs phantom legalább is az árlistán majd azért holnap hívom őket.Ha van valakinek ötlete hol lehet kapni megköszönném.(mármint az FSP-t)
Ha sikerül vennem írok egy részletes tesztet ide -
gorlin
köszönöm!
A pixelnél már néztem.Sajnos nincs.Bár azt kell mondjam az igazi 'álmom egy Phantom -
gorlin
Akkor mégegyszer megpróbálom.Hátha olvassa a cikk írója.
Hol lehet ilyen tápot kapni?
Csak azért ilyen fontos mert ha minden igazrászántam magam egy tápra csak az Antec Phantom hiánycikk,van raktáron Thermalthake de mintha azt olvastam volna róla itt a Ph-n hogy nem az igazi.
Üdv -
gorlin
Lehet tudni,hogy pontosan hol lehet ilyen tápot venni? -
LukE
1. Milyen tartalékról beszélsz? Rákattintasz Vikthor nevére és megnézed a konfigját. Athlon 64-et használ 160-180W-os teljesítményfelvétellel.
A géped nem fogyaszt ennél a konfignál többet megnyugodhatsz.
Pontosan milyen kompromisszumokra gondolsz a 300W-os táppal kapcsolatban?
High A64
Athlon A64-3800+ (130nm core)
Soltek SL-K8TPro-939 motherboard
4 x 512 mb OCZ PC4000 DDRAM
ATI 9800-256 Pro VGA
Hitachi 7K400 HDD (400gb)
Samsung P160 HDD
Silverstone ST30NF PSU (fanless)
M-Audio Firewire 410 external firewire-driven sound card
low speed 80mm fan
DC teljesítményfelvétel idle: 76W
Teljes terhelés: 147W
Pontosan mit tegyünk még ebbe a konfigba ha ez kompromisszum?
Szerintem ez a Watt mánia inkább egy zavar a konfigurációk valós fogyasztásával kapcsolatban, amit a tápgyártók 5-600W-os termékeinek és a codegen Vargáné és társai 3-400W-os tápjainak köszönhetünk.
[Szerkesztve] -
Tigerclaw
Nem bánnám, ha a jövőben a PC tápegységeknek csak 12V-ot kellene szolgáltatni és minden eszköz saját maga állítaná elő az egyéb szükséges feszültségeket. Lehetne építeni végre teljesen egyszerű megbízható, magas hatásfokú tápokat.
L3zl13
Flashcash #50 üzenetére
1. A fenti tesztkonfignál szvsz még az én gépem is többet fogyaszt. (Tuningtól függően.)
Annyira nem extrém a konfig, hogy bátran lehessen ajánlani mindenkinek a 300W-os tápot.
Persze nem kötelező nagy fogyasztású alkatrészeket venni, de ennyi rővel jó hogy nem azt mondod, hogy vagyen mindenki mobil procikat a gépébe integrált alaplappal, 128MB rammal, meg 4200-as noti vinyóval és akkor ninsz szükség még 200W-os passzív tápra sem...
2. Ok, hogy az AC és a DC teljesítmény eltérő, de jó hatásfok esetén ez kb 15% környékén van. Még midig elég kevés tartalék van szvsz.
3. Tudom, hogy nehezebb ilyet készíteni. Ettől még mindenki vágyhat ilyesmire.
Pl 10GHz-s passzív hűtést igénylő P4-et sem lehet gyártani, ez még nem jelenti azt, hogy nem szeretne mindenki ilyet.
A lényeg, hogy most a 300W-s passzív táppal néhányan kompromisszumra kényszerülnek. Ideális az volna, ha kompromisszum nélkül lehetne passzív hűtésű tápokat alkalmazni. -
_cirmos_
hadd javítsalak ki egy kicsit:
a tápoknál adott teljesítmény adat a leadott hasznos teljesítményre vonatkozik (hiszen ezt olvashatod a tápok matricáján hogy melyik ágon mennyit tud leadni, persze bizonyos megkötésekkel).
