silentkiller
slimshady #8911 üzenetére
Én a HyperX mod 1.0 után használtam a HyperX 100 quality only mod-ot - nagyon bejött - de most kipróbáltam sklchan mod-ot (megy a folyamatos/automata fókusz HD videóban, 256-os hanggal 128-as helyett + 100%-os JPG - vagyis 0%-os tömörítés). Nagyon bejött, mondjuk egy kép 7-8-9 Mb (!). Jó fénynél, alacsony ISO-nál már nem kell másik (zseb) fényképezőgépen gondolkozni
Ami miatt a sklchan-t választottam:
S^3 Multiple Mods v6.00 Released
01. KS Improvement
- Improve on Kinetic Scrolling, now your list will be easier/faster/longer on kinetic scroll (you wil SURE feel the different)02. UI Improvement - Experiment Mod
- Experiment mods, changed the default FPS from 67FPS to 60FPS and max processing power from 75% to 95%. Need more users experience feedback on
it's actual improvement (if it have any)03. Camera Sound Mute
- Enable the camera sound to be mute when warning tone been turn off.For Mods #04,#05 ONLY select 1 option, if multiple options selected the top most option will be use.
04. N8 Continuous AutoFocus
- You will have an EXTRA option under Video Setting that enable the Continuous AF during video.05. E7/C7 Video Mods
- Mods for E7/C7/C6-01 video, enhance zoom steps and increase night mode FPS.For Mods #06,#07,#08,#09,#10,#11,#12,#13, ONLY select 1 option, if multiple options selected the top most option will be use.
06. N8 Photo/Video (100/30FPS)
- Photo quality change the compression ratio from original 85/75/60 to 100/85/75, video will change from 25FPS to 30FPS and the capture audio quality will change from 128kbps to 256kbps.07. N8 Photo/Video (097/30FPS)
- Photo quality change the compression ratio from original 85/75/60 to 97/85/75, video will change from 25FPS to 30FPS and the capture audio quality will change from 128kbps to 256kbps.08. N8 Photo/Video (095/30FPS)
- Photo quality change the compression ratio from original 85/75/60 to 95/85/75, video will change from 25FPS to 30FPS and the capture audio quality will change from 128kbps to 256kbps.09. N8 Photo/Video (097/25FPS)
- Photo quality change the compression ratio from original 85/75/60 to 97/85/75, video remain 25FPS with capture audio quality will change from 128kbps to 256kbps.10. E7/C7 Photo/Video (100/30FPS)
- Photo quality change the compression ratio from original 85/75/60 to 100/85/75, video will change from 25FPS to 30FPS and the capture audio quality will change from 128kbps to 256kbps.11. E7/C7 Photo/Video (097/30FPS)
- Photo quality change the compression ratio from original 85/75/60 to 97/85/75, video will change from 25FPS to 30FPS and the capture audio quality will change from 128kbps to 256kbps.12. E7/C7 Photo/Video (095/30FPS)
- Photo quality change the compression ratio from original 85/75/60 to 95/85/75, video will change from 25FPS to 30FPS and the capture audio quality will change from 128kbps to 256kbps.13. E7/C7 Photo/Video (097/25FPS)
- Photo quality change the compression ratio from original 85/75/60 to 97/85/75, video remain 25FPS with capture audio quality will change from 128kbps to 256kbps.14. Photo Gallery Folders
- Photo Gallery Folders excluded lots of folders path, hopefully now it's will only show E:\Images\ & F:\Images\ contents.15. Music Gallery Folders
- Music Gallery Folders excluded lots of folders path, hopefully now it's will only show E:\Music\, E:\Sounds\, F:\Music\, F:\Sounds\, G:\Music\, G:\Sounds\ contents.For Mods #16,#17, ONLY select 1 option, if multiple options selected the top most option will be use.
16. Browser's Cache (D:\)
- Change the default browser cache folder from C: to D: and set the amount to 32MB, actual effects need those HEAVY internet users feedback.17. Browser's Cache (E:\)
- Change the default browser cache folder from C: to E: and set the amount to 32MB, actual effects need those HEAVY internet users feedback.For Mods #18,#19,#20, ONLY select 1 option, if multiple options selected the top most option will be use.
