Battery, summary
The battery, labeled HTC Innovation, has a capacity of 1150 mAh and it can be swapped out. This power is unfortunately not enough for Android, it didn’t take it for even a day at me, but of course I’ve been tampering a lot with it, the WiFi was turned on lots of time, and I’ve been talking about one-one and a half hour every day. According to factory data talk time is 5 hours and 20 minutes, I think this is completely unrealistic, but I think G1 can take it for a day when not using the WiFi.
Summary: first we should make it clear that when rating the handset I practically rate Android itself, as this is the first handset with such a system. Of course we could abstract from this and then I’d say that G1 is a well-assembled, large and ugly handset that sports a great screen, an awesome keyboard and robust hardware. And then add Android. Android, which is new, a bit immature, but I think it’s very promising. Unfortunately I just have to compare to iPhone’s operating system, as it’s about that fast, it’s easy to use and it’s hard to make things go wrong. There is still one important different: it’s easier to develop software for it and opposed to Apple, Google is a great supporter of developers. I am sure that in a couple of months we will have tons of good and better applications, and I also trust that one of the manufacturers will launch a handset with a better design that might even have a good camera. I’m happy that you’re here Android.
| T-Mobile G1 |
Bocha
Translated by Szaszati
The handset has been provided by www.speedshop.hu, thanks.
