- Igazi csúcskészülék lett a Poco F7 Ultra
Vangelis
Üdv Skacok!
Most csinálnám a 3. ilyen tabot és mindig valami xart ír ki.
Eddigiek gond nélkül mentek.
Most csak a droidboot jön be. Fastboot cmd WAITING ......
Sorry bemásoltam mindent.01/11/16 15:36:53.609 INFO : Phone Flash Tool V 3.1.8-2 (build on Mon Feb 11 18:23:41 RST 2013)
01/11/16 15:36:53.609 INFO : Using xFSTK version: 1.3.6.
01/11/16 15:36:53.650 INFO : Using Android Debug Bridge version 1.0.31
01/11/16 15:36:53.671 INFO : Total size of downloaded flash files: 0.00 bytes
01/11/16 15:36:55.874 ERROR : Cannot start "AutoUpdater" -style cleanlooks --project-name PhoneFlashTool --remote-xml http://mcg-build-depot.jf.intel.com/build/eng-builds/Tools/PhoneFlashTool/update/update.xml --non-interactive
01/11/16 15:36:55.874 WARNING: Cannot load the remote servers from the remote xml config file, please check the file url in the option panel
01/11/16 15:37:03.596 INFO : Please select a valid flash file or download it
01/11/16 15:37:05.755 INFO : Please load a valid flash file
01/11/16 15:37:07.310 INFO : Loading Flash file ...
01/11/16 15:37:07.311 INFO : Ready to flash!
01/11/16 15:37:13.211 INFO : Please load a valid flash file
01/11/16 15:37:17.109 INFO : Loading Flash file (C:/Users/F.B.I/Downloads/op3endott/TAB FW/flash.xml)
01/11/16 15:37:17.114 INFO : Ready to flash!
01/11/16 15:38:35.394 INFO : Port 1/2: Start flashing BLANKPHONE flash file for
01/11/16 15:38:35.395 INFO : Port 1/2: IFW flash started - SN : F4E69B365DA35C25
01/11/16 15:38:35.448 INFO : Disabling xFSTK Misc DnX
01/11/16 15:38:35.448 INFO : Disabling xFSTK wipe out ifwi option
01/11/16 15:38:35.448 INFO : Using xFSTK Solo interface
01/11/16 15:38:35.448 INFO : xFSTK args(10):
01/11/16 15:38:35.448 INFO : C:/Users/F.B.I/Downloads/op3endott/TAB FW/dnx_fwr.bin
01/11/16 15:38:35.448 INFO : C:/Users/F.B.I/Downloads/op3endott/TAB FW/ifwi.bin
01/11/16 15:38:35.448 INFO : C:/Users/F.B.I/Downloads/op3endott/TAB FW/dnx_osr.bin
01/11/16 15:38:35.448 INFO : C:/Users/F.B.I/Downloads/op3endott/TAB FW/droidboot.img.POS.bin
01/11/16 15:38:35.448 INFO : 0x80000245
01/11/16 15:38:35.448 INFO : xFSTK Soft Fuse not set
01/11/16 15:38:35.448 INFO : XFSTK Downloader API 1.3.6.77
01/11/16 15:38:35.448 INFO : Copyright (c) 2012 Intel Corporation
01/11/16 15:38:35.448 INFO : fwdnx -- C:/Users/F.B.I/Downloads/op3endott/TAB FW/dnx_fwr.bin
01/11/16 15:38:35.448 INFO : fwimage -- C:/Users/F.B.I/Downloads/op3endott/TAB FW/ifwi.bin
01/11/16 15:38:35.448 INFO : osdnx -- C:/Users/F.B.I/Downloads/op3endott/TAB FW/dnx_osr.bin
01/11/16 15:38:35.448 INFO : osimage -- C:/Users/F.B.I/Downloads/op3endott/TAB FW/droidboot.img.POS.bin
01/11/16 15:38:35.448 INFO : gpflags -- 0x80000245
01/11/16 15:38:37.582 INFO : XFSTK-PROGRESS--0
01/11/16 15:38:37.582 INFO : XFSTK-STATUS--Detecting Intel Device - Attempt #0
01/11/16 15:38:37.582 INFO : XFSTK-PROGRESS--5
01/11/16 15:38:38.714 INFO : ....XFSTK-LOG--USBSN:--virtual bool CloverviewPlusDownloader::SetDevice(IGenericDevice*)
01/11/16 15:38:38.714 INFO : Initiating download...
