Data transfer, battery
3610 supports only GPRS and EDGE, there is no 3G. We might list the manufacturers who didn’t omit this for this amount of money (but it might be enough to say: Nokia 6151), it’s a pity. We might use the built-in browser, but if the Finnish guys have installed Opera Mini, we shouldn’t be using anything else.
At local level we can theoretically connect via microUSB 2.0 or Bluetooth of the same version. I have used this latter one, I have managed to achieve a copy speed of 40 KB/s. But there is a surprise waiting for us under the cover, as 3610 fold (let’s finally call it at its full name) has a 1020 mAh Li-Ion battery, which is powerful enough to keep this folding monster alive for 3-4 days without a problem.
Summary? Should I get into details? A big pile of nothing: inside and outside. It doesn’t even look good. It doesn’t have anything extra, it lacks a lot of small features (FM radio, normal headset, data cable, maybe 3G), but at least the battery can take it for long. It’s a completely meaningless, gray, boring handsets, I hope I won’t even remember it in a couple of days. There’s no reason why I should.
And it’s not even cheap.
Bog
Translated by Szaszati
XXL GSM
