- Új HMD modell bukant fel
- Google Pixel 6/7/8 topik
Broken Roads teszt
gp Azt, hogy mi történt az atomháborút követően Amerikában, jól ismerjük a Falloutokból. A Broken Roads e történetet ausztrál szempontból meséli el – igencsak hasonló eszközökkel.
Sonja
válasz Frawly #57971 üzenetére
Érdekes, nekem a Spectre2 a VULNERABLE, a Spectre1 és a Meltdown nem.
Spectre and Meltdown mitigation detection tool v0.33+
Checking for vulnerabilities on current system
Kernel is Linux 3.13.0-141-lowlatency #190-Ubuntu SMP PREEMPT Fri Jan 19 13:43:10 UTC 2018 x86_64
CPU is Intel(R) Core(TM) i7-3770 CPU @ 3.40GHz
Hardware check
* Hardware support (CPU microcode) for mitigation techniques
* Indirect Branch Restricted Speculation (IBRS)
* SPEC_CTRL MSR is available: NO
* CPU indicates IBRS capability: NO
* Indirect Branch Prediction Barrier (IBPB)
* PRED_CMD MSR is available: NO
* CPU indicates IBPB capability: NO
* Single Thread Indirect Branch Predictors (STIBP)
* CPU indicates STIBP capability: NO
* Enhanced IBRS (IBRS_ALL)
* CPU indicates ARCH_CAPABILITIES MSR availability: NO
* ARCH_CAPABILITIES MSR advertises IBRS_ALL capability: NO
* CPU explicitly indicates not being vulnerable to Meltdown (RDCL_NO): NO
* CPU microcode is known to cause stability problems: NO
* CPU vulnerability to the three speculative execution attacks variants
* Vulnerable to Variant 1: YES
* Vulnerable to Variant 2: YES
* Vulnerable to Variant 3: YES
CVE-2017-5753 [bounds check bypass] aka 'Spectre Variant 1'
* Kernel has array_index_mask_nospec: NO
* Checking count of LFENCE opcodes in kernel: YES (99 opcodes found, which is >= 70, heuristic to be improved when official patches become available)
> STATUS: NOT VULNERABLE (Kernel source has PROBABLY been patched to mitigate the vulnerability (LFENCE opcodes heuristic))
CVE-2017-5715 [branch target injection] aka 'Spectre Variant 2'
* Mitigation 1
* Kernel is compiled with IBRS/IBPB support: YES
* Currently enabled features
* IBRS enabled for Kernel space: NO
* IBRS enabled for User space: NO
* IBPB enabled: NO
* Mitigation 2
* Kernel compiled with retpoline option: NO
* Kernel compiled with a retpoline-aware compiler: NO
* Retpoline enabled: NO
> STATUS: VULNERABLE (IBRS hardware + kernel support OR kernel with retpoline are needed to mitigate the vulnerability)
CVE-2017-5754 [rogue data cache load] aka 'Meltdown' aka 'Variant 3'
* Kernel supports Page Table Isolation (PTI): YES
* PTI enabled and active: YES
* Running as a Xen PV DomU: NO
> STATUS: NOT VULNERABLE (PTI mitigates the vulnerability)
A false sense of security is worse than no security at all, see --disclaimerHa csalódni akarsz, bízz az emberekben!
Qoaltrain
válasz Frawly #58006 üzenetére
+ Mindenkinek, aki válaszolt: közben "megoldódott" a helyzet, beraktam egy HDD-t (amin Win10 van), az SSD-t pedig külső merevlemezként csatlakoztattam. Sajnos az SSD-t még ígysem látom, szóval nagyon valószínű, hogy tönkrement, ami így 1,5 év után igen érdekes.
Btw az SSD márkája ADATA.
Tim82
ALFA
válasz Frawly #58044 üzenetére
A gond az az ilyen válaszokkal, hogy off-topic témájúak, és nemcsak feleslegesek, de rosszak is.
