Samsung M8800 Pixon - 8 megs of touch
Battery, summary
The battery has a capacity of 1000 mAh, and it can be changed. I can say the same thing as for all similar handset: it can keep the handset alive for two days at most (depending on use), but if we use lots of multimedia features we will surely have to charge it daily.
Samsung M8800 Pixon
Summary: it’s inevitable to compare Pixon with its great rival, Renoir. Well, the difference between the end user prices of the two handsets is about €60 EUR. From Samsung we get – theoretically – a better design and higher quality materials. It would be no use looking for huge differences between the menu systems, both are sluggish sometimes, but they are basically good, easy to use and user friendly. We shouldn’t forget that Pixon has no WiFi, and Renoir has it, not mentioning that Samsung’s phone, even though it has some serious software lacks, takes some really crappy pictures. In spite of this Pixon is not a bad handset at all: the software bugs will hopefully be patched soon, maybe the camera will improve a bit as well, so it might become better. Still, in its current state it doesn’t deserve the recommended award, so let’s stick to this one:
Samsung M8800 Pixon
Bocha
Translated by Szaszati
Samsung M8800 Pixon has been provided by XXL GSM. The handset can be purchased at:
Budapest VI. Jókai tér 6.
Budapest VI. Teréz körút 18.
On-line at www.xxlgsm.hu.
