petya220
Just_Reboot #89 üzenetére
Így gondoltam
Támogatja a kamera api2-t -
petya220
Just_Reboot #87 üzenetére
Mindegyiken működik
Szinte az összes egy forrásból épült. -
petya220
petya220
UPDATE!!!
lineage-14.1-20170214-METICULUS-hi6250.zip
Live Display
Added some logical error handling for unknowns. This should not have been necessary and it may handle the errors in a way that effectively disables live display. If you find that Live Display doesn't work at all please let me know... Somethin' fishus is going on here... In any case this should* fix the random reboots some were experiencing.
CodinalteParts Integration: Settings -> Extras
Glove Mode
Usb Host ModeNEW: Doubletap 2 Wake!
Seems to work better in combination with Glove Mode...
SIM2 (Requires reboot)
Google Codec Workaround (Still laggin...)
Charger functions not working yet...
Debug (logcat ) functions not working yet
WELCOME BACK Sponsors: Settings ->About Phone -> Sponsors
Sponsors Updated!
Camera:
Fix occasional crash of media server. -
petya220
UPDATE!!
Lineage-14.1-20170212-METICULUS-hi6250.zip
Live Display: fix lag
Uses HW and not composite GPU
Fix MTP Host crash
ADB Secure
USB Init Clean up
Fix property issue
When using the "getprop" command with no arguments, getprop would not list anything where it would normally list all properties and their values.
This might fix an issue mentioned where Android Studio does not determine the "api level" of this device when connected to adb.
Installation Checks for those comming from EMUI 4.1
Check to make sure that Meticulus Development's TWRP is being used to flash ROM
Data is automatically formatted after we get permission on screen.
Reboot to recovery to convert TWRP to 'CM' mode after prompt on screen
If you are already on a 'custom' ROM you will not see any difference.
Fix 2g/3g/4g Switch.
Power HAL implement POWER_HINT LAUNCH -
petya220
Bocsánat, helyesbítek, a következő build-ben lesz update... még nem lett közzétéve a rom
NEXT BUILD
- Fixed "janky" camcorders on Camera1 API
- Include Snap Camera App as default
- Fixed orientation sensor
- Fixed FC in Calendar App
- Include NFC
---- Online and turns on and off fine but otherwise untested.
- Fixed Wifi Hotspot
---- Changed USB init for compatiblity. -
petya220
Akinek nem működik normálisan a RIL, eldobálja a hálózatot, annak itt a megoldás
build.prop-ban át kell írni ezt a két sort:
ro.config.client_number=2 --> ro.config.client_number=1
ro.config.modem_number=2 --> ro.config.modem_number=1LineageOs update!
A videó felvétel működik, de csak camera api2-nél..
szóval Open camerát kell használni hozzá -
petya220
LineageOs 20170202 build
Camera Fixes
Photo snap on both front and back cameras are working.
Video recording functions without error but recorded video is "janky".
Képet tudunk már készíteni, de videót még felejtsük el[ Módosította: Intruder2k5 ]
- Bomba ár! Dell Latitude 3550 - i5-5GEN I 4GB I 500GB I 15,6" HD I HDMI I Cam I W10 I Garancia!
- BESZÁMÍTÁS! MSI B450M R5 5500 16GB DDR4 512GB SSD RTX 2070 8GB Rampage SHIVA FSP 650W
- iKing.Hu - Xiaomi 14 Ultra - Ultra White - Használt, karcmentes
