Communication, battery
The phone has an own-standard connector, this is for charging USB synchronizing and for using the headset too. The question evidently comes up: how can I charge and listen to music at the same time? This is why the manufacturer attached a mini docking station, which is a curved metal plate, the Serenata sits on this. A cable mender from this which has a really simple switch on the end with 3 connectors: one for the charger, and other for the USB cable, and the third for the earphone. These accessories can be connected to the phone directly, docking station is only needed if you want to use more than one of them, or if you wanna be cool, because the Serenata standing oblique on the table looks very good.
The USB is version 2.0, the mode of connection can be set in the menu. In storage mode, the whole, 3,8 GB memory is detected my the OS as USB storage, but the synchronizing of the contact list and messages requires the old Samsung PC Studio to be installed to the computer. The built-in Bluetooth is version 2.0, it has stereo voice transfer ability. It could synchronize itself with my pc without and problems, but it had a bit with my car-speaker: when I started the call, it transmitted the call, when I was called, it didn’t.
The communication with mobile networks can be any of GPRS/EDGE/UMTS/HSDPA, so there is no cause to complaint, but it’s typically the phone that I wouldn’t criticized if it hadn’t have 3.5G. Anyway, it’s included, and browser belongs it, it has much to work with because it fragments the sites and gives no opportunity to overrule. It this case, we usually suggest Opera Mini, but this is cancelled now because the Serenata doesn’t support Java standard, so no further applications can be installed.
The battery worked two days for me, naturally I talked a lot on it (maybe I don’t have to mention that the sound quality is excellent in this case too), and my acquaintances nagged it a lot, it could stand 3 days it relent usage. When the battery is going low, the phone decreases brightness as every Samsung does, no music playing in this case, this is the "look for charger" message.
Totally I have to say that this model became much better after the Serene. Of course, I wouldn’t like to have it for everyday usage, too extreme (and the universal car holder can’t hold it, because this rounded whale simply falls from it) and the text entry is important for me. Cool, flash stuff with outstanding sound quality, materials, exclusivity and price. You won’t meet it on the street.
Bog
Translated by EQMontoya
