Deliver Us the Moon - Jövő hónapban jön Switch-re
gp Bár korábban elkaszálták a Nintendo gépére szánt változatot, júliusban mégis megkapjuk az új kiadást.
Megérkezett a Razer DeathAdder V3 Hyperspeed verziója
ph A Pro és a vezetékes változat után tehát itt a Razer saját rádiós megoldását használó változat, mely 8 grammal könnyebb is az előbbinél.
Archívum #1
Archívum #2
Kommy
válasz r3dsnake #61556 üzenetére
Nem kell hozzá helymeghatározás a következő backgroud tevékenységek vannak
Audio audio The app plays audible content to the user or records audio while in the background. (This content includes streaming audio or video content using AirPlay.)
Location updates location The app keeps users informed of their location, even while it is running in the background.
Voice over IP voip The app provides the ability for the user to make phone calls using an Internet connection.
Newsstand downloads newsstand-content The app is a Newsstand app that downloads and processes magazine or newspaper content in the background.
External accessory communication external-accessory The app works with a hardware accessory that needs to deliver updates on a regular schedule through the External Accessory framework.
Bluetooth networking bluetooth-central The app works with a Bluetooth accessory that needs to deliver updates on a regular schedule through the Core Bluetooth framework.
Bluetooth data sharing bluetooth-peripheral The app supports Bluetooth communication in peripheral mode through the Core Bluetooth framework.
Using this mode requires user authorization; for more information, see “Best Practices for Maintaining User Privacy.”
Background fetch fetch The app regularly downloads and processes small amounts of content from the network.
Remote notifications remote-notification The app’s response to a push notification includes optionally downloading content related to the notification. The purpose of downloading the content in the background is to incorporate it and be able to present it immediately when the user responds to the push notification.[ Szerkesztve ]
Onderon
válasz r3dsnake #61684 üzenetére
mert undorító, amit magyarországon művel mindenki. többek között emiatt is lesz ez beszüntetve. hazánk megint élen jár valamiben végre!
ha nem lenne a sok "minimális hibája lesz én is megjátszom" csaló, akkor nem kellene a valóban hibás készüléket gyomorideggel 4-5 boltba vinni, mire nagynehezen cserélik.
Onderon
válasz r3dsnake #61690 üzenetére
a te esetedben semmit. nem is értem miért vetted magadra. alapvetően nem rólad beszéltem, mint ahogyan a hozzászólásomat sem hozzád intéztem először.
nekem is cserélve volt az i5-m, kétszer is. elsőnek a wifije volt rossz, azt visszadtam (8 napon belül) a másodiknak meg a kijelzője volt hibás, azt cserélték. de 3 t-pontban voltam, mire sikerült elintéznem, mert mindenhonnan elhajtottak, pedig eléggé szembetűnő és egyértelműen gyári hiba volt, mert ilyet nem lehet máshogyan előidézni, mégis elhajtottak a westendből is és az allee-ból is, végül a mammutban cserélték szó nélkül. és meg vagyok róla győződve, hogyha a sok pistike nem vinné be minden lófing hibával cserére az uzsonnapénzből megspórolt telefonját, akkor gördülékenyebben menne a valós hibával rendelkező telefonok cseréje is.
(#61691) B-L-A-C-K: oké, akkor tisztázzuk mi a minimális hiba. mert az nem minimális hiba, ha nem megy a home gomb, vagy dobálja a wifit vagy a hálózatot. az hiba. amúgy pedig (már nem emlékszem pontosan melyik) szervizes fogalmazta meg nagyon szépen: cserére jogosít minden olyan hiba, ami a telefon használatát befolyásolja. szerintem (én úgy értelmezem) a minimális hiba, attól minimális, mert nem befolyásolja a telefon használatát.