a Dzsekó által linkelt táblázatnál érdemes figyelembe venni hogy ezek a hálózatból felvett értékek, tehát a gép fogyasztását akkor kapjuk meg ha megszorozzuk ezt a táp hatásfokával. a zen 157W-os teljesítményfelvétele (a hírben említett 89%-os hatásfok mellett) így alig 140W, azaz ennyit fogyaszt valósan a tesztben használt konfig.
fentebb elhangzott hogy nem egészséges a tápot csúcson járatni. a tartós túlterhelés biztos nem is használ, de annyit tudni kell hogy egy táp hatásfoka 90% körüli terhelésnél a legjobb (nem is csoda, hiszen akkora terhelésre lett tervezve). -
Bőven elég a te Athlon 64 konfigodhoz, én maximum 160-180W-ra saccolom a DC teljesítményfelvételét tuning nélkül. Ha 0,09 mikronos procid van akkor még kedvezőbb ez az adat.
Inkább a megfelelő légáramlás okozhat gondot, de ez a probléma egy 400W-os passzív tápnál is előjön.
A nagy W értékű tápokkal kapcsoltban nézd meg ezt a hatásfok görbét:
Bővebben: link
Ha azt mondom neked hogy az asztali konfigurációk 80 és 150-200W (idle/full) közötti tartományban terhelik a tápot, akkor szerinted melyik táppal jártunk volna jobban a 600 vagy a 300W-os verzióval?
A teljes cikket is ajánlom figyelmedbe mért fogyasztási adatok vannak benne, különböző köztük Athlon 64 konfigurációval is.
Bővebben: link
[Szerkesztve] -
1. A tesztkonfiguráció messze nem átlagos PC. Aki passzív tápot akar nem feltétlenül kell nagyfogyasztású processzort venni mellé nem kötelező azt még tuningolni sem.
2. A 300W amit a tápnál megadnak DC teljesítményfelvételt jelent, tehát a 277W AC teljesítményfelvétel nem 100% egy 300W-os tápnál.
3. Nem véletlenül 300W-os ez a táp, sokkal nehezebb nagy teljesítménytartományban méretezni az alkatrészeket, és egyenletesen jó hatásfokot fenntartani a teljes tartományban.
[Szerkesztve] -
Megkérdezhetem hogy minek a 400W?
Processor INTEL Pentium 4 560
Mother chart Asus P5AD2 Premium
2x512 Mo of DDR2 Corsair PC-5400 (667 MHz)
Graphics board Abit X600 XT
2 hard disks Western DIGITAL Raptor 74 Go in RAID
Ez a konfiguráció tuningolva 277W AC teljesítményt vesz fel egy FSP Zens-ről.
Teljesen felesleges 400W-os tápot vásárolnod ilyen hatásfok mellett.
Nézd meg az Avance 460W-os táp eredményét ugyanennél a konfignál 368W. Az a +100W a tápban alakul hővé.
A tuningolt Intel konfiguráció 277W AC teljesítményfelvétele kb. 240-250W DC-t jelent itt, ezt még stabilan kiszolgálja ez a táp. De egy teljes kiépítésű Athlon 64 konfig csak 150W körül fogyaszt, ha passzív tápot akarsz akkor megfelelő processzorral nem árt picit a gépet is igazítani a feladathoz.
[Szerkesztve] -
Dzsekó meg én megrendeltünk 2 db Green Power tápot az egyik egy csendes alacsony fogyasztású Athlon 64 konfigba kerül, a másik pedig egy tuning K7 Barton konfigurációba.
Majd írunk a tapasztalatokról hogy érdemes-e megvenni. -
Obi-1
Valaki éppen említette a legutóbbi passzív tápos témában, hogy ő megvárja, amíg a megbízható gyártók, mint FSP és Enermax, Chieftec is kijönnek a saját passzív tápjaikkal.
Ez nagyon olcsó lett, csak ámulok! Ennek ellenére a saját favorit továbbra is a 12 centis ventivel szerelt táp. -
Én örülnék egy passzív 400W-osnak, nem mintha hangos lenne a 400-as Zalman, de a passzív azért jobb lenne...
