- Xiaomi 12T Pro - kétszínű, mint a kétszázas
Mikrotik routerekkel foglalkozó téma. Mikrotik router típusok, hardverek, router beállítások, programozás (scriptek írása), frissítés, és minden Mikrotik routerrel kapcsolatos beszélgetés helye.
iceQ!
Jó pofa kis termékbemutató
iceQ!
Ez mit is jelent pontosan?
executing script BLABLABLA from scheduler failed, please check it manually
Egyik scriptem nem fut le ilyen hibával. -
iceQ!
Mai nap ez fogadott mikor frissíteni szerettem volna a routert. Idáig tökéltesen működött, a konfigon nem változtattam semmit. Pingelni a download/update.mikrotik.com oldalt tudom a router-ről.
Mi lehet a gond? -
iceQ!
Istv@n #20838 üzenetére
Notice - Starting from RouterOS version 7.13, significant changes have been made to the RouterOS wireless packages. This is done due to a new product developemnt which will require more disk space for hardware drivers so we had to split it in order to maintain old products alongside the new ones. More wireless packages are yet to come.
1. When upgrading by using "check-for-updates", all versions earlier than 7.12 will display 7.12 as the latest available version. Upgrade from v7.12 to v7.13 or later versions must be done through 7.12 in order to convert wireless packages automatically. Fresh installation with Netinstall or manual package installation works in the same manner as always.
2. Drivers for older wireless and 60GHz interfaces, as well as the wireless management system CAPsMAN, are now part of a separate "wireless" package instead of being a part of the bundle package. This package can be uninstalled if not needed.
3. The existing "wifiwave2" package has been divided into distinct packages: "wifi-qcom" and "wifi-qcom-ac", and the necessary utilities for WiFi management are now included in the RouterOS bundle. RouterOS and "wifi-qcom-ac" packages alongside each other now fit into 16MB flash memory.
What's new in 7.13beta1 (2023-Nov-09 13:15):
!) package - convert "wireless" and "wifi" packages automatically, if upgrading from v7.12;
!) wifi - split existing "wifiwave2" package into separate packages "wifi-qcom", "wifi-qcom-ac", and include required utilities for WiFi management into bundle;
!) wireless - separate "wireless" package from bundle and build as a standalone package;
*) bridge - added automatic "path-cost" values depending on interface rate;
*) bridge - added bridge interface property "port-cost-mode" with "short" and "long" arguments;
*) bridge - fixed bogus VLAN entries from wifi when vlan-filtering is not enabled;
*) bridge - improved host flush when removing VLAN on HW offloaded bridge;
*) bth - added "VPN Prefer Relay Code" option;
*) certificate - add support for multiple DNS names for Let's Encrypt;
*) certificate - fixed certificate auto renewal via SCEP when certificate contains "subject-alt-name";
*) certificate - improved initial certificate creation using SCEP;
*) cloud - improved re-connect speed after network related connection errors;
*) console - added ":grep" command;
*) console - added ":onerror" command;
*) console - added ":serialize" and ":deserialize" commands for converting values to/from JSON;
*) console - added "read" command under "file" menu;
*) console - added "where" functionality for "export" command;
*) console - added flags to "print" command with "value-list";
*) console - added interface helper for "gateway" property under "ip/route" menu;
*) console - clear console history when resetting configuration;
*) console - disallow setting existing "name" under "system/script" and "system/scheduler" menus;
*) console - fixed "export" boolean arguments when saving output to file using API;
*) console - fixed "interface/ethernet/switch/port-isolation" export;
*) console - fixed "on-event" argument highlighting under "system/scheduler" menu;
*) console - fixed graphic distortions in WinBox;
*) console - fixed issue where API incorrectly asks for missing arguments;
*) console - fixed printing of "on-event" under "system/scheduler" menu;
*) console - fixed printing to file using API;
*) console - ignore negative values for ":delay" command;
*) console - improved flag printing in certain menus;
*) console - improved stability when running "tool/ping" from API;
*) console - removed "route-cache" setting from "ip/settings" menu;
*) console - replace reserved characters in file and script names with underscores;
*) console - resolve "wifiwave2" directory to "wifi";
*) console - show "l2vpn-link" address family under "routing/route" menu;
*) console - use more compact login screen for empty branding;
*) defconf - expire password when reverting configuration;
*) defconf - hide default configuration for users without "sensitive" policy;
*) defconf - updated configuration with new "wifi" directory;
*) defconf - use "fan-min-speed-percent=25" for CRS354-48G-4S+2Q+ device;
*) defconf - use device factory preset credentials when using CAPs mode;
*) defconf - use one SSID and enable FT when using "wifi" packages;
*) ethernet - improved packet CPU core classifier for Alpine CPUs for non IPv4/IPv6 traffic;
*) fetch - added "http-content-encoding" setting;
*) fetch - allow to receive HTTP response headers;
*) fetch - require "ftp" user policy;
*) firewall - added "nat-pmp" support;
*) firewall - added new IPv6 filter arguments "icmp-err-src-routing-header" and "icmp-headers-too-long" for "reject-with" setting;
