Destiny 2: The Final Shape - Befutott a fejlesztői videó második része
gp A minap kiadott videóban többek között a képességek kerülnek a középpontba.
Opel topik
dokar
bántották astrámat:
extra - SEXRay
dokar
ne tudtok adni olyan forrást ahol le van írva, hogy egyes opelekbe gyárilag milyen hangszórókat raktak be?
extra - SEXRay
dokar
helkis-el megnéztük, hogvy az astrám hol szabályoz le:
2-ben 95, míg 3-ban 140extra - SEXRay
dokar
válasz parandroid #2003 üzenetére
helkis-el próbáltuk a GPS-t, nagyon durva számokat dobott valszeg szoftveres probléma miatt
extra - SEXRay
dokar
sorry meg is találtam a választ
TwinPort variable intake geometry: twin intake ports with a choke closing one of the ports at low RPM, providing strong air swirl pattern for higher torque levels and better fuel economy.
Variable Length Intake Manifold (VLIM) is an automobile engine manifold technology. As the name implies, VLIM can vary the length of the intake tract in order to optimize power and torque, as well as provide better fuel efficiency.
There are two main effects of variable intake geometry:
Swirl: Variable geometry can create a beneficial air swirl pattern in the combustion chamber. The swirls help distribute the fuel and form a homogeneous air-fuel mixture which ignites without engine knocking. At low rpm, the speed of the airflow is increased by directing the air through a longer path with limited capacity (i.e., cross-sectional area), but the shorter and larger path opens when the load increases so that a greater amount of air can enter the chamber. In DOHC designs, the air paths are often connected to separate intake valves so the shorter path can be excluded by de-activating the intake valve itself.
Pressurization: A tuned intake path can have a light pressurizing effect similar to a low-pressure supercharger due to Helmholtz resonance. However, this effect occurs only over a narrow engine speed band. A variable intake can create two or more pressurized ''hot spots'', increasing engine output. When the intake air speed is higher, the dynamic pressure pushing the air (and/or mixture) inside the engine is increased. The dynamic pressure is proportional to the square of the inlet air speed, so by making the passage narrower or longer the speed/dynamic pressure is increased.extra - SEXRay
dokar
na koma itt a segítség:
én is a philips car400-at lg rádióra cseréltem, szoptam is vele rendesen, szal a következő volt a helyzet: az lg csatijából egy 2x4-es tömböt (3 tömbből áll) levágtam, hogy ne kelljen átkötni az egészet. utána a 3-ast és a 7-est (ha jól emlékszem a számokra) felcseréltem. aztán már csak egy érpárt kellett elvágnom, ugyanis, nekem leállt a motor az új rádióval. nem vicc, hihetetlen de igaz.
az antennához lehetvenni csatlakozó véget fillérekért
mellesleg én is alig tudtam betuszkólni a rádiót a helyére. több szerelő kellett hozzá.
kieg: mellesleg felvettelek msn-re
[Szerkesztve]extra - SEXRay
dokar
tegnap lett fotózva:
a legjobb az egészben az, hogy az enyémextra - SEXRay
dokar
extra - SEXRay
dokar
dokar
dokar
válasz bolondember #2117 üzenetére
hoppá az opel de odaver
''Az OPC Astráról nagyon is hihető, hogy sportos, élvezetes és különleges. Övé az első pont.''
nem hiába, az opel ismét alázza a rizsrakétátextra - SEXRay
dokar
vannak már infók az új Vectra D-ről? nagyon érdekel a téma.
2008-ban jelenik meg ha minden igaz.
ezek lennének azok?
továbbá: [link]
dokar
dokar
a régi km órám W=1102-es volt, a mostani W=1111. lehet, hogy ezért ennyire pontatlan?
extra - SEXRay
- fűnyíró traktor
- E-roller topik
- Multimédiás / PC-s hangfalszettek (2.0, 2.1, 5.1)
- Microsoft Excel topic
- Békésen legelészik a májusi hardvercsorda