18. Startup/Shutdown (C:\Animations)
- Redirect the phone to look for the Startup.gif and Startup.mp3 during startup in C:\Animations folder and look for the Shutdown.gif and Shutdown.mp3 during shutdown in C:\Animations folder. If none are found then the phone won't play any startup/shutdown animations at all.19. Startup/Shutdown (E:\Animations)
- Redirect the phone to look for the Startup.gif and Startup.mp3 during startup in E:\Animations folder and look for the Shutdown.gif and Shutdown.mp3 during shutdown in E:\Animations folder. If none are found then the phone won't play any startup/shutdown animations at all.20. Startup/Shutdown (F:\Animations)
- Redirect the phone to look for the Startup.gif and Startup.mp3 during startup in F:\Animations folder and look for the Shutdown.gif and Shutdown.mp3 during shutdown in F:\Animations folder. If none are found then the phone won't play any startup/shutdown animations at all.21. Voice Recorder (12H/256kbps/Stereo)
- Set the default Voice Recorder to high quality recording (from 64kbps to 256kbps) and increase the max duration of the recording clip from 60mins to 720mins.22. Music Player Volumn/Heap Mods (80%/32MB)
- Experiment mods, no significant effect after the mods.23. Context Data Object Maximum Size Mod
- Experiment mods, no significant effect after the mods.24. Light Sensor Disable
- Totally disable the Light Sensor, LCD will have 100% brightness all the time (will dim ONLY in power safe mode)25. Haptics Improvement
- Lower the vibration and fine tune level 1/2/3 haptics feedback (not must different as i can tell)26. Vibration Alert Improvement
- Same goes with haptics mods, can't really feel big different27. Camera Full Shutdown (RAM)
- Camera apps will fully shutdown once you close the apps (won't remain in the memory), but the N8 have better camera apps as the total shutdown and without only make ~1Mb ram saving (not like what we see in 5800xm as it's camera apps are memory *****)28. Fast Screen Rotation
- Can feel "a bit" faster but not lighting fast as the delay seem not from the sensor but rather from the UI.29. FM Transmitter RDS
- The FM Transmitter now send RDS "Nokia N8" and not just "Nokia".30. Video Call FPS Improvement
- Slightly change the video call setting fps from original min/norm/max of 5/10/15 to 10/15/20. Not tested as not really use video call.31. MSG/LOGS/CONT/CLK/CAL Shutdown (RAM)
- Disable Messaging, Logs, Contacts, Clock, Calendar Apps from staying in the background after you exit them.32. Database Max Record Count
- Experimental mod, Increase database from 20 to 50.33. Default Application Orientation State
- Change default orientation from Landscape to Hardware Sensor.34. HWRM Process Priority
- Experimental mod, Hardware sensor priority change from background to foreground.35. Music Player Equalizer
- Add in additional 6 EQ presets, Flat/Speech/Enhance/Treble booster/Bass & Treble/ZigZagFélkövérrel jelöltem, hogy mi az ami miatt ezt választottam...
CS_D
slimshady #8857 üzenetére
Szerintem jobban jársz, ha letöltesz egy olyan modot, amiben csak a kamera tulajdonságait állítja (pl. BZS73 kamera mod), és valamelyik SIS fájl kicsomagoló programmal belenyúlsz.
A benne lévő txt fájlt pedig saját ízlésed szerint állítgatod. Nem túl nehéz kiigazodni rajta.
Szerintem nem túl bonyolult dolog, és így biztosan olyan lesz a kamerád, mint, ahogy elképzelted.
De egyébként miért nem akarod, hogy jobb minőségben menjen a kép tömörítés? Szerintem a gyári 85%-os minőség az elég kevés. Én 97%-on használom.
Katsu
slimshady #8848 üzenetére
Hali,
Keresd ezt: SKLCHAN.
Csak simán eltávolítod a telepített progik közül és reboot a telefonnak. Olyan lesz, mintha semmit nem tettél volna a telóddal. Bár lehet, hogy nem erre gondoltál, de nem olvastam el az egész kálváriádat. Csak ezt az utolsó posztot.Üdv: Katsu
MC Pite
MC Pite
slimshady #8548 üzenetére
Nem rossz a gyári (X6-éból indulok ki), de ha csak strapára rakom fel; akkor az 1-1,5mm-es szilikon toknál sokkal masszívabb. Általában nálam jó kis kezdősebességgel repülnek eleve a telefonok. Illletve _állítólag_ a gyárinéál kevésbé tapad az impact zsebhez. A gyári mocskosul, 1 kézzel nem tudod zsebrevágni
Assdak: gyári CC1005-öt ezresért? 2,5 körül adják... Annyi előnye van hogy pl zöldet vennék, mert jobban látszik ha elejtem/övtáskában, stb, mint a fekete. Ezresért inkább azt venném ha találnék.
tibike8
slimshady #8460 üzenetére
Na akkor elbeszéltünk egymás mellett, de szerintem ne ragozzuk túl
Egyébként előtte is voltak ilyen telepítési gondjaim (most már had ne nézzem meg, hogy írtam-e ezt vagy sem). A szignózás után sem települt. Ez a hiba az 1.1 felrakása után részben megoldódott. Egyedül a camerapro nem települt azután sem, de mint írtam, a sisx-es verziót fel tudtam rakni, így most nincs problémám. De mindenesetre nem sikerült kilogikázni, hogy mi mivel akadt. Volt, hogy fél óráig semmi baja nem volt, ment minden, aztán megint behalt a kamerája, pedig nem módosítottam/telepítettem semmit.
