- Íme az új Android Auto!
Skull and Bones - Egy hétig ingyen játszhatunk vele
gp Az önjelölt kalózok ránézhetnek az Ubisoft játékára, hátha valaki úgy dönt, hogy megvásárolja azt.
The Division 2 (PC, XO, PS4) összefoglaló
5150head
válasz s4hu|SyD^ #15819 üzenetére
Nem lesz erősebb, csak NY-ban, de ott mindenki 40es lesz szval... E-Penis lesz max.
"To minimize the division of playerbase, any level 40 player will be able to join level 30 activities with level scaling." Forrás: [link]
Az a kérdés, h a WoNY-os exok mennyire lesznek OP-k. -
Anonymus23
válasz s4hu|SyD^ #15877 üzenetére
Igen, köszönöm valami ilyesmire gondoltam.
Ha valakit érdekel egyébként az 5 TIER feltételei
ST1
* Set enemies on fire - 10
* Kill enemy Scorschers - 10
* Kill enemies closer than 7m - 20ST2
* Defeat "The Wildfire" in Rooswelt Island after destroying her fuel tank on Normal or higher difficulty
* Neutralize named enemieswhile they are afflicted by status effect - 3
* Apply 2 status effects to a single enemy before defeating them - 3
* Complete the Manning National Zoo Mission againts the Outcasts on Normal or higher difficultyST3
* Eleminate "The Bloodhound" in the Federal Emergency Bunker after applying the bleed effect to him on Normal or Higher difficulty
* Kill elite enemies while they are inflicted with a status effect - 5
* Kill enemies while you are burning - 5
* Kill named enemies using your sidearm - 5
* Complete the Space Administration HQ mission againts True Sons on Normal or higher difficultyST4
* Neutralize " The Corpulent" in the Potomac Event Center after destroying his ammo pack on * Normal or higher difficulty
* Elemintae enemies with melee attacks using the ballistic shield - 5
* Salute a burning enemy before killing them - 3
* Kill named enemies Using skills - 5
* Complete the DARPA Research Labs mission at the Pentagon on Normal or higher difficultyST5
* Destroy the XB-31 "Marauder" in The Pentagon mission on Normal or higher difficulty
* Neutralize Milla "Wyvern" Radek in the Tidal Basin Mission after blinding her twice on Normal or higher diffculty
* Eliminate elite Scorcher enemies - 10
* Eliminate named enemies while they are bleeding - 5
* Complete any invaded stronghold mission on Hard or highher difficulty;) - The Power of the Light Side
Pferi
válasz s4hu|SyD^ #15922 üzenetére
Akkor az egyiket szerintem felboostolhatod (de szép magyar szó... ) lvl30-ra.
Egyszer használatos szerintem a boost.[ Szerkesztve ]
Gigabyte B650M DS3H ; Amd Ryzen 7 7800X3D; CoolerMaster ML 120 Lite ; 2x16 Gbyte Kingston DDR5 6000MHz; Asrock 6900XT OC Formula; 2 Hdd 2 db SSD ; FD ION + 2 Platinum 860W; CoolerMaster HAF XB ház
Pferi
válasz s4hu|SyD^ #15929 üzenetére
Ha már előrendelted New York-ot, akkor játékon belül a Store részen van a Boost menüpont.
Anonymus23
válasz s4hu|SyD^ #15997 üzenetére
Meg hozzá kell adni egymást a recruit oldalon
Ez mi?
Konkrétan kaptam egy emailt a sráctól, hogy Invite-olt engem (friend listáról), azon a linken keresztül megvettem a játékot egy üres accra, amit be is aktivált arra az accra az Ubi, be se kellett lépnem azzal az accal ott a vásárlásnál.
Letoltunk 6 küldetést, de semmi.Ok, közben meglett....