01/11/16 15:38:38.715 INFO : XFSTK-LOG--USBSN:--virtual bool CloverviewPlusDownloader:pdateTarget()
01/11/16 15:38:38.715 INFO : XFSTK-LOG--USBSN:--FWDnxPath -- C:/Users/F.B.I/Downloads/op3endott/TAB FW/dnx_fwr.bin
01/11/16 15:38:38.715 INFO : XFSTK-LOG--USBSN:--FWImagePath -- C:/Users/F.B.I/Downloads/op3endott/TAB FW/ifwi.bin
01/11/16 15:38:38.715 INFO : XFSTK-LOG--USBSN:--SoftfusesPath -- BLANK.bin
01/11/16 15:38:38.715 INFO : XFSTK-LOG--USBSN:--OSDnxPath -- C:/Users/F.B.I/Downloads/op3endott/TAB FW/dnx_osr.bin
01/11/16 15:38:38.715 INFO : XFSTK-LOG--USBSN:--OSImagePath -- C:/Users/F.B.I/Downloads/op3endott/TAB FW/droidboot.img.POS.bin
01/11/16 15:38:38.715 INFO : XFSTK-LOG--USBSN:--MiscDnxPath --
01/11/16 15:38:38.715 INFO : XFSTK-LOG--USBSN:--Gpflags -- 80000245
01/11/16 15:38:38.715 INFO : XFSTK-LOG--USBSN:--DebugLevel -- ffffffff
01/11/16 15:38:38.715 INFO : XFSTK-LOG--USBSN:--UsbDelay ms -- 0
01/11/16 15:38:38.715 INFO : XFSTK-LOG--USBSN:--TransferType -- USB
01/11/16 15:38:38.715 INFO : XFSTK-LOG--USBSN:--WipeIFWI -- False
01/11/16 15:38:38.715 INFO : XFSTK-LOG--USBSN:--Idrq -- False
01/11/16 15:38:38.715 INFO : XFSTK-LOG--USBSN:--Verbose -- True
01/11/16 15:38:38.715 INFO : XFSTK-LOG--USBSN:--void CloverviewPlusDownloader::Init()
01/11/16 15:38:38.715 INFO : XFSTK-LOG--USBSN:--Open
01/11/16 15:38:38.716 INFO : XFSTK-LOG--USBSN:--void CloverviewPlusUtils::SetUsbsn(char*)
01/11/16 15:38:38.716 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 USB Device found - USBSN: F4E69B365DA35C25 Address:2
01/11/16 15:38:38.716 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 void CloverviewPlusDownloader::do_update(CloverviewPlusOptions*)
01/11/16 15:38:38.716 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 Start
01/11/16 15:38:38.716 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 Sending DnER...
01/11/16 15:38:38.716 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 WriteOutPipe DnER
01/11/16 15:38:38.716 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 WriteOutPipe 0
01/11/16 15:38:38.717 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 Write --->DnER
01/11/16 15:38:38.717 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 GetOpCode
01/11/16 15:38:38.717 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 ReadInAck
01/11/16 15:38:38.717 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 GetAck
01/11/16 15:38:38.717 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 GetAck - DFRM(0x4)
01/11/16 15:38:38.717 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 FW: Handle virgin part DnX ...
01/11/16 15:38:38.717 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 Changing to DLDR_STATE_FW_NORMAL ...
01/11/16 15:38:38.717 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 InitNoSize
01/11/16 15:38:38.717 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 CheckFile
01/11/16 15:38:38.718 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 C:/Users/F.B.I/Downloads/op3endott/TAB FW/dnx_fwr.bin size:99296 bytes
01/11/16 15:38:38.718 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 InitFwImage
01/11/16 15:38:38.718 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 C:/Users/F.B.I/Downloads/op3endott/TAB FW/ifwi.bin size:2031600 bytes
01/11/16 15:38:38.718 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 allocating buffers for FW images...
01/11/16 15:38:38.718 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 allocating buffers for primary/secondary security FW images...
01/11/16 15:38:38.718 INFO : 7198209778999459788
01/11/16 15:38:38.718 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 loading buffers for FW images...
01/11/16 15:38:38.718 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 loading buffers for primary/secondary security FW images...
01/11/16 15:38:38.718 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 loading buffers for FUPH...
01/11/16 15:38:38.718 INFO : Port 1/2: XFSTK-STATUS SN: F4E69B365DA35C25 FW download is in progress ...
01/11/16 15:38:38.719 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 StartFw
01/11/16 15:38:38.719 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 CLVP Total number of calculated steps : 28.000000
01/11/16 15:38:38.719 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 sending 6 DWORDS of DnxFW size and checksum...
01/11/16 15:38:38.719 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 WriteOutPipe à
01/11/16 15:38:38.719 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 WriteOutPipe 0
01/11/16 15:38:38.719 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 Write --->à
01/11/16 15:38:38.719 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 End of StHandleFwNormal
01/11/16 15:38:38.719 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 GetOpCode
01/11/16 15:38:38.719 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 ReadInAck
01/11/16 15:38:38.719 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 GetAck
01/11/16 15:38:38.719 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 GetAck - DXBL(0x4)
01/11/16 15:38:38.720 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 FW: Sending DnX ...
01/11/16 15:38:38.720 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 FwDXBL
01/11/16 15:38:38.720 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 Sending FW Dnx data...19bf48
01/11/16 15:38:38.720 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 WriteOutPipe __BINARY__
01/11/16 15:38:38.720 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 WriteOutPipe 0
01/11/16 15:38:38.720 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 Write --->__BINARY__
01/11/16 15:38:38.720 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 LogProgress
01/11/16 15:38:38.720 INFO : Port 1/2: XFSTK-PROGRESS SN: F4E69B365DA35C25 3
01/11/16 15:38:38.720 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 GetOpCode
01/11/16 15:38:38.720 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 ReadInAck
01/11/16 15:38:38.720 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 GetAck
01/11/16 15:38:38.720 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 GetAck - RUPHS(0x8)
01/11/16 15:38:38.721 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 FW: Sending FW Update Profile Hdr Size...
01/11/16 15:38:38.721 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 WriteOutPipe $
01/11/16 15:38:38.721 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 WriteOutPipe 0
01/11/16 15:38:38.721 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 Write --->$
01/11/16 15:38:38.721 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 LogProgress
01/11/16 15:38:38.721 INFO : Port 1/2: XFSTK-PROGRESS SN: F4E69B365DA35C25 7
01/11/16 15:38:38.721 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 GetOpCode
01/11/16 15:38:38.721 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 ReadInAck
01/11/16 15:38:38.721 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 GetAck
01/11/16 15:38:38.721 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 GetAck - RUPH(0x4)
01/11/16 15:38:38.721 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 FW: Sending FW Update Profile Hdr...
