- Megjött a Honor szuperakkumulátoros mobilja
- Igazi csúcskészülék lett a Poco F7 Ultra
rocket
The 90nm R520 components will come in three flavors as we mentioned earlier, all with the X1800 Radeon moniker. The available marketing information claims that the GPU uses an ''ultra-threaded quad-core 3D architecture'' and a ''512-bit ring bus'' memory controller. There's definitely some marketing hyperbole going on there, but let's get into the details.
Those of you who know a little bit about GPU architecture should recognize the ''ultra-threaded quad-core'' design as a standard GPU. X800XL/XT would also qualify as ultra-threaded and quad-core, as would the 6800GT/Ultra. They have a core split up into groups of ''quads'' - four pixel pipelines that can be deactivated as a group in case one of them is faulty. Our understanding from the documentation is that there are once again four quads, so expect to see 16 pipes on this card. There are some ''confirmations'' of 24pp and 32pp, but the roadmaps clearly say four cores/quads (at least to begin with) due to yeild. All signs indicate that a future generation, R580, will use six cores instead.
The 512-bit internal ring bus actually excites us the most; Cell's Elemental Interface Bus (EIB) uses a 16-byte wide quad ring bus, capable of transferring 16-bytes per cycle to the various SPEs. R520's ring bus would actually be four times wider than the bus found on Cell; though this implementation is in R520's memory controller rather than the PPE-to-SPE interface. With all the hype for R520 so far, everyone is banking on the memory controller to put X1800 ahead of G70. However, there is once again some hype occurring. The memory subsystem is still connected by a more typical 256-bit memory bus, and the 512-bit ring bus is something else. We'll have to wait for actual cards and benchmarks before we can really discover how the card performs.
Other interesting technologies on R520 include Shader Model 3.0 (and thus HDR), Adaptive anti-aliasing, and up to 512MB of GDDR3 memory. Our sources indicate that only the Crossfire versions of X1800 will support 512MB initially, but this may change further downstream. Radeon X1800, X1600 will also feature ATI's AvivoTM technology, which we currently cannot discuss further. There was also indiciation in the roadmap that this generation of ATI cards will fully support Windows Vista, with beta drivers already available.
Bővebben: link
Adaptive AA, hmm
Latszik anandtech-es hir, a ''zold''seg beszel beloluk 1-2 helyen
[Szerkesztve] -
rocket
Joparan beszeltek mar rola az nv-tol, nem nagyon titkoloznak a rsx-rol.
''For those that don't know, if you've been living under a rock for the last few months, the graphics processor in the PlayStation 3 is NVIDIA-designed and is called RSX. How does it compare next to the 7800?
''The two products share the same heritage, the same technology. But RSX is faster,'' said Kirk.''
Bővebben: link
Egyebkent a ket konzol erdekes ellentete egymasnak, mig az xbox360 a gpu, a ps3 a cpu erejere epit elso sorban, legalabbis ez latszik kirajzolodni a jelekbol -
rocket
Igen amig barmilyen gond van vele ne is adjak ki, ez nem egy sw, hogy majd utolag kiadnak egy patchet amit javitja a hibakat
Szamitastechnikaban olyan, hogy 100% nem nagyon van, megterveznek egy chipet amirol van egy elkepzeles papiron, aztan kiderul, hogy a valosagban, jo ha 100 chip-bol 1 tudja azt amit terveztek neki, persze ez nem jelenti azt, hogy az rossz lesz, csak azt, hogy nem 100%-os.
Altalaban magasra teszik a mercet ilyen helyzetekben, hogy legyen hely alkotni valamit ha megse jonne be annyira
Errol nincsenek pontos adatok, tobb fele hir is van ami ellentmond egymasnak, az egyik ,hogy a c1-et es az r580-at tervezte az art-x, a masik szerint az art-x mint az r300 koraban nem letezik mar, felosztottak oket, eszerint 3 csapata van az ati-nak, az egyik aki a r420/r520-on dolgozott, a masik akik c1/r580-on, es a harmadik ahol a legtobben maradtak az art-x-bol ok csinaljak/csinaltak a nintendo revolution gpu-jat.
Szoval kodosites van ezekben a dolgokban, erdekes modon errol nem szoktak beszelni hivatalosan, es a gpu-n meg nincs stablista, hogy kik keszitettek -
rocket
Az eremnek van egy masikfele is, mig a ps3 lelke az rsx egy g70 0.09 mikron-on, addig a c1/xenos egy teljesen uj chip , semmi koze az r520-hoz.
Tehat ha igy nezzuk a dolgokat, az ati ket chipet fejlesztett mig az nv egyet, es meg ott van a nintendo revolution is amibe szinten ati chip lesz.
Ez nem elszamitas, egy uj gyartasi folyamatra nem lehet felkeszulni, Dave Orton az ati elnoke nyilatkozta, hogy a szimulacio soran semmilyen gond nem volt a chippel, viszont a tapeout-nal mar voltak gondok az ujfajta memoria vezerlovel amit ujra kellett tervezni.
Ha nem ujitanak akkor azert karog a felhasznalok tobbsege, ha meg igen es gondok akadnak, akkor meg azert karognak mert miert kesik, ez egy ilyen iparag kockaztatni kell neha
Nv30-hoz hasonlitgatassal varni kene, egyetlen kozos dolog van eddig a ket esett kozott, a csuszas. -
rocket
Rsx nem mas mint egy (gyengebb? Bővebben: link )g70 , mig az c1/xenos egy teljesen egyedi chip, igy ertette gondolom
rocket
M$ meg a vista elott kiakarja adni az uj dx-et ami tamogatja mar a sm4.0-at, ezt beszelik mostanaban, lehet ok mar tudnak valamit?
Persze idejemult, ez csak egy vicc akart lenni a reszemrol(nem emlekszem mar volt e hivatalos bejelentes, de arra igen, hogy nagyon extreme ultraztak anno, tobb tesztben is szerepelt a kartya
rocket
Bővebben: link
Ugytunik nem x900, hanem x1800 lesz az r520 neve.
[Szerkesztve] -
rocket
Interview with Dave Orton, sok mindenre feny derul benne
''Sampsa: Can you tell us a little about the problems which you encountered when you moved to 90nm production technology?