Mindenesetre se hard-, se softresetet nem volt tervemben csinálni, maximum a gyári állapotra visszahozást, de azt sem kellett végül. A reset helyett inkább a szerviz lett volna, ha szükéséges. -
tibike8
slimshady #8453 üzenetére
Én meg nem értem, hogy mit nem értesz.
Erre válaszoltam:'tibike8: Te hogy oldottad meg? Ezek szerint nálad ment a szoftverfrissítés után? (Nálam pont azután gányolódott el vmi. Én ilyet még nem láttam pedig használok Symbiant egy ideje.)'
Erre kérdezte meg, hogy pontosan mit hogy oldottam meg és leírtam egy esetet ami nálam gond volt és az meg az 1.1-es update után jelentkezett és írtam, hogy mi lett a vége. Más gondom nem volt. Tanúsítvány hiba ami volt az megszűnt az 1.1 után, kivéve a camerapro para mert azt utána sem tudtam felrakni, de a nokiaprogramokon fent volt egy sisx-es verzió és az már felment. Ennyi...
CS_D
slimshady #8450 üzenetére
Ha Phoenix-szel flasheled, a megfelelő produc kódhoz tartozó firmware-rel, akkor kb ugyanannyit csináltál, mintha bevitted volna a Nokiába, hogy tegyék már fel a legújabb firmware-t.
Ha nem ugyanazzal a product kódhoz tartozó firmware-t flashelsz fel, akkor viszont már a garanciát kockáztatod, de mindaddig nem bukod el, amíg nem követsz el valami hibás lépést. 2 hibás lépés van: átírt product kóddal NSU-val vagy FOTA-n frissíted a telót, vagy pedig úgy viszed be garanciáztatni, hogy más product kódhoz tartozó firmware van fent.
tibike8
slimshady #8430 üzenetére
Pontosan mi is? Az 1.1 utáni probléma megoldás? Mert itt addig pakolgattam az elmentett beállításokat, amíg egyszer csak jó lett. Egyik műveltre sem tudnám egyértelműen mondani, hogy na az oldotta meg a gondot. De nem csináltam semmilyen resetet és gyári visszaállítást sem.
djbahool
Nem. Phoenix-el újra flasheled akkor 100% jó lesz, olyan lesz mint a gyári.
De van aki eszerint elég feltenni csak a QT packot.
Tényleg olvastam vmi olyasmit én is , hogy a pr2.0-ban alapból benne lesznek ezek, vagyis HR után nem kell kinlódni.Gl4diator: nem hiszem, hogy 1 órával is többet fog bírni, bár ne legyen igazam.
Ha lehetne ilyen akksit kreálni, akkor sztem a nokia is azzal forgalmazná. -
deka10
deka10
slimshady #8354 üzenetére
NSU-val megpróbálhatod azt nem próbáltam akkor még nem volt kint az 1.1, azóta már kint van és azt nem tiltja semmi de minden esetben csinálj biztonsági mentést. Bár mikor 1.0-nál hardreseteltem akkor a Pesti központi szerviz tudta vissza rakni pedig NSU-val is próbáltam de akkor nem lett eredménye.
- Samsung Galaxy Z Fold 5 (SM-F946B/DS) 512GB/12GB - Jégkék
- Honor Magic V5 -- 512Gb -- 16Gb Ram -- Magyar Nyelv -- EREDETI
- Samsung Galaxy A26 128GB, Kártyafüggetlen, 1 Év Garanciával
- Xiaomi Redmi Note 13 Pro+ 5G 12GB RAM / 512GB ROM (Garancia 2026.04.10-ig)
- Xiaomi 13T 256GB, Kártyafüggetlen, 1 Év Garanciával
- 122 - Lenovo Legion Pro 5 (16ARX8) - AMD Ryzen 7 7745HX, RTX 4070 (48 hónap garancia!)
- Utolsó 3db - KIÁRUSÍTÁS - REFURBISHED és ÚJ - HP Thunderbolt Dock G2 230W docking station (3TR87AA)
- LG 65C3 - 65" OLED evo - 4K 120Hz 1ms - NVIDIA G-Sync - FreeSync Premium - HDMI 2.1 - PS5 és Xbox!
- BESZÁMÍTÁS! 1TB Kingston KC3000 NVMe SSD meghajtó garanciával hibátlan működéssel
