emitter
a magyar kde-t honnan tölthetem le? csak mert a kde.hu-ról egyik link sem érhető el ''550 Failed to change directory''
emitter
nekem most a usr/lib/mozilla-firefox mappában levő 1.0.7-es firefox-ot futtatva is az 1.5ös jön be, ez mitől lehet?
Másik kérdés: el tudnátok magyarázni szájbarágósan, hogyan kell felinstallálni ezt a játékot: (innen szedtem le: [link])
[[ Frozen-Bubble ]]
Requirements
SDL_mixer >= 1.2.2
http://www.libsdl.org/projects/SDL_mixer/
SDL perl >= 1.19.0
http://sdlperl.org/
If you compile by hand, double-check you first compile SDL, then SDL_image
and SDL_mixer, then SDL perl, otherwise you might get the error that
NewFont.al is not found.
Installation instructions
[*] First, build Frozen-Bubble and provide the prefix where the
game will be installed (most probably /usr or /usr/local).
make OPTIMIZE=''my_arch_opt_flags'' PREFIX=''my_prefix''
[*] Second, install the files on the system.
- if you're root (case when you build a Debian package, or
when you build it locally on your own machine), you will
choose the same prefix location than for previous step
make install PREFIX=''my_prefix''
- if you're not root (case when you build a RPM package), you
need to install to a temporary directory where you have
write access
make install PREFIX=''/home/my_home/tmp/my_buildroot''
Then an external program such as RPM will collect the
installed files and write the package.
thx -
emitter
emitter@LAPTOP:~/Letoltesek/firefox$ ./firefox-bin
./firefox-bin: error while loading shared libraries: libmozjs.so: cannot open shared object file: No such file or directory
./firefox-bin: error while loading shared libraries: libstdc++.so.5: cannot open shared object file: No such file or directory
akkor vmi lib hiányzik nálam, ami az 1.0.7-eshez nem kellett, de ehhez már kell? -
emitter
emitter@LAPTOP:~/Letoltesek/firefox$ ls -l
összesen 12693
-rw-r--r-- 1 emitter emitter 218 2005-12-07 18:38 browserconfig.properties
drwxr-xr-x 3 emitter emitter 544 2005-12-07 18:38 chrome
drwxr-xr-x 2 emitter emitter 776 2005-11-12 02:00 components
drwxr-xr-x 5 emitter emitter 128 2005-12-07 18:38 defaults
drwxr-xr-x 5 emitter emitter 184 2005-11-12 01:59 extensions
-rwxr-xr-x 1 emitter emitter 5239 2005-11-12 01:59 firefox
-rwxr-xr-x 1 emitter emitter 9889508 2005-11-12 02:00 firefox-bin
drwxr-xr-x 2 emitter emitter 144 2005-11-12 01:59 greprefs
drwxr-xr-x 2 emitter emitter 176 2005-11-12 01:59 icons
-rwxr-xr-x 1 emitter emitter 563656 2005-11-12 02:00 libmozjs.so
-rwxr-xr-x 1 emitter emitter 176012 2005-11-12 02:00 libnspr4.so
-rwxr-xr-x 1 emitter emitter 426224 2005-11-12 02:00 libnss3.so
-rwxr-xr-x 1 emitter emitter 240360 2005-11-12 02:00 libnssckbi.so
-rwxr-xr-x 1 emitter emitter 15304 2005-11-12 02:00 libplc4.so
-rwxr-xr-x 1 emitter emitter 8240 2005-11-12 02:00 libplds4.so
-rwxr-xr-x 1 emitter emitter 138284 2005-11-12 02:00 libsmime3.so
-rw-r--r-- 1 emitter emitter 476 2005-11-12 02:00 libsoftokn3.chk
-rwxr-xr-x 1 emitter emitter 420964 2005-11-12 02:00 libsoftokn3.so
-rwxr-xr-x 1 emitter emitter 126752 2005-11-12 02:00 libssl3.so
-rwxr-xr-x 1 emitter emitter 94892 2005-11-12 02:00 libxpcom_compat.so
-rwxr-xr-x 1 emitter emitter 687172 2005-11-12 02:00 libxpcom_core.so
-rwxr-xr-x 1 emitter emitter 9240 2005-11-12 02:00 libxpcom.so
-rwxr-xr-x 1 emitter emitter 8284 2005-11-12 02:00 libxpistub.so
-rwxr-xr-x 1 emitter emitter 10336 2005-11-12 02:00 mozilla-xremote-client
drwxr-xr-x 2 emitter emitter 80 2005-11-12 02:00 plugins
-rw-r--r-- 1 emitter emitter 177 2005-11-12 01:59 readme.txt
-rw-r--r-- 1 emitter emitter 256 2005-04-11 23:17 README.txt
-rwxr-xr-x 1 emitter emitter 1538 2005-11-12 01:59 removed-files
drwxr-xr-x 6 emitter emitter 1688 2005-11-12 01:59 res
-rwxr-xr-x 1 emitter emitter 10492 2005-11-12 01:59 run-mozilla.sh
drwxr-xr-x 2 emitter emitter 432 2005-12-07 18:38 searchplugins
-rwxr-xr-x 1 emitter emitter 67496 2005-11-12 02:00 updater
-rw-r--r-- 1 emitter emitter 153 2005-08-25 16:42 updater.ini
-rwxr-xr-x 1 emitter emitter 21368 2005-11-12 02:00 xpicleanup
egyébként egy partíció van, amin maga a rendszer is van (egy 37G-s), ill. 1.5G swap -
emitter
sziasztok!
ma raktam föl ubuntu-t tökre tetszik
egy-két kérdésem lenne:
Firefoxban hogyan lehet átállítani a betűtípust TimseNewromanra? Mert alapból sans serifen van, de ez nem jön be...
Aztán leszedtem a magyar FF 1.5-öt, egy tar.gz csomagban. Kicsomagoltam, oké, mit csináljak vele? Kell fordítani valamit, vagy csak felülírjam vele az 1.07-es FF-ot?
thx
Milyen program ami... [link]
- Vélemény Ubuntu 20.04 LTS
- Tudástár MX-Linux 19
- Mikrotik routerek
- sziku69: Szólánc.
- Windows: mi történik valójában Leállításkor, Alvó módban és Újraindításkor?
- Óra topik
- Fizetős szoftverek ingyen vagy kedvezményesen
- Hardcore pizza és kenyér topik
- Nyíregyháza és környéke adok-veszek-beszélgetek
- Milyen TV-t vegyek?
- Adobe Előfizetések - Adobe Creative Cloud All Apps - 12 Hónap
- HUAWEI MateBook 13 2020 - Kijelző nélkül - I7-10510U - 16GB - 512GB SSD - Win11 - MAGYAR
- Telefon Felvásárlás!! iPhone 14/iPhone 14 Plus/iPhone 14 Pro/iPhone 14 Pro Max
- HIBÁTLAN iPhone 13 128GB Midnight -1 ÉV GARANCIA - Kártyafüggetlen, MS3033, 100% Akkumulátor
- Dell 7400 Intel Core i7-8665U
- HIBÁTLAN iPhone 15 Pro Max 256GB White Titanium -1 ÉV GARANCIA - Kártyafüggetlen, MS3006, 90% Akksi