Anonymus23
válasz s4hu|SyD^ #15999 üzenetére
Megcsináltuk a 3 küldetést, ki is írta, hogy 3/3, de nem volt skin, de akkor ezért nem jelent meg
Kissé véleményes volt, mivel előtte letoltunk már 6 küldetést, és 1:25 játékidő volt már az accban, de 1:51-re meglett a 3 küldetés. Mondjuk erről a 2 órán belüli játékidőről én nem láttam semmit a leírásban.;) - The Power of the Light Side
- = Zk = -
válasz s4hu|SyD^ #16028 üzenetére
értem, köszönöm..
mondjuk ennek is az lesz a sorsa számomra, mint a Div 1... végigmegyek a sztori vonalon és ennyi... 1-2 mellék küldi és ágyő... szigorúan PvE..." Persze, ha elég ideig torzítasz egy "nézőpontot" akkor előbb-utóbb találsz hozzá igazságot. " , "A minőséget meg kell fizetni,minden másra ott az AMD!!! " " Pontosan. Különben is, akkor jó, ha nekünk jó. Ha mindenkinek jó, abban mi a jó" by Zebra
Anonymus23
válasz s4hu|SyD^ #16241 üzenetére
Nekem tegnap meglett mind a 4 karin a 165 pont az utolsó specializációhoz is.
* Heti bounty-k (a 7 bounty fixen ad 27 pontot 4x3+3x5) ez a leggyorsabban összeszedhető
* Heti invaded küldetések
* Field cache ládák fixen
* Napi challange küldetések (igazából csak akkor ha jó a loot, vagy szereted az adott küldetést)
Ezen kívül a heti projektek is adnak elvileg hármat, igaz nem írja a rewardnál, de amikor feloldod őket, akkor meg a jutalom listában benne van, ezeket nem feltétlenül éri meg csinálni (befektetett idő több mint egy heroic küldetés, ami pl fixen ad egy field cache-t az összegyűjtött XP-k utzán), de ha úgy hozza a feltétel lista, hogy pont azokat is teljesíted, akkor meg lehet csinálni.;) - The Power of the Light Side
arnikusz
válasz s4hu|SyD^ #16269 üzenetére
Azért nem kell ajnározni őket majd működjön minden ne legyen lagghalmaz, fps drop, a Chameleon is essen max sebzéssel ne legyen bugos stb....
Tényleg körkérdés az első 2 napot követően esett valakinek hétvégén vagy a héten Chameleon.Soha ne azonosulj a legyőzöttekkel
Pferi
válasz s4hu|SyD^ #16296 üzenetére
Ezt én is tapasztaltam. DARPA-ban a végső csatánál szarrá lőttek, amit eddig simán megoldottam.
arnikusz
válasz s4hu|SyD^ #16368 üzenetére
3 szettet hagytam meg 1. AR-EB 30.5k, SWolverine 27.7K 190.K armor 239K heal.
2. Aces tank, 3. Gunner tank. A stasht kiürítettem az 1. Alton van 50 szettelem, fegyverek és 83 mód. A 2. Alt farmolós, a 3. HC Alt sniper a HC Raidre.Alapanyagok a maxon, még Providence-ből kell feltoni 80-ra.
Ami nagyon fontos és ne feledkezzünk meg (mert az ördög nem alszik) a szettelemekből és a skillekből a módkat legkésőbb jövő hétfőn kivenni.
Anonymus23
válasz s4hu|SyD^ #16389 üzenetére
Textiles-ért szinte minden beszerezhető, nekem hiányzott még pár cuccos.
Korábban szerencsére XP-t adott az apparel láda nyitás, lehet szintezésre használni, de most már Textiles-t kapsz és ezeket a kozmetikai cuccokat (a signautre festésen kívül) be lehet szerezni textiles pontokért is.
Még mindig van vagy 650 kulcsom, nyitásonként 40-110 Textiles pontot szokott adni, a legdrágább cuccos is 600 Textiles pontba került.;) - The Power of the Light Side
FireKeeper
válasz s4hu|SyD^ #16423 üzenetére
én nagyon tartok ettől az egész lvl30-lvl40 majrétól. kicsit magam ellen beszélek, meg mindenki ellen aki megvette vagy megveszi a kiegészítőt, de ha a teljes játékosközösséget nézem, az lenne a korrekt a devek részéről, ha előbb vagy utóbb a lvl40-et elérhetővé tegyék mindenkinek. a kieg tulajoknak meg maradna NY-exkluzív az összes új brandset, gearset és exotic.