01/11/16 15:38:38.721 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 WriteOutPipe __BINARY__
01/11/16 15:38:38.722 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 WriteOutPipe 0
01/11/16 15:38:38.722 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 Write --->__BINARY__
01/11/16 15:38:38.722 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 LogProgress
01/11/16 15:38:38.722 INFO : Port 1/2: XFSTK-PROGRESS SN: F4E69B365DA35C25 10
01/11/16 15:38:38.722 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 GetOpCode
01/11/16 15:38:38.722 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 ReadInAck
01/11/16 15:38:38.722 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 GetAck
01/11/16 15:38:38.722 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 GetAck - DMIP(0x4)
01/11/16 15:38:38.722 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 FW: Sending MIP...
01/11/16 15:38:38.722 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 WriteOutPipe __BINARY__
01/11/16 15:38:38.723 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 LogProgress
01/11/16 15:38:38.723 INFO : Port 1/2: XFSTK-PROGRESS SN: F4E69B365DA35C25 14
01/11/16 15:38:38.723 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 GetOpCode
01/11/16 15:38:38.723 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 ReadInAck
01/11/16 15:38:38.723 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 GetAck
01/11/16 15:38:38.723 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 GetAck - IFW1(0x4)
01/11/16 15:38:38.723 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 sending first 96k...
01/11/16 15:38:38.723 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 WriteOutPipe __BINARY__
01/11/16 15:38:38.723 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 WriteOutPipe 0
01/11/16 15:38:38.723 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 Write --->__BINARY__
01/11/16 15:38:38.723 INFO : Port 1/2: XFSTK-PROGRESS SN: F4E69B365DA35C25 17
01/11/16 15:38:38.724 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 GetOpCode
01/11/16 15:38:38.724 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 ReadInAck
01/11/16 15:38:38.724 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 GetAck
01/11/16 15:38:38.724 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 GetAck - IFW2(0x4)
01/11/16 15:38:38.724 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 sending second 96k...
01/11/16 15:38:38.724 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 WriteOutPipe __BINARY__
01/11/16 15:38:38.724 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 WriteOutPipe 0
01/11/16 15:38:38.724 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 Write --->__BINARY__
01/11/16 15:38:38.744 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 LogProgress
01/11/16 15:38:38.744 INFO : Port 1/2: XFSTK-PROGRESS SN: F4E69B365DA35C25 21
01/11/16 15:38:38.744 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 GetOpCode
01/11/16 15:38:38.744 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 ReadInAck
01/11/16 15:38:38.744 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 GetAck
01/11/16 15:38:38.754 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 GetAck - IFW3(0x4)
01/11/16 15:38:38.754 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 sending third 96k...
01/11/16 15:38:38.754 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 WriteOutPipe __BINARY__
01/11/16 15:38:38.754 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 WriteOutPipe 0
01/11/16 15:38:38.754 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 Write --->__BINARY__
01/11/16 15:38:38.764 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 LogProgress
01/11/16 15:38:38.764 INFO : Port 1/2: XFSTK-PROGRESS SN: F4E69B365DA35C25 25
01/11/16 15:38:38.764 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 GetOpCode
01/11/16 15:38:38.764 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 ReadInAck
01/11/16 15:38:38.764 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 GetAck
01/11/16 15:38:38.794 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 GetAck - PSFW100(0x8)
01/11/16 15:38:38.794 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 FW: Sending Primary Security FW 1 Chunk 1
01/11/16 15:38:38.794 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 WriteOutPipe __BINARY__
01/11/16 15:38:38.794 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 WriteOutPipe 0
01/11/16 15:38:38.794 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 Write --->__BINARY__
01/11/16 15:38:38.804 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 LogProgress
01/11/16 15:38:38.804 INFO : Port 1/2: XFSTK-PROGRESS SN: F4E69B365DA35C25 28
01/11/16 15:38:38.804 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 GetOpCode
01/11/16 15:38:38.804 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 ReadInAck
01/11/16 15:38:38.804 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 GetAck
01/11/16 15:38:38.874 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 GetAck - PSFW101(0x8)
01/11/16 15:38:38.874 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 FW: Sending Primary Security FW 1 Chunk 0
01/11/16 15:38:38.874 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 Allocation done
01/11/16 15:38:38.874 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 Writing the Bytes
01/11/16 15:38:38.874 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 WriteOutPipe __BINARY__
01/11/16 15:38:38.874 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 WriteOutPipe 0
01/11/16 15:38:38.874 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 Write --->__BINARY__
01/11/16 15:38:38.874 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 LogProgress
01/11/16 15:38:38.874 INFO : Port 1/2: XFSTK-PROGRESS SN: F4E69B365DA35C25 32
01/11/16 15:38:38.874 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 GetOpCode
01/11/16 15:38:38.874 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 ReadInAck
01/11/16 15:38:38.874 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 GetAck - SSFW00(0x8)
01/11/16 15:38:38.874 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 FW: Sending secondary security fw Chunk 2
01/11/16 15:38:38.875 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 Write --->__BINARY__
01/11/16 15:38:38.875 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 LogProgress
01/11/16 15:38:38.875 INFO : Port 1/2: XFSTK-PROGRESS SN: F4E69B365DA35C25 35
01/11/16 15:38:38.875 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 GetOpCode
01/11/16 15:38:38.875 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 ReadInAck
