- Mobilinternet EU-n kívül, eSIM adatcsomagok használata
- uleFone Power
- Atlasszal készül a HMD a középkategóriába
OneSport OT05 - finomhangolás
ma Mit hiányoltunk eddig a kedvező árfekvésű kínai bringákból a leginkább? A nyomatékszenzort. A OneSport újdonsága végre megkapta ezt a megoldást.
Bezárt a Wizard With a Gunt fejlesztő stúdió
gp Alig kilenc évvel a megalapítása után sajnos feloszlott a csapat.
Házimozi belépő szinten
mikrofon
válasz VoidXs #59400 üzenetére
Minap futottam bele ebbe, mikor kerestem a DSP beállításokat a Yamaha erősítőhöz.
What is it?
A 'reference' level is simply a commonly agreed upon setup so that playing a source on multiple setups produces the same volumes, peaks and quiets. The most common one used for home cinema is based upon a 'peak' of 105db. This is the maximum which will be touched on with the loudest explosions (i.e. audio signal at 0dB). Most standard dialogue will be intended to come out around 85dB at these levels. (referred to as 20dB of 'headroom').
The master volume on most AV receivers is referred to as dBFS (decibels Full Scale) and goes from -80 to +20dB or thereabouts. This allows significant adjustment and in principle, the 0dB setting on your receiver plays the sound at the volume it is 'supposed' to be or at reference level. This guide helps you to confirm that 0dB on your receiver is at reference level.
Most home cinema receivers have a test tone of pink noise, which is recorded at -30dB relative to full scale (simply because listening to a test tone at 105dB isn't going to be comfortable). The principle being you can play the test tone, set your speakers to output 75dB at the listening point with a sound meter and this corresponds with a reference level of 105dB (30+75=105dB)
How do I do this?
The explanation below is for a Yamaha RXV-675 but the principle and instructions are much the same. This is all manual setup. It presumes you have already set the correct speaker distance, speaker sizes and crossover points if applicable. -
mikrofon
válasz VoidXs #59437 üzenetére
Az enyém annyiban tér el ettől, hogy +16,5 a maximum, amire fel lehet hangosítani. De ezt sosem próbáltam úgy hogy szólt rajta bármi. nekem a -25 tökéletes, ha nagyon hangosan szeretnék mozizni, mert senki nincs otthon. Azért -25 mert többhelyen találkoztam, azzal, hogy a Yamaha-nál ez a tipikus "sajátreferenciaérték". Tehát ez alatt kell minden féle olyan segéd lehetőséget bekapcsolni az erősítőn, amit arra találtak ki, hogy halkan is jól szóljon a Yamaha mérnökei által programozott hangképek DSP-k.....
Valójában én le is korlátoztam a max- értéket -25re.... -
mikrofon
válasz VoidXs #59441 üzenetére
Ezekre egyébként nincs hatással a bemeneti jelszínt? Vagyis hogy mi jön ki a média player-ből. Azt értem hogy a passtrought mód valójában egy az egybe tovább küldi a jelet a médiabox-ból de vajon ez nem függ magától a lejátszótól? Vagy ez is szabványos és független a lejátszó hardver?
Teal'C
válasz VoidXs #59449 üzenetére
Ezzel nem kell megvárni míg felforr. Beállítod mondjuk 45fokra utánna kötsz egy fordulatszám szabályzót beállítod és kész ( vagy egy nagyon halk ventit)
De itt egy másik is [link]
"Nagy az Isten állatkertje és alacsony a kerítés" Nem már nincs kerítés!!!
gabber01
válasz VoidXs #59513 üzenetére
Ja ezt csak példaként raktam be. Akkor azt mondod ha a sub oldalán mind a kettőt bedugom, az erősítőn meg csak az egyik oldalt és a másik meg lóg a levegőben az úgy jó? Most így van végül is. Mindegy melyik oldalt?
Man proposes, god disposes. Dum spiro, spero.
