Battery, conclusion
The battery has a capacity of 1050 mAh. The low-consumption CPU and the lack of WiFi provide an uptime of up to two days with one charge, although this is highly influenced by the amount of phone calls.
Summary: Toshiba Portégé G710 is not a very compelling one. Its design is okay, it’s really easy to use, but it’s tragically slow which is not acceptable. The number of features is quite low, the manufacturer probably wanted to make the handset more attractive with the GPS receiver, but thanks to the Windows Mobile Smartphone system this is a failed try, this is not the best platform for navigation, let’s just say there’s no iGO for it. And then there’s the €350 EUR gross price, which is a lot, no matter the GPS. Asus M530w costs about €250 EUR nowadays, and if someone really sticks to this platform then he should go for that one. There’s no award.
Bocha
Translated by Szaszati
The handset has been provided by MobilX.
The device can be purchased online at www.mobilx.hu.
Info line: +36-52-501-868
