- Kapható a strapamobil, aminek kikapcsolása nélkül lehet kicserélni az aksiját
- A vártnál korábban érkezhet a Xiaomi 17 Ultra
tibi-d
Itt a kód, amit az Arduino.cc "learning" oldaláról ollóztam.State change detection (edge detection)
Often, you don't need to know the state of a digital input all the time,
but you just need to know when the input changes from one state to another.
For example, you want to know when a button goes from OFF to ON. This is called
state change detection, or edge detection.This example shows how to detect when a button or button changes from off to on
and on to off.The circuit:
* pushbutton attached to pin 2 from +5V
* 10K resistor attached to pin 2 from ground
* LED attached from pin 13 to ground (or use the built-in LED on
most Arduino boards)created 27 Sep 2005
modified 30 Aug 2011
by Tom IgoeThis example code is in the public domain.
http://arduino.cc/en/Tutorial/ButtonStateChange
// this constant won't change:
const int buttonPin = 2; // the pin that the pushbutton is attached to
const int ledPin = 13; // the pin that the LED is attached to// Variables will change:
int buttonPushCounter = 0; // counter for the number of button presses
int buttonState = 0; // current state of the button
int lastButtonState = 0; // previous state of the buttonvoid setup() {
// initialize the button pin as a input:
pinMode(buttonPin, INPUT);
// initialize the LED as an output:
pinMode(ledPin, OUTPUT);
// initialize serial communication:
Serial.begin(9600);
}void loop() {
// read the pushbutton input pin:
buttonState = digitalRead(buttonPin);// compare the buttonState to its previous state
if (buttonState != lastButtonState) {
// if the state has changed, increment the counter
if (buttonState == HIGH) {
// if the current state is HIGH then the button
// wend from off to on:
buttonPushCounter++;
Serial.println("on");
Serial.print("number of button pushes: ");
Serial.println(buttonPushCounter);
else {
// if the current state is LOW then the button
// wend from on to off:
Serial.println("off");
// save the current state as the last state,
//for next time through the loop
lastButtonState = buttonState;// turns on the LED every four button pushes by
// checking the modulo of the button push counter.
// the modulo function gives you the remainder of
// the division of two numbers:
if (buttonPushCounter % 4 == 0) {
digitalWrite(ledPin, HIGH);
} else {
digitalWrite(ledPin, LOW);
Természetesen úgy alakítod, ahogy neked megfelel. -
gyapo11
Ez beolvassa a nyomógomb állapotát, a buttonState változó értéke vagy 0 vagy 1 lesz.
Az #1031-be linkelt példa jó, ha nem értesz benne valamit akkor kérdezz.
Illetve még javaslom a folyamatábrát, azal könnyű megérteni a működést programnyelvtől függetlenül, és utána át kell fordítani az arduino nyelvére, ebben tudok segíteni.
tibi-d
Minden programomban én úgy oldom meg a nyomógombok prellmentesítését, hogy a menüvezérlést egy önálló szubrutinba hívom meg. Ezt a szubrutint egy (Timer1.attachInterrupt) hívja meg, ami nálam 0.1s alatt fut le 1X.
Ekkor figyelem a nyomógomb változását. Ha változott, beállítok egy változót (PinOld) amit csak akkor írok vissza, ha már végrehajtottam a feladatot, amit a nyomógomb vezérelt, és felengedtem a gombot. Így biztos, hogy csak 1X fogja végrehajtani. Ez az algoritmus bármennyi gomb vezérléséhez használható, ha kell prioritás is felállítható a gombok között. ( és csak 1X kell megírni, utána bármelyik projektben alkalmazható.) -
gyapo11
Egy változóban őrzöd, hogy most éppen melyik állapot az aktuális, az időmérés, vagy a nem időmérés.
A gombnyomásnál és a fölengedésnél lesznek prellek, ezeket kezelni kell. Lehet külső áramkörrel, ami garantáltan prellmentesen vált egyik állapotból a másikba, vagy software-ből, mondjuk 50 ms-et várni, de szeritnem elég 30 is.
Amikor érzékeled a nyomógomb lenyomását, akkor a millist leteszed, és addig vársz, amíg 30-cal nem lesz több, ha még mindig be van nyomva, akkor úgy veszed, hogy megtörtént a lenyomás. Ekkor elvégzed az ehhez tartozó műveleteket, beírod az állapotváltozóba, hogy 1 (mérés), és figyeled, hogy mikor enged föl. Amikor észreveszed, hogy föl van engedve, akkor ugyanaz a menet, mint a lenyomásnál. Vársz 30 ms-et, megnézed, hogy még mindig föl van-e engedve, ha igen elvégzed a műveleteket és beírod a változóba a 0-át (nincs mérés). És a delay-t elfelejted. -
nyunyu
elapsedTime 64 bites egesz tipusu, azert inicializalja az 1000-es osztot ugyanilyen adattipusnak.