Tommancs
válasz VoidXs #59567 üzenetére
Szia,
igen, azt láttam. Köszönöm. Én annak a gyártónak a VLB200 nevű termékét ki is néztem. Ez tűnik a legmasszívabbnak, és ha jól látom, oldalról is be tudom tenni a hagfalat.
Azt tudom, hogy 60-90 cm-rel fül fölé érdemes tenni nem-atmos rendszerekben. Viszont érdemes lefele irányítani kicsit? -
Tommancs
Értem.
Ezt a 60-90 centit itt a topic guidjában olvastam, aminek elolvasása kötelező. (És én meg is tettem.) Egész pontosan: "A hangok lokalizálhatósága érdekében a surround hangsugárzók sugárzási tengelyének is a nézőre/hallgatóra kell irányulnia, nagyjából az ülő ember fülénél 60-90 cm-rel magasabban kell elhelyezni azokat. A legjobb térhatást dipól vagy bipól kialakítású háttérsugárzók biztosítják, viszont alkalmazásuk nem minden esetben célravezető."Gondolom "átlag" méretű nappali részre gondolt. Elővettem szögfüggvény ismereteimet, és mivel jobbra balra 2-2 méter felfelület van, így nagyjából fülmagasságtól 60 centire felfúrva 16 fokos, 90 centire felfúrva pedig 24 fokos szöget jelent a fülmagassághoz képest.
A 90-110 fokot gondolom horizontálisan írtad, hogy mennyire legyen "mögöttem". Ugye?
mikrofon
válasz VoidXs #59590 üzenetére
Ne érts félre! Eszem ágában sincs vitatkozni hiszen ez a Te tudományod. Egyszerűen leírtam miket olvastam.
Két idézet az FX dokumentációjából:
"The Bronze FX’s should be positioned in accordance with the below illustrations and instructions, and approx
2 feet (60cm) to the bottom of the speaker above ear height when in your listening position."
"Surround Speakers
Surround speakers should be placed high enough so that the drivers do not fire directly at ear level when
sitting down — one rule of thumb is to place them at ear level while standing, to avoid overpowering
the front speakers. If the surrounds are mounted on brackets on the side walls, experiment with aiming
them. "
Egyébként én így csináltam és nekem nagyon tetszik így a hang. De lehet hogy csak azért mert máshogy nem próbáltam[ Szerkesztve ]
mikrofon
válasz VoidXs #59596 üzenetére
"Csak a topikban túl gyakran előforduló dolgokkal szembeni ellenszenvem fejeztem ki. "
Azt hiszem ezt most kicsit tútótad. Az összefoglalos minősítésed is eléggé gázra sikeredett...
Lehet hogy tudományosan, képletekkel nem úgy jön ki. De végülis a hallás egy szubjektív dolog. Épp úgy mint a jó , szép és élvezhető hangzásvilág. Senki sem halt még bele abba ha elfogadja a másik véleményét és tapasztalatát. Esetleg ki is próbálja. Végülis a mérnöki világban is így van. Van az elmélet, a gyakorlat és a tapasztalat. Ezeket rengeteg biztonsági tényező, állandó és hatásfok kapcsolja össze....
Nincs szükség szerintem ellenszenvekre és belharcokra . Ezzel romlik a közhangulat. Legyünk nyitottak egymásra!
Illetve az ellenszenv valójában természetes dolog. Ez is egy érzés ami csak így jön. De nem muszáj mindenáron és nyomatékosan kifejezni...[ Szerkesztve ]
Tommancs
válasz VoidXs #59579 üzenetére
Koszi a valaszokat.
