- Motorola G86 - majdnem Edge
cont
újonc
fpeter84
#9771
Nem, ezt a beállítást a szerző javasolta, mert kompatíbilis az SSD1963-mal. De az SSD1963-at is beállítottam a programban, ugyanaz a jelenség.
A legutolsó próba ezzel a beállítással futott:
// UTouch_ButtonTest (C)2010-2014 Henning Karlsen
// web: http://www.henningkarlsen.com/electronics
// This program is a quick demo of how create and use buttons.
// This program requires the UTFT library.
// It is assumed that the display module is connected to an
// appropriate shield or that you know how to change the pin
// numbers in the setup.
#include <UTFT.h>
#include <UTouch.h>
// Initialize display
// Set the pins to the correct ones for your development board
// Standard Arduino Uno/2009 Shield : <display model>,19,18,17,16
// Standard Arduino Mega/Due shield : <display model>,38,39,40,41
// CTE TFT LCD/SD Shield for Arduino Due : <display model>,25,26,27,28
// Teensy 3.x TFT Test Board : <display model>,23,22, 3, 4
// ElecHouse TFT LCD/SD Shield for Arduino Due : <display model>,22,23,31,33
// Remember to change the model parameter to suit your display module!
//UTFT myGLCD(ITDB50,38,39,40,41);
UTFT myGLCD(SSD1963_800,19,18,17,16);
// Initialize touchscreen
// Standard Arduino Uno/2009 Shield : 15,10,14, 9, 8
// Standard Arduino Mega/Due shield : 6, 5, 4, 3, 2
// CTE TFT LCD/SD Shield for Arduino Due : 6, 5, 4, 3, 2
// Teensy 3.x TFT Test Board : 26,31,27,28,29
// ElecHouse TFT LCD/SD Shield for Arduino Due : 25,26,27,29,30
UTouch myTouch( 6, 5, 4, 3, 2);
// Declare which fonts we will be using
extern uint8_t BigFont[];
int x, y;
char stCurrent[20]="";
int stCurrentLen=0;
char stLast[20]="";
** Custom functions **
void drawButtons()
// Draw the upper row of buttons
for (x=0; x<5; x++)
myGLCD.setColor(0, 0, 255);
myGLCD.fillRoundRect (10+(x*60), 10, 60+(x*60), 60);
myGLCD.setColor(255, 255, 255);
myGLCD.drawRoundRect (10+(x*60), 10, 60+(x*60), 60);
myGLCD.printNumI(x+1, 27+(x*60), 27);
// Draw the center row of buttons
for (x=0; x<5; x++)
myGLCD.fillRoundRect (10+(x*60), 70, 60+(x*60), 120);
myGLCD.drawRoundRect (10+(x*60), 70, 60+(x*60), 120);
if (x<4)
myGLCD.printNumI(x+6, 27+(x*60), 87);
myGLCD.print("0", 267, 87);
// Draw the lower row of buttons
myGLCD.fillRoundRect (10, 130, 150, 180);
myGLCD.drawRoundRect (10, 130, 150, 180);
myGLCD.print("Clear", 40, 147);
myGLCD.fillRoundRect (160, 130, 300, 180);
myGLCD.drawRoundRect (160, 130, 300, 180);
myGLCD.print("Enter", 190, 147);
myGLCD.setBackColor (0, 0, 0);
void updateStr(int val)
if (stCurrentLen<20)
stCurrent[stCurrentLen]=val;
stCurrent[stCurrentLen+1]='\0';
stCurrentLen++;
myGLCD.setColor(0, 255, 0);
myGLCD.print(stCurrent, LEFT, 224);
else
myGLCD.setColor(255, 0, 0);
myGLCD.print("BUFFER FULL!", CENTER, 192);
delay(500);
myGLCD.print(" ", CENTER, 192);
delay(500);
delay(500);
// Draw a red frame while a button is touched
void waitForIt(int x1, int y1, int x2, int y2)
myGLCD.drawRoundRect (x1, y1, x2, y2);
while (myTouch.dataAvailable())
myTouch.read();
** Required functions **
void setup()
// Initial setup
myGLCD.InitLCD();
myGLCD.clrScr();
myTouch.InitTouch();
myTouch.setPrecision(PREC_MEDIUM);
myGLCD.setFont(BigFont);
myGLCD.setBackColor(0, 0, 255);
drawButtons();
void loop()
while (true)
if (myTouch.dataAvailable())
myTouch.read();
x=myTouch.getX();
y=myTouch.getY();
if ((y>=10) && (y<=60)) // Upper row
if ((x>=10) && (x<=60)) // Button: 1
waitForIt(10, 10, 60, 60);
updateStr('1');
if ((x>=70) && (x<=120)) // Button: 2
waitForIt(70, 10, 120, 60);
updateStr('2');
if ((x>=130) && (x<=180)) // Button: 3
waitForIt(130, 10, 180, 60);
updateStr('3');
if ((x>=190) && (x<=240)) // Button: 4
waitForIt(190, 10, 240, 60);
updateStr('4');
if ((x>=250) && (x<=300)) // Button: 5
waitForIt(250, 10, 300, 60);
updateStr('5');
if ((y>=70) && (y<=120)) // Center row
if ((x>=10) && (x<=60)) // Button: 6
waitForIt(10, 70, 60, 120);
updateStr('6');
if ((x>=70) && (x<=120)) // Button: 7
waitForIt(70, 70, 120, 120);
updateStr('7');
if ((x>=130) && (x<=180)) // Button: 8
waitForIt(130, 70, 180, 120);
updateStr('8');
if ((x>=190) && (x<=240)) // Button: 9
waitForIt(190, 70, 240, 120);
updateStr('9');
if ((x>=250) && (x<=300)) // Button: 0
waitForIt(250, 70, 300, 120);
updateStr('0');
if ((y>=130) && (y<=180)) // Upper row
if ((x>=10) && (x<=150)) // Button: Clear
waitForIt(10, 130, 150, 180);
stCurrent[0]='\0';
stCurrentLen=0;
myGLCD.setColor(0, 0, 0);
myGLCD.fillRect(0, 224, 319, 239);
if ((x>=160) && (x<=300)) // Button: Enter
waitForIt(160, 130, 300, 180);
if (stCurrentLen>0)
for (x=0; x<stCurrentLen+1; x++)
stLast[x]=stCurrent[x];
stCurrent[0]='\0';
stCurrentLen=0;
myGLCD.fillRect(0, 208, 319, 239);
myGLCD.print(stLast, LEFT, 208);
else
myGLCD.print("BUFFER EMPTY", CENTER, 192);
delay(500);
delay(500);
delay(500);
cont
újonc
Szervusztok!
