Hardware, speed, data transfer
The operating system is Windows Mobile 6 Professional which runs on a 528 MHz Qualcomm MSM7200 CPU, along with 128 MB RAM and 256 MB ROM. There is 49 MB free for running programs and 127 for storing data, this latter one of course can be expanded with a microSD card, the slot is SDHC-compatible.
Now would be the time and place for the speed tests… unfortunately the small ET was no good friend of ours. I understand this partially, VsBenchmark has probably been confused by the screen that works only in 800 x 480, it cannot be rotated. It’s another question why didn’t Pocket PC Mark run; let’s just say that it’s because Anton Tomow’s software is nothing up to date. Knowing these I can only have a subjective opinion about the machine’s speed. Well, it’s medium. We unfortunately have to wait most of the time for screen changes, scrolling is not perfect either, which is probably due to the high-resolution display. Fortunately there were no problems with running applications, at least when they launched.
The stylus is on the left
The GSM module is tri-banded (900/1800/1900 MHz), but we can use the handset on third generation networks too. The fastest data transfer mode is HSDPA, WiFi is 802.11b/g compatible. There is of course Bluetooth too, version 2.0 and it supports A2DP. There is a built-in GPS receiver, I could find my position with it, speed is medium, but I had no iGO on a microSD card at me at the moment, so I couldn’t test navigation. Anyway, G910 is not the best choice for such things, due to its size.