Dave: ''Xbox 360-game console’s Xenon-graphics chipset was developed on 90 nm with tremendous success, so we felt confident using it for the R5xx family. RV515, which will be aimed at the entry-level PC segment, also worked perfectly from the outset without encountering any manufacturing issues. But to be honest, we’ve had our share of challenges with the R520 and RV530 chips. Even though all the simulations that were done with the chips were looking good, there were still issues with the silicon when it came back from the fab. It was also surprising that RV515 and RV530 were designed by the same team and manufactured in the same fab using same technology, but RV515 worked perfectly and RV530 caused us problems''.
According to Dave, R520 chips taped-out in November 2004 and original plan was to announce it seven to eight months later during the June-July period. Adopting smaller manufacturing technology delayed the schedule by a couple of months, but because of other challenges the engineers faced, the chips were delayed by an additional 2-3 months.
Es itt jon a leglenyegesebb :
''Sampsa: Did you have to remove any planned features from R520 in order to reach the version of R520 which you’re about to bring to the market?
Dave: ''No we didn’t. The graphics chip runs extremely fast, and although we’re still finalizing clocks, I can tell you that we’re hitting stock engine speeds never seen before in this industry. The chip had to be produced with 90nm technology, because 110 nm would have made it way too large, and it’s still not a small chip.''
According to Dave, the memory controller of the graphics chip has gone through a complete redesign, and ATI will be providing more details when they launch their new product family this fall.''
Bővebben: link -
rocket
Ugynezki amirol irogattunk paran itt marketing temaban, az ati is rajott erosodnie kell ezen a fronton
Bővebben: link
Aztan mostmar johetne az r520 is, a marketing csapat keszen all mar -
rocket
Bar inq hir, de:
''520 frequency goes to 700+ MHz''
Bővebben: link -
rocket
Itt olvashatsz bovebben a TAAA-rol:
Bővebben: link
Battlefield 2 alatt supersamplingnel tul ''jol'' mukodik a kepek tanusaga szerint
[Szerkesztve] -
rocket
Inq vagy total marhasagot ir arrol amit eppen kitalal Fuad, hogy legyen mit olvasni, vagy nagyobb reszben igazuk lesz egy hirrel kapcsolatban.
Ezek a ''we heard'' ''we learn'' kezdetu dolgok amik altaban bejonnek
Valoban biztos vannak szandekosan kifecsegett dolgok amik a PR reszei, hogy addig is legyen mirol beszelni, es ''eletben'' tartani a kartyat amig megjelenik
Oke, tehat az r520 sm3.0+hdr+32bit+0.09+ 600+mhz lesz es bonuszkent ott lesz a hdr+aa akkor az mar good work ? -
rocket
Kis nosztalgia, nekem ami nagyon megmaradt a hires ''3dfx only''
Sajnos ebbol is ugytunik, hogy rengeteg penz kell megtapadni a vga gyartok kozott, es nem eleg csak egy jo kartyat csinalni ujdonsagokkal, ha nincs aki jatekot irjon ra ami kihozza azt a pluszt es ujdonsagot/undonsagokat amivel tobbet tud mint x ceg kartyaja.
Egesz mas kepe lenne a vga vilaganak, ha lenne egy 3. eros ''versenyzo'' (intel-t nem sorolom ide mert ok mas vonalon nyomulnak es erik el a legnagyobb piaci reszesedest, sot talan az integralt intel vga-kat nem is neveznem igazi 3d gyorsitonak).
Kar, hogy anno a 3dfx beolvadt az nv-be, mara mar biztosan lennenek akik eletre porbaltak volna kelteni, bejaratott nev azert megis masjobb mint egy uj nevvel indulni.
Az is biztos, nem jon a siker egyik naprol a masikra, az ati is iden 20 eves, es nem konnyen jutottak oda ahol most tartanak. -
rocket
A mhz nem minden ebben igazad van, ezek nem igergetesek, hanem pletykak csak, az ati nem igergetett semmilyen orajelet, inq igerget
Pont ez a legnehezebb feladat ha nem kozepen kezdik, bar egyben a sm3.0, hdr, 32bit, 0.09 se pajzan majalis foleg felso szegmensben kezdve.
Hivatalos idopont nincs meg, de augusztus 30.-a elott lesz szerintem r520 premier (ahogy az a banner is sugalja, ha arrol szol egyatalan), augusztus 30.-an indul a jatekfejlesztok europai konferenciaja, majd az ati sajat jatekfejlesztoknek szant konferenciaja szeptember 6-7, addigra kell a kartya, hogy legyen mirol beszelniuk a jatek fejlesztoknek
Holiday szezonban remelhetoleg mar kemeny verseny lesz, es sok-sok kartya kozul lehet majd valasztani mindket oldalon, ami az arakra is hatassal lehet felhasznalo szempontjabol jo iranyba -
rocket
Egy cikk a tavolkeletrol
Bővebben: link
Ezt dekodolni nem lesz egyszeru, fordito se birkozott meg vele -
rocket
Inq ezt irja
''Chip will be clocked incredible high and our sources implies that will end up much higher than 600MHz plus than we suggested before.''
Vegen meg tenyleg 700 mhz lesz kis oc-vel, es akkor kerem majd toled rudi politikus modra az anno megirt cafolatod korrekciojat, es minimum 5 orszagos napilapban kell lekozolnod
Inq mar a g71-rol is irogat (Bővebben: link ), hogy az is dual slot hutos lesz, es az lesz a 7800 ultra szerintuk, viszont 0.11 chip lesz.
r580-rol is pletykaznak mar, most az a hir jarja, hogy nem csak szokasos orajel emeles lesz az r520-nak, hanem egy teljesen mas chip es nem az r520, hanem a xenos (r500) chippel lesz szorosabb kapcsolatban.
Inq-nak mostanaban nem sok hire jott be, leirtak, hogy ibm fogja gyartani a xenos-t masnap kiderult, hogy a tsmc
[Szerkesztve] -
rocket
Igazad van hype az volt (kicsit elkapkodtam amit irtam mielott jobban atgondoltam volna
), hatas az mar mas kerdes, bar errol nem ok tehetnek, hogy nem jottek anno a sm2.0 jatekok.
Utana levo generacioban talan nagyobb sikert ertek el, es az ido azt mutatja kozelebb voltak az igazsaghoz mint a konkurencia. (persze ez lehet csak papiron tukrozodik, az eladasokban nem, igy meg ugye nem sok ertelme van).
Fejlodnie kell az ati-nak, foleg a gitg programot kellene megerositeniuk arra tobb penzt szanni, es az internetes sajto fele is szorosabb szalakat szoni.