01/11/16 15:38:38.875 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 GetAck
01/11/16 15:38:38.904 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 GetAck - SSFW01(0x8)
01/11/16 15:38:38.904 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 FW: Sending secondary security fw Chunk 1
01/11/16 15:38:38.904 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 WriteOutPipe __BINARY__
01/11/16 15:38:38.904 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 WriteOutPipe 0
01/11/16 15:38:38.904 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 Write --->__BINARY__
01/11/16 15:38:38.914 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 LogProgress
01/11/16 15:38:38.914 INFO : Port 1/2: XFSTK-PROGRESS SN: F4E69B365DA35C25 39
01/11/16 15:38:38.914 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 GetOpCode
01/11/16 15:38:38.914 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 ReadInAck
01/11/16 15:38:38.914 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 GetAck
01/11/16 15:38:38.985 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 GetAck - SSFW02(0x8)
01/11/16 15:38:38.985 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 FW: Sending secondary security fw Chunk 0
01/11/16 15:38:38.985 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 WriteOutPipe __BINARY__
01/11/16 15:38:38.985 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 WriteOutPipe 0
01/11/16 15:38:38.985 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 Write --->__BINARY__
01/11/16 15:38:38.985 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 LogProgress
01/11/16 15:38:38.986 INFO : Port 1/2: XFSTK-PROGRESS SN: F4E69B365DA35C25 42
01/11/16 15:38:38.986 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 GetOpCode
01/11/16 15:38:38.986 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 ReadInAck
01/11/16 15:38:38.986 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 GetAck
01/11/16 15:38:38.986 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 GetAck - PSFW200(0x8)
01/11/16 15:38:38.986 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 FW: Sending Primary Security FW 2 Chunk 0
01/11/16 15:38:38.986 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 WriteOutPipe __BINARY__
01/11/16 15:38:38.986 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 WriteOutPipe 0
01/11/16 15:38:38.986 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 Write --->__BINARY__
01/11/16 15:38:38.986 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 LogProgress
01/11/16 15:38:38.986 INFO : Port 1/2: XFSTK-PROGRESS SN: F4E69B365DA35C25 46
01/11/16 15:38:38.987 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 ReadInAck
01/11/16 15:38:38.987 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 GetAck
01/11/16 15:38:39.617 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 GetAck - VEDFW00(0x8)
01/11/16 15:38:39.617 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 sending VED FW Chunk 0
01/11/16 15:38:39.617 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 WriteOutPipe __BINARY__
01/11/16 15:38:39.617 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 WriteOutPipe 0
01/11/16 15:38:39.617 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 Write --->__BINARY__
01/11/16 15:38:39.617 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 LogProgress
01/11/16 15:38:39.617 INFO : Port 1/2: XFSTK-PROGRESS SN: F4E69B365DA35C25 50
01/11/16 15:38:39.617 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 GetOpCode
01/11/16 15:38:39.617 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 ReadInAck
01/11/16 15:38:39.617 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 GetAck - SuCP(0x4)
01/11/16 15:38:39.617 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 FW: Sending ROM Patch Chunk 0
01/11/16 15:38:39.617 INFO : Port 1/2: XFSTK-PROGRESS SN: F4E69B365DA35C25 53
01/11/16 15:38:39.618 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 GetAck
01/11/16 15:38:39.618 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 GetAck - DMIP(0x4)
01/11/16 15:38:39.618 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 FW: Sending MIP...
01/11/16 15:38:39.618 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 WriteOutPipe __BINARY__
01/11/16 15:38:39.618 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 WriteOutPipe 0
01/11/16 15:38:39.618 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 Write --->__BINARY__
01/11/16 15:38:39.618 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 LogProgress
01/11/16 15:38:39.618 INFO : Port 1/2: XFSTK-PROGRESS SN: F4E69B365DA35C25 57
01/11/16 15:38:39.618 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 GetOpCode
01/11/16 15:38:39.618 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 ReadInAck
01/11/16 15:38:39.687 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 GetAck - IFW1(0x4)
01/11/16 15:38:39.687 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 sending first 96k...
01/11/16 15:38:39.687 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 WriteOutPipe __BINARY__
01/11/16 15:38:39.687 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 WriteOutPipe 0
01/11/16 15:38:39.687 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 Write --->__BINARY__
01/11/16 15:38:39.687 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 LogProgress
01/11/16 15:38:39.687 INFO : Port 1/2: XFSTK-PROGRESS SN: F4E69B365DA35C25 60
01/11/16 15:38:39.687 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 GetOpCode
01/11/16 15:38:39.687 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 ReadInAck
01/11/16 15:38:39.717 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 GetAck - IFW2(0x4)
01/11/16 15:38:39.717 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 sending second 96k...
01/11/16 15:38:39.717 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 WriteOutPipe __BINARY__
01/11/16 15:38:39.717 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 WriteOutPipe 0
01/11/16 15:38:39.717 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 Write --->__BINARY__
01/11/16 15:38:39.717 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 LogProgress
01/11/16 15:38:39.717 INFO : Port 1/2: XFSTK-PROGRESS SN: F4E69B365DA35C25 64
01/11/16 15:38:39.717 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 GetOpCode
01/11/16 15:38:39.717 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 ReadInAck
01/11/16 15:38:39.747 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 GetAck - IFW3(0x4)
01/11/16 15:38:39.747 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 sending third 96k...
