Phone calls, data communication
I had no problems during phone calls; both sound volume and quality were all right. The phonebook is the default one from Windows Mobile, it has countless extra fields for contacts, whose number is limited by the memory, so the number is quite close to infinite.
The device has nothing to be ashamed of in means of data transfer technologies. Only HSDPA misses from the list. The fastest available is UMTS. Near 802.11b/g WiFi-compatibility there is support for Bluetooth 2.0 (with A2DP – stereo sound for BT) and IrDA. The USB port is also of version 2.0.
Outlook is responsible for message handling. It supports MMS and email messages, the client can handle authenticated IMAP servers and attachments too.