Az ehez vezeto uton az elso lepes a verfrissites
[Szerkesztve] -
rocket
R520 is a dual slot card
Looks like Radeon X850XT PE, just shorter
Bővebben: link
Az ati az A tervet valasztotta ugytunik, 2 slotos hutes de rovidebb nyak, kivancsi leszek, hogy csak a xtpe-n alkalmazzak e majd.
Es egy kicsit off hir, de ugyis beszeltunk errol is az elmult napokban
Bővebben: link
Ugynezki az ati kezd rajonni marketing fronton erositeni kell
Ez a resz tetszik ''Dan Vivoli definitely knows how to create hype for products.''
Ez nem nagyon latszott eddig , hogy tudna -
rocket
Attol, hogy kozelebb vannak a vga technologiak egymashoz meg igaz amit irtam.
Ha az nv megtudta volna csinalni, hogy nagyobb orajeleken menjen a kartyajuk megcsinalta volna, ennyi, ezert hulyeseg a clock for clock osszehasonlitas.
Ezt toluk kene megkerdezni.
Talan nem gondoltak, hogy az nv ennyire eros kartyaval jelenik meg a mainstream kategoriaban es akkor mar volt egy elkepzelesuk milyen lesz a sajat mainstream kartyajuk, igy azt kaptuk amit terveztek vagy ennyire tellet, az, hogy tudtak volna e jobbat orok rejtely marad mostmar.
Agp fronton ott volt a bejaratott nevu 9800pro, pci-e fronton meg maradt az x700 szeria.
Nehez kivulrol belelatni a dolgokba mi miert zajlik, kivulrol tunhet ugy, hogy az ati hatalmas piacot veszitett igy mainstreamben, de lehet oem piacon tele tomtok a zsebuket.
Ezeket megtudni sose fogjuk, max. az uzleti jelentesekbol kovetkeztethetunk. -
rocket
Bizony igy van ahogy irod ezzel partatlan maradhatsz, de olvasd el honnan indultunk:
#339-re valaszoltad a #340-ben a kovetkezot:
''Hát én most bogozom a 7800GTX szintetikus shader eredményeit,és hótmindegy mit csinál az ATI nagyon meg lesz verve ha a programozók végre ráállnak a heavy-weight shader kódolásra.''
Szerintem zarjuk le a temat, nem vagy elfogult, de az ilyen kijelentesekkel ovatosan.
''Mekkora pionír volt az ATI az SM2.0 és R3xx idejében! Hová tűnt ez? Megette volna a céges érdek és az M$''
Szerintem az ati kicsit elaludt az r300 sikerein, addig azert labdaba se rugtak nagyon, es egy monopoliumot tortek meg az r300-al, ehez persze kellett az fx szeria gyengelkedese is.
Ezutan meg jott a rancfelvarras ami teljesen normalis dolog, kikell szedni minden centet amig lehet valamibol, de itt kicsit alabecsultek a konkurenciat, ebbol jott a ''lemaradas'' amit probaltak kivedeni (szerintem igazuk lett nagyobb reszben, mert valoban nem nyert annyira teret a sm3.0 amennyire azt a konkurencia hirdette anno).
Es akkor ugye a xenos, ami ha lehet hinni a hireknek 2 evig dolgozott az r300-at keszito mernok csapat, es valoban revolucio lett.
Tehat amit te szoktal mondani, most is igaz, ott a xenos az unified shader modellel, longhorn beta a nyakunkon, igy lesz hw amivel keszulhetnek a jovore.
Vicces lenne az ati kijonne az r520-al es unified shader modell lenne benne, m$ meg ugye most az o oldalukon van, egy gyors longhorn megjelenes meg a kovetkezo generacio elott es maris megfordulna a kocka , persze ez nem valoszinu, az r600-ig. -
rocket
Lehet az az ati elkepzelese, hogy egy show musor altal mutatjak be, ahol kiosztanak egy csomo ajandekot, es a nem szokasos helyszin is pozitiv lehet marketing szempontbol
Persze ez meg csak egy banner,lehet egesz massal kapcsolatos, de nem lenne hulyeseg az ati reszerol, ha kicsit show jelleget adna a bemutatonak, es a mediabol ez csorogna mindenhol napokig, akkor vegre kaphatna a pr osztaly egy piros pontot -
rocket
Vajon milyen launch event lesz, es miert pont Ausztralia-ban
Innen Bővebben: link szarmazik a banner
[Szerkesztve] -
rocket
Ezt a clock for clock dolgot nem lehetne skipelni mert total ertelmetlen osszehasonlitasi alap.
Amd-nek lennenek valodi 3.6ghz-es procijai intelnek K.O. lenne, de nincsenek valoban 3.6 ghz orajelu processzorai, mert kivitelezhetetlen lenne az altaluk alkalmazott tervezesi es gyartasi technologiaval.
Ati es az nv mas utakon jar, mint ahogy az amd es az intel is.
Egyebkent ezekkel a hozzaszolasaiddal csak a partatlansagod cafolod egyre jobban, es masokkal ellentetben akik sima forumozok neked megkene maradnod partatlannak ha mar cikkeket irsz ph-n, ne te legyel a kovetkezo Palik Laci meg ha nem muszaj
[Szerkesztve] -
rocket
rocket
rocket
Meg mindig nem ertem.
Ezzel csak az fx szeria alatti sm2.0 mizeriara akartam celozni, hogy amit ott negativ iranyba tereltek, azt az nv40 alatt a sm3.0-val pozitiv iranyba tereltek.
Az ati-nak akkoriban lehetosege se lett volna elhiteni barkivel is amit akar, se penze se szabad partnerek nem voltak ehez, akkor mar boven megvolt telve a konkurencia tarsolya, es meg a m$ is ott volt a mellek zsebben. -
rocket
Bővebben: link
Itt azt irjak, hogy nincs 3Dc tamogatas a g70-ben. -
rocket
En ugytudom nincs, mindjart utana nezek.
Ez nem igy mukodik a valosagban, nezd meg hany twimtbp jatek kerul fel a listara a megjelenes elott par honappal amikor a jatek mar reg kesz van, nem a hw-re fejlesztettek a sw-t (mint ami ugye ezeknek a programoknak a lenyege lenne), legujabb pelda a serious sam 2, regota ati kartyakon mutogattak sot a 3Dc-t is ezzel prezentalta az ati tavaly az r420 premierekor, erre most par honappal megjelenes elott twimtbp jatek lett, ez nem hiszem, hogy ez a hadseregnyi embernek koszonheto aki ezzel foglalkozik, hanem inkabb a csekk fuzetnek.
