O2 XDA Flame - graphically accelarated
Hardware, operating system
As I have already mentioned, Flame is a bit old guy now and this can be seen on the OS: Windows Mobile 5.0 for Pocket PC Phone Edition. It is said that WM 6 Professional is also available, but only unofficially, so installing it leads to the warranty becoming void. Fortunately the hardware compensates for this nuisance: 520 MHz Intel XScale PXA270 CPU, 128 MB RAM, 2 GB ROM (user space: 1720 MB for storage, 82 MB memory), GoForce 5500 graphic accelerator. This is typically the wow category; it’s worth being called a unique phone. As for games, the nVidia graphic chip is not the best choice and for energy saving a PXA310 processor would have been better, but anyway, the brute force is still given, so the overall picture is just fine.
After turning it on I sadly observed that the system is not as fast as I would have expected it to be. There is no problem when scrolling in the main menu, but starting up applications takes up quite a time, even returning from standby lasts 2 seconds. Unfortunately speed tests further support my statement.
Pocket PC Mark v1.03
Dhrystone Benchmark (CPU)87,82 MIPS
Whetstone Benchmark (CPU)1,40 MWIPS
Memory Benchmark282,67 points
File system Benchmark33,56 points
Graphics Benchmark66,65 points
Looking at the results of Asus P735, equipped with a similar processor, Flame’s results are disappointing. We’re not talking about a few percents of difference – the processor is three times slower, the same is true for the memory, the file system and unfortunately for the graphics performance too: what does the GoForce do, may we ask by right. I can only hope that only optimization – that is the lack of it – is the trouble, which can be corrected with a newer ROM, but I could not verify this.
Városi közlekedés új formában: mit tudnak a modern rollerek?
PR Egy új elektromos roller kiválasztása jóval összetettebb döntés annál, mint hogy milyen gyorsan képes eljutni vele valaki A pontból B pontba.
  • O2
  • HP iPAQ 214 - it's been time
    HP made a daring move: no matter the popularity of combo devices, they have released a classic PDA. They did it well.
  • HTC Shift - hotshot
    HTC's first UMPC contains the hardware of a PDA too, so it can function in two modes. It's interesting, that's sure.
  • Asus P750 - VGA and not
    The high-end Pocket PC from Asus has a VGA display, but the OS doesn't use it.
  • LG KS20 - PDA in the phone
    LG did it: they crammed a fully functional, advanced Pocket PC in a case the size of a cell phone. And it's without trade-offs.
  • HTC Panda - the mistake
    HTC's model with a large display is basically not a bad handset, but its price is not tailored to its features. Absolutely not.