Vikthor -
brownus
Ez jó Dzseko!! Bekellene linkelni a táblázatot ide is:Bővebben: link
hátha megvilágosodik pár ember
[Szerkesztve] -
al_age
Szerintem a Zen és a Green Power egy családba tartozik és a család legkisebb tagja lett a passzív verzió, a Zen. Ezeket a sorozatszámokat FSP honlapján (Bővebben: link) találtam:
Ez a Zen szériaszáma:
FSP300-60GNF
Ezek pedig a Green Power-eké:
FSP350-60GLN
FSP400-60GLN -
LukE
valszeg kihagytak a sallangot: atlatszo venti, kabel harisnyazas, vicces szinu molexek, minimalista karton doboz, marketinges siutja
Nem kizart, hogy kitenyesztettek egy jo alapot, es ezt aruljak vagy nagy bordaval es lukacsos hazzal, vagy minimal dobozzal, es 120-as ventivel.
Azert remelem a ventin nem sporoltak.
ja, az fsp-nel levo nagy kep kozeli rokonsagot sejtet a zen-nel, legalabbis ami latszik, az ugyan az. -
al_age
Igen-igen pont ezek a dolgok foglalkoztatnak engem is...
Mert az elmélet egy dolog...
De ha nem is nagyon halk, az árát még úgy is megéri ez a táp. Ennyiért nagyon kevés minőségi 400 wattos tápot lehet kapni.
MOD: Hogyan lett pl ez a táp olcsóbb még a BlueStorm-nál is?
[Szerkesztve] -
Dzsekó
A tápok a beépíttett ventilátor fordulatszámát a hőmérséklet függvényében szabályozzák.
Innentől kezdve egy 85% hatásfokú Green Power előnyből indul hiszen sokkal kevesebb hőt termel -> alacsonyabb fordulatszám.
2 fő kérdés van:
A, Milyen ventilátort tettek a tápba? Ha Yate Loon akkor az egyik legjobb semleges nem rezonáló, jellemző alapzajjal nem rendelkező venti van benne. Ha protechnik vagy egyéb rosszabb gyártótól van benne ventilátor akkor lehet hogy van némi alapzaja.
B, Mennyire fejlett, milyen jól van hangolva a ventilátor vezérlő áramköre? Hiába termel kevés hőt a táp ha ezt a ventilátor vezérlő nem követi és sokkal nagyobb feszültséget ad / fordulatszámot tart fenn mint szükséges.
[Szerkesztve] -
BosX
De, a tápom azért kapcsol rá, mert hűtésre van szüksége. Mert alapjáraton nem elég, hogy kihúzza a hőt a házból. És nyugi, nem fog megfőni egyik szabályozható táp sem,mert ''fölészabályoz'', ha melegszik, rákapcsol.
Egyébként meg ''hidegindításnál'' hangtalan, és nem csak ez az egész gép (gt silentbrezze), 15-16óra menet után meg átlagos hangja van.
[Szerkesztve] -
BosX
FlasH-BacK #25 üzenetére
Szerintem a mai technikai szinten ha vlaki paszív gépet szeretne ( nem halk, hanme passzív) annak le kell venni az igényszintjét is, ergo nem a legszerencsésebb egy prescottot bika videokártyával millió winyóval passzív tápra kötni. Én szívesen lemondanék a teljesítményről, ha ez lenne az ára.
Nem hiszem, hogy gyengék lennének, amit el kell vinniük, azt el is viszik, amelyik ptápnak meg venti kell az már nem passzívtápÉs a 12cmes tápok is tudnak zajtcsapni, ventikkel nem lehet csöndet elérni. szvsz
Dzsekó
Itt olvasható egy teszt az FSP Zens-ről:
Bővebben: link
A következő konfiggal tesztelték:
A lényeg.
Itt vannak a fogyasztási adatok különböző hatásfokú tápok esetén:
Az eredmény nagyon brutálhirtelen elgondolkoztam azon hogy passzív tápot teszek a gépbe, ezt egy megfelelően megépített Athlon 64 konfigba nyugodtan be merném tenni.
Az FSP Green power tápot megtaláltam a www.varazspalca.hu árlistáján.