Ezt nem hasznaltak anno akkor a flatout keszitoi, hogy sikerult ongolt rugniuk
Egyetertek es semmi gond ezzel, de vannak azert hatarok, es ezeken mar reg tul leptek, ha mar hw szinten nem tudnak a konkurencia fole noni, akkor sw oldalrol probaljak a monopoliumot kialakitani es a piacot iranyitani.
Nem egyszer lathattuk mar amikor egy nagynevu jatek marketing eszkozze valt, mint pl. a chaos theory tette a kihagyott sm2.0-val, mikozben masik oldalrol a hl2-ben kulon path-ot irtak, hogy normalisan fusson a legtobb fx kartyan, ahelyett, hogy csak odadobtak volna dx9 modban ,''ezt nektek'' cimszoval.
Intel meg az nv ebben hasonlitanak, hasonlo eszkozokkel jatszanak, az egyik a gepepitoket tartja sakkban, a masik a jatekfejlesztoket.
Jot tenne egy eros 3. resztvevo, mert akkor nem lenne eleg 1 fele figyelni es sokkal erdekesebb csatak alakulhatnanak ki.
Ne csak off topic legyen es az R520-rol is irjak piros lesz a nyak szine
Arra kivancsi leszek , hogy sikerul e a beigert megjelenesre tenyleg egy egesz csaladnyi kartyat kiadniuk, es a tobb fele r520 melett, rv530 ott lesz e a rajtnal a nagyteso mellett.
[Szerkesztve] -
rocket
Azt elobb is kozolhettek volna, viccet felreteve, gondolom sok penzt rakoltottek mar nem lehet csak ugy kidobni az ablakon, ezert mindent kikell preselni belole, amit ugye nem latunk, hogy ezt jo ertelemben csinaljak mert a chip olyan jo lett, vagy tenyleg kapunk egy nv30-at ati modra, erre majd a megjeleneskor kapunk valaszt lekorabban.
Ahogy te is irtad valamelyik masik hozzaszolasban, ha ez bekovetkezne nehezebb dolga lenne az ati-nak, mert nem allnak mogottuk annyian akik eltudjak hitetni a vasarlokkal, mire van es mire nincs szukseguk, mint ahogy azt az fx szeria alatt tette az nv es udvartartasa.
''Anno az ATI nyomta (vagyis próbálta nyomni de nincs hozzá megfelelő képessége) az SM2.0-t, most az NV nyomja az SM3.0-t és HDR-t.''
Megfelelo kepesseg alatt mit ertesz ? mert a zoldhasuakat nem igy hivjak szerintem
Ugytudom nem tudja az ''igazi'' 3Dc-t a g70, csak az nv sajat V8U8 megoldasat. -
rocket
En mashogy latom ezt, de nem irom le ujra.
''Persze az nv semilyen 7800 kártyát nem dobott piacra, csupán marketing.''
Total kiforgattad a szavakat, nem errol beszeltem, hanem a megjelenes elotti es utani dolgokrol, nem a kartya nem letezeserol.
Vegyen mindenki amit tud es akar, ez jo zarszo reszemrol -
rocket
Az mas kor volt, egesz mas a helyzet ma, raadasul az ati-nak ott az r500 a zsebeben, meg mas fronton is nyomulnak.
Az ati most kisebb godorben van, ami elsosorban a kesesnek tudhato be (vagy tenyleg az xenos (r500) volt az eloterben), ezert nem teljesitettek jol az elmult penzugyi negyedevben mert sok volt a kiadas ami ugye a befektetesek resze igy hoszabb tavon hasznot hozz majd.
[Szerkesztve] -
rocket
Ez nem mentseg, hanem teny.
Akit nem erdekel az megfogja venni az r520-at is.
Tobbseg kivar valoszinuleg mert szeretne a legjobbat kapni a penzert amit kifizet.
Crossfire augusztusra volt igerve anno amikor volt a paper launch, jelenleg julius kozepe van.
Ez azert nem igy zajlik, konkurencia szereti mar elore szidni/megmagyarazni azokat a dolgokat amit az o kartyajuk nem fog tudni es pletykak alapjan a masik igen (vagy lehet jol mukodik az ipari kemkedes), volt erre pelda mar mindket oldalon, es nem csak a vga gyartoknal, hogy kinek van igaza arra utolag az ido majd valaszol.
Azon vannak, hogy bizonyitsak, csak turelmesnek kene lenni, ha lenne olyan jatek ami igenyelne ezeket a kartyakat megertenem a turelmetlenseget, de jelen esetben amikor nincs ilyen jatek es a cpu a szuk keresztmetszet nem ertem miert lenne gond 2 honap keses.
Eddig kb. ket es fel hivatalos bejelentes volt az r520-rol, minden mas pletyka, igy ne csodalkozz minden nap ilyen hireket olvasol.
Az, hogy csond van az r520 korul inkabb a mentalitas beli kulonbsegeknek koszonheto, az ati az nv-vel ellentetben nem a ''mindenaron az emberek szajaba ragni'' marketing hive, persze ez hiba a mai vilagban mar, mert miota net van az agressziv marketing egy termek eladasanak a legfontosabb kulcsa, ebben kene fejlodjenek az biztos.
Szoval megkell varni a kesz termeket, es aztan lehet majd szidni, vagy dicserni. -
rocket
Ebben egyetertek veled, hogy az ati ados mar regota valami szep/uj/jo-val, talan ezert nem kene elitelni lathatatlanba az r520-at.
Gondolom azert nem kell magyarazni, hogy a 0.09 gyartas nem setagallop meg manapsag, mint a 0.11.
Ez igy van, mainstream kategoriaba elvereztek az elozo generacioban. (mar lehet igy nevezni)
Arra nem gondoltal az nv menekul az r520 elol ? azert ez a nagy sietseg 7800gtx korul. (erdemes elolvasni David Kirk (nv chief scientist) amokfutasanak masodik reszet, ahol mar elore elkezdte fricskazni a jelenlegi infok alapjan r520-ban benne levo es a g70-bol kimarado dolgokat).
Erre mar valaszoltam feljebb, 0.09 gyartas nem setagallop, ezert keshet par honapot.
