Exterior
The red and white box is surprisingly large so the phone, the charger and the headset have quite a lot of room inside. There is nothing else besides some papers, so it’s time to take out the handset which is absolutely boring at first look, but at least it’s small. We’ll have a very simple, grey-black clamshell in our hands.
The cover’s shiny part is soft to the touch. In the center there is a monochrome display which displays only the most important information – continuously. It barely consumes any energy, but it’s practical. Under and above the small screen we can see Samsung and Vodafone labels, and on top of the front there is a small hole, which is the VGA camera, hooray.
There isn’t much stuff on the sides; on the left we can only discover the volume control keys, while on the right we can see the cover of the characteristic Samsung data connector. The back is highly boring, although the reticular material provides a pleasant grip. Neither on top nor on the bottom of the phone will we find anything surprising, as there is nothing here.
The seamlessly opening cover proves that there will be no problem with at least one thing, as the use of materials and the assembly quality are both okay. The keypad is also fine, nothing spectacular, it’s very logical, easy to use, the button labels are rather large and have a white backlight.
