Bakancslista Route 66 Chicagótól Los Angelesig 3.
lo Sziasztok Olvasók! A harmadik rész immár elkészült egy kis betegeskedés után (mármint a jelenben sajna), és a múltban már teljesen gyógyultan folytatjuk utunkat az USA-ban.
OFF beszélgetős topic nyílt, a nem Battlefield 4 témákról kérjük, hogy ott beszélgessetek, ez a téma maradjon meg szakmainak! Cheatek a topikban szintén tiltottak!
Kérlek olvasd el mielőtt kérdezel, köszönjük!
@rglaaf
Zero-downtime Update, November 7th 2013
FEATURES & IMPROVEMENTS
New setting to automatically launch BattleScreen when a multiplayer game starts
Video background can now be turned on or off in Settings
Improvements to Quickmatch/Play Now that increases the likelihood of joining a populated server
Recommended Servers now link to the Server Info page
Soldiers on the Profile page are now sorted in the order of BF4, BF3 and Medal of Honor
The currently equipped Dog Tags are now shown for all soldiers on the Settings -> Soldiers page
Usernames in the Geo Leaderboards are no longer written in uppercase
Your soldier name and tag are now shown on Dog Tags everywhere
Vehicles are now better categorized in Stats -> Vehicles
You can now see emblem shapes you don’t yet have access to
Various minor improvements to LoadoutFIXES
Fixed an issue where Emblems could not be saved if too many users were saving at the same time
Marking a Battle Report as a favorite on the Reports page no longer highlights the report
Fixed an issue where Battle Reports wouldn’t always load on the Reports page
Fixed an issue where favorite Battle Reports would not show WON or LOST correctly
Menu in the tablet app now highlights the page or section you’re currently viewing
You can now see the kills for the selected vehicle in Stats -> Vehicles
BattleScreen now shows the G and H flags that were previously missing
Fixed an issue where sorting by score in Battle Reports didn’t sort correctly
Opening Battlepacks on Battlelog while playing will no longer result in an error
Added a scrollbar to Leaderboards in the in-game Battlelog overlay for PC, so it doesn’t go out of bounds
Fixed an issue where you couldn’t see all the maps and modes on the server on the Server Info page
The notice bar no longer breaks the menu on the Soldier pages
Fixed an issue where the 3rd recommended server would overflow in some browsers
Fixed an issue, where you wouldn’t return to the Profile page after viewing a Battle Report and pressing back
Forum signatures will no longer break the forum layout
Fixed various minor issues with LoadoutPSN:BiZzare_0 ️
@rglaaf
PSN:BiZzare_0 ️
@rglaaf
Azért egyezzünk már ki annyiban hogy ha valaki fel rakja az egere driverét vagy át bindel pár bill funkciót egérre az ne legyen már meghurcolva, a macró az teljesen más tészta ne keverjük össze
PSN:BiZzare_0 ️
@rglaaf
Szerencsére nem az a macro egy előre meg irt program sor ami módosit az egéren billen van olyan egér amibe már csak be kell illeszteni a driveren keresztül de van külső program is, azzal előnyt tudsz szerezni többek között lmg csinálsz egy 1 lövetű fegyoból nem kell kölön lenyomni a gombot stb és nincs az az anticheat ami szűri mert nem nyul bele a játék fájlokhoz
PSN:BiZzare_0 ️
@rglaaf
az emblémával vigyázzatok nehogy bant -kapjatok mindenki tudja gondolom miért járt
PSN:BiZzare_0 ️
@rglaaf
válasz LamaCube #19311 üzenetére
Dehogy
De azért jol tetted hogy levetted az emblémádatKotaku:How Battlefield 4 Battles Nazi Flags and Dick Drawings
PSN:BiZzare_0 ️
@rglaaf
Ez kell valakinek? kodot küldöm privibe
PSN:BiZzare_0 ️
@rglaaf
Az egyik pack találtam egy t-rex dogtagot
PSN:BiZzare_0 ️
@rglaaf
patch notes votmá?
PSN:BiZzare_0 ️
@rglaaf
válasz Gyula84 #20879 üzenetére
mán csak azé is berakom
PDATE #9:
PC Game Update Goes Live Nov 14
We are happy to report that the PC Battlefield 4 game update will go live tomorrow, November 14. The main focus of this update is threefold:1) Reduce the number of crashes
We believe this update will solve a large portion of the most commonly occuring game crashes, and the improvement in overall stability should make a big difference for many players.2) Eliminate a network sync bug
If you’ve been experiencing situations in multiplayer where it appears that you are taking damage from enemies through walls, you might have been the victim of a network sync bug. In this game update, we have identified and eliminated one such bug that caused this type of gameplay experience. We are continuing to work on more multiplayer optimizations concerning network performance.3) Improve Network Smoothing
We have made some improvements to the ”Network Smoothing” functionality that you can find in the OPTIONS>GAMEPLAY menu. The Network Smoothing slider governs a group of settings that aim to produce a tighter multiplayer experience based on your specific packet loss situation.If you’ve been experimenting with the Network Smoothing slider earlier, it might now yield better results. If you haven’t tried it before, please explore this setting and set it to the lowest value you can without experiencing graphical glitches in the game. By setting it lower, you can get a tighter multiplayer experience, depending on your specific network situation.
More details upcoming
Besides the above mentioned focus areas, this PC game update contains a number of other fixes and tweaks that we will detail once it’s live.This game update for PC goes live around 10AM UTC/2AM PST November 14. Your Origin Client should acknowledge and automatically download this update for you, as usual. Otherwise, you can right click your game in the client and select ”Check for Update”. There will be a Battlelog maintenance downtime for about an hour as this update goes live. During this time multiplayer on PC will be unavailable.
We will release full patch notes for this game update later, but the three items mentioned above are by far the most important changes in this update. We understand that stability has been rocky for some players, and hope that this update will make the game run smoother and more stable for you. Let us know in the comments below.
PSN:BiZzare_0 ️
@rglaaf
PSN:BiZzare_0 ️
@rglaaf
Ez a gunner incendiary ér valamit? mert be tettem de kb közelröl ugyan ugy dobálták ránk a c4-t meg a slam-t
PSN:BiZzare_0 ️
@rglaaf
válasz kriszpontaz #21864 üzenetére
jah hogy aktiválni kell az is külön gombal? remek
PSN:BiZzare_0 ️
@rglaaf
GeForce GTX 770/780/TITAN/780Ti:
Up to 50% in Metro: Last Light
Up to 26% in Crysis 3
Up to 18% in Battlefield 4
SLI Technology
Assassins Creed IV: Black Flag – updated profile
Path of Exile – added profile
Natural Selection – updated profile
3D Vision
Assassins Creed IV: Black Flag – "Good"
Gaming Technology
Enables GeForce ShadowPlay™ technology
Call of Duty: Ghosts – added TXAA support (disabled FXAA)
SHIELD
Enables NVIDIA GameStream™ technologyPSN:BiZzare_0 ️
@rglaaf
PSN:BiZzare_0 ️
@rglaaf
PSN:BiZzare_0 ️
@rglaaf
PSN:BiZzare_0 ️
- Microsoft Surface Pro 6 12.3" 2736 x 1824/i5 8350u/
- Legjobb ÁR!!!HP EliteBook 640 G9 Ezüst (14" / Intel i5-1235U / 16GB / 512GB SSD / Win 11 Pro)
- HP Probook 340S G7 i5-1035G1/8GB/256SSD/Windows 11
- MSI MAG274QRF-QD QLED Gamer Monitor!27"/2k/165hz/1ms/Freesync-Gsync/Type C/Konzolhoz is/Beszámítás!