Egyebkent valoszinu, hogy az ati nem gondolt arra, hogy az nv paper launch maga a store launch lesz, es emiatt inkabb nem jelentik be a kartyat juliusban, hogy aztan majd osszel kaphato legyen, hanem probalnak ok is a store launchra ramenni.
Azert nem jon a crossfire szerintem, mert jelenleg ertelmetlen lenne, inkabb tartogatjak.
Semmi egetrenegtot nem latok az 500mhz-be, foleg mivel valojaban 470mhz alapbol a kartya 3d orajele.
Ez megint egy olyan terep amit felesleges felhozni, ha csak az orajelek szamitananak az amd legazolta volna a szinterrol az intel-t hasonlo orajelen.
Ez teljesen erheto, pc mint jatekgep a vegehez ert, eves szinten 2-3 jatek van amiert erdemes fejleszteni a gepet, ezen kivul mar csak a strategiai jatekok maradtak a pc-nek, nem csoda, hogy menekulo utvonalat kerestek.
Konzol egy vga ara, es 5 evig elvezheto szinvonalat nyujt.
Az xbox360 mar van unified shader modell, meg az edram is erdekes megoldas ezzel ''ingyen van'' az AA, ezert se kell temetni oket.
Es mivan ha palira vettek a vilagot, es mar az r520-ban is unifed shader modell lesz? (persze ez nem valoszinu, de azert jot mosolyognak ha bejonne)
Ezeket az erveidet eddig is ertettem, es nagy reszben egyetertek veluk, de meg mindig nem volt meg a valasz egy megnem jelent termeket miert jo fricskazni, ezek csak kovetkeztetesek mind amiket irtal es nem tenyek (amik ugye nem is lehetnenek mert nem jelent meg a kartya es hivatalos info is keves van rola).
Egy szo mint szaz varjuk meg az oszt, akkor raersz majd temetni az ati-t, jelenleg ugysincs semmi amihez kellenenek ezek a kartyak igy nem hiszem ha par honapot csusznak nagy gondban lesznek, foleg ha valoban egesz csaladnyi kartya jon egyszerre.
Lehet adni egy kis idot az ati-nak gondolom, erdekes, hogy a fejletebb orszagokban mennyivel masabb az emberek mentalitasa, ott mindenki varja az r520-at nem itelkezik ellene, nem isteniti a g70-et amig nicns mihez merni.
Es egy kis velemeny aztan lezarhatjuk az off topicot, az nv egyertelmuen monopolium kiepitesen munkalkodik (intel feletti magassagokban jarnak mar), a jatekfejlesztok nagyresze utan, mar az internetes sajto nagy resze is a zsebukben van, igy terjeszthetik az iget minnel gyorsabban, es sikeres ez a torekvesuk, mert minden 5. hozzaszolasban egyes topicokban azok az ervek szerepelnek szorol szora amit eloszor a pr manager szajabol vagy az altaluk keszitett grafikonon volt olvashato.
Legtobben akik elore isznak a medve borere belese gondolnak ha az ati gondba kerul, azzal csak ok maguk jarnak rosszul mert az arak majd ehez fognak igazodni.
Zarszokent jelenleg nv 1: ati 0 ,a ''haborunk'' meg nincs vege es nem biztos az nyeri a haborut aki az elso csatat nyeri (erre az r420 vs nv40 jo pelda volt) -
rocket
Az biztosnak tunik vannak/voltak gondok az r520 korul, de mar lathatatlanba temetni felesleges..
Ezt a reszt nem ertem
''Kezdek egyre szkeptikusabb lenni, ráadásul most láttam, hogy pontosan mennyire erős a 7800GTX azokban a tesztekben, ahol korábban az ATI volt a nyerő.''
Itt melyik ati kartyahoz hasonlitottad ? mert csak elozo generacios lehet ( ha csak az ati nem adott neked ajandekba egy r520-at), azoknal meg persze, hogy gyorsabb.
Ez az amit par honapja mondtam neked es akkor nem ertettunk egyet, amiert 1 eve az ati-t szidta mindenki, azert most az nv elott meghajolnak a legtobben, ez pedig ugye a rancfelvarras.
Akarmilyen is lesz az r520 megkene varni es utana itelkezni, mert hiaba fog olyan dolgokat tudni amit a g70 nem tud, mivel az ati nem vasarolta fel a jatekfejlesztok 90%-at igy ezek az ujdonsagok nem fognak eloterbe kerulni, vagy meglesznek magyarazva, hogy miert nem ernek semmit, es ezt persze twimtbp programban resztvevo jatek fejlesztoje fogja elmondani.
Elgondolkodtam mi vezerel teged aki tenyleg kened/vagod a temat, hogy ilyen elhamarkodottan itelkezel es nem tudtam rajonni valaszra (ha csak nem elfogult lettel), kifejthetned, mert a shadermark tesztelosdi osszehasonlitasi alap nelkul nem hiszem valaszt adna a kerdesemre.
Ezt egeszseges kritikanak szantam feled rudi, es nem szemelyeskedesnek, remelem nem annak veszed.
Mailben is irhatsz ha gondolod, kivancsi vagyok mar mi vezerel amikor ilyeneket irsz. -
rocket
Mibol latod, hogy nagyon meglesz verve? mert semmit nem tudni az ati uj kartyajarol, foleg nem a shader teljesitmenyet
Es pont toled hallok ilyet, azt hittem lathatatlanba nem itelekezel
Unreal 3 engines jatekok elott nem hozza el nekunk senki a shader intenziv vilagot.
Talan a F.E.A.R. lesz ehez a legkozelebb, de mas jatek nem ugrik be hirtelen.
[Szerkesztve] -
rocket
Par erdekesseg ismet
Egy kicsit off:
ATI a takeover target?
Bővebben: link
Meg egy kis off:
IBM preparing to build ATI R500 for Xbox 360
Bővebben: link
R520 tape-out number three was successful
Bővebben: link
Inq minden heten mast ir, multheten azt irtak nem lett jo a megismetelt tapeout Bővebben: link, 5 nap alatt nem lehet uj tapeout-ot csinalni
Beszelhetnenek mar a tenyek inq helyett, mert annyira osszekavarja a dolgokat, hogy kibogozni se lehet
[Szerkesztve] -
rocket
Kezdodik a mozgolodas, mondjuk minden nap mas hir van, egyik csak igaz lesz
ATI R520 to be available in mid-3Q
ATI Technologies expects to begin volume shipments of its 90nm graphics processing units (GPUs), the R520, R530 and RV515, in the middle of the third quarter, as unspecified issues for manufacturing on 90nm technology will soon be solved, according to ATI Taiwan. ATI also plans to introduce another flagship chip, the R580, in early 2006.