Semmi közötök hozzá, de jó páran élvezettel kotorásztok más zsebében, így közlöm, hogy webre sincs pénz, és azért ez a gép, mert ezt sikerült a pincében lévő alkatrészekből összerakni. IDE HDD és flopy is van benne.
Ami erre a fórumra tartozik, az az, hogyan lehet működésre bírni, a 8.2-es linux ott van cd-ken, dvd-n, csak éppen nem tudni arról, amit a telepítő követel. Én nem is értem, talán utólag jöttek rá, hogy kimaradt a cd-kről valami fontos, és egy floppyra tették?
Amiért igazából válaszoltam, hogy vegyétek végre észre, hogy pontosan az ilyen hozzáállásotok miatt maradnak az emberek a win-nél, mert előkap pl. egy win telepitőt és kész.
Mert az igazi kérdés az, hogyan lehet működő, használható Pc-t csinálni, és nem olyan lényegtelen dolgok, hogy kinek mennyi pénze van és hány éves programokat használ.
Amit ma megtehetsz - miért nem tetted meg tegnap?
King Unique
válasz Frawly #58089 üzenetére
Nem mondod, én is tudom, hogy natív USB 3.0 támogatás van benne, sőt a 4.6-os kernel óta elvileg 3.1 Gen 2 is. Ahogyan nyilván az UEFI-s telepítést és a GPT-t is támogatja, bár a Secure Boot már nem mindegyik rendszernél OK. Viszont a modern mivolta és az említett dolgok támogatása ellenére a mostani esetnél mégis trükközni kellett vele azon a hardveren, mert normál módon nem akart menni a telepítés... Igaz, nem egy naprakészebbnek mondható Arch, Manjaro, vagy Fedora volt az alany, hanem az Ubuntu és az arra épülő Budgie.
ubyegon2
válasz Frawly #58171 üzenetére
Szerintem a Xubuntuban ezek vannak, amitől Xubuntu:
xubuntu-artwork 16.04.2
xubuntu-community-wallpapers 16.04.0
xubuntu-community-wallpapers-xenial 16.04.0
xubuntu-core 2.206
xubuntu-default-settings 16.04.6
xubuntu-desktop 2.206
xubuntu-docs 16.04.4
xubuntu-icon-theme 16.04.2
xubuntu-live-settings 16.04.6
xubuntu-wallpapers 16.04.2Egyébként ugyanazokkal a repositorykkal dolgozik, mint a Mint XFCE, csak a Mint-nek van pluszban saját repoja saját csomagokkal, így inkább utóbbiban van több csomag.
Rosa XFCE repo list:
deb http://ftp.energotel.sk/pub/linux/linuxmint-packages rosa main upstream import backport
deb http://extra.linuxmint.com rosa main
deb http://ubuntu.inode.at/ubuntu trusty main restricted universe multiverse
deb http://ubuntu.inode.at/ubuntu trusty-updates main restricted universe multiverse
deb http://security.ubuntu.com/ubuntu/ trusty-security main restricted universe multiverse
deb http://archive.canonical.com/ubuntu/ trusty partnerAzt nem tudom, hogy a xubuntu-desktop mennyivel több az xfce-desktopnál, nem használtam még a Xubut.
A legjobb választás talán a Lathronos Openboxos remastere, abban választható igény szerint az LXDE felület is. Lubuntu lesz ez is így azok kedvéért, akik nem ismerősek a témában.
ubyegon2
válasz Frawly #58177 üzenetére
Valahol ízlés és bizalom kérdése is.
Pontosan, ezért is használnak sokan Mint-et. Ha már a bizalom is szóba került, ugye a Canonical rendes volt, mert közreadta anno, hogyan lehet kikapcsolni az Amazon kémprogramját.
Azt a remastert nem ismerem, nem is lebeszélni akarok róla senkit, de mivel azt írta, hogy Openbox, azt én úgy értelmeztem, hogy Openbox only LXDE-s körítés nélkül,
Írtam egyébként, hogy az Openbox mellett választható felületként ott a LXDE is.
A többiben egyetértünk.