Ha siman /1000 lenne odairva, akkor alapertelmezetten 32 bites int tipusu lenne az oszto, amit osztas elott at kell alakitania a forditonak 64 bitesre, mivel az aritmetikai muveletek csak azonos tipusu parametereken vegezhetoek el.
Legalabbis a fejlett programnyelvek altalaban automatikusan szoktak castolni a rovidebb valtozot a hosszabb adattipusara, de elegansabb eleve ugyanolyan adattipust hasznalni mindenhol.
Ugy rovidebb es valamivel gyorsabb is lesz a leforditott kod.Regebbi progamnyelvek hibauzenetet dobtak forditaskor, ha nem egyezett a ket adattipus.
Legalabbis a C meg elegge haklis volt erre. -
gyapo11
Nem feltétlenül kell megszakítással számolni, a loop egy ledvillogtatással 100 ezerszer fut le másodpercenként, a te programod nyilván hosszabb lesz, de ha csak 10 ezerszer fordul, akkor is lesz ideje számolni az impulzusokat.
Nyomógombot (mikrokapcsolót) simán kezelem bármelyik lábon, még kondi se kell. Az első lenyomott állapot érzékelése után 30 ms múlva kell leolvasni, ha még mindig benyomott, akkor jó, addigra az összes prell elmúlik. Ezután kell figyelni a fölengedést, nekem 40 ms volt kb. a leggyorsabb fölengedésem, de inkább 100 ms-re kell számítani. Fölengedésnél a prellel nem kell törődni, amint 1-be ugrik a bemenet az föl van engedve.
Ez az egyszeri megnyomás beolvasására igaz, ha nyomvatartott állapot is van, akkor kicsit más, én órát programoztam egy gombbal, és volt 500 ms-nél kisebb, 500-1500 közötti, és ennél hosszabb idő, ezek mind más funkciót töltöttek be.
Mivel számolnod kell az impulzusokat, a delay() függvényt felejtsd el, vannak timer libraryk delay nélkül, vagy akár programozhatod magad is, de a loop pörögjön. -
bacus
miért kell két nyomógomb? egy nem elég? ha mér akkor ne mérjen, ha nem mér akkor mérjen. ez egy gombnyomás.
az lcd kijelzőt érdemes úgy választani, hogy legyen rajta i2c busz és akkor 2 vezeték elég, csak magadnak könnyited meg az életed.
ja, most olvasom, hogy soha nem forrasztottál, nos ez a kisebbik baj, mert azt gyorsan megtanulod, lehet az elején nem lesz szép, de működni fog, de ezt ha tartósan meg akarod tartani, akkor a próba panel a minimum, a breadboard, egyrészt drága, másrészt hogy néz ki, hogy a kanócok ott mennek és beleakadsz leesik, ki is húzódik?
Mondom a minimum, hogy veszel próbanyákot, azon szépen beforrasztgatod az alkatrészeket, majd összehuzalozod.
- Lenovo ThinkPad P1 Gen 4 i7 32GB RAM 512GB SSD NVIDIA T1200 16 2560 1600 Garancia
- Dell Precision 7550 i7 32GB RAM 512GB SSD NVIDIA Quadro T1000 FHD
- Dell Precision 5560 i7 32GB RAM 512GB SSD NVIDIA RTX A2000 FHD+
- BOMBA áron eladó új Microsoft Surface Laptop 4 garanciával! AMD Ryzen 5 /16GB /256 SSD/TOUCH/13.5"/
- Dell Latitude 7420 i7 / 32GB /1TB SSD / FHD IPS
- HIBÁTLAN iPhone 13 Pro 256GB Sierra Blue -1 ÉV GARANCIA - Kártyafüggetlen, MS3022, 100% Akksi
- Zalman S3 Black modern, letisztult szèpsèg
- Samsung Galaxy S23 Ultra Green 120 Hz Dynamic AMOLED 2X, 200 MP kamera, beépített S Pen
- GYÖNYÖRŰ iPhone 11 Pro Max 64GB Midnight Green -1 ÉV GARANCIA -Kártyafüggetlen, MS3253,100% Akkumulá
- LG 40WP95XP-W - 40" NANO IPS - 5120x2160 5K - 72Hz 5ms - TB 4.0 - HDR - AMD FreeSync
Cég: NetGo.hu Kft.
Város: Gödöllő
ekkold