The delay of the ATI R520 has allowed Nvidia to gain some orders on the high end of the market, as the company announced the availability of its flagship GeForce 7800 GTX (G70) in June.
The upcoming launch of ATI’s three 90nm graphics chips is expected to boost overall 90nm output from Taiwan Semiconductor Manufacturing Company (TSMC), industry sources suggested. Although less than 4% of TSMC’s sales came from 90nm technology in the second quarter of 2005, the percentage should grow to more than 10% by the fourth quarter, according to Rick Tsai, CEO of TSMC.
ATI will also soon enter the tape-out stage of its flagship R580, an upgrade of the R520, according to the sources.
The launch of ATI’s 90nm chips will accelerate the migration from AGP8X to PCI Express (PCIe), as falling prices for PCIe-capable products will stimulate demand, graphics-card makers commented. The PCIe segment is expected to account for half of graphics-card shipments by the end of this year, though the AGP8X segment should continue to dominate the entry-level segment through the middle of 2006, according to the makers.
Bővebben: link -
rocket
Meg 1 kis hir
Bővebben: link
“From a 90nm technology, we are extremely encouraged both with readiness of the technology, the capacity, the yields… And we’ve got very successful experience with the Xbox 360 and a bring up and ramp of its GPU,” ATI’s CEO said.''
Nekem ugytunik egyre jobban, hogy a xenos-t az r520 ele helyzei az ati, azert csuszkal ossze-vissza.
A konzol piac jobban elore kalkulalhato, es gondolom a m$ is kopogtat kemenyen az ati-nal. -
rocket
Ne csak inq hirek legyenek
R520 to Come Late Summer
Bővebben: link -
rocket
Ahogy varhato volt g70 megjelenese utan, folytatodnak a pletykak
''R520 finally supports HDR
Bővebben: link''
Ez ugye nem tul nagy pletyka, inkabb papirformanak szamit ahogy rudi is mondana
''R520 delayed? Probably not
Bővebben: link
Ez mar erdekesebb tortenet, kivancsi leszek lesz e paper launch juliusban, vagy inkabb store launchot csinalnak inkabb szeptemberben -
rocket
R520 - Pixel Shader 3.0a?
Bővebben: link
Ez mekkora poen, amikor nincs hivatalos info, es egy patch readme-bol derulnek ki a dolgok -
rocket
Egy kis AntiAlias demo humus-tol
''This demo implements supersampling antialiasing by rendering the scene multiple times with just a tiny tweak to the projection matrix between the renders and accumulating the results in the accumulation buffer. It allows you to change between 1x (no AA), 2x, 4x and 11x (default). If you enable antialiasing in the control panel you can get really large AA modes, for instance 6x multisampling + 11x supersampling, which would give you essentially 66x AA.''
Bővebben: link -
rocket
ATi R520 Launch On 26th July
Bővebben: link -
rocket
Ez a hir annyi ujdonsagot tartalmaz mint az elultetlen borso mag borsoszemet
En azert nem lennek ilyen optimista a g70-rol junius 22.-en lesz a paper launch es a computex infok szerint csunya eges nyomok voltak az ott bemutatott kartyan es nem volt live prezentacio sem.
Mikozben az ati az r520 kepesegeit prezentalta mar az e3-on es most a computex-en is zart ajtok mogott, sot mar hivatalos prezentacio is volt az r520 h.264 decoding hardwares gyorsitasarol.
Paper launch az egy dolog, ha azt nem kovetik tettek nem er semmit, osznel elobb nem lesz semmi ebbol a kartyabol, addigra meg mar az r520 is esedekes lesz, es elkepzelheto az ati strategiat valtott es azert nem lesz nyaron paper launch mert egybe kotik a bejelentest a megjelenessel, bar ez nem valoszinu -
rocket
ATI Demos R520, Accelerates H.264 Decoding
ATI is addressing one part of the problem by offering GPU-accelerated H.264 decoding with the R520. The demo was conducted on 25Mbps HD footage recorded using a HD video camera and played back on a Pentium 4 3.6GHz system (Hyper Threading enabled) with a R520 graphics card.
CPU utilization without the GPU acceleration enabled was stated to be between 90 - 95%, but when GPU accelerated H.264 decode was enabled the CPU utilization dropped to around 33%. We witnessed the GPU-accelerated playback first hand and were quite impressed.
ATI has committed to us that they would have a H.264 player available by the end of this year that would offer this level of acceleration when paired with a R520 GPU. ATI said they were looking into bringing the acceleration to older GPUs, but they would not say anything beyond that.
Igy elsore ez tenyleg impressziv, az utolso mondat erdekes meg, kivancsi vagyok mit sikerul alkotni ebben a kerdesben visszamenoleg a regebbi gpukkal -
rocket
Egy kemfoto a hutesrol
rocket
ATI’s R520 to Feature Hardware Accelerated HD Content Playback.
ATI to Demo HD DVD, BD ROM Playback on R520 at Computex Taipei 2005
Bővebben: link
Bővebben: link
Vegre valami amit hivatalosan prezentaltak a chiprol, hw-es hd-dvd es blu-ray gyorsitas, jol hangzik -
rocket
ATI demos R520 GPU at E3
Bővebben: link
Kinyithatnak mar az ajtokat -
rocket
Bejott a joslatod, indulhat a shader parti
''The Graphics Processor
The new Xbox will have a next-generation ATI graphics chip much more powerful than the current top-of-the-line Radeon X850 desktop graphics chip.
Microsoft will pair the IBM processor with an advanced 500MHz ATI graphics chip. The ATI chip will have ''48-way parallel floating-point dynamically-scheduled shader pipelines.'' Today's PC desktop video cards max out at 16 pipelines, but the technologies aren't quite the same. The new ATI graphics chip will be based on a new unified shader model that processes vertex and pixels through the same multipurpose pipelines. Current PC video cards have pipelines dedicated to pixel processing or vertex processing. ATI's current top-of-the-line Radeon X850 XT PE graphics chip, for example, has 16-pixel pipelines and 6-vertex pipelines. We don't know how these new hybrid pipelines will perform compared to the older, dedicated pipeline designs, but with 48 of 'em, we're betting that the next-gen ATI chip will live up to expectations.'' -
rocket
Kivancsi leszek ra, meg arra is holnap ''darabokra'' szedik e az xbox360 vga chipet, vagy azt majd az E3-ra meg a computex-re tartogatjak esetleg, es csak annyit mondanak majd, hogy xy kodnevu chip van a gepben.