*) firewall - do not mark all IPv6 GRE packets as invalid;
*) firewall - fixed altered address-list when upgrading from RouterOS v6;
*) firewall - fixed connections being tracked when tracking is disabled;
*) firewall - fixed IPv6 address-list timeout;
*) firewall - removed "prohibited" and "unreachable" IPv4 address-type arguments;
*) health - dynamically add and remove invalid sensors (e.g. sfp-temperature);
*) hotspot - fixed incorrect host moving to VLAN 0 when receiving packets through bridge;
*) ike2 - fixed ike2 double reply;
*) ipv6 - do not send out IPv6 RA deprecate message for re-used prefix;
*) isis - added IS-IS protocol support (CLI only);
*) l3hw - fixed routing for IPsec encapsulated packets;
*) leds - fixed LED indication in multi-APN setup for Chateau;
*) leds - improved LED indication during modem registration state for Chateau;
*) log - added "fetch" topic;
*) lora - fixed issue with lost LoRa configuration when rebooting the device;
*) lte - added RNDIS support for neoway N75-EA modem;
*) lte - added support for FOTA firmware upgrade from custom URL for R11eL-FG621-EA;
*) lte - disabled IMS service for Chateau 5G on A1 HR network;
*) lte - fixed rare cases where Chateau 5G in passthrough mode may stop forwarding packets;
*) lte - improved SIM slot status change notification handling for MBIM modems;
*) lte - replaced "passthrough-subnet-selection" with "passthrough-subnet-size" setting (CLI only);
*) lte - show each CA band in a new line;
*) mipsbe - improved system stability when removing USB devices;
*) mmips - properly mount and unmount USB devices;
*) modem - added option to read SMS using MBIM interface;
*) mpls - added "te-tunnel" property for VPLS monitor (CLI only);
*) mpls - fixed IPv6 RSVP-TE;
*) mpls - improved logging;
*) netinstall-cli - added more details to help messages;
*) ovpn - improved memory allocation during key-renegotiation;
*) ovpn - removed "ping-timer-rem" option from client config file;
*) package - added warning log about missing "wireless" or "wifi" package;
*) pimsm - improved elected BSR change;
*) poe-out - improved firmware upgrade stability for AF/AT controlled boards;
*) ppp - added remote-ipv6-prefix to IPv6 firewall address-list if "address-list" property is provided;
*) ppp - allow at-chat and info commands in "waiting for packets" state for modems with shared data/info channel;
*) ppp - improved IPv6 link-local address uniqueness;
*) pppoe-server - fixed connection count limit per license level;
*) profiler - improved "disk" and "supout.rif" classifiers;
*) qos-hw - added initial congestion avoidance support for 98DX224S, 98DX226S, and 98DX3236 switch chips (CLI only);
*) qsfp - added support for QSFP-to-SFP adapters;
*) quickset - show DDNS name as VPN address for devices with new style serial number;
*) sfp - improved link establishment with certain modules for hEX S device;
*) sfp - improved SFP interface handling for 98DX224S, 98DX226S, 98DX3236, 98DX8208, and 98DX8216 switch chips;
*) ssh - fix error that caused large chunks of text not being pasted in their entirety into console;
*) supout - added VXLAN FDB section;
*) switch - fixed service VLAN tagged IP multicast packets for 98DX8208, 98DX8216, 98DX8212, 98DX8332, 98DX3257, 98DX4310, 98DX8525, 98DX3255 switches;
*) system - added "rtrace" debugging tool (CLI only);
*) traffic-generator - improved system stability when modifying interfaces;
*) usb - added support for RTL8152 USB ethernet on ARM, ARM64 and x86;
*) vpls - improved performance when decapsulating data;
*) vrf - fixed ICMP reply lookup;
*) webfig - allow to display comments in multiline or compact modes;
*) webfig - make table headers always visible;
*) webfig - use local storage for user preferences;
*) wifi - added "flat-snoop" tool for surveying WiFi APs and stations (CLI only);
*) wifi - added "remove" command in "capsman/remote-cap" menu;
*) wifi - after radar detections, avoid selection of channels not permitted by the user;
*) wifi - changed CAPsMAN generated certificate common name;
*) wifi - fixed EAP authentication failures when the Session-Timout RADIUS attribute is defined;
*) wifi - fixed occasional failures to start on 20/40mhz-eC channels for 2.4GHz 802.11ax interfaces;
*) wifi - fixed overridden datapath settings on CAP when unsetting from CAPsMAN;
*) wifi - make slave APs use datapath bridge settings inherited from master by default;
*) wifi - removed "openflow-switch" setting;
*) winbox - added "Hw. Offload" property under "IP/Firewall/Filter" menu;
*) winbox - added "none" argument for "Preshared Key" under "WireGuard/Peers" menu;
*) winbox - added "Ping" button under "IP/DHCP Server/Leases" menu;
*) winbox - added "Tx bps" and "Rx bps" monitor values under "WiFi/Registration" menu;
*) winbox - added icon to entries under "WiFi/Access List" menu;
*) winbox - added missing "qos-classifier" argument for "Hw. Caps" under "WiFi/Radios" menu;
*) winbox - added missing arguments for "MAC Format" under "Wireless/Security Profiles/RADIUS" menu;
*) winbox - allow opening entries under "WiFi/Registration" menu;
*) winbox - fixed default "Name Format" property under "WiFi/Provisioning" menu;
*) winbox - fixed minor typo under "Routing/BFD" menu;
*) winbox - updated "wireless" and "wifi" menus;
*) wireless - fixed "wlan1" default name for RBSXTsqG-5acD and RBLDFG-5acD;
*) wireless - fixed snooper information gathering from re-assocation requests; -
iceQ!