01/11/16 15:38:39.747 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 WriteOutPipe __BINARY__
01/11/16 15:38:39.747 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 WriteOutPipe 0
01/11/16 15:38:39.747 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 Write --->__BINARY__
01/11/16 15:38:39.757 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 LogProgress
01/11/16 15:38:39.757 INFO : Port 1/2: XFSTK-PROGRESS SN: F4E69B365DA35C25 67
01/11/16 15:38:39.757 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 GetOpCode
01/11/16 15:38:39.757 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 ReadInAck
01/11/16 15:38:39.757 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 GetAck
01/11/16 15:38:39.787 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 GetAck - PSFW100(0x8)
01/11/16 15:38:39.787 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 FW: Sending Primary Security FW 1 Chunk 1
01/11/16 15:38:39.787 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 WriteOutPipe __BINARY__
01/11/16 15:38:39.787 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 WriteOutPipe 0
01/11/16 15:38:39.787 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 Write --->__BINARY__
01/11/16 15:38:39.797 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 LogProgress
01/11/16 15:38:39.797 INFO : Port 1/2: XFSTK-PROGRESS SN: F4E69B365DA35C25 71
01/11/16 15:38:39.797 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 GetOpCode
01/11/16 15:38:39.797 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 ReadInAck
01/11/16 15:38:39.797 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 GetAck
01/11/16 15:38:39.867 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 GetAck - PSFW101(0x8)
01/11/16 15:38:39.867 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 FW: Sending Primary Security FW 1 Chunk 0
01/11/16 15:38:39.867 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 Allocation done
01/11/16 15:38:39.867 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 Writing the Bytes
01/11/16 15:38:39.867 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 WriteOutPipe __BINARY__
01/11/16 15:38:39.867 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 WriteOutPipe 0
01/11/16 15:38:39.867 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 Write --->__BINARY__
01/11/16 15:38:39.867 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 LogProgress
01/11/16 15:38:39.867 INFO : Port 1/2: XFSTK-PROGRESS SN: F4E69B365DA35C25 75
01/11/16 15:38:39.867 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 GetOpCode
01/11/16 15:38:39.867 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 ReadInAck
01/11/16 15:38:39.867 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 GetAck - SSFW00(0x8)
01/11/16 15:38:39.867 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 FW: Sending secondary security fw Chunk 2
01/11/16 15:38:39.867 INFO : Port 1/2: XFSTK-PROGRESS SN: F4E69B365DA35C25 78
01/11/16 15:38:39.868 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 GetAck
01/11/16 15:38:39.897 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 GetAck - SSFW01(0x8)
01/11/16 15:38:39.897 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 FW: Sending secondary security fw Chunk 1
01/11/16 15:38:39.897 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 WriteOutPipe __BINARY__
01/11/16 15:38:39.897 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 WriteOutPipe 0
01/11/16 15:38:39.897 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 Write --->__BINARY__
01/11/16 15:38:39.907 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 LogProgress
01/11/16 15:38:39.907 INFO : Port 1/2: XFSTK-PROGRESS SN: F4E69B365DA35C25 82
01/11/16 15:38:39.907 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 GetOpCode
01/11/16 15:38:39.907 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 ReadInAck
01/11/16 15:38:39.907 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 GetAck
01/11/16 15:38:39.977 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 GetAck - SSFW02(0x8)
01/11/16 15:38:39.977 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 FW: Sending secondary security fw Chunk 0
01/11/16 15:38:39.977 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 WriteOutPipe __BINARY__
01/11/16 15:38:39.977 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 WriteOutPipe 0
01/11/16 15:38:39.977 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 Write --->__BINARY__
01/11/16 15:38:39.977 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 LogProgress
01/11/16 15:38:39.977 INFO : Port 1/2: XFSTK-PROGRESS SN: F4E69B365DA35C25 85
01/11/16 15:38:39.977 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 GetOpCode
01/11/16 15:38:39.977 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 ReadInAck
01/11/16 15:38:39.977 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 GetAck - PSFW200(0x8)
01/11/16 15:38:39.977 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 FW: Sending Primary Security FW 2 Chunk 0
01/11/16 15:38:39.977 INFO : Port 1/2: XFSTK-PROGRESS SN: F4E69B365DA35C25 89
01/11/16 15:38:40.610 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 GetAck - VEDFW00(0x8)
01/11/16 15:38:40.610 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 sending VED FW Chunk 0
01/11/16 15:38:40.610 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 WriteOutPipe __BINARY__
01/11/16 15:38:40.610 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 WriteOutPipe 0
01/11/16 15:38:40.610 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 Write --->__BINARY__
01/11/16 15:38:40.610 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 LogProgress
01/11/16 15:38:40.610 INFO : Port 1/2: XFSTK-PROGRESS SN: F4E69B365DA35C25 92
01/11/16 15:38:40.610 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 GetOpCode
01/11/16 15:38:40.610 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 ReadInAck
01/11/16 15:38:40.610 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 GetAck - SuCP(0x4)
01/11/16 15:38:40.610 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 FW: Sending ROM Patch Chunk 0
01/11/16 15:38:40.611 INFO : Port 1/2: XFSTK-PROGRESS SN: F4E69B365DA35C25 96
01/11/16 15:38:40.611 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 GetOpCode
01/11/16 15:38:40.611 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 ReadInAck
01/11/16 15:38:40.611 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 GetAck
01/11/16 15:38:40.611 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 GetAck - HLT$(0x4)
01/11/16 15:38:40.611 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 FW: Firmware update completed...
01/11/16 15:38:40.611 INFO : Port 1/2: XFSTK-PROGRESS SN: F4E69B365DA35C25 100
01/11/16 15:38:40.611 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 LogError
01/11/16 15:38:40.611 INFO : Port 1/2: XFSTK-STATUS SN: F4E69B365DA35C25 Error Code: 0 - Success
01/11/16 15:38:40.611 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 void CloverviewPlusDownloader::do_abort()
01/11/16 15:38:40.611 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 Abort
01/11/16 15:38:40.611 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 C:/Users/F.B.I/Downloads/op3endott/TAB FW/ifwi.bin size:2031600 bytes
01/11/16 15:38:40.611 INFO : Port 1/2: XFSTK-STATUS SN: F4E69B365DA35C25 PASS
01/11/16 15:38:40.611 INFO : Port 1/2: XFSTK-STATUS SN: F4E69B365DA35C25 Firmware download completed. Continuing to OS...