Ha már feltetted azt, és normálisan megy, azért ne bolygasd, mert valaki azt írja x. fórumon, hogy mégis Xubuntu legyen helyette, minimális a különbség a kettő között. Ismerkedj azzal, amit feltettél, használd azt, amíg lehet, és meg nem szokod rendesen.
Más a két disztró kezdő színe meg a MInt-ben a saját programok vannak, amik általában a disztróikhoz vannak. Persze van olyan ebben, amit az Ubuntusok nagyon nem szeretnek, például a Frissítéskezelő...
Frawly
válasz Frawly #58216 üzenetére
Előző hsz. folytatása, kicsúsztam a szerkesztési időből. Szóval Arch szinte minden téren a legjobb disztrók közé tartozik. Egy dologba tudok vele kapcsolatban belekötni, hogy sok program csak az AUR-os tárolóból érhető el, és ha fel akarod tenni, akkor előtte forráskódból fordul le minden (kevés kivétellel), egy kicsit lassú, körülményes ez a része, de ezt megszüntetendő csinálhatnának hozzá bináris user-tárolót, meg több fontos csomagot betehetnének a hivatalos tárolóba, de ezt feltehetőleg nem lustaságból nem lépik meg, hanem nincs elég csomagfenntartó az összes csomag rendszeres karbantartására. Az Uborkának, Debiannak, Mintnek ezen a ponton van előnye, azokban az alap tárolókban is több csomag érhető el, és ott könnyebb PPA-t hozzáadni. PPA-féleség van Archra is, csak nagyon kevés, nem népszerű, nincs elterjedve a használata.
kovaax
(Meg a többieknek is.)
-=- There's no place like /home -=-
ubyegon2
Alapból tartalmazza a firmware-t, ez jó lehet, bár az arcom mégsem ettől változik majd.
Némi fw itt is akad.
(#58219) kovaax
Ezek benne vannak a tárolókban, az AMD viszont már igencsak régóta van ott.
(#58213) Lathronos
Ez komoly lépés! Várhatjuk lassan az Archos remastereket?
(#58212) csixy
Ezt a bárkit hogyan érted? Bárki bárhonnan vagy hogy? Vagy, aki a géped elé ül?
ubyegon2
válasz Frawly #58244 üzenetére
Várjál, valamit félreértettél. Gyakorta előfordul, mint most is.
Egyébként amiket használok/tam, azokban úgy emlékszem telepítve volt a fw- free része, a non-free firmware-eket kell külön felrakni tárolóból, ahol benne van. Most hirtelen a Debian van előttem virtuálisan, ott látom, hogy így van. -
mirci18
válasz Frawly #58328 üzenetére
Köszi a válaszokat.
Jelentem sikerült üres jelszóval megoldanom a problémát.A laptop hűtés:
Régebben vásárolt sima hűtő pasztát használtam olyat amit injekciós tubusban árulnak.
de esetleg adhatok egy újjabb kenést neki egy frissebbel.
Mikor a gépet szétszedtem nem csak a ventillátort takarítottam le hanem kivettem az előtte levő műanyag lamellás levegőbeömlőt is ami 60 százalékban kb el volt tömődve.
Plussz levettem a rézhűtő csövet ami végigfut a gépen is.
Arra is gondolok nem e esetleg már a rézhűtő nem a régi kezd bedögleni vagy valamiért egyáltalán nem teszi a dolgát.Még egy kérdés mára.
Kikapcsolás és hibernálás.
Meglepődtem hogy a laptopot lecsukva nem hibernálja a gép magát.
Ha a hibernálásra lépek pedig nem hibernál hanem kikapcsol.
Közben megtaláltam a felfüggesztésre kell menni.
Másik.
Akárhányszor ki akarom a gépet kapcsolni bejön kikapcsoláskor a Mint logója de a gépet nem kapcsolja ki csak ha a bekapcsoló gombot hosszan nyomom.
Mi lehet a gond?[ Szerkesztve ]
Nincs annál gonoszabb ember mint aki az előtt jó volt de egy másik gonosz őt is gonosszá tette.-BSTH
Slownz
válasz Frawly #58334 üzenetére
Rufus-al írtam ki. Ez most a Deepin, a Solus megy rendesen, mióta a Bios-ban módosítgattam ezt, azt.
