- Májusi bemutató, júliusi piacra kerülés, áremelés
- Megérkezett a Poco M6 Pro 4G
- LG Wing - szárnyas fejvadász
- Angwatt CS1 - akár jó is lehetne
Diablo 3 topik
radi8tor
mikromanus #18984 üzenetére
15 órakor beraktam valamit. Remélem ki is tudom majd venni, ha nem érkezik rá licit időben.
radi8tor
Sirandrish #18726 üzenetére
Csillámpóni után szabadon.
radi8tor
Szép ez a marquise kavics, de még kellene hozzá 3 essence. Affene
radi8tor
mikromanus #18532 üzenetére
Magasabb ChC gearrel érdekes módon nekem is az jött ki, ami neked. Ruby-val -20k DPS, Emeralddal +8.8kDPS.
Szerintem akkor marad a Marquise Emerald. -
radi8tor
Igen természetesen a 297% ChD-t átírtam 97%-ra mikor a min-max-ot növeltem 300-al (2 socket)
radi8tor
mikromanus #18530 üzenetére
Köszi a választ.
Überezéshez használt gearnél 3600 DPS pluszt adna két Marquise Ruby a fegyverben, két Marquise Emerald pedig 8000-et.
Majd megnézem a másik gearrel is, ott több ChC-m van. -
radi8tor
#57919488 #18362 üzenetére
Pedig pont ezt akarják:
Q. What's the reasoning behind account-bound items in a game based on trading? And why will the new gems be account bound?
Andrew: Trading is certainly super important, but I wouldn’t say the game is based on trading. Diablo III is about killing monsters and finding evermore powerful enemies and items to kill them with. Trading is just one method by which players can obtain items, and the Auction House is currently the most popular way to do that. We feel that gearing up is perhaps too skewed towards trading right now, and account-bound items are a way of balancing that out with farming.
We don’t really like that, for most players, all of your current gear is very likely to be something you’ve found on the Auction House. This can create a situation where it doesn’t feel like you "own" the gear you’ve obtained; instead, it feels like you are renting it. This is one of the big draws of making items account-bound. We also need more end game item and gold sinks, and making something account bound permanently "removes" those items from the game. Having gear (or gems) that feels like you own it forever is good for you, and removing a lot of things from the economy is good for the game.
radi8tor
Kérdezd a fejlesztőket 1.0.7-ről. első kör.
Ezek szerint, amibe bele rakod a Marquise gem-et, az account bound lesz. Nem adhatod el. Vagy unsocketelés után eladható?
Lehet ezért kerül 5M-ba az unsocket, hogy utána eladhasd a cuccot. -
radi8tor
killerjohn #18085 üzenetére
Az ilyeneket priviben kellene.
radi8tor
Maradjunk a topic témájánál! És az nem az illegális megoldásokról szól.
radi8tor
mikromanus #17978 üzenetére
Nyilvántartásunk szerint
neked DPS Unbuffed: 151k.
JSaN: Persze gondoltam, csak nem tudtam kihagyni.
radi8tor
mikromanus #17969 üzenetére
Nem tudom mikor volt ez, de már tuningoltak rajta. Random neki rohan valakinek Breki.
Kula meg lövi a nyamvadt tűzgolyóit, így nem érdemes előle futni. -
radi8tor
Sirandrish #17893 üzenetére
Ahhoz nem volt hálózat. Telepítheted újra 6 floppy lemezről a 3.11-et
radi8tor
olahjana #17876 üzenetére
Persze, hogy lehet. 10 aktív karaktered lehet egyidőben, de a gold állomány az közös minden karakter között. Emiatt lehet kellemetlen a páros használat.
Két gépnél való használat esetén előfordulhat, hogy átmenetileg zárolják az accountot (biztonsági okokból), mivel másik földrajzi helyen lépsz be rövid időn belül. Ezt authentikátorral lehet kiküszöbölni (de nem tudom, hogy lehet-e authentikátort klónozni páros használatra). -
radi8tor
Patch búcsúztató megvolt. Várom 1.0.7-et.
radi8tor
Sirandrish #17723 üzenetére
Nekem is 2.08 van egy 1.21-es fegyverrel.
radi8tor
Sirandrish #17695 üzenetére
Lehet én értettem félre, de ezen rugóznak többen...
radi8tor
Sirandrish #17691 üzenetére
Mi a baj ezzel? Én sem nyaggatok senkit, hogy miért MP1-2-n nyomja a runokat.
Szoktam menni 6-7-en is, ha olyan a partner, de olyan szinten nem túl haladós, akikkel gyakran megyek. -
radi8tor
killerjohn #17669 üzenetére
Sharpshooter, Steady Aim, Archery passzív, Frenzy shrine.
Legközelebb ha találok egy ilyet, akkor magam mellé veszem Scoundriel barátunkat, az is ad némi buffot.(talán)Szatesz.: Nem is célom az 1 milla, mivel ez csak 1 lövés erejéig ennyi.
Fixen 328k. -
radi8tor
Találtam egy tök jó helyet, ahol nem kell OFF-ban megvitatnotok: Path of Exile fórum.
radi8tor
Sirandrish #17570 üzenetére
így is kellett takarítani utána, hát még ha 10-en reagálnak rá minden fórumban.
radi8tor
mikromanus #17565 üzenetére
Nélkületek nem menne, jelenteni kell az ilyeneket a megfelelő helyen, hogy intézkedni tudjunk.
18 percet élt amúgy. -
radi8tor
Sirandrish #17563 üzenetére
Visszatérő trolloknak nincs helye itt.
radi8tor
Vismajor01 #17094 üzenetére
Portforwardnak semmi köze ehhez a jelenséghez. Portforward akkor kell, ha szerverként üzemel a géped például CoD-ban egy dedikált szerver.
QoS-t kell beállítani a routerben, ahogyan az előttem szóló kolléga mondta. (QoS = Quality of Service)
Adjon prioritást a játékoknak torrenttel szemben (persze ha csontra kiakasztod a feltöltési sebességet, akkor azért hal be a játék). Olvass utána a router leírásában, hogy hogyan kell beállítani.
- MW2 - MW3 játékosok baráti köre
- Nők, nőügyek (18+)
- ASZTALI GÉP / ALKATRÉSZ beárazás
- Villanyszerelés
- Belekezdeni egy vállalkozásba
- Xiaomi 14T Pro 16/512 1év garanciával, Független!
- Új Dell 16 Inspiron 5630 FHD+ IPS i5-1340P 4.6Ghz 12mag 16GB 512GB SSD Intel Iris XE Win11 Garancia
- AMD Ryzen 5 5600X Dobozában
- MacBook Air M1 (13", 8/256 GB) Szép állapotban, dobozával, töltőjével!
- Lenovo legion 5 gamer RTX3060 tgp130w 32gb ddr4 , 1.5 terra m2 ssd
- Felújított laptopok / PC-k Számlával, garanciával! Ingyen Foxpost! 05.03
- Acer Predator Helios 300 - 15,6"FHD IPS - i7-7700HQ - 8GB - 256GB SSD+1TB HDD - GTX 1060 6GB -MAGYAR
- Okosóra felvásárlás!! Samsung Galaxy Watch 6, Samsung Galaxy Watch 7, Samsung Galaxy Watch Ultra
- Csere-Beszámítás! Asztali számítógép PC Játékra. I5 12400F / RTX 3070 / 32GB DDR4 / 1TB SSD
- AKCIÓ! "ÚJ" Microsoft Surface 5 13,5 notebook - i5 1235U 8GB RAM 256GB SSD Intel Iris Xe IGP 27% áfa