01/11/16 15:38:45.743 INFO : XFSTK-PROGRESS--0
01/11/16 15:38:45.743 INFO : XFSTK-PROGRESS--10
01/11/16 15:38:45.743 INFO : XFSTK-STATUS--Reconnecting to device - Attempt #1
01/11/16 15:38:46.876 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 virtual bool CloverviewPlusDownloader:pdateTarget()
01/11/16 15:38:46.876 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 FWDnxPath -- C:/Users/F.B.I/Downloads/op3endott/TAB FW/dnx_fwr.bin
01/11/16 15:38:46.876 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 FWImagePath -- C:/Users/F.B.I/Downloads/op3endott/TAB FW/ifwi.bin
01/11/16 15:38:46.876 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 SoftfusesPath -- BLANK.bin
01/11/16 15:38:46.876 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 OSDnxPath -- C:/Users/F.B.I/Downloads/op3endott/TAB FW/dnx_osr.bin
01/11/16 15:38:46.876 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 OSImagePath -- C:/Users/F.B.I/Downloads/op3endott/TAB FW/droidboot.img.POS.bin
01/11/16 15:38:46.876 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 MiscDnxPath --
01/11/16 15:38:46.876 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 Gpflags -- 80000245
01/11/16 15:38:46.876 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 DebugLevel -- ffffffff
01/11/16 15:38:46.876 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 UsbDelay ms -- 0
01/11/16 15:38:46.876 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 TransferType -- USB
01/11/16 15:38:46.876 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 WipeIFWI -- False
01/11/16 15:38:46.877 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 Idrq -- False
01/11/16 15:38:46.877 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 Verbose -- True
01/11/16 15:38:46.877 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 void CloverviewPlusDownloader::Init()
01/11/16 15:38:46.877 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 Open
01/11/16 15:38:46.877 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 void CloverviewPlusUtils::SetUsbsn(char*)
01/11/16 15:38:46.877 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 USB Device found - USBSN: F4E69B365DA35C25 Address:2
01/11/16 15:38:46.877 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 void CloverviewPlusDownloader::do_update(CloverviewPlusOptions*)
01/11/16 15:38:46.877 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 Start
01/11/16 15:38:46.877 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 Sending DnER...
01/11/16 15:38:46.877 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 WriteOutPipe DnER
01/11/16 15:38:46.877 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 WriteOutPipe 0
01/11/16 15:38:46.877 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 Write --->DnER
01/11/16 15:38:46.877 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 GetOpCode
01/11/16 15:38:46.877 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 ReadInAck
01/11/16 15:38:46.877 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 GetAck
01/11/16 15:38:46.877 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 GetAck - DORM(0x4)
01/11/16 15:38:46.877 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 OS: Handle OS download...
01/11/16 15:38:46.877 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 Changing to DLDR_STATE_OS_NORMAL ...
01/11/16 15:38:46.877 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 CheckFile
01/11/16 15:38:46.877 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 _num OS Images : 1
01/11/16 15:38:46.877 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 _temp_data : 6259
01/11/16 15:38:46.877 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 OSII: 0 Data Size: 12890624
01/11/16 15:38:46.877 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 _Temp Data is: 6259 h
01/11/16 15:38:46.878 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 InitOsipHdr
01/11/16 15:38:46.878 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 Init OSIP header ...
01/11/16 15:38:46.878 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 _After fread osip_hdr
01/11/16 15:38:46.878 INFO : Port 1/2: XFSTK-STATUS SN: F4E69B365DA35C25 POS download is in progress ...
01/11/16 15:38:46.878 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 StartOs
01/11/16 15:38:46.878 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 sending 6 DWORDS of DnxOS size and checksum...
01/11/16 15:38:46.878 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 GetOsDnXHdr
01/11/16 15:38:46.878 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 C:/Users/F.B.I/Downloads/op3endott/TAB FW/dnx_osr.bin size:99296 bytes
01/11/16 15:38:46.878 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 WriteOutPipe à
01/11/16 15:38:46.878 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 WriteOutPipe 0
01/11/16 15:38:46.878 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 Write --->à
01/11/16 15:38:46.878 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 End of StHandleOsNormal
01/11/16 15:38:46.878 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 GetOpCode
01/11/16 15:38:46.878 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 ReadInAck
01/11/16 15:38:46.878 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 GetAck
01/11/16 15:38:46.878 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 GetAck - DXBL(0x4)
01/11/16 15:38:46.878 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 OS: Sending DnX ...
01/11/16 15:38:46.878 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 OsDXBL
01/11/16 15:38:46.878 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 WriteOutPipe __BINARY__
01/11/16 15:38:46.878 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 Write --->__BINARY__
01/11/16 15:38:46.878 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 LogProgress
01/11/16 15:38:46.878 INFO : Port 1/2: XFSTK-PROGRESS SN: F4E69B365DA35C25 3
01/11/16 15:38:46.879 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 GetAck
01/11/16 15:38:46.879 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 GetAck - ROSIP$$$(0x8)
01/11/16 15:38:46.879 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 GetOsipHdr
01/11/16 15:38:46.879 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 Get OSIP header + Partion Table...
01/11/16 15:38:46.879 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 sending OSIP...
01/11/16 15:38:46.879 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 sending OSIP header + Partion Table...
01/11/16 15:38:46.879 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 WriteOutPipe __BINARY__
01/11/16 15:38:46.879 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 WriteOutPipe 0
01/11/16 15:38:46.879 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 Write --->__BINARY__
01/11/16 15:38:46.879 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 GetOpCode
01/11/16 15:38:46.879 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 ReadInAck
01/11/16 15:38:46.879 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 RIMGBuff: 25177
01/11/16 15:38:46.879 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 RIMG, 0, 4, RIMGChunkSize: 25177
01/11/16 15:38:46.879 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 GetAck - RIMG(0xC)
01/11/16 15:38:46.879 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 GetOsImageDataChunk
01/11/16 15:38:46.879 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 Get OS image data...