Onderon
válasz r3dsnake #61693 üzenetére
nekem is annyit kellett volna várnom, de még csak be sem vették bevizsgálásra! végül jött a másik véglet, a mammut. még én is meglepődtem. már kezdtem beletörődni, hogy ezzel így jártam. végső próbálkozásra 3 különböző stílusú védőbeszéddel készültem, egy aranyos/kedvessel egy tárgyilagossal és egy támadóval, minden kérdést lejátszottam magamban előre, jobb lettem volna, mint bármelyik ügyvéd, erre odaadom, megnézi és közli, hogy oké, pont van bent cserekészülék, mindjárt hozza, adatokat lementettem? fél perc sem volt. csak pislogtam.
privacy99
válasz r3dsnake #61703 üzenetére
De kopni fog. És mint mondtam, átverhető a dolog bármikor. Meg is történt számtalanszor, mint ahogy olvashattuk x alkalommal.
Egyetértünk, mert ne kopjon, de kopik és kész, most ezzel mit tudsz csinálni? Semmit.. Életem végéig meg nem viszem vissza az 1232. telefonomat.
lajki7
válasz r3dsnake #62451 üzenetére
Hello
Bongeszobol masolni? Ugy erted adat hordozokent latja a gep a telot es csak behuzom a mappaba a filmet?!Ilyen serveres dolgokat nem akarok en butykolni a gepen mezei modon wifin keresztul latni szeretnem a megosztott mappakat ennyi. Ezt csak lehet nem?
iPhone 11 Pro
lajki7
válasz r3dsnake #62454 üzenetére
Koszi mind kettotoknek akkor van megoldas az a lenyeg csak ossze hozom majd ha meg lesz a vas!
Mas: velemeny erdekel. Van egy i5 64gbos majdnem harom honapos,dominosan lett veve egy eve (csak csereltek az urgenek mert beszart valami gomb rajta) ezert ujra el a 12ho gar. Minden papir meg van 140 pezot kernek erte??! megeri mi?:/ en ugy velem h igen
iPhone 11 Pro
ittakary
válasz r3dsnake #62827 üzenetére
Ez egy kiskapu: itt nincs semmilyen "vonatkozik" vagy ilyesmi. Gondolj bele: a fülesen nincs semmi egyedi serial szám, stb, csak a termékazonosító, hogy az egy EARPOD. Honnan tudnák a szervizben, hogy ez most melyik készülékkel lett vásárolva.... Azaz bárkivel elintéztetheted, aki hajlandó rá.
(rögzített hozzászólás)
Kérünk benneteket, hogy a jövőben az iOS BETA-verzióval kapcsolatos érdemi kérdéseket inkább a Béta iOS-t használók topikja-ban beszéljétek meg.
Ide értendő a
- hogyan tudok csatlakozni a BETA-hoz?
- hogyan történik a telepítés?
- hogyan lehet visszatérni a stabil iOS verzióhoz?
- mi történik a mentésekkel, amik BETA alatt készültek?
- hogyan lehet visszajelzést küldeni?
- mely appok működnek megfelelően?
- mely appokkal van probléma?
- az akkuidő hogy alakul?
- mennyi a SoT (képernyőidő, Screen on Time)?jellegű kérdéskör.
Ami maradhat itt, az iPhone-topikban, az pl ilyen kérdés: "mutassatok már egy screenshotot, hogyan néz ki a színezett ikon", vagy "vajon hogy néz ki az új híváslista".
Köszönjük!
iPhone 15 — https://hardverapro.hu/apro/iphone_15_tok_elado_2/friss.html
- Apple iPhone 13 Pro Max 256GB
- Eladó iPhone 15 Pro 256GB - Blue (kék) Titanium
- Motorola Edge 50 Ultra 16/1024GB, Fa hátlapos, újszerű, 2 év gyári garanciával, eladó!
- Iphone 13 128GB független, nagyon szép mélyzöld, 2026. januárig garanciás
- Bontatlan ÚJ IPHONE 13 mini 128-512Gb gyári független Minden Szín Deák Térnél Azonnal Átvehető.