Segítségeteket kérem.
Összeállítás:
- ER-AS-SSD1963 LCD érintőképernyő meghajtó Arduino shield
[https://www.buydisplay.com/arduino/ER-AS-SSD1963_Datasheet.pdf][link]- ER-TFTM070-4V2.1 TFT LCD modul
[https://www.buydisplay.com/download/manual/ER-TFTM070-4V2.1_Datasheet.pdf][link]- Arduino DUE
Több szoftvert is feltöltöttem az Arduinora, de egyikkel sem működik. A háttérvilágítás megy, de a képernyő sötét marad és csak akkor jelenik meg egy pillanatkép, ha az alaplap vagy a shield RESET gombját megnyomom. A szoftverek hibakód nélkül lefutottak. Mi lehet a probléma, hogy tudom elhárítani?
Ez a szoftver, amit a GitHubról töltöttem le:
//#include <UTFT.h>
#include <UTouch.h>// Initialize display
//UTFT myGLCD(SSD1963_800,19,18,17,16);
UTouch myTouch( 6, 5, 4, 3, 2);// Declare which fonts we will be using
extern uint8_t BigFont[];int x, y;
int stCurrentLen=0;
char stLast[20]="";/*************************
*************************/void drawButtons()
for (x=0; x<5; x++)
for (x=0; x<5; x++)
if (x<4)
}void updateStr(int val)
stCurrentLen++;
else
delay(500);
delay(500);
delay(500);
}// Draw a red frame while a button is touched
myTouch.read();
*************************/void setup()
// Initial setup
myGLCD.InitLCD();
myGLCD.clrScr();myTouch.InitTouch();
myTouch.setPrecision(PREC_MEDIUM);myGLCD.setFont(BigFont);
drawButtons();
}void loop()
while (true)
myTouch.read();
x=myTouch.getX();
y=myTouch.getY();if ((y>=10) && (y<=60)) // Upper row
updateStr('1');
updateStr('2');
updateStr('3');
updateStr('4');
updateStr('5');
}if ((y>=70) && (y<=120)) // Center row
updateStr('6');
updateStr('7');
updateStr('8');
updateStr('9');
updateStr('0');
}if ((y>=130) && (y<=180)) // Upper row
stCurrent[0]='\0';
stCurrentLen=0;
if (stCurrentLen>0)
stCurrent[0]='\0';
stCurrentLen=0;
else
delay(500);
delay(500);
delay(500);
}Nem ez volt az egyetlen program amit feltöltöttem, de mindegyikkel így jártam. Volt olyan is, amelyik nem használta az érintő funkciókat, csak a megjelenítést, az sem működött.
- Milyen széket vegyek?
- Battlefield 6
- Okos Otthon / Smart Home
- Végleg kitiltaná a Huawei-t az EU a hálózatkiépítésből
- Steam topic
- Call of Duty: Black Ops 6
- 2,5 gigabittel hasítanak a belépőszinten az új Asustor NAS-ok
- Autós kamerák
- iPhone 15 Pro Max 256GB Blue Titanium -1 ÉV GARANCIA -Kártyafüggetlen, MS3957, 100% Akkumulátor
- BESZÁMÍTÁS! ASRock B450M R5 Pro 3400G 16GB DDR4 240GB SSD 2TB HDD GTX 1070 8GB RAMPAGE Shiva 450W
- GYÖNYÖRŰ iPhone 13 Pro 128GB Graphite -1 ÉV GARANCIA - Kártyafüggetlen, MS3962, 100% Akkumulátor
- HOWEAR HW ULTRA 3 Call okosóra
- Gamer PC-Számítógép! Csere-Beszámítás! R5 5600 / RX 6700XT 12GB / 16GB DDR4 / 500GB SSD
ekkold