01/11/16 15:38:46.879 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 RIMGChunkSize is : 25177
01/11/16 15:38:46.879 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 OS Data Size is : 12890624
01/11/16 15:38:46.879 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 allocating buffer for data to send...data size: 12890624
01/11/16 15:38:46.879 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 reading data from file
01/11/16 15:38:46.879 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 data size to read: 12890624
01/11/16 15:38:46.879 INFO : Port 1/2: XFSTK-PROGRESS SN: F4E69B365DA35C25 100
01/11/16 15:38:46.879 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 OS: Bytes left to send: 0
01/11/16 15:38:46.879 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 sending data to USB...
01/11/16 15:38:46.880 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 WriteOutPipe 0
01/11/16 15:38:46.880 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 Write --->__BINARY__
01/11/16 15:38:47.507 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 ReleaseOsImageDataChunk
01/11/16 15:38:47.507 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 End of RIMG
01/11/16 15:38:47.507 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 GetOpCode
01/11/16 15:38:47.507 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 ReadInAck
01/11/16 15:38:47.507 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 GetAck
01/11/16 15:38:52.641 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 usb_bulk_read() fails
01/11/16 15:38:52.641 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 Windriver Error: 0x20000015, Timeout expired
01/11/16 15:38:54.775 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 GetAck - EOIU(0x4)
01/11/16 15:38:54.775 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 LogError
01/11/16 15:38:54.775 INFO : Port 1/2: XFSTK-STATUS SN: F4E69B365DA35C25 Error Code: 4 - Error attempting to read ACK/NACK from IN Pipe
01/11/16 15:38:54.775 INFO : Port 1/2: XFSTK-STATUS SN: F4E69B365DA35C25 Unknown Ack code:0, aborting ...
01/11/16 15:38:54.775 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 void CloverviewPlusDownloader::do_abort()
01/11/16 15:38:54.775 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 Abort
01/11/16 15:38:54.775 INFO : Port 1/2: XFSTK-STATUS SN: F4E69B365DA35C25 FAIL
01/11/16 15:38:54.775 INFO : Port 1/2: XFSTK-STATUS SN: F4E69B365DA35C25 Errors encounter during OS download. Aborting ...
01/11/16 15:38:59.911 INFO : XFSTK-PROGRESS--0
01/11/16 15:38:59.911 INFO : XFSTK-PROGRESS--10
01/11/16 15:38:59.911 INFO : XFSTK-STATUS--Reconnecting to device - Attempt #2
01/11/16 15:39:00.825 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 virtual bool CloverviewPlusDownloader:pdateTarget()
01/11/16 15:39:00.825 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 FWDnxPath -- C:/Users/F.B.I/Downloads/op3endott/TAB FW/dnx_fwr.bin
01/11/16 15:39:00.825 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 FWImagePath -- C:/Users/F.B.I/Downloads/op3endott/TAB FW/ifwi.bin
01/11/16 15:39:00.825 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 SoftfusesPath -- BLANK.bin
01/11/16 15:39:00.825 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 OSDnxPath -- C:/Users/F.B.I/Downloads/op3endott/TAB FW/dnx_osr.bin
01/11/16 15:39:00.825 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 OSImagePath -- C:/Users/F.B.I/Downloads/op3endott/TAB FW/droidboot.img.POS.bin
01/11/16 15:39:00.826 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 MiscDnxPath --
01/11/16 15:39:00.826 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 Gpflags -- 80000245
01/11/16 15:39:00.826 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 DebugLevel -- ffffffff
01/11/16 15:39:00.826 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 UsbDelay ms -- 0
01/11/16 15:39:00.826 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 TransferType -- USB
01/11/16 15:39:00.826 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 WipeIFWI -- False
01/11/16 15:39:00.826 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 Idrq -- False
01/11/16 15:39:00.826 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 Verbose -- True
01/11/16 15:39:00.826 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 void CloverviewPlusDownloader::Init()
01/11/16 15:39:00.826 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 Open
01/11/16 15:39:00.826 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 void CloverviewPlusUtils::SetUsbsn(char*)
01/11/16 15:39:00.826 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 USB Device found - USBSN: F4E69B365DA35C25 Address:2
01/11/16 15:39:00.826 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 void CloverviewPlusDownloader::do_update(CloverviewPlusOptions*)
01/11/16 15:39:00.826 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 Start
01/11/16 15:39:00.826 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 Sending DnER...
01/11/16 15:39:00.826 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 WriteOutPipe DnER
01/11/16 15:39:00.826 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 WriteOutPipe 0
01/11/16 15:39:00.826 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 Write --->DnER
01/11/16 15:39:00.826 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 GetOpCode
01/11/16 15:39:00.826 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 ReadInAck
01/11/16 15:39:00.826 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 GetAck
01/11/16 15:39:00.826 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 usb_bulk_read() fails
01/11/16 15:39:00.826 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 Windriver Error: 0xC0000011, HC status: The host controller has set the Transaction Error (XactErr) bit in the transfer descriptor's status field
01/11/16 15:39:00.826 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 Windriver Error: 0x2000000F, Device not found
01/11/16 15:39:00.827 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 usb_bulk_read() fails
01/11/16 15:39:00.827 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 Windriver Error: 0x2000000F, Device not found
01/11/16 15:39:00.827 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 Device is not responding...
01/11/16 15:39:00.827 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 GetAck - (0xBAADF00D)
01/11/16 15:39:00.827 INFO : Port 1/2: XFSTK-STATUS SN: F4E69B365DA35C25 Unknown Ack code:baadf00d, aborting ...
01/11/16 15:39:00.827 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 void CloverviewPlusDownloader::do_abort()
01/11/16 15:39:00.827 INFO : Port 1/2: XFSTK-LOG SN: F4E69B365DA35C25 Abort
01/11/16 15:39:00.827 INFO : Port 1/2: XFSTK-STATUS SN: F4E69B365DA35C25 FAIL
01/11/16 15:39:00.827 INFO : Port 1/2: XFSTK-STATUS SN: F4E69B365DA35C25 Errors encounter during OS download. Aborting ...
