- A vártnál korábban érkezhet a Xiaomi 17 Ultra
- Miért fárad gyorsabban az iPhone akku, mint az androidos?
sg22
Most of the actions we tested have a fairly low parallel efficiency (below .7 or 70%). They still benefit from having more cores, but in most situations a CPU with a lower core count but higher operating frequency will give you the best performance. However, exporting images - which pretty much any Lightroom user is going to do - has a very high parallel efficiency which means a CPU with a high core count will allow you to export images faster. This means that the best CPU for you is going to depend on exactly what actions in Lightroom you regularly find yourself waiting on.
azt irjak h magasabb freki jobb mint a tobb mag ehhez a progihoz (lightroom). megoldas lett volna egy tobb magos xeon proci alacsonyabb frekivel ezaltal alacsonyabb tdp-vel. de mivel magas freki kell ezert a tdp is magas lesz
- Kingston FURY 32GB KIT DDR5 6000MT/s CL30 Beast Black EXPO (garanciális, Alza)
- Corsair Vengeance RGB RS 32GB (2x16GB) DDR4 3600MHz C18 Memória!
- Asus P8H61-M LX3 Plus R2.0 LGA 1155 alaplap
- Corsair Vengeance LPX 2x8GB 3200MHz DDR4 kit / Beszámítás OK!
- ASUS ROG STRIX X670E-E GAMING WIFI - Garancia 2026.05.15.
- magyar billentyűzet - 161 - 162 - 163 - Lenovo LOQ (15ARP9) - AMD Ryzen 7 7435HS, RTX 4060
- Dell USB-C dokkolók: (K20A) WD19/ WD19S/ WD19DC + 130W, 180W, 240W töltők
- BESZÁMÍTÁS! Intel Core i7 4790 4 mag 8 szál processzor garanciával hibátlan működéssel
- IKEA (HAVREHOJ) tablet tartó
Cég: NetGo.hu Kft.
Város: Gödöllő