(#58335) ubyegon2: Igen, a Solus Gnome alatt tetszett meg, jobban bejön, mint a Budgie. Ha már Budgie, akkor 1000x Ubuntu Budgie, mert azt hellyel közel ismerem (mármint az Ubuntu-t).
mirci18
válasz Frawly #58333 üzenetére
Köszi a válaszokat.
Természetesen egy könyv mindíg van alatta vagy egy szilárd tárgy asztal stb hogy kapjon levegőt.
Újrapasztázom aztán ha nem megy akkor sem akkor marad a coolerpad.Nincs annál gonoszabb ember mint aki az előtt jó volt de egy másik gonosz őt is gonosszá tette.-BSTH
válasz Frawly #58377 üzenetére
az Xfce-nek van egy olyan fogyatékossága, hogy ha teljes képernyőre teszem az alkalmazást, akkor eltünteti az ablak körül a kereteket (ennek így is kell lennie), de a legfelső keretet meghagyja, mivel az az ablakfejléc része, és erre nincs workaround.
titleless_maximize a Settings Editorban
vagy
"Hide title of windows when maximized" a Window Manager Tweaksben.A kettővel ezelőtti hozzászólásomban a FF pont így van teljes képernyőn.
(#58378) csixy
Az ablakkeret itt jobb, a "start menü" és a "tálca" siralmas. Amúgy ne másoknak próbálj ezzel megfelelni. Ha neked tetszik, akkor mindegy, hogy xy-nak mi a véleménye róla.[ Szerkesztve ]
válasz Frawly #58384 üzenetére
Most már tényleg nem értem, mire gondolsz. Hol van a különbség a "felső keret" és az "egész ablakfejléc" között?
A thunar nálam így néz ki teljes képernyőn. Ott a menüsor, ami gondolom nálad az ablakfejléc. Firefoxnál csak azért nem látszik, mert jó arcok voltak és eltüntették, mert ott normális ember nem használja, de Alt-ra előjön.[ Szerkesztve ]
válasz Frawly #58393 üzenetére
Értem már; ez így fura. Olyan, mintha a GTK téma "hibája" lenne, mert én sehogy nem tudom előhozni, hogy ott bármilyen keret legyen, se teljes képernyőn, se máshogy. Illetve valószínűleg nálam is van keret, de max. 1 px lehet, mert a nem teljes képernyős ablakoknál is nagyítóval kell keresni.
Azt viszont nem értem, hogy mihez kell a fejléc teljes képernyőnél. Illetve Alt+F10-zel leszedheted a teljes képernyőből és akkor egyből ott vannak a gombok. (amúgy meg Alt+F9 minimalizál, Alt+F4 meg ugye bezár, szóval mindenre van shortcut)
csixy
válasz Frawly #58397 üzenetére
Már felraktam a Manjaro i3-at. Addig eljutottam , hogy lett 1 firefoxom. xfce beállítót töltöttem le. Nem adom fel. Ez a felület nem az én vinnyózos előéletehez lett kitalálva de majd meglátjuk. Jólenne megtalálni benne ,hogy hogy lehet teljesre magyarítani , meg kireszelni belőle az angolt. de majdcsak rájövök lassacskán.
A proci 70% környékén jár , a firefox néha felküldi 100%-ra. A RAM 700 mega környékén használódik.Kert, kütyük,munka,matek,morfondír...ennyi. Szóval ács nem vagyok, de nemrégiben sikerült faragnom egy mőködőképes fogpiszkálót.
BoB
ubyegon2
válasz Frawly #58426 üzenetére
Követem majd a példádat ebben, namechange is lesz, de nem árulom el/őre. te/tő vagy hasonló. Egyedi arcképre egy darabig nem pályázhatom szerintem.
Lehet az ő gépében valami nem szabványos USB3-vezérlő van, amihez a kernelben nincs driver.