Meg egy dolog: az egyik elozdoben irod, hogy erdemes magam fele iranyitani oket (hattersugarzok). Ezt csupan horizontalisan tegyem meg, vagy vertikalisan is tegyem meg? Tehat kozepre nezzen, de ne lefele (vagyis ne a ful iranyaba, hanem a fejem felett “lojon” a hangfal, vagy pedig kozepre ES lefele is iranyuljon, azaz konkretan a fulem iranyaba, es eleg a “hatterhatashoz” az, hogy magasabbrol jon? -
gabber01
válasz VoidXs #59618 üzenetére
Akkor ezt nem értem. Akkor ha össze vannak kapcsolva a portok, a hangfal lényegében 4Ohm-os? Mert ugye 8ohm van ráírva, de a 4 meg elvileg nem annyira tenne jót az erősítőnek (már amelyik nem bírja).
De ha szétválasztom és az A-B portokra kötném, akkor is ugyanott vagyok szerintem, mert az erősítőn belül ezek összefutnak. Sőt, akkor még annyira sem működik, mert a külön 4ohmos részek eredője 2 ohm lenne. De lehet tévedek.Man proposes, god disposes. Dum spiro, spero.
Dorian
Remélem még jól emlékszem a derékszögű háromszöggel kapcsolatosakra, de nekem a 15 foknál nagyobb "magasság-különbség" már soknak tűnik.
Nálam az oldalsó sr-ok 9,4 fok, egyik hátsó 11,3, a másik 14,7 fok, utóbbi sztem már határeset. És vertikálisan enyhén még döntve is vannak felém (hátul magasabb tüske)
Persze ez a hangdobozok alja. Valószínű, hogy a magas-sugárzó magasságával kellene inkább számolni. Ekkor SR-ek 16,8 fok, SRB pedig 19,1 és 24,4 fokKétfajta ember van. Kerüld mindkettőt!
mikrofon
válasz VoidXs #59631 üzenetére
Akkor ezt nem árt tudni, ha valaki elkezd a Bi-Amp funkcióval bűvészkedni. Hiszen rosszabb eredményt kap kötéssel, mint egy nem Bi-amp képes hasonló adottságú de valódi 8ohm-os hangszóróval, vagy rosszul következtetek?
Bár szerintem ha erre egy dedikált bi-Amp AVR-t használunk, akkor ez jól le van kezelve, tehát nem sül meg az erősítő....
gabber01
válasz VoidXs #59644 üzenetére
Szerintem már egy 320as mp3 és flac között sem nagyon lehet különbséget tenni, de ugye emiatt is szinte vérre menő csaták szoktak lenni. :)
Amúgy nem azt kell ilyenkor mondani, hogy: a drágább kábellel kinyílik a tér, szinte érezni a robbanásokat, a mélyek egyszerűen mélyebbek lesznek, blablabla? :)
Teal'C
válasz VoidXs #59905 üzenetére
Egy 75" tévét nem raknék falra sosem. Egy tv szerelő mondta hogy nem túl baráti mert a 400x400 vesa mikor fel van csavarozva a saját súlya alatt vetemedik a tv és felhősödik a képernyő úgy magyarízta hogy a tv képernyő részei mikronokra vannak egymástól és ezek távolságának csökkenése növekedése okozza. Azt is megtanította hogyan kell eltüntetni ha ilyen történne és bevált, akkor még csak egy 65-ös tv-m volt és egy nagymagyarország térkép lett a közepén de eltünt, majdnem sírva fakadtam először. Így megfogadtam hogy soha többé.
Teal'C
válasz VoidXs #59907 üzenetére
A projektor jó dolog még 2011 környékén volt egy acer házimozi projektorom kb 2 évig használtam, full hd volt és 210cm széles volt a vászon Akkor ez csúcsnak számított. Aztán olcsóbbak lettek a nagy tv-k és visszaváltottam.
