Samsung F700 - do not scroll
Data communication, battery
The engineers of the Samsung surely made this big display for browsing. At least, I was thinking about it, when I set up the application, which can handle GPRS, EDGE, UMTS and HSDPA networks to display the sites. Well, it has no essential mistakes, but it dismissed the flash banner of our homepage to the top left corner of the screen, we still haven’t seen a phone doing the same. It only makes problem in horizontal case, if the phone is closed, it breaks to page-width automatically.
We can adjust the size of the page to fit for our taste, the display is wide enough to handle the Mobilarena in its whole width with readable letters. So we can admit that the browser is very good in this phone, it doesn’t have too many points to argue with, perfect for surfing on the internet, but the user has to get used to the slider buttons.
For local data transfer 2.0-s Bluetooth (stereo, of course), or USB with the same version can be used. We got cable for the phone - not surprisingly – there is a menu item in the set up where the connection mode can be set: work with the Samsung PC Studio or as modem or storage. In the last case, only the contents of the memory can be seen by the operating system.
The battery bore surprisingly long. I used the phone a lot as usual however it stood 3 days, I wouldn’t be surprised if it could bear 4-5 days with light usage which is a nice performance from a phone with a big display like this.
It’s difficult to write summary about the F700. I kept it till the end of the test time, it’s perfect for writing messages and browsing, can be used well in common usage, but far from perfect. The user would like to bring it down especially when there is no room on the display for a part of the user interface so scrolling is required. The Korean engineers simply couldn’t make it correspondingly, and it really ruins the menu system which is thought over otherwise. A lot of ideas and I think a lot of working hours are in the F700, the direction is good, look on it as a first step.
Samsung F700