steam, GOG, uPlay: @petermadach || HotS: PeterMadach#2675 || Xperia 10 V || Ultrawide & SFF masterrace || Unofficial and unpaid VXE R1 shill
#75376384
válasz s4hu|SyD^ #16455 üzenetére
en se varok el nagy dolgokat, de basszus tenyleg semmi olyat nem csinalt, amitol azt gondolnam ez egy marha okos, kegyetlen, foboss. valahogy ugy tunik az irok amikor kitalaltak valamit es nem tudtak megmagyarazni, akkor rakentek erre a makira, hogy az is az o osszetett tervenek a resze. jobban belegondolva meg ez is bocsanatos bun lenne, de kozben miert kellett ennyiszer elmondani, hogy o milyen agyafurt etc? megolte a karaktert.
Anonymus23
válasz s4hu|SyD^ #16485 üzenetére
Hát ahhoz képest, hogy volt akinek kiesett a fullos cuccos első lootként, te meg farmolhattál egy cuccért éveket és még akkor is talán, ahhoz képest bármi, ami díjazza a befektetett időt az jobb.
Azért ez még messze van a no life addikciótól;) - The Power of the Light Side
Anonymus23
válasz s4hu|SyD^ #16550 üzenetére
Neutralize " The Corpulent" in the Potomac Event Center after destroying his ammo pack on Normal or higher difficulty
Ezen nincs mit szépíteni szétlövöd az ammo packjét mielőtt megölöd, érdemes egyedül csinálni a küldetést, vagy ismerősökkel, hogy ne lőjék le előtte.Eleminate enemies with melee attacks using the ballistic shield (x5)
Lelövöd szinte nullára a mobot, előkapod a shieldet és leütöd.Salute a burning enemy before killing them (x3)
Először is érdemes valamelyik gyorsbillentyűre tenni a szalutálást, lángszóróval meggyújtod a mobot, ha még nincs meg, mivel csak most unlockolod, akkor a Potomac pont jó erre, a Molotovos tatyóját kilőve meggyullad, mehet a szalutálás és utána a kill.Kill named enemies using skills (x5)
Küldetések alatt (Potomac, DARPA) skillel kinyírod a bossokat, ha jól tudom neked van hive+seeker, arra mindre beadja. Ha nem adná mindre, vagy nem sikerül, akkor egy vagy több gyors bounty.Complete the DARPA Research Labs mission at the Pentagon on Normal or higher difficulty
Ezt végig kell tolni, vagy MM, és ha szerencséd van, akkor a végére dob be valakihez;) - The Power of the Light Side
Anonymus23
válasz s4hu|SyD^ #17182 üzenetére
attol felek, hogy megint rossz iranyba fognak azok a javitasok menni.
az egesz hiszti kezdodott azzal, hogy sokat kell loni a mobokba. majd ezt osszemostak a fenti dolgokkal, amiket en is irtam.
a vegen pedig megint ott fogunk tartani, ahol kieg elott. ugye volt mar ilyen a div2 korabban is. akkor nerfet kapott a tuz es ezt az rusholos mob dolgot is orvosoltak, kozben szepen letekertek a mobok hp-jat is.
kozel sincs maxos buildem (a melleny es a taska pl kraftolt ), de a challenge mar-mar olyan szint, mint korabban volt. csak most a fenti hibak fennallnak, ami inkabb frusztralo, mert nem lehet ellenuk semmit se tenni.
arnikusz
válasz s4hu|SyD^ #17432 üzenetére
A játékstílusodnak megfelelő.
Komolyan Negotiators D., True Patriot, Striker-ha ügyesen célzol, CHC/CHD build 3Providence, 1 Ceska, Exotic maszk, meg még egy az Overlord térdest látom. Végül skill healer tactician ha csapatban, ha alone akkor Seeker és Hive.Soha ne azonosulj a legyőzöttekkel
dvd24
Amit a legkönnyebb összeszedni az 3 providence, 1 ceska, 1 grupo sombra és egy fenris vagy petrov, attól függően, hogy AR vagy LMG párti vagy. Én a petrovot javaslom egy fasza MG5-el.
Mindenhol piros legyen, addig pakold magadra a CHC-t amíg minimum 55% megvan, aztán mehet minden CHD-re.
