- Hívószám-hamisítás
- Apple Watch
[SoP] Konzolokra is megjelenik a Marvel Rivals
gp A következő zárt béta júliusban érkezik, ez már mindhárom platformon futni fog.
Sonja
Ezt az exploitot most nem értem!
Ha csalódni akarsz, bízz az emberekben!
Sonja
Ez érdekes rész innen!.
"Terms of Service
RESTRICTIONS AND CONDITIONS OF USE.
B. You will not:
(iii) use the Auction Houses as an investment vehicle;"Magyarán, ha veszek egy cuccot 3 euróért, és el akarom adni pl. 100 euróért, akkor bannolhatnak. Szép.
Sonja
Sonja
"Probably a load of bull, but supposedly someone with a friend in Blizzard supposedly has info on the MF update.
"If my 'Insider' is to be believed (so far, everything he told me, which i shared on various twitch streams regarding class changes has been bang on):
*MF swapping made obsolete. Your MF rises 'slowly' to its max equipped value ie over ~120 seconds from you equipping a piece, its MF bonus is added to your character sheet - cant swap just before final blow, unless you want to kite around last mob for 120 secs.
*Levels of Excellence added. Gain a temporary 'level of excellence' on each elite kill. This number is tracked on your character perpetualy and you dont lose it if you change games/acts etc.
*Every time you kill your 500th elite, a guranteed Legendary drops (ilvl and affix rolls depending on Act and MF Gear as usual). This resets your 'Level of Excellence' to zero.
*This Legendary is BindOnEquip, so now while a certain amount of farming gurantees everyone a legendary drop, you need to make a choice - use it/save it for alt OR put it on AH/Trade. Cant use and pass on. This will provide the much needed item sink, else a guranteed Legendary drop will eventually flood the economy.
*This LoE system was favored for its simplicity and effectiveness. Its pretty much the WoW 'token' system, which essentially gurantees end game gear progression, as long as youre running the content, even if youre missing out on drops.
*Theyve spend a lot of time and effort making Legendaries cool. Needed to strike a balance between them being too common and too rare. Hence this system, as well as making them BoE, to ensure balance of economy. There will be some changes to affix rolls of class specific items"
Highly likely that its not true, but it is pretty interesting."Ha csalódni akarsz, bízz az emberekben!
Sonja
Kösz mindenkinek. Visszautasítottam, és report!
Sonja
SSD-n egészen más élmény a játék. Gyors betöltés, sehol semmi macro lag. Hanyag programozói munka.
Sonja
válasz mikromanus #48498 üzenetére
A macro laggolás bizos hanyag programozói munka, mivel HDD-n nem is tesztelték a játékot.
Sonja
válasz hackeeeee #48505 üzenetére
Na, az a "néha-néha van valami apró lag" bizony a macro lagolás, ami SDD-n és Pendrive-on elmúlik. A készítők is beismerték, hogy HDD-n nem is próbálták ki soha(!) a játékot. Persze az elején lévő nagy töltögetés is teljesen megszünt SSD-ről futtatva. 15eHUF-ot megért ez a kis Samu 830-as.
- Eredeti játékok OFF topik
- Steam Deck
- Mikrotik routerek
- AMD Navi Radeon™ RX 7xxx sorozat
- IN WIN 909 Black Edition SZÉP ÁLLAPOTBAN NAGYON OLCSÓN
- EVGA X570 Dark RITKASÁG!!!! 2 hetet használt.
- Beszámítás! ASUS B450M R5 3600X 16GB DDR4 240GB SSD 1TB HDD RTX 2060 6GB Rampage Shiva ZALMAN 600W
- Beszámítás! ASRock H510M i7 10700 16GB DDR4 480GB SSD RTX 3070 8GB AeroCool Aero One Seasonic 650W
- SAPPHIRE RX 6800 XT 16GB GDDR6 NITRO+ SE Eladó! 145.000.-