lionhearted #20818 üzenetére
Milyen kell?
iceQ!
Bubukain #20636 üzenetére
Mindent a leírtak szerint csinálok és nincs net. Ha meg van akkor nem kapok publikus IP-t csak NAT-olt címet, pedig központilag ki is van kapcsolva.
kammler
Tűzfalszabályok rendben vannak már, korábban koaxos telekommal használtam a routert, viszont ott elég volt egy dhcp klienst beállítani mivel nincs PPPoE kapcsolat.
iceQ!
Tegnap elkezdtem átnézni a beállítást a Cloud-nak. Telekom optika van, pppoe passthrough-n keresztül jelentkezek be. Már kiírta, hogy hogy a hálózatom nat mögött van. Feljebb azt az infót kaptam, hogy pupblic IP lesz akkor is ha a modem és a router is fel van csatlakozva a Telekom hálózatra. Ezek szerint akkor mégsem? Ilyenkor a PPPoE kapcsolatot töröljem a Telekom routerből és csak a saját eszközömmel használjam?
iceQ!
Megtörtént a beállítás. Nagyon keservesen ment az egész. A nettel is gond van, mintha akadna. Pl.: Speedtest.exe így indul, majd az utolsó error után elkezdi a sebességmérést.
[error] Error: [0] Unknown error
[error] Error: [0] Unknown error -
iceQ!
Sziasztok
Telekom PPPoE Passthrough be van kapcsolva a Telekom-os eszközben, viszont nálam valamiért nem kapcsolódik. Ethernet 1-re állítottam be a pppoe klienst. Egyébként egy hAP Ax3-as az eszköz amin gyakorlatozok.
A kábelt a Telekom routerban a Wan portba dugtam. Valami tipp esetleg, hogy miért nem tud kapcsolódni?
iceQ!
A hAP AX3 egy 55 nm-es panelt a két antennájával körbe tud lőni? Mindenhol lesz rendes jelerősség?
iceQ!
lionhearted #19183 üzenetére
Mi van?
Teszt? Még dobozban van, konfigolni kellene,de egyelőre még nincs rá időm.
iceQ!
Van itt esetleg olyan aki Linux-on futtat OpenVPN szervert és a hálózati eszközök Mikrotikesek?
iceQ!
Ilyen kábelből hol tudnék venni 15-20cm-es változatot? A gyári 10cm, az kevés.
iceQ!
iceQ!
Olyan mikrotik eszközt keresek amire lehet utólag 2 antennát szerelni(ha van rajta az még jobb), illetve el tud menni egy power bankon is (2A-es). Esetleg tudtok ilyet?
iceQ!
ratkaics #18530 üzenetére
# Created Jotne 2019 v1.2
# This script add ip of user who with "IPSEC negotiation failed" and "SPI* not registered" to a block list for 24hour
# Schedule the script to run every 5 min
# It should run on all routerOS version
# Find all "negotiation failed" error last 5 min
:local loglistN [:toarray [/log find time>([/system clock get time] - 5m) message~"negotiation failed"]]
# for all error do
:foreach i in=$loglistN do={
# find message
:local logMessageN [/log get $i message]
# find ip
:local ipN [:pick $logMessageN 0 [:find $logMessageN " "]]
# Add ip to accesslist
/ip firewall address-list add address=$ipN list=IPSEC
# Send a message to the log
:log info message="script=IPSEC_failed src_ip=$ipN why=negotiation_failed"
# Find all "SPI* not registered"" error last 5 min
:local loglistS [:toarray [/log find time>([/system clock get time] - 5m) message~"SPI.*not regist"]]
# for all error do
:foreach j in=$loglistS do={
# find message
:local logMessageS [/log get $j message]
# find ip
:local ipS [:pick $logMessageS ([:find $logMessageS "for "]+4) [:find $logMessageS "["]]
/ip firewall address-list add address=$ipS list=IPSEC
:log info message="script=IPSEC_failed src_ip=$ipS why=SPI_not_registered"
iceQ!