Bar ketlem csak ennyi lenne, mutogatni kell mit tud a gep, es a vga a gep szive, ugyhogy johetnek a shader hegyek
Senki ne felejtse el pentek 22:00 mtv europe -
rocket
Ez nagyon off lesz de nem tudtam hova irjam, nv sales director akcioban:
''He said ATI represented the Dark Force as represented by Darth V. and Nvidia the Light Force, as represented by Yoda. And showed a slide with Darth V holding a red wand and Yoga a green wand.''
Bővebben: link
Ezen meg most is mosolygok, kivancsi lettem volna a gepepitok reakciojara, amikor ezzel jott elo -
rocket
Kikerult par reszlet az xbox360-rol de a vga chiprol semmi uj.
Ennyit irnak a cikkben:
''A grafika megjelenítéséről 500 MHz-es egyedi ATI videochip gondoskodik. Az Xbox 360-ban 512 megabájt GDDR3 memória kapott helyet, amely 700 MHz-es órajelen működik. A videochipben további 10 megabájt beágyazott memória található. ''
Bővebben: link
Majd talan penteken kiderul, mit tud a chip valojaban -
rocket
Erdekes megkozelites,az biztos erdekes lenne ha bejonne amit irtal
Mondjuk azt sose mondta senki hivatalosan hogy az xbox360-ban r500 lesz, kodneven fejlesztettek a chipet jol emlekszem xenos-nak hivtak, tehat igy akar ez lehet egy teljesen mas chip is, vagy akar a next-next generation
Most penteken este 10-kor MTV EUROPE-on lesz a xbox360 premier, akkor egy kicsit okosabbak leszunk 1-2 dologban
Kicsit tovabb gondolva, nem buta otlet az ATI-tol, hogy egyelore 2 kartyas fronton szallnak harcba, ugyanis jelenleg nekik van a leggyorsabb kartyajuk igy vigan villoghatnak megy egy kicsit 2x850xtpe-vel (persze ha a driverek tenyleg keszen vannak es jol mukodnek), aztan majd egyszer lesz r520 is.
Persze inq hirrol van szo ezt meg hozza kell venni azert, mostanaban naponta irnak ellent maguknak, nagy a kaosz naluk
[Szerkesztve] -
rocket
ATI's R520 delayed until autumn
Bővebben: link
Kezdodhet a talalgatas, gondok vannak a chipel azert toljak el a megjelenest, vagy valoban marketing strategia van a hatterben, es az AMR technologiaval akarnak odaporkolni az NV sli-nek, meg mielott kijonne az r520
Ha ez igy halad tovabb, a vegen tenyleg elobb lesz xbox360 r500 maggal, mint r520 magos vga
[Szerkesztve] -
rocket
Szerintem nem tul szerencses otlet lenne, igy mindenki azt gondolna az r4xx generacionak az ujabb tagjarol van szo, szinte biztos, hogy az X = 10-et jeloli, de nem mutatna tul jol a XI900 vagy a x1900 (ez meg talan elmenne
), szoval vagy uj szamozas kene vagy valami mas.
rocket
Kizartnak tartom, hogy x900 legyen a neve, az arra utalhatna, hogy ez valami ami egy picit tobb egy picit ujabb, ami ugye nem lenne tul eszszeru megoldas marketing szempontbol.
Raadasul mainstream kartya neve milenne x750, x825, x875?
Ha megis az lenne, akkor kikell rugni a marketingeseket a fenebe -
rocket
Igen az egeszre vonatkozik.
Itt van egy resze lebontasban:
''ATI maintained its lead in the discrete desktop segment during Q1'05 by a margin similar to that of the fourth quarter. ATI's discrete desktop shipments declined 9.0% sequentially and its share in the segment fell slightly from 51.9% in Q4'04 to 51.4% in Q1'05. Nvidia's discrete desktop shipments declined 8.0% sequentially and its segment share was essentially flat, growing from 46.7% to 46.8% during the same period.
JPR estimates that 14.6 million mobile graphics processors shipped from six suppliers in Q1'05, down a mere 0.2% from the previous quarter and up 40.8% year-over-year. Mobile graphics held a record 24.4% share of the total graphics market during the period. Shipments of integrated graphics chipsets for notebooks outpaced those of discrete (stand-alone) mobile graphics processors in Q1'05, showing sequential growth of 12.6% and annual growth of 71.2%. Discrete mobile controller shipments fell 15.8% sequentially but grew 9.1% year-over-year.
Intel surpassed ATI as the largest PC graphics supplier to the mobile market in the first quarter with its share growing from 39.5% to 50.8% sequentially. ATI's share fell from 42.9% in Q4'04 to 35.5% in Q1'05. ATI's loss of share came on increased shipments from Intel of integrated chipsets for notebooks. During the quarter, Intel launched its mobile 915 PCI Express chipset (formerly code-named Alviso) with integrated graphics based on the GMA900 engine and subsequently saw its mobile chipset shipments increase 28.4% sequentially and 148.3% year-over-year during the period.'' -
rocket
Rank Graphics Supplier Q4'04 Market Share Q1'05 Market Share
1 Intel 40.2% 43.1%
2 ATI Technologies 27.6% 26.1%
3 Nvidia 18.6% 17.9%
4 VIA Technologies 7.3% 6.9%
5 Silicon Integrated Systems (SiS) 5.7% 5.4%
6 Matrox Graphics 0.35% 0.33%
7 XGI 0.28% 0.25%
8 3Dlabs (Creative Technology) 0.02% 0.02%
Meg ennyit akartam a cikk cimehez hozzatenni, mondjuk tenyleg ott van az allitolagos roadmap aljan, hogy ''regaining channel leadership'' -
rocket
Uj gepnel teljesen logikus a pci-e vonal, viszont sokan nem szeretnenek mindent lecserelni, igy alaplapot megtartjak, alaplap csere = fel gep lecserelesevel (agp-rol pci-e-re valtasnal), ezert azt nyujta el az ember mindig ameddig tudja, foleg a ''felzarkozoban'' levo regiokban.
