- Honor 200 Pro - mobilportré
- Honor 90 - modellalkat
Z Fold6 imitátor árulkodik a fogyókúrázó igaziról
Kíváncsi az EU, milyen online védelmet adnak a pornóplatformok a kiskorúaknak
it Az EB felkereste a nagy pornóplatformokat, hogy megtudja, milyen intézkedéseket tettek.
Samsung LCD és LED TV-k
nightshadow
Samsung UE40JU6400 4K TV review [link]
nightshadow
Samsung UE55JU6400 4K TV Review [link]
Motion Handling
As always we used our FPD Benchmark test disc to measure the motion resolution of the JU6400 at around 300 lines which is what we would expect from an LCD TV. What we didn’t expect was that turning on the Auto Motion Plus made no difference to the motion resolution. Normally we would expect a frame interpolation feature like Auto Motion Plus to deliver the full 1080 lines of resolution but in fact it appeared to have no affect at all, regardless of which option we chose. We can only assume this is due to a software bug and have reported our findings back to Samsung. As it happens we found the motion handling on the Samsung to be just fine without the need to resort to frame interpolation. When watching 24p Blu-rays with Auto Motion Plus off, the motion retained a suitably film-like quality and overall the motion handling on the 55JU6400 was perfectly acceptable.
nightshadow
REVIEW / Samsung UE40JU6670 [link]
CONS:
- 50 Hz panel
- Limited motion compensation
- Poor response time (17 ms)
- Narrow viewing angles
- Glossy screen susceptible to glare -
nightshadow
Samsung UE48JU7500 review [link]
Cons:
- Severe motion issues using all but the movie preset
- Screen is quite reflective
- Relatively small size diminishes return on UHD and curved screen features -
nightshadow
Tanulságos cikk a 4K-ról: The Ultimate Guide to Ultra High Definition TV [link]
nightshadow
gorog67 #79245 üzenetére
az UE32H6200 200 Hz-es. Ha nem 3D-vel használom, akkor milyen előnye van a 100-asokhoz képest?
Jobb a mozgásmegjelenítés, jobb a panel az 5-ös sorozathoz képest. A régiek közül érdemes választani: H6200 vagy H6400 kerettől függően. A J6300 pedig még nagyon drága, nem ér annyit.
nightshadow
REVIEW / Samsung UE32J5500 [link]
nightshadow
Samsung UE48JU7000T review [link]
nightshadow
Samsung UE78JS9500 (JS9500) SUHD 4K TV Review [link]
nightshadow
PH:Tíz év, tíz emblematikus Samsung tévé. Rövidke animáción keresztül mutatjuk be, hogy mennyit változott, hogy fejlődött a tévék külseje egy dekád alatt. [link]
nightshadow
Gabesz1019 #79417 üzenetére
Van most a Samsungnak a 102cm-s kategóriában smart és 3D nélkülije
nightshadow
Gabesz1019 #79419 üzenetére
Tehát ennél "lejjebb" nem érdemes venni?
Alapesetbe azt mondanám hogy nem, de egy 78 éves ember esetében nem merném egyértelműen kijelenteni. Gondolom sima tévénézésre kell, ott annyira nem jön ki a két tévé közötti különbség szerintem. Szerintem nézzétek meg élőben.
nightshadow
Hajlított tévéhez hajlított soundbar dukál: [link]. Komolyan már nem tudnak mit kitalálni?
nightshadow
Samsung JU7500 review [link]
nightshadow
Azurooandrew #79840 üzenetére
csalódott vagyok a 2015-ös FHD tv felhozatal kapcsán – és ez a rivális márkákra is érvényes, mindenhol (lg, sony) a 4K került előtérbe.
Azért vannak még, lásd Panasonic CS630, Sony W7C-W75C-W8C,
LG LF630-LF652[ Szerkesztve ]
nightshadow
kovimre #79859 üzenetére
mi a baj a J vel?
Pl. aki középkategóriás FHD tévét szeretne venni, az egyedül a J6300-at tudja választani, ami ráadásul hajlított. Ez utóbbi már önmagában sokaknál kizáró ok. A 4K tévének meg 55" alatt nem sok értelme van, ráadásul az alsóbb-kategóriás JU6400-ből még a 24p támogatás is hiányzik, csak tévénézésre meg elég luxus ilyen tévét venni. JU7000-től a nagy többség meg anyagi okok miatt elesik. Tehát aki egy normális középkategóriás tévét szeretne választani megfizethető áron az kénytelen idén más márkát nézni. A H-ból viszont ott volt a H6200, H6400, H6500.
nightshadow
Getting a Smoother and Sharper TV Picture: How Does it Work? BFI, interpolation, refresh rate—what it all means [link]
nightshadow
Samsung UE55JS8500 SUHD TV Review [link]
nightshadow
Samsung UE40J6300 review: [link]
nightshadow
Stevenstyle #80378 üzenetére
így DSE nem nagyon lesz rajta
"there is a significant amount of dirty screen effect." [link]
nightshadow
Samsung UE48JU7500T review [link]
nightshadow
Samsung UE48J6300 HD TV review [link]
Pros: beautiful design (hát ez erősen szubjektív)
nightshadow
Samsung UE55JS8500 review [link]
nightshadow
Na, vajon mennyi SUHD tévé fogy? A Samsung azt reméli, hogy ez év első felében 15 ezer kvantumpont-technológiás tévét sikerülhet eladnia.
[link]A 15,000 db globálisan csak nekem tűnik nagyon kevésnek?
nightshadow
SunMount3r #81425 üzenetére
Valamint, hogy egy H6400-as szintű 40"-os J szériás ára vajon mikorra csökkenhet a reális 140K körülire?
A J62xx nálunk hivatalosan nem kapható, webshopokban is csak elvétve: [link].
A J6300 pedig ívelt. Nincsen más Full HD-s J6xxx-os tévé.[ Szerkesztve ]
nightshadow
az idei tv-k közül a Ju7000 az amit talán érdemes lesz venni.
Csak ezzel az a probléma hogy a konkurenciánál meg van olyan amit érdemes megvenni s jóval olcsóbb. A 48JU7000 410-450k között van most, s ha lemegy mondjuk 300k-ra akkor az már jónak mondható az eredeti árhoz képest. MO-on viszont kevés ember vesz 300k-ért tévét.
nightshadow
Samsung UE32J6300 review [link]
- Fujifilm X
- Gurulunk, WAZE?!
- Xbox Series X|S
- Projektor topic
- Pécs és környéke adok-veszek-beszélgetek
- Airpods Pro 2 Lightning /// Apple Garancia 6 Hónap + SZÁMLA
- AirPods Pro 1 MagSafe Charging Case /// Számla + Garancia
- Samsung Galaxy Buds FE Fekete Fülhallgató /// Bontatlan // Számla + Garancia
- Eredeti, új, Airpods Pro 2 lightning töltőtok, 6 hó apple gari A2700
- Eredeti, új AirPods Pro 2 lightning bal oldali füles A2699