iceQ!
lionhearted #18471 üzenetére
lionhearted nem neked akartam válaszolni
Mikrotik - nemMikrotik kérdés:
CAPsManager otthon egy hapAC3, és van CAP-ből 2 db. 1 hapAC2 és egy mAPLite.
Közöttük van egy DLINK switch és a DLINK azon portja ami a AC2-be megy, valamiért x időközönként átáll 100Mbit-re. Kihúzom, bedugom újra Gigabites lesz. Más Mikrotik eszköz ezt nem csinálja a hálózatban csak a AC2. Miért lehet ez?
iceQ!
Backup vonalat akarok csinálni, egy hAP AC3-as eszközön. A backup line LTE-n keresztül menne, ha nincs vezetékes net akkor álljon át erre. Ez a leírás jó nekem?
Illetve, ha visszajött a vezetékes uplink,automatikusan visszaáll rá? Erről nem láttam semmi leírást.
iceQ!
Véletlen felkerült a 7.6beta6 a hAP AC3-ra. Valaki rajtam kívül még feltette? Van vele valami gond? Mert ha nincs, akkor hagynám rajta. 7.4-el nagyon meg vagyok / voltam elégedve.
A véletlen az úgy történt, hogy rányomtam a Developer menü pontra majd Download&install-ra is egyben
iceQ!
Az előző frissítéssel 154 Mib volt szabadon, a jelenlegivel pedig 175(hAP AC3). Mi változott? Azt látom hogy sok minden, de miért szabadult fel ennyi memória?
iceQ!
iceQ!
Felraktam egy SPLYNX-et egy ubunut szerverre, hogy monitorozzam a hAP Ac3-t (memory & cpu usage)
Ahogy látom, ez fizetős (még van 12 nap hátra). Ki milyen ingyenes megoldást talált erre a célra?
Egyébként ez elég jó kis megoldás lenne, de a havi díj 200$, nekem meg annyit nem ér meg ez. Esetleg egy ZABIX jó lehet erre a célra?
iceQ!
Az egyik pc-nek fix ip-t adok, nem tudom pingelni a default gateway-t. Mi lehet a gond?
iceQ!
Tegnap este én is felraktam a 7.4.1-es ROUTER OS-t. Kíváncsi leszek, hogy lesz -e továbbra is memory leak a hAP AC3-as eszközön.
iceQ!
Köszi mindenkinek.
iceQ!
Uraim,
Arra van megoldás, hogy hálózaton belül megtudjuk, hogy melyik az az eszköz ami a letöltési sebességet felzabálja? Ma volt egy incidens, hogy a fel-letöltés szinte 0 volt, mert valami nagy okos töltött fel-le órákon át (hogy mit azt nem tudjuk) Erre keresnék megoldást.
iceQ!
yodee_ #17553 üzenetére
Nem egyedi másnak is volt. MEMORY LEAK
Nézegettük nem jöttünk rá.
- AKCIÓ! GAMER PC: Új RYZEN 5 4500-5600X +RTX 3060/3070/3080 +Új 16-64GB DDR4! GAR/SZÁMLA! 50 FÉLE HÁZ
- UHH! HP EliteBook 840 G8 Fémházas Laptop 14" -45% i5-1145G7 4Mag 32/512 FHD IPS Intel Iris Xe Magyar
- Xiaomi Redmi Note 13 Pro 5G - 8/256 - Media Markt garancia
- Xiaomi Redmi 9at - 2/32 - szürke
- Xiaomi Mi8 - 6/128 - fekete
- LG 27CN650N-6A - Felhő Monitor - 1920x1080 FHD - 75Hz 5ms - USB Type-C - Quad Core - BT + WiFi
- ÁRGARANCIA!Épített KomPhone Ryzen 7 5700X 16/32/64GB RAM RX 7600XT 16GB GAMER PC termékbeszámítással
- Új Apple iPhone 16 Pro 128GB, Kártyafüggetlen, 3 Év Garanciával
- BESZÁMÍTÁS! Gigabyte B760M i5 14600KF 32GB DDR4 1TB SSD RX 6700XT 12GB Zalman Z1 Plus Seasonic 650W
- AKCIÓ! Lenovo Legion Slim 5 Gamer notebook - R7 7435HS 16GB RAM 1TB SSD RTX 4070 8GB GDDR6 WIN11
