- Idő előtt felbukkant a Motorola Razr 70: képek, specifikációk és ár is van
- Kiszivárgott a Xiaomi 17T és 17T Pro teljes specifikációja és eurós ára
- Akciófigyelő: jelentős kedvezménnyel nyit a Honor 600
Thom!
http://www.go-l.com/desktops/machl38/features/index.htm
Extra-Mega brutalitás mitegy 20millióért. ~8000 dollár
3.8GHz* Accelerated Hyper-Threading Intel®
Pentium 4 Extreme Edition CPU w/ 2MB L3 Cache
512K L2 Cache
950MHz** System Bus
PuRam™ No System Hard Drive Configurable
Up to 100 times faster than ATA/SCSI/FC HD based
designs with Data Burst Speeds up to 8GB/s
and I/O data requests at over 150.000 I/O sec.
Enhanced CacheFlow™ Technology
SuperBIOS™ IBPT Technology
180W Sub-zero Vapor Compression Cooling
PC4200 533MHz Dual-Channel Performance
DDR, up to 4GB
Up to 16GB Total RAM with optional RamDrives.
Over 8.4Gb/s Memory Bandwidth
ATA-133 RAID, Serial ATA-150 Connectivity
UltraSCSI-320 & FiberChannel Expansion
Up to 2 Terabytes of Colossal Storage Capacity
Intel Performance Acceleration Technology
AGP Pro 8x Accelerated 256bit MemoryBus
Radeon™ 9800 Pro/ XT Graphics with 8 Pixel
Pipelines at 3.04Gp/s Pixel Fil rate, 21.8GB/
bandwidth & Multi-monitor, High-Definition support.
Optional direct connectivity with the Gemini,
Cinerama & Grand Canyon Series Displays (or a
total of 8 external high-resolution monitors) via
ColorGraphgic Xentera GT, Appian Rushmore, Nvidia
Quadro NVS & Matrox Parhelia, 450MMs & QID
Graphics Adapter Series bundle.
Ultra High-speed 8x DVD+/-RW Optical Drive
Front Panel Multi-information LCD Status
Display, External removable HD Storage racks
with LCD Monitoring or Multi-Optical Drives
interchangeable bays
FireWire 400 & 800 Ports
Up to 8 Full-Duplex USB2 480Mb/s Ports
6 Channel Digital IA Audio with Artificial
Intelligence Audio-Sensing Technology &
S/PDIF Digital interface
3COM Gigabit LAN with AI Net
(Artificial Intelligence Net-Diagnosing)
Up to 74 32-bit or 64-bit PCI slots expandability
550W VF-Speed Power Supply
AI Ultra-low noise Q-Fan technology
802.11G Wireless LAN & Bluetooth Expansion
Artificial Intelligence Auto-Recovery BIOS
Absolutely stunning design combined high-end
european critical components quality worksmanship.
- Dell Latitude 5450 Újszerű, Ultra 5 135U, FHD IPS LCD,16GB, Magyar vil bill., gyári gar 2027.11-ig
- Bambu Lab A1 mini azonnal használható szett
- Samsung 860 Evo 1TB SATA3 93%-os és Samsung 860 QVO 1TB 97%-os
- Apple Watch Ultra (1. generáció) ÚJSZERŰ, 100% AKKU
- Macbook Pro 16" A2485 2021 M1 Pro 16/512 (5)