Létezne ilyen USB driverban is? Ez elég durva, ezek szerint USB 2.0 sebességgel kéne másolnia is. Na majd ezt megírja a kolléga.
batai15
válasz Frawly #58455 üzenetére
Nem tudom hogy nálam az unity műve volt e vagy nem, de anomáliák voltak. Néha veszettül belaggolt, vagy nem ébredt fel a rendszer, továbbá a tálcán "" ha le raktam egy progit nem akarta vissza nyitni.
Igazabol ennyi gondom volt, csak sajnos régebben brickeltem a telómat és vissza kelett rakni a winfost.
Közbe kiderült h szarakodik a vinyo és lehet amiatt van.
Most viszont teljesen át akarok állni Linuxra a biztonság miatt is. -
Frawly
Na, megoldottam ezt a Win 3.1-es felső ablakkeret dolgot IceWM-ben. Bár még mindig nem jó, mert nem tökéletes az ablakfejlécben a program nevének a pozíciója, kicsit mintha 1 pixellel fentebb lenne. Meg a Compton sem tud az ablakfejlécre átlátszóságot adni, mivel az ablak területének érzi, csak akkor lesz transzparens, ha az egész ablakot azzá teszem, de az meg nekem nem jó, csak a keretet és fejlécet akarom. Meg arra sem jöttem rá, hogy az IceWM-et hol lehet rávenni, hogy a tálca helyett az asztalra minimalizálja a programokat. Program Manager-t tudok imitálni PCManFM-mel, igaz nem 100%-osan, mert ablakon belüli alablakot nem tudok megjeleníteni úgy, ahogy a Windows 3.1 Program Managere használta.
Egyébként nagyon állat az IceWM, sokkal jobban testre lehet
szabnihekkelni a kinézetet, mint *box WM-ekben, LXDE-ben vagy Xfce-ben. Viszont ennek is van nyűgje, ahogy fent írtam, de majd megoldom őket. Elég jó témákat találtam hozzá, nem csak Windows 3.1, de Ambience (narancssárga Ubuntu-téma), BeOS r5 téma, klasszikus MacOS téma. -
válasz Frawly #58611 üzenetére
Bal a win,az újabb kép jobb oldali a Linux Mint. Viszont nálam minden linux ilyen volt. Ezért utáltam az összes. Majd még játszom vele,de ez nekem igy ronda. De tudtam ennél szebbet csinálni,csak az alap beállítás szörnyű.
Png-re sose figyeltem. Majd legközelebb úgy mentem.
ubyegon2
válasz Frawly #58614 üzenetére
Van akinek passzió, van akinek kihívás az fstab, egyébként rejlenek még abban bőven szívások, ha systemd, ha nem. a másfél perces bootkésleltetés például, ha nem találja a swap-ot meg hasonlók.
grabber
Infinality fonts simítást kipróbáltad?
(#58625) BoB
Akkor minek van ez a topik? OK.
Frawly
válasz Frawly #58642 üzenetére
Kicsúsztam a szerkesztési időből. Elírtam, az első fájl ~/.Xdefaults helyesen. Nálad attól is függ, hogy milyen felületet használsz, nekem azért kellett ilyen fájlokba beleszerkesztenem, mert minimalista ablakkezelőket használok (Openbox, IceWM, i3wm), de ha nálad rendes asztali környezet fut (KDE, Gnome3, Cinnamon, ilyesmi), akkor abban van rá külön grafikus felületre kivezetett beállítás.
ubyegon2
válasz Frawly #58733 üzenetére
Fura ez az FSTAB iszony nálad. Én mindig piszkálom az első pillanatoktól kezdve, de az általad említett modern disztróknál is ugyanúgy kell, mert a fájlkezelőben ugyan kattintásra csatolódik, de azt a leghipermodernebb disztró sem fogja tudni, mit akarsz auto módban csatolni.
Nekem példuel van egy külön partícióm torrentek néven meg más partició is van, amik nem működnének böngészőből kattintva automatikusan, ha nem lennének felcsatolva FSTAB-ban.