[Szerkesztve] -
Dzsekó
Nem volt róla szó a hírben, de lesz ennek a magas hatásfokú FSP szériának egy 12cm-es ventilátorral szerelt csendes tápja, FSP Green Power néven fog futni itt találsz róla információkat:
Bővebben: link -
marcee
Ez csak okoskodás és még sántít is.
Nem gondolod, hogy a tápod azért kapcsol rá mert szüksége van a hűtésre? Ezzel szemben hasonló körülmények között a paszív táp simán megfő vagy lekapcsol.
Abból sem kellene messzemenő következtetéseket levonni, hogy a _TE_ 12 centis tápod hangos, esetleg nem mindenkié az.
Én például a haverom állítható kétventis, fordulatszámú enermax 365W-os tápjával eléggé meg voltam lőve, mert szvsz elég hangos, szívesen lejebb tekertem volna, de akkor meg attól féltem nem lesz-e baja és állalndóan az asztal alá mászkáltam megvizsgálni, hogy mennyire meleget ereget. Azóta tudom, hogy nekem csakis ventis, önszabályzó tápok valók. -
Dzsekó
Ennek a tápnak a kulcs tulajdonsága a magas hatásfok.
A 89% nagyon jó érték messze lekőrözi az átlag tápokat.
200W DC teljesítményfelvételt és 89%-os hatásfokot feltételezve ez a táp:
225W-ot vesz fel az AC hálózatból, tehát az alkatrészeinek összesen 25W hőt kell eldisszipálnia.
Egy jó minőségű ATX 2.03 ajánlásoknak megfelelő táp (Enermex/FSP) ideális esetben 80%-os hatásfokot nyújt, 200W DC teljesítményfelvétel esetén:
250W-ot vesz fel az AC hálózatból, tehát az alkatrészeknek a ventilátor segítségével 50W-hőt kell elvezetnie.
Egy átlagos ATX táp (köztük sok márkás jó minőségűnek gondolt is) 70-75% körüli hatásfokkal rendelkezik, és 70-85W körüli hőt kell elvezetnie.
Tájékoztatásul egy teljes kiépítésű Athlon 64 konfig fogyasztási adatai:
Athlon A64-3800+ (130nm)
Soltek SL-K8TPro-939 alaplap
Samsung P160 HDD
Silverstone ST30NF tápegység
M-Audio Firewire 410 külső hangk.
low speed 80mm vent.
Üresjárás (DC teljesítményfelvétel): 76W
A konfigban a 9800PRO teljes terhelésnél kb. 45W-ot fogyaszt.
Egy X800Pro fogyasztása hasonló esetben szintén 45W egy 6800GT kb. 55W-ot eszik. Nem játékőrülteknek egy 9600PRO kb. 19W-ot fogyaszt teljes terhelésnél.
Ha valaki tudja hol lehet kapni írja le ne tartsa titokban.
[Szerkesztve] -
L3zl13
Sixkiller6 #28 üzenetére
Mint a hírekben látható tavaly nyáron mutatták be valamelyik számtech kiállításon. Az oldalukon viszont azóta sincs fent. Szvsz ejtették az ötletet végül.
De lehet, hogy csak rájuk kell kérdezni...
[Szerkesztve] -
Dzsekó
Hol lehet nálunk kapni?
FlasH-BacK
kalmanka19 #27 üzenetére
De az Amper növekedésével nő a Watt is!
Inkább ugy mondanám, hogy olyan táp kell, ami az 5v és 3.3v ágon elég kakaót tud tolni egyszerre. Na meg persze a 12V-os ág sem elhanyagolandó!
kalmanka19
bőven elég lenne a 300w-mert egy átlag konfig nem eszik 200w-nál többet!!!
(pl 3000+os a64,1hdd,6800,giga mem,2 optikai meghajtó,ventik világítás, terhelten 250w körül van! terheletlenül 140-körül! nem a w-a lényeg hanem az hogy normális tápot kell venni ami elég a-t tud dolni mert az a lényeg a w-t az kevésbé) -
FlasH-BacK
Na igen, ki más csinálna külső tápot, ha nem a Zalman!