01/11/16 15:39:00.827 INFO : XFSTK: Download operation encountered errors.
01/11/16 15:39:00.827 INFO : XFSTK: Please verify fw/os image integrity and reprovision target.
01/11/16 15:39:00.827 INFO : xfstkFlashTool exited with error
01/11/16 15:39:00.827 ERROR : Port 1/2: IFW flash failed - SN : F4E69B365DA35C25 -
Vangelis
Akciós a karperec a tesÓban.
5000ft alatt.
Ha már volt sorry -
Vangelis
Én is vettem ma a lányomnak egy tokot rá.
Nagyon tetszik neki... igaz már csak kéket találtam. De szép és nem is xar minőség... ennyiért jó. -
Vangelis
Off:
Ha találtok valahol Lenovót vegyétek... nyúztam és nagyon jó kis cucc!
Vangelis
Vermilion69 #6060 üzenetére
Igen mind a kettőt!
Olyan kis számokkal volt kiírva az ára!!!!
Kettő volt bontaltan azt el is hoztam.... nem rossz ár szerintem.
Vangelis
Én meg vettem LENOVO TAB 7et 13990Ft-ért.,
Volt 3 darab.. kettőt elhoztam.
Majdnem 6gb elérhető és 4 magos....
Nem volt szívem otthagyni..
Vangelis
AndrewBlase #4414 üzenetére
Nekem van prémium Samsung hangszóróm
Bontatlan
Hehe
Nem hirdetés , mert nem szívesen adom el
Igaz még kis sem bontottam
Vangelis
Nálunk még a alma 8 -at is szétszedték rögtön...
Erről meg semmi szétszerelés vagy lezúzás-.....
Vangelis
Lányom lassan belakja a 2GB-ot
Gyerekek! Kicsit igyekezzetek a megoldással
Vangelis
Baxa meg, hogy most is itt irkálunk .... vagy is én csak olvasok...
Vangelis
Nekem is besípolt a gyerkőc tablete.Azt hittem a fülem cseng.
De resart és no problem.
Vangelis
Mondjuk ez sem rossz cucc ennyiért:
Processzor sebesség: 1.8 GHz Processzormagok száma: 4 Processzor: Intel® Atom™ Baytrail 3735E Quad Core Processzor gyártója: Intel® Processzor modell: Atom™ Baytrail 3735E Memória: 1 GB RAM Képernyőátló (col): 8 col
Vangelis
shuttlex27d #2511 üzenetére
Tesco nem tesztelte
Felelőtlenek.
A telefont viszont hasonló képen leakciózhatnák. Asszonynak kellene egy dual simes teló.
Vangelis
Itt barcikán délben már csak 2 darab volt kirakva.
Vangelis
Megyek a tescoban. Valakinek valami?
Kenyér tej, tablet stb?
Vangelis
Akkor most 10 ből 8 hibás?
MI lehet vajon az átlag?
Vangelis
Itt barcikán délben tele volt a polc vele.
Vangelis
DiamondBack #2237 üzenetére
Akkor tényleg csak a szerencsén múlott a dolog.
Kinek milyen jutott.
Amikor én visszamentem a garancia miatt kérdezte a hölgy, hogy tönkrement-e.
Mondom még nem -
Vangelis
Nekem a gyerkőc reggel 7 től nyomja.Alig merült valamit..... De még nem is dugtuk töltőre. Gyári töltéssel nyomja a játékot!
Bírja!
Vangelis
Barcikán még dugig volt most is... most pakoltak ki,
Vangelis
diablo1984 #1942 üzenetére
Akkor majd reklamálok én is a 2 éves papírért.
De a kis matrica is rajta volt a garancia levélen. A szériaszám gondolom. -
Vangelis
Én is még ott frissítettem.
Nincs semmi gond.
Sok darab, már nem volt.
Feketét dugtam el, de inkább fehéret akartam. Volt szerencsére választék.
Pixel hiba nincs. ... működik.
Vangelis
Sötéttükörnek jó lesz ez a cucc
Vangelis
Blackmirror #1863 üzenetére
Ott nem keresik a hiénák
Vangelis
Akkor a tescoban még senki nem vett "jobb" verziót.
Lehet pont ezért akciózzák.
Jönnek a rendes verziók! -
Vangelis
Akkor ne is vegyek ilyen cuccot
Vangelis
Memória kártya nem megoldás?
Vangelis
Csak nem találják meg amit eldugtam
- GARANCIÁLIS, 100% AKKSI iPad Mini 7 128GB Asztroszürke
- Xiaomi Redmi Pad SE Mint Green (8GB/256GB) ÚJ!
- Amazon Kindle 7. Gen Paperwhite 3rd Edition DP75SDI kis szépséghibával
- Kobo Aura Edition 2 (N236) 6" háttérvilágításos kijelzővel, 4 GB-os tárhellyel - jó állapotban
- Chuwi HiPad Pro 8GB/128GB 10.8" 2K 8mag 2SIM Alu ház 7,5mm 450g
- AKCIÓ! Apple iPad Pro 13 2024 M4 512GB Cellular tablet garanciával hibátlan működéssel
- ÁRGARANCIA!Épített KomPhone Ryzen 5 5600X 16/32/64GB RAM RTX 4060 8GB GAMER PC termékbeszámítással
- Honor 200 256GB Kártyafüggetlen 1Év Garanciával
- AKCIÓ! HP Elitedesk 800 G1 USDT mini asztali számítógép - i7 4770S 16GB RAM 128GB SSD Intel HD