Szerintem pont jó, ha mindenki megismeri az FSTAB adta lehetőségeket, automount, különböző opciók.....Ritka esetben a discard opció sem tökéletes (blacklist view, gyakori nagy fájlokkal végzett műveletek), de Te ezt jobban tudod nálam, ebben az esetben nem árt, ha tudja az ember, hová nyúljon. Kezdőnek minden új, de néhány minimum szintű dolgot azért ismerni érdemes.
A torrentjeim egyszer újra kezdték tölteni az állományokat, mert nem figyeltem az FSTAB-ra és a Debian pont nem oda csatol, ahová az Ubuntu/Mint. (/mnt - /media)
szerintem
ubyegon2
válasz Frawly #58736 üzenetére
A régebbi disztrók hiányosságaival kapcsolatban igazad van, anno nulla tudással kellet megoldanom a még NTFS HDD csatolását torrentezéshez, nem volt egyszerű, ezek ma már nem okoznak gondot. Az FSTAB-ot meg az SSD vásárlása miatt ismertem meg anno, akkoriban nem volt semmi opció erre a disztrók FSTAB-jában.
Ez a fat TRIM nemrég volt is téma, most nem ugrik be, de elsőre nekem a discard tűnik gyanúsnak, hogy nem működik. valószínűleg keverem most ezt, ezt teszi az inaktivitás
Flowtation
No én tényleg nem értek hozzá, de én mindig berakom az nfs megosztásokat (omv) az fstab-ba, mert nem jelenik meg auto a fájlkezelőben. Ráadásul pont manjaro alatt van gondom, mert a sima fstabos bejegyzések ott nem működnek. Olvastam sokat utána, pont manjo alatt már mehet a systemd-s felcsatolás (bármit jelent is ez), de nem tökéletes. Szóval, egy szó mint száz, nekem az fstab csatolás olyan mint win alatt a hálózati meghajtó hozzáadása, egyszer kell aztán jóvan. Tudom azt is, hogy el kell felejtenem a wint, csak az összehasonlítás végett írtam.
De akkor, hogyan oldanád meg az én helyemben ezeket? Ha kell, adok részleteket is. Tényleg nem kötekedésből kérdem.
Keresek: D-link covr-1102 2 pack routert.
agy73p
Akármelyikőtöknek is van igaza, köszönöm az infót.
Én csak ilyen egyszerű instrukciók alapján tudom megoldani a problémáimat, sokkal bonyolultabb már nem mindig megy.@CPT.Pirk: miért pont /mnt/....? ..... és hogy állítottad be?
Én tegnap a /media/.... útvonalat határoztam meg (mielőtt kérdeztem volna ), ma meg már automatikusra állítottam, hagyhatom, vagy jobb lenne /mnt/... ? Valamint, ha átállítom, hogy tudom az előző parancsot visszacsinálni?Még egy megjegyzés a parancsokhoz:
tudom, hogy nagyon sokat kéne olvasni, jegyzetelni, memorizálni, gyakorolni ezeket, de nem minden héten fordul ez elő nálam (sem) és mire legközelebb szükségem van rá, megint utána kell néznem vagy kérdeznem.
Ezt most elmentem.
Szóval, amit akartam mondani, hogy sokkal könnyebb lenne, ha például tudnám, hogy a chown és a -R miért pont az, ami.[ Szerkesztve ]
Tails111
válasz Frawly #58794 üzenetére
Jól gondoltad a HPLIP és HPLIP-GUI csomagokat kellett telepíteni, azokban a szkennert beállítani.
Ezt meg is csináltam. Viszont ahol az eszközt be kellett volna állítani ott sajnos nem látta az eszközt.
Kezdőként balfékként tovább olvasgatva keresgélve a témát ráleltem a Simple Scan ott van az orrom előtt és ez felismeri és használja is. Funkcionálisan jól használja de a képminőség lehetne jobb. Akad pár beállítási lehetőség próbálgatom. Jóformán csak dokumentumokhoz használom.
Milyen program ami... [link]
- Vélemény Ubuntu 20.04 LTS
- Tudástár MX-Linux 19
