- Ideiglenesen leállította az Xperia 1 VII értékesítését Japánban a Sony
- Apple Watch
D.Orion
" The facts come first. AMD released the embedded Radeon E9550 on September 27. That card packs 2304 SPs with a base clock of 1.12GHz and a boost clock of up to 1.26 Hz, along with 8GB of GDDR5 at 7 GT/s on a 256-bit bus. The E9550 has the same number of SPs as the Radeon RX 480 , but its core and memory clocks are a bit slower. The 95W TDP of the E9550 is a lot more interesting, as it's about 35% less than the RX 480's 150W TDP.
The embedded Radeon E9260 , released at the same time, delivers up to 2.5 TFLOPs from 896 SPs at unspecified clocks paired with 7 GT/s memory on a 128-bit bus, all with total TDP of 50W. The hardware specifications for this card are similar to the RX 460's , but with higher throughput and decreased power consumption.
The speculation comes second. The notorious rumor-mongers over at WCCFTech take the opportunity to speculate about refreshed Polaris desktop cards, which they are bold enough to dub RX 465, 475, and 485. The site's optimists predict the apperance of an RX 465 with a slight clock speed bump, bringing floating-point performance up from 2.15 to 2.5 TFLOPS while power consumption drops from 75W to "less than 50W." A possible Radeon RX 485 with RX 480-like clock speeds and increased efficiency would get AMD close to the 2.8X performance-per-watt claims it made at the Polaris launch. " -
A most bejelentett HIS RX460 iCooler OC 2GB-ról pedig azt írja a gyári oldal, hogy IDLE, 60 Celsius fokig leállnak a ventijei, pedig ez egy 6pin-es tápcsatival ellátott, OC áltozat!
Ahogy nézem, mind a hűtőbordája, mind a venti lapátai csontra megegyeznek az XFX Single Fan megoldásával, ami ráadásul tápcsatival nem is rendelkezik, +2GB memóriával annál inkább. Szóval van még remény, az XFX jónak tűnik, lehet hogy mégis félpasszív, vagy mókolással azzá tehető.
XFX:
HIS:
Ja, csak nem biztos, hogy leállítja a ventiket IDLE; a gyári oldal sem említi ezt, ahogy az MSI-nél sem. PEdig amilyen kis kávédaráló van a gyári OEM példányokon...
Tápcsati nélküli verziókból lehet a Giga WF lesz a legjobb választás...
A 256MB-os címteret "kapuként" használja a VRAM felé. A pontos mechanizmust nem tudom, de feltételezem, hogy a VGA driveren keresztül lehet beállítani, hogy a 256MB írásával / olvasásával a VRAM melyik részét éri el. Ezen belül aztán lehet cizellálni lapozással meg mindenfélével.
smilecat
4Gb van benne, de eddig egy règebbi videokártyával ment rendesen a gèp. Most, hogy ezt beraktam nem hajlandó felismerni akármit csinálok. Jelen pillanatban települ egy 64bit-es rendszer kíváncsi vagyok mit szól hozzá. Remèlem megoldódik a problèma ès működik majd a PCIe 2.0 alatt is.
D.Orion
Ezt így nem erősíteném meg, mert hosszú ideig winyóra megegyező gépünk volt öcsémmel. Nekem HD6850-el, neki HD7770-el és még így sem volt mindig gyorsabb a gépe.
Az RX460 750ti felett és kb. 950szintjén teljesít. Mindenképpen erősebb a HD6870nél vagy 30-40% százalékkal(most kissé a hasamra ütöttem).
Amiről nem váltanék RX460ra az a HD7870 és leszármazottjai.
- BestBuy topik
- Spórolós topik
- Elektromos autók - motorok
- Ez lenne a népkártya? Teszten a GeForce RTX 5060 Ti 16 GB
- Xbox Series X|S
- Samsung Galaxy Xcover 5 64GB, Kártyafüggetlen, 1 Év Garanciával
- Újszerű Lenovo Legion 5 - 15,6"FHD IPS - Ryzen 5 5600H - 16GB - 512GB SSD - RTX 3050 - Win11 -MAGYAR
- Xiaomi Redmi A3 64GB Kártyafüggetlen, 1Év Garanciával
- Xiaomi Redmi Note 13 256GB Kártyafüggetlen 1Év Garanciával
