HP iPAQ 914c - design flaw
Battery, summary
The battery is a fine example of the “oh my God!” category: it has a capacity of 1940 mAh. According to this, it’s really large; the 150 grams weight of the handset is due mostly to it. Uptime, however, will make up for this: 914c took it for three days, even though I’ve been talking a lot on it. This is an exceptionally great result for a Windows Mobile Pocket PC!
HP iPAQ 914c
Summary: HP iPAQ 914c is basically an exceptionally good handset. There are no problems with the number of features, it’s okay on both the hardware and software sides, it’s fast, it looks good and the uptime makes us pass out. And it’s also relatively cheap, at the moment of writing this review it cost about €465 EUR. Still, that rubber cover I’ve discussed in detail at the beginning is something I just cannot understand: why did they have to ruin such a great handset with such a small annoyance? This might be an exaggeration for many of you, but that hanging piece of rubber annoyed me a lot, mostly because we’re talking about a nice, elegant phone. Unfortunately this is not a unique case, but a design flaw, so all future users should decide if they can go on living with it. If it doesn’t annoy you, then I can really recommend the phone.
HP iPAQ 914c Business Messenger
Bocha
Translated by Szaszati
The handset has been provided by www.speedshop.hu. Thanks! To access the shop, please click here.
Integrált szervizrendszerrel forradalmasítja a piacot a TMX Mobile Solution
PR A Nemzeti Kutatási, Fejlesztési és Innovációs Hivatal támogatásával megvalósult Főnix rendszer egy olyan integrált informatikai platform, amely a mobilkészülékek aftersales életciklusát fogja át.
  • HP