Jo lesz majd az az AGP-s r520 egy intel 865/875 chip-es lapban -
rocket
rocket
Nem nagy kunszt az tuti, lehet ilyet varni otthon is, kell hozza egy tu meg par fonal, meg otletgazdagsag
Altalaban a kodnevek amiket hasznalnak a cegek (intel,amd) nagyon otletesek es jolcsengoek szoktak lenni, aztan a kesz termek meg mondjuk megkapja a p4 630 nevet, es elfelejtodik az otletes es jolhangzo kodnev
Vga chip gyartok nem viszik tulzasba, altalaban szamokkal jelolik (r420,nv40), xbox2-be keszulo mindenki altal r500-nak hivott chipnek allitolag xenos a kod neve.
Radeon nev befutott, azon nem kell valtoztatni, mint ahogy a catalyst neven se, szamozason/jelolesen lehetne talan, hogy ne XI800 jojjon a sorban -
rocket
ATI R520 ''Fudo'' codename confirmed
Bővebben: link
Egy ujabb inq pletyi ami vegulis megerositest nyert, pedig anno meg sokan azt gondoltak hogy Fuad Abazovic sajat nevebol kiindulva talalta ki a fudo nevet
Aztan lehet a kep fake, vagy akar mas termek code neve is lehet
[Szerkesztve] -
rocket
Inqurieren mostanaban semmi uj pletyi nem volt, lehet vihar elotti csend, pedig irhatnanak mar valamit, addig is van mirol talalgatni, aztan majd ha megjelnik az r520 visszaolvassuk, es kiderul ki jart az legkozelebb az igazsaghoz
rocket
Igaz, lenyeg egyenlore a 32bit es a sm3.0 es ehez ''tartozik'' a 0.09 gyartas
Az ma is jol latszik, ha kemeny harc megy a 2 nagy vga gyarto kozott akkor a vasarlok jol jarnak, par honapja ki gondolta, hogy 65-70k-ert mar lehet kapni majd 16 pipeline-os kartyakat.
Jo hogy irtad a fogyasztast, szerintem ez se elhagyagolhato tenyezo, valahogy ezt a dolgot nem igazan veszik fontos tenyezonek a gyartok jelenleg, eleg csak az intel 130 wattot evo szornyetegere gondolni, vagy ami tegnap volt hirben Bővebben: link 25 watt-os fogyasztassal.
Bar aki ezeket a kartyakat veszi, 500+ $-ert, biztos nem szamit az a +30%-os villanyszamla
[Szerkesztve] -
rocket
Xbox2 premier majus 12.-en lesz, r500-al a belsejeben (a nintendo nextgen konzoljaban is ati chip lesz, ott is r500 valoszinuleg), persze xbox2 tomegyartasa max. nyar vegen indulna legjobb esetben is (ha igaz lenne az oszi xbox2 bolti megjelenes), addigra mar valoszinu az r520 is piacon lesz pc fronton.
Teljesen igazad van, viszont presztizs gyozelemre hajtanak a gyartok igy barmi elkepzelheto, aztan a tesztelokon kivul max. 100 hardcore moddernek jut ezekbol a kartyakbol, ezek mar a highend felett helyezkednek el very high end
Szep majus ele nezunk az biztos, xbox2 premier, E3 (ps3 es nintendo bemutatokkal), sw3 (ez kicsit off), es egyre tobb terjengo info a nextgen vgakrol
Nagyon kivancsi leszek mit alkot az ati, sikerul e ujra egy ''r300-at'' csinalniuk, es persze arra is az nv mit lep -
rocket
''We heard that'' , ''We have also heard'' , kezdok meg nagyon a pletyka cikkek gyartasaban,mig az inquirer mesterien uzi ezt mar
Kizartnak tartom, barmifele dual core-os 0.09-es chip megjeleneset juniusra
Meg mindig azt tippelem az nv semmi ujdonsaggal nem all elo az r520-al egyidoben, csak felvarjak a rancokat az nv40-en.
G70 meg a ps3 chipjenek a neve lesz szerintem, vagy valami next generation projectnek, de juniusban se nv50 se g70 nem lesz, aztan ha megis akkor tevedtem
[Szerkesztve] -
rocket
ATI Multiple VPU works with two different cards
Radeon R520 and X800 paired
Bővebben: link
Erre kivancsi leszek nagyon mi lesz a realitas -
rocket
Ugynezki juniusban lesz a hivatalos bejelentese az r520-nak
Bővebben: link
Az meg messze van, tavaly aprilis elejen mar nagy mocorgas volt -
rocket
Kiment kavezni az egyik mernok, egy kis ember beugrott a kameras mobiljaval a gep ele, letoltotte a 3dmar2k5-ot, gyorsan felrakta, regisztralta,lenyomott egy gyors tesztet, es vadul kattingatni kezdett a kameras mobiljaval
Viccet felreteve az ilyen tavolkeleti portalok nem szoktak inquirer szinten pletykazni, ok ott kozel vannak a tuzhoz, mint pl. hkpec, pcpop, de ettol meg persze lehet fake kep, meglatjuk majd -
rocket
Jol elvannak
Itt a valasz a topic egyik talalgatasara:
Patti Mikula, Public Relations Manager, Desktop and Handheld Products, ATI Technologies Inc. wrote:
I am happy to confirm that the card will be red....now which exact tone of red I can't say, that is a highly guarded secret.... -
rocket
Megneztem inq-t szokasos pletyi adagert, 3 napja 1 hir nem volt semmi vga-rol , most milesz velunk, nehez pletyka nelkul a sonkat megemeszteni
- BESZÁMÍTÁS! SAPPHIRE Pulse OC RX 9060 XT 16GB GDDR6 videokártya 27% áfa 3 év garancia
- Eladó PNY GeForce RTX 4070 Ti SUPER 16GB OC XLR8
- Sapphire R7 250 1GB
- BESZÁMÍTÁS! SAPPHIRE NITRO+ RX 7900 XTX 24GB GDDR6 videokártya garanciával hibátlan működéssel
- MSI RTX 3080 Ti SUPRIM X 12GB GDDR6X Videokártya! BeszámítOK
- AKCIÓ! ASUS PRO WS W790E-SAGE SE alaplap garanciával hibátlan működéssel
- LG 65C3 - 65" OLED evo - 4K 120Hz 1ms - NVIDIA G-Sync - FreeSync Premium - HDMI 2.1 - PS5 és Xbox!
- Kingmax 2x2GB DDR3 RAM eladó
