Nokia 5130 - Express second class
Battery, summary
The fastest data transfer methods supported by the handset are GPRS and EDGE, unfortunately there is no 3G or HSDPA support this time. The default browser on the phone is Opera Mini, which is a great thing, although it could have used some higher speeds. There are a couple of apps that require internet connection, these would all be much better if the phone would support some kind of high-speed internet access.
Nokia 5130 XpressMusic
The BL-5C battery in the handset should keep the music player online for up to 2 hours (based on the specs), but the normal standby time isn’t bad either. In my case the phone was online for three days with one charge, which is not a bad result, considering the above average use. Altogether I think that being the little brother of 5310, and having a pleasant price-tag, the phone can be a real success, so I can say that I recommend it.
Gubro
Nokia 5130 XpressMusic has been provided by XXL GSM. The handset can be purchased at:
Budapest VI. Jókai tér 6.
Budapest VI. Teréz körút 18.
On-line at www.xxlgsm.hu.
  • Nokia