Szerintem is ötletes megoldás, főleg annak, akinek amúgy is passzív a gépe, így legalább nem melegítik egymást a táp és a gép.
Viszont másrészről nem vágom, miért ez a nagy felhajtás a passzív tápok körül. Manapság egyre több gyártó dob piacra hangtalan tápokat, pedig:
1. Ezek a tápok tök gyengék
2. Iszonyatosan melegszenek, van amelyik nem is megy passzívban ha terhelve van
3. Nem hinném, hogy egy 12cm-es ventivel szerelt táp olyan nagy zajt csapna, hogy egy amúgy passzív gép ''összhangját'' elrontaná.
Pl az én tápom (350W Seventeam) a maga 2 ventijével (8+9cm) 1.5 évig olyan halk volt, hogy direkt megnéztem a gépből kivéve és külön elindítva, gyakorlatilag nem volt hangja! Mostanság kezdem el hallani néha, gondolom a ventik kezdenek csapágyasodni benne... -
BosX
nekem is 12cm ventis tápom van (aopen), fordulatszabályzóval, s bizony ha le is van tekerve minre, egy idő után mégis felveszi a fordulatot és ezzel a ahngot
Passzív tápnál nincs ilyen probléma, max melegszik egy picit
, de szvsz tényleg jobban meg vannak építve a jobbfajták, mint a ventis tápok.
L3zl13
Sixkiller6 #16 üzenetére
Ilyesmire gondoltál?
Bővebben: link
Bővebben: link
[Szerkesztve] -
erdoke
Sixkiller6 #13 üzenetére
Minél kisebb feszültséget vezetsz a kábelen, annál nagyobbat esik adott úton a kábel ellenállása miatt. Ahhoz, hogy egy 3,3 vagy 5 vagy akár a 12 V pontos értékkel érkezzen, nagyon pontosan kellene fölélőni indításkor. Nem véletlen, hogy lemondtak a processzornak szánt 3,3 V-ról.
Más: Hogyan viszonyul ennek az ára más passzív tápokhoz? Esetleg 350-400 W-osakhoz?
[Szerkesztve] -
ody42
viccet félretéve _szerintem_ a legjobb, legcsöndesebb megoldás, amivel a házat lehet hűteni, az egy 12 centis ventivel felszerelt táp, ugyanis hiába passzív a ház, valaminek azért ki kell szippantania a meleget a házból, nem?
ody42
ez nekem is tetszik, pláne a ''gennyesre keresem magam rész''. belevágunk?
Niquis
Nem jól tudod. Olvasd el ezt:
Bővebben: link -
faster
Sixkiller6 #11 üzenetére
Sok vezeték, vastag kábel vagy sok sok hosszú kábel ( csak az alaplapra most már 24+4 vezeték megy, a perifériákkal együtt meg ne is beszéljünk.)
[Szerkesztve] -
Tonyo
300 watt nem kevés egy kicsit?
[Szerkesztve] -
faster
Sixkiller6 #8 üzenetére
Illetve az lenne a jó, ha a házaknál azon a részen, ahol a táp van, hiányozna a borítás (félig külső-félig belső)
wiziloo
Sixkiller6 #5 üzenetére
francba megelőztél
wiziloo
Teccik
Végre nem lóg ki belőle semmi hítpájpos óriásbordás borzalom, jó szellős a borítás -
Sixkiller6
érdekes, h nem lóg ki belőle egy jókora borda, mint a többi passzívból
Esmein
Egész jól terhelhető a 3.3 és az 5 volt.
BosX
hát olcsóbb mint az antec phantom...
- GYÖNYÖRŰ iPhone 13 Pro 128GB Graphite -1 ÉV GARANCIA - Kártyafüggetlen, MS3083
- Intel Core i5 3470 confidential Ivy bridge Quad Core
- Logitech G513 Carbon Tactile DE (3)
- HIBÁTLAN iPhone 14 Pro Max 256GB Space Black -1 ÉV GARANCIA - Kártyafüggetlen, MS3009
- HP ZBook Studio 8 WorkStation i7-11850H 16GB 512GB Nvidia Quadro T1200 15.6" FHD IPS 1 év garancia