válasz VoidXs #59916 üzenetére
projektornal van mas faktor is. kell rendes vaszon (ami also hangon 1000+ euro hacsak nem nagyon mazlival veszi az ember), nappal talan 1-2 ledes megoldas ami oke (1500 euro az fHD, 2500+ a 4K), tetejeben olyan 4000 euro alatt kizarolag pixeleltolas van. jo, nekem sikerult 1200 eurobol osszehozni egy Benq W2000 + motoros Grandview Fantasy 120" kombot ujonnan, de a vasznat 65%os leertekelesben vettem (kb utolso darabot raktarsopreskor egy olyan weboldalrol ahol a szeriaszambol kellett kisakkoznom, hogy egyaltalan mit arulnak). es ez kb tenyleg az alja, ahol erdemes elkezdeni projektorozni, meg mindenkeppen kell egy hazimozi erosito is melle.
projektoros topikban vannak, akik 10+ eves fHD ipari gepekre eskusznek, de ott 3 meteres kephez adott esetben 5-6+meterre kell lennie a vetitonek, szoval nem mindenhova fer be. meg persze hangosak, de ugy megall 1000 euro korul a cucc es tenyleg szep kepet tud.
igaz itt bejon a kepbe, hogy mondjuk 1:1-1.2es nezesi tav mellett szerintem meg eleg a fHD, namost 120"nel itt ilyen 120-150" tavolsagrol beszelunk, es akkor nagyon kozel ul az ember. HDR, meg foleg a nagyszobakompatibilitas ami nagyon problemas tud lenni.
mondjuk itt azt is figyelembe kell venni, hogy mondjuk legyen 55", Oled meg techporno, vagy legyen 120" es igazabol kit erdekel ha nem tokeletes a fekete (bar egy kommersz IPS TV szintjet azert hozza) es nincs 120Hz, ha tenyleg megvan a mozi feeling. mondom ugy, hogy egy 55os TV be van kotve a vaszon mogott hogy pl tarsasagi osszejovetelekkor a spotifynak legyen sajat kijelzoje.
Don't dream it, be it. // Lagom amount.
mikrofon
válasz VoidXs #59969 üzenetére
Uhh tényleg a függönyök. Erre nem is gondoltam. Az ajtókkal meg egyéb dolgokkal már próbálkoztam . Itt van ablak felület és függönyök is vannak csak ugye általában kihúzva.
Még a hátsó falra kéne valami.
Egyébként a tapétázott falfelület számottevően jobb mint a festett?Akusztikai szivacs természetesen nem játszik a nappaliban .
mikrofon
válasz VoidXs #59981 üzenetére
Akkor mi az, ami olcsóbb és jól működik.
Végül is egy megfizethető árú és egyszerű de szép függönnyel akár leválaszthatnám a nagy nappali étkező konyha helyéből a 4x5m-es nappali részt csak mivel 4,2m hosszan kell így nem árt a jó ár. Ez még az esti filmezésem élvezhetőségét is növelheti ha tényleg észrevehetően csökkenti a hang átjutását.
Ezzel szembeni oldalra is mehetne ilyen mert ott ablakok vannak. Tehát így már 9m...... -
Habell
válasz VoidXs #59945 üzenetére
Olyat találtam, hogy Lg Sound Sync beállítása. Alatta meg, hogy HDMI ARC és egy állítható sáv. Van egy Bypass is ami nem tudom mire jó. Amúgy minden ilyen beállítás ki volt kapcsolva.
Még digitáls tv hangbeállítás van. Jelenleg Automatikusra van állítva. Mellette van Dolby Digital és Dolby Digital Plus, HE-AAC, MPEG -
mpo
válasz VoidXs #60202 üzenetére
Megoldódott hamar, azóta úgy van. (2019. végén vettem a szubot).
A 9 óra az ennek a Klipsch R-120SW-nek 18 nm-en jó beállítás, én az Audyssey-t használtam.
Az a film és a Tenet volt, ami túltolta a mélyet. Olyan film is van, amikor oda kell néznem, hogy világít-e a LED.Ha érted, akkor már elavult.
- A topik kompakt "házimozi" szettekkel igen, de hangprojektorokkal (soundbar) tapasztalatok híján nem foglalkozik.
- Házimozi haladó szinten topic
- Hi-Fi topic
